TMS320C206PZA80
TMS320C206PZA80
    ROCHESTER(罗切斯特)
    100-LQFP
    DIGITAL SIGNAL PROCESSOR, 16-BIT
TMS320C206PZA80 数据手册
       SPRS065B − JUNE 1998 − REVISED JANUARY 1999 D High-Performance Static CMOS Technology D Includes the ’320C2xLP Core CPU D TMS320C206, TMS320LC206 are Members of the ’C20x/’C2000 Platform Which Also Includes the TMS320C203/LC203 and TMS320F206 Devices Instruction-Cycle Time 25 ns at 3.3 V Source Code Compatible With TMS320C25 and other ’20x Devices Upwardly Code-Compatible With TMS320C5x Devices Four External Interrupts TMS320C206, 5-V I/O (3.3-V core) TMS320LC206, 3.3-V core and I/O TMS320C206, TMS320LC206 Integrated Memory: − 544 × 16 Words of On-Chip Dual-Access Data RAM − 32K × 16 Words of On-Chip ROM − 4K × 16 Words of On-Chip Single-Access Program/ Data RAM 224K × 16-Bit Maximum Addressable External Memory Space − 64K Program − 64K Data − 64K Input/Output (I/O) − 32K Global D D D D D D D D D 32-Bit Arithmetic Logic Unit (ALU ) D D D D D D D D D Accumulator 16 × 16-Bit Multiplier With a 32-Bit Product Block Moves from Data and Program Space TMS320C206, TMS320LC206 Peripherals: − On-Chip 20-Bit Timer − On-Chip Software-Programmable Wait-State (0 to 7) Generator − On-Chip Oscillator − On-Chip Phase-Locked Loop (PLL) − Six General-Purpose I/O Pins − Full-Duplex Asynchronous Serial Port (UART) − Enhanced Synchronous Serial Port (ESSP) With Four-Level-Deep FIFOs Input Clock Options − Options: Multiply-by-One, -Two, or -Four, and Divide-by-Two (1, 2, 4, and 2) Support of Hardware Wait States Power Down IDLE Mode IEEE 1149.1†-Compatible Scan-Based Emulation TMS320C206, TMS320LC206 100-Pin PZ Package, Small Thin Quad Flat Package (TQFP) Industrial Temperature Version Planned, (− 40°C to 85°C) description The Texas Instruments (TI) TMS320C206‡ and TMS320LC206‡ digital signal processors (DSPs) are fabricated with static CMOS integrated-circuit technology. The architectural design is based upon that of the TMS320C20x series and is optimized for low-power operation. The combination of advanced Harvard architecture, on-chip peripherals, on-chip memory, and a highly specialized instruction set is the basis of the operational flexibility and speed of the ’C206. The ’C206 offers these advantages: D D D D D Enhanced TMS320 architectural design for increased performance and versatility Advanced integrated-circuit processing technology for increased performance ’C206 devices are pin- and code-compatible with ’C203 and ’F206 devices. Source code for the ’C206 DSPs is software-compatible with the ’C1x and ’C2x DSPs and is upwardly compatible with fifth-generation DSPs (’C5x) New static-design techniques for minimizing power consumption and increasing radiation tolerance Please be aware that an important notice concerning availability, standard warranty, and use in critical applications of Texas Instruments semiconductor products and disclaimers thereto appears at the end of this data sheet. † IEEE Standard 1149.1 - 1990, IEEE Standard Test-Access Port ‡ Device numbers are hereafter referred to in the data sheet as ’C206, unless otherwise specified. TI is a trademark of Texas Instruments Incorporated. Copyright  1999, Texas Instruments Incorporated       !   "#$ %!& %   "! "! '! !  !( ! %% )*& % "!+ %!  !!$* $%! !+  $$ "!!& POST OFFICE BOX 1443 • HOUSTON, TEXAS 77251−1443 1        SPRS065B − JUNE 1998 − REVISED JANUARY 1999 V DD A15 A14 A13 A12 V SS A11 A10 A9 A8 V SS A7 VDD5 A6 A5 A4 V SS A3 A2 A1 A0 V SS PS IS DS PZ PACKAGE ( TOP VIEW ) 75 74 73 72 71 70 69 68 67 66 65 64 63 62 61 60 59 58 57 56 55 54 53 52 51 EMU0 EMU1 / OFF TCK TRST TDI TMS TDO VSS CLKR FSR DR CLKX VSS FSX DX VDD5 50 49 48 47 46 45 44 43 42 41 40 39 TMS320C206† 38 37 36 35 34 33 32 31 30 29 28 27 26 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 VDD5 READY VSS R/W STRB RD WE BR VSS D15 D14 D13 D12 VSS D11 VDD5 D10 D9 D8 D7 VSS D6 D5 D4 D3 EXT8 MP/MC DIV1 V DD DIV 2 HOLDA V DD5 IO2 IO3 PLLRS V DD CLKIN/X2 X1 VSS CLKOUT1 V DD5 NMI HOLD/INT1 INT2 INT3 VSS D0 D1 D2 VSS TOUT TX VSS RX IO0 IO1 XF BIO RS 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 † VDD5 pins 7, 16, 35, 50, 63, and 91 represent I/O supply voltage. V DD A15 A14 A13 A12 V SS A11 A10 A9 A8 V SS A7 VDD A6 A5 A4 V SS A3 A2 A1 A0 V SS PS IS DS PZ PACKAGE ( TOP VIEW ) 75 74 73 72 71 70 69 68 67 66 65 64 63 62 61 60 59 58 57 56 55 54 53 52 51 EMU0 EMU1 / OFF TCK TRST TDI TMS TDO VSS CLKR FSR DR CLKX VSS FSX DX VDD 50 49 48 47 46 45 44 43 42 41 40 39 TMS320LC206 38 37 36 35 34 33 32 31 30 29 28 27 26 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 EXT8 MP/MC DIV1 V DD DIV 2 HOLDA V DD IO2 IO3 PLLRS V DD CLKIN/X2 X1 VSS CLKOUT1 V DD NMI HOLD/INTI INT2 INT3 VSS D0 D1 D2 VSS TOUT TX VSS RX IO0 IO1 XF BIO RS 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 2 POST OFFICE BOX 1443 • HOUSTON, TEXAS 77251−1443 VDD READY VSS R/W STRB RD WE BR VSS D15 D14 D13 D12 VSS D11 VDD D10 D9 D8 D7 VSS D6 D5 D4 D3        SPRS065B − JUNE 1998 − REVISED JANUARY 1999 device features Table 1 shows the capacity of on-chip RAM and ROM, the number of serial and parallel I/O ports, the execution time of one machine cycle, and the type of package with total pin count of the TMS320C206 and TMS320LC206 devices. Table 1. Characteristics of the TMS320C206 and TMS320LC206 Processors ON-CHIP MEMORY (16-BIT WORDS) RAM ’x206 DEVICES TMS320C206 ROM FLASH EEPROM I/O PORTS DATA DATA/ PROG PROG PROG SERIAL PARALLEL 288† 4K + 256‡ 32K − 2 64K 288† 4K + 256‡ POWER SUPPLY (V) CYCLE TIME (ns) PACKAGE TYPE WITH PIN COUNT 5 (3.3 core) 25 100-pin TQFP TMS320LC206 32K − 2 64K 3.3 25 100-pin TQFP † On-chip RAM space B1 (256 words) and B2 (32 words) can be used as data memory only. ‡ On-chip RAM space B0 (256 words) can be used either in data space or program space depending on the value of the CNF bit in the ST1 register. On-chip SARAM (4K) can be mapped in program space, data space, or both. POST OFFICE BOX 1443 • HOUSTON, TEXAS 77251−1443 3        SPRS065B − JUNE 1998 − REVISED JANUARY 1999 TMS320C206, TMS320LC206 Terminal Functions TERMINAL NAME NO. TYPE† DESCRIPTION DATA AND ADDRESS BUSES D15 D14 D13 D12 D11 D10 D9 D8 D7 D6 D5 D4 D3 D2 D1 D0 41 40 39 38 36 34 33 32 31 29 28 27 26 24 23 22 A15 A14 A13 A12 A11 A10 A9 A8 A7 A6 A5 A4 A3 A2 A1 A0 74 73 72 71 69 68 67 66 64 62 61 60 58 57 56 55 Parallel data bus D15 [most significant bit (MSB)] through D0 [least significant bit (LSB)]. D15−D0 are used to transfer data between the ’C206 devices and external data / program memory or I / O devices. Placed in the high-impedance state when not outputting (RD, WE high) or when RS asserted. They also go into the high-impedance state when OFF is active low. I/O/Z Parallel address bus A15 (MSB) through A0 (LSB). A15−A0 are used to address external data / program memory or I / O devices. These signals go into the high-impedance state when OFF is active low. O/Z MEMORY CONTROL SIGNALS PS 53 O/Z Program-select. PS is always high unless low-level asserted for communicating to off-chip program space. PS goes into the high-impedance state when OFF is active low. DS 51 O/Z Data-select. DS is always high unless low-level asserted for communicating to off-chip data space. DS goes into the high-impedance state when OFF is active low. IS 52 O/Z I / O space select. IS is always high unless low-level asserted for communicating to I/O ports. IS goes into the high-impedance state when OFF is active low. READY 49 I Data-ready. READY indicates that an external device is prepared for the bus transaction to be completed. If the external device is not ready (the external device pulls READY low), the ’C206 waits one cycle and checks READY again. If READY is not used, it should be pulled high. R/W 47 O/Z Read / write. R / W indicates data transfer direction when communicating with an external device. R/W is normally in read mode (high), unless low level is asserted for performing a write operation. R / W goes into the high-impedance state when OFF is active low. † I = input, O = output, Z = high impedance, PWR = power, GND = ground 4 POST OFFICE BOX 1443 • HOUSTON, TEXAS 77251−1443        SPRS065B − JUNE 1998 − REVISED JANUARY 1999 TMS320C206, TMS320LC206 Terminal Functions (Continued) TERMINAL NAME NO. TYPE† DESCRIPTION MEMORY CONTROL SIGNALS (CONTINUED) RD 45 O/Z Read-select indicates an active, external read cycle. RD is active on all external program, data, and I / O reads. RD goes into the high-impedance state when OFF is active low. To implement a glueless zero wait-state memory interface, the inverted R/W signal can be used as the “read” signal in place of RD. The function of the RD pin can be programmed to provide an inverted R/W signal instead of RD. The FRDN bit (bit 15) in the PMST register controls this selection. FRDN=1 chooses R/W as the new “read” signal. FRDN=0 (at reset) chooses RD as the “read” signal on pin 45. WE 44 O/Z Write enable. The falling edge of WE indicates that the device is driving the external data bus (D15 −D0). Data can be latched by an external device on the rising edge of WE. WE is active on all external program, data, and I / O writes. WE goes into the high-impedance state when OFF is active low. STRB 46 O/Z Strobe. STRB is always high unless asserted low to indicate an external bus cycle. STRB goes into the high-impedance state when OFF is active low. MULTI-PROCESSING SIGNALS BR 43 O/Z Bus-request. BR is asserted when a global data-memory access is initiated. BR goes into the high-impedance state when OFF is active low. HOLDA 6 O/Z Hold-acknowledge. HOLDA indicates to the external circuitry that the processor is in a hold state and that the address, data, and memory control lines are in the high-impedance state so that they are available to the external circuitry for access of local memory. HOLDA goes into the high-impedance state when OFF is active low. XF 98 O/Z External flag output (latched software-programmable signal). XF is used for signalling other processors in multiprocessing configurations or as a general-purpose output pin. XF goes into the high-impedance state when OFF is active low. BIO 99 I IO0 IO1 IO2 IO3 96 97 8 9 I / O/Z Branch control input. When polled by the BCND pma,BIO instruction, ’C206 executes a branch to the specified program memory address if BIO is low. Software-controlled input / output by way of the asynchronous serial-port control register (ASPCR). At reset, IO0−IO3 are configured as inputs. These pins can be used as general-purpose input / output pins or as handshake control for the UART. IO0 −IO3 go into the high-impedance state when OFF is active low. INITIALIZATION, INTERRUPTS, AND RESET OPERATIONS RS 100 I Reset. RS causes the ’C206 and ’LC206 to terminate execution and forces the program counter to zero. When RS is brought high, execution begins at location 0 of program memory after 16 cycles. RS affects various registers and status bits. PLLRS 10 I Phase locked loop reset. PLLRS resets the PLL to initiate PLL locking. At power up, both PLLRS and RS should be active (low) to reset the DSP core and the PLL circuitry. The PLL can only be reset along with the core as shown in Table 2. The state of the PLLRS is not applicable for 2 mode and should always be tied high or low. EXT8 1 I Bootloader mode pin. EXT8 is latched to bit 3 (LEVEXT8) in the PMST register. The bootloader located in ROM uses EXT8 to determine the type of boot method. If EXT8 is high, the enhanced ’C206 bootloader is used. If EXT8 is low, the ’C203 style bootloader is used. Refer to the TMS320C20x User’s Guide (literature number SPRU127) for more details regarding the ’C203 style bootloader. MP/MC 2 I Microprocessor/microcomputer mode select. If MP/MC is low, the on-chip ROM memory is mapped into program space. When MP/MC is high, the device accessess off-chip memory. This pin is only sampled at RESET, and its value is latched into bit 0 of the PMST register. NMI 17 I Nonmaskable interrupt. NMI is an external interrupt that cannot be masked by way of the interrupt-mode bit (INTM) or the interrupt-mask register (IMR). When NMI is activated, the processor traps to the appropriate vector location. If NMI is not used, it should be pulled high. HOLD/INT1 18 I HOLD and INT1 share the same pin. Both are treated as interrupt signals. If the MODE bit is 0 in the interrupt control register (ICR), hold logic can be implemented in combination with the IDLE instruction in software. At reset, the MODE bit in ICR is zero, enabling the HOLD mode for the pin. INT2 19 External user interrupts. INT2 and INT3 are prioritized and maskable by the IMR and the INTM. INT2 and INT3 I 20 INT3 can be polled and reset by way of the interrupt flag register (IFR). † I = input, O = output, Z = high impedance, PWR = power, GND = ground POST OFFICE BOX 1443 • HOUSTON, TEXAS 77251−1443 5        SPRS065B − JUNE 1998 − REVISED JANUARY 1999 TMS320C206, TMS320LC206 Terminal Functions (Continued) TERMINAL NAME NO. TYPE† DESCRIPTION OSCILLATOR, PLL, AND TIMER SIGNALS TOUT 92 O Timer output. TOUT signals a pulse when the on-chip timer counts down past zero. The pulse is one CLKOUT1 cycle wide. TOUT goes into the high-impedance state when OFF is active low. CLKOUT1 15 O/Z Master clock ouput. The CLKOUT1 high pulse signifies the logic phase while the low pulse signifies the latch phase. CLKIN/X2 X1 12 13 I O Input clock. CLKIN/X2 is the input clock to the device. As CLKIN, the pin operates as the external oscillator clock input and as X2, the pin operates as the internal oscillator input with X1 being the internal oscillator output. DIV1 DIV2 3 5 I DIV1 and DIV2 are used to configure the on-chip PLL options, providing four clock modes (÷2, ×1, ×2, and ×4) for a given input clock frequency. Refer to clock options in electrical characteristics section. Note that in the divide-by-2 mode, the PLL is bypassed. DIV1 −DIV2 should not be changed unless the RS signal is active. SERIAL PORT SIGNALS (SSP AND ASP) CLKX 87 I/O Transmit clock. CLKX is a clock signal for clocking data from the XSR (transmit shift register) to the DX data-transmit pin. CLKX can be an input if the MCM bit in the synchronous serial-port control register (SSPCR) is set to 0. CLKX can also be driven by the device at one-half of the CLKOUT1 frequency when MCM = 1. If the serial port is not being used, CLKX goes into the high-impedance state when OFF is active low. Value at reset is as an input. CLKR 84 I Receive clock. External clock signal for clocking data from the DR (data-receive) pin into the serial-port receive shift register (RSR). CLKR must be present during serial-port transfers. If the serial port is not being used, CLKR can be sampled as an input by IN0 bit of the SSPCR. FSX 89 I/O Frame synchronization pulse for transmit. The falling edge of the FSX pulse initiates the data-transmit process, beginning the clocking of the SR. Following reset, FSX is an input. FSX can be selected by software to be an output when the TXM bit in the serial control register, SSPCR, is set to 1. FSX goes into the high-impedance state when OFF is active low. FSR 85 I Frame synchronization pulse for receive input. The falling edge of the FSR pulse initiates the data-receive process, beginning the clocking of the RSR. FSR goes into the high-impedance state when OFF is active low. DX 90 O Synchronous serial port (SSP) data transmit output. Serial data is transmitted from the transmit shift register (XSR) through the DX pin. DX is in the high-impedance state when OFF is active low. DR 86 I Synchronous serial port (SSP) data receive input. Serial data is received in the receive shift register (RSR) through the DR pin. TX 93 O Asynchronous serial port (ASP/UART) data transmit output pin RX 95 I Asynchronous serial port (ASP/UART) data receive pin TEST SIGNALS TRST 79 I IEEE Standard 1149.1 (JTAG) test reset. TRST, when active high, gives the scan system control of the operations of the device. If TRST is driven low, the device operates in its functional mode, and the test signals are ignored. If the TRST pin is not driven, an external pulldown resistor must be used. TCK 78 I JTAG test clock. TCK is normally a free-running clock signal with a 50% duty cycle. The changes on the test-access port (TAP) input signals (TMS and TDI) are clocked into the TAP controller, instruction register, or selected test-data register on the rising edge of TCK. Changes at the TAP output signal (TDO) occur on the falling edge of TCK. TMS 81 I JTAG test-mode select. TMS is clocked into the TAP controller on the rising edge of TCK. TDI 80 I JTAG test-data input. TDI is clocked into the selected register (instruction or data) on a rising edge of TCK. TDO 82 O /Z JTAG test-data output. The contents of the selected register (instruction or data) are shifted out of TDO on the falling edge of TCK. TDO is in the high-impedance state except when the scanning of data is in progress. EMU0 76 I/O/Z Emulator pin 0. When TRST is driven low, EMU0 must be high for activation of the OFF condition. When TRST is driven high, EMU0 is used as an interrupt to or from the emulator system and is defined as an input / output through the JTAG scan. † I = input, O = output, Z = high impedance, PWR = power, GND = ground 6 POST OFFICE BOX 1443 • HOUSTON, TEXAS 77251−1443        SPRS065B − JUNE 1998 − REVISED JANUARY 1999 TMS320C206, TMS320LC206 Terminal Functions (Continued) TERMINAL NAME NO. TYPE† DESCRIPTION TEST SIGNALS (CONTINUED) I/O/Z Emulator pin 1. Emulator pin 1 disables all outputs. When TRST is driven high, EMU1 / OFF is used as an interrupt to or from the emulator system and is defined as an input / output through the JTAG scan. When TRST is driven low, this pin is configured as OFF. EMU1 / OFF, when active low, puts all output drivers in the high-impedance state. Note that OFF is used exclusively for testing and emulation purposes (not for multiprocessing applications). Therefore, for the OFF condition, the following apply: TRST = 0 EMU0 = 1 EMU1 / OFF = 0 EMU1 / OFF 77 VDD5 7 16 35 50 63 91 PWR 5-V I/O power supply (Applicable for TMS320C206 only‡) VDD 7 16 35 50 63 91 PWR 3.3-V I/O power supply (Applicable for ’LC206 only) VDD 4 11 75 PWR 3.3-V core power supply (Applicable for both ’C206 and ’LC206 devices‡) VSS 14 21 25 30 37 42 48 54 59 65 70 83 88 94 GND Ground SUPPLY PINS † I = input, O = output, Z = high impedance, PWR = power, GND = ground ‡ For the ’C206, the 3.3-V and 5-V power supplies may be sequenced in any order. Table 2. Resetting the DSP Core and PLL Circuitry RS PLLRS CORE STATUS PLL STATUS 0 0 Reset Reset 0 1 Reset Normal Operation 1 0 Normal Operation Normal Operation§ 1 1 Normal Operation § The PLL can only be reset along with the DSP core and peripherals. POST OFFICE BOX 1443 Normal Operation • HOUSTON, TEXAS 77251−1443 7        SPRS065B − JUNE 1998 − REVISED JANUARY 1999 functional block diagram of the ’C206 internal hardware Program Bus DIV1 DIV2 IS DS PS 16 PC PAR MSTACK RD WE NMI RS MP/MC INT[1−3] NPAR Data Bus Control X1 CLKOUT1 CLKIN/X2 Program Bus MUX R/W STRB READY BR XF HOLD HOLDA MUX STACK 8 x 16 3 ROM (32K  16) 16 PCTRL 16 MUX A15−A0 16 16 16 16 MUX D15−D0 16 16 16 Data Bus 16 Timer Data Bus 16 9 3 AR0(16) TCR DP(9) AR1(16) TOUT PRD 16 7 LSB from IR 16 16 AR2(16) ARP(3) 16 9 AR4(16) 3 AR5(16) ARB(3) TREG0(16) AR6(16) ASP Multiplier AR7(16) 3 ASPCR ISCALE (0−16) PREG(32) 16 32 ADTR TX PSCALE (−6,ā 0,ā 1,ā 4) MUX IOSR RX 32 I/O[0−3] 16 MUX MUX AR3(16) 3 TIM 16 32 BRD 4 16 MUX SSP ARAU(16) MUX 32 SSPCR CALU(32) 16 SDTR Memory Map Register IMR (16) SSPST SSPMC 32 Data/Prog SARAM (4K x 16) IFR (16) GREG (16) 32 MUX MUX Data/Prog DARAM B0 (256 x 16) Data DARAM B2 (32 x16) C ACCH(16) ACCL(16) 32 B1 (256 x16) SSPCT MUX MUX OSCALE (0−7) 16 16 Reserved 16 16 16 16 I/O-Mapped Registers NOTES: A. Symbol descriptions appear in Table 3 and Table 4. B. For clarity, the data and program buses are shown as single buses although they include address and data bits. 8 POST OFFICE BOX 1443 • HOUSTON, TEXAS 77251−1443 Program Bus DX CLKX FSX DR FSR CLKR        SPRS065B − JUNE 1998 − REVISED JANUARY 1999 Table 3. Legend for the ’C206 Internal Hardware Functional Block Diagram SYMBOL NAME DESCRIPTION ACC Accumulator 32-bit register that stores the results and provides input for subsequent CALU operations. Also includes shift and rotate capabilities. ACCH is the accumulator high word; ACCL is the accumulator low word. ADTR Asynchronous Data Transmit and Receive Register 16-bit read/write register used to transmit data from/receive data into the asynchronous serial port. Note that the ASP works with 8-bit data. ARAU Auxiliary Register Arithmetic Unit An unsigned, 16-bit arithmetic unit used to calculate indirect addresses using the auxiliary registers as inputs and outputs. ARB Auxiliary Register Pointer Buffer See Table 4 for status register field definitions. ARP Auxiliary Register Pointer See Table 4 for status register field definitions. ASP Universal Asynchronous Receive/Transmit ASP is the asynchronous serial port (UART). ASPCR Asynchronous Serial-Port Control Register ASPCR controls the asynchronous serial-port operation This register contains bits for setting port modes, enabling/disabling automatic baud-rate detection, selecting the number of stop bits, and configuring I/O pins, etc. AUX REGS (AR0−AR7) Auxiliary Registers 0 −7 These 16-bit registers are used as pointers to anywhere within the data space address range. They are operated upon by the ARAU and are selected by the auxiliary register pointer (ARP). AR0 can also be used as an index value for AR updates of more than one and as a compare value to AR. BR Bus Request Signal BR is asserted during access of the external global data memory space. READY is asserted to the device when the global data memory is available for the bus transaction. BR can be used to extend the data memory address space by up to 32K words. BRD Baud-Rate Divisor Used to set the baud rate of the UART C Carry Register carry output from CALU. C is fed back into the CALU for extended arithmetic operation. The C bit resides in status register 1 (ST1), and can be tested in conditional instructions. C is also used in accumulator shifts and rotates. CALU Central Arithmetic Logic Unit 32-bit-wide main arithmetic logic unit for the TMS320C20x core. The CALU executes 32-bit operations in a single machine cycle. CALU operates on data coming from ISCALE or PSCALE with data from ACC, and provides status results to PCTRL. DARAM Dual Access RAM If the on-chip RAM configuration control bit (CNF) is set to 0, the reconfigurable dual-access RAM (DARAM) block B0 is mapped to data space; otherwise, B0 is mapped to program space. Blocks B1 and B2 are mapped to data memory space only, at addresses 0300−03FF and 0060−007F, respectively. Blocks 0 and 1 contain 256 words, while Block 2 contains 32 words. DP Data Memory Page Pointer See Table 4 for status register field definitions. GREG Global Memory Allocation Register GREG specifies the size of the global data memory space. IFR Interrupt Flag Register The 7-bit IFR indicates that the ’C206 has latched an interrupt pulse from one of the seven maskable interrupt sources. IMR Interrupt Mask Register IMR individually masks or enables the seven interrupts. INT# Interrupt Traps A total of 32 interrupts by way of hardware and/or software are available. IOSR I / O Status Register IOSR detects current levels (and changes with inputs) on pins IO0 −IO3 and the status of UART. IR Instruction Register IR is the instruction register. POST OFFICE BOX 1443 • HOUSTON, TEXAS 77251−1443 9        SPRS065B − JUNE 1998 − REVISED JANUARY 1999 Table 3. Legend for the ’C206 Internal Hardware Functional Block Diagram (Continued) SYMBOL NAME DESCRIPTION ISCALE Input Data-Scaling Shifter 16-bit to 32-bit barrel left-shifter. ISCALE (ISFL) shifts incoming 16-bit data 0 to16 positions left, relative to the 32-bit output within the fetch cycle; therefore, no cycle overhead is required for input scaling operations. MPY Multiplier 16 × 16-bit multiplier to a 32-bit product. MPY executes multiplication in a single cycle. MPY operates either signed or unsigned 2s-complement arithmetic multiply. MSTACK Micro Stack MSTACK provides temporary storage for the address of the next instruction to be fetched when program-address-generation logic is used to generate sequential addresses in data space. MUX Multiplexer Multiplexes buses to a common input NPAR Next Program Address Register NPAR holds the program address to be driven out on the PAB on the next cycle. OSCALE Output Data-Scaling Shifter 32-bit to 16-bit barrel left-shifter. OSCALE (OSFL) shifts the 32-bit accumulator output 0 to 7 bits left for quantization management and outputs either the 16-bit high- or low-half of the shifted 32-bit data to the Data-Write Data Bus (DWEB). PAR Program Address Register PAR holds the address currently being driven on PAB for as many cycles as it takes to complete all memory operations scheduled for the current bus cycle. PC Program Counter PC increments the value from NPAR to provide sequential addresses for instruction-fetching and sequential data-transfer operations. PCTRL Program Controller PCTRL decodes instruction, manages the pipeline, stores status, and decodes conditional operations. PRD Timer-Period Register PRD contains the 16-bit period that is loaded into the timer counter when the counter borrows or when the reload bit is activated. Reset initializes the PRD to FFFFh. PREG Product Register 32-bit register holds results of 16 × 16 multiply. PSCALE Product-Scaling Shifter 0-, 1- or 4-bit left shift or 6-bit right shift of multiplier product. The left-shift options are used to manage the additional sign bits resulting from the 2s-complement multiply. The right-shift option is used to scale down the number to manage overflow of product accumulation in the CALU. PSCALE (PSFL) resides in the path from the 32-bit product shifter and from either the CALU or the DWEB, and requires no cycle overhead. SDTR Synchronous Data Transmit and Receive Register 16-bit read/write register used to transmit data from/receive data into the synchronous serial port. This register functions as the path to the transmit and receive FIFOs of the SSP. SSP Synchronous Serial-Port SSP is the synchronous serial-port. SSPCR Synchronous Serial-Port Control Register SSPCR is the control register for selecting the serial port’s mode of operation. SSPCT Synchronous Serial-Port Counter Register SSPCT is the synchronous serial-port counter register. SSPMC Synchronous Serial-Port Multichannel Register SSPMC is the synchronous serial-port multichannel register. SSPST Synchronous Serial-Port Status Register SSPST is the synchronous serial-port status register. STACK Stack STACK is a block of memory used for storing return addresses for subroutines and interrupt-service routines, or for storing data. The ’C20x stack is 16-bit wide and eight-level deep. TCR Timer-Control Register TCR contains the control bits that define the divide-down ratio, start / stop the timer, and reload the period. Also contained in TCR is the current count in the prescaler. Reset initializes the timer divide-down ratio to 0 and starts the timer. 10 POST OFFICE BOX 1443 • HOUSTON, TEXAS 77251−1443        SPRS065B − JUNE 1998 − REVISED JANUARY 1999 Table 3. Legend for the ’C206 Internal Hardware Functional Block Diagram (Continued) SYMBOL NAME DESCRIPTION TIM Timer-Counter Register TIM contains the current 16-bit count of the timer. Reset initializes the TIM to FFFFh. TREG Temporary Register 16-bit register holds one of the operands for the multiply operations. TREG holds the dynamic shift count for the LACT, ADDT, and SUBT instructions. TREG holds the dynamic bit position for the BITT instruction. architectural overview The ’C206 advanced Harvard-type architecture maximizes the processing power by maintaining two separate memory bus structures—program and data—for full-speed execution. The multiple buses allow data and instructions to be read simultaneously. Instructions support data transfers between the two spaces. This architecture permits coefficients stored in program memory to be read in RAM, eliminating the need for a separate coefficient RAM. This, coupled with a four-instruction deep pipeline, allows the TMS320C206/TMS320LC206 to execute most instructions in a single cycle. status and control registers Two status registers, ST0 and ST1, contain the status of various conditions and modes. These registers can be stored into data memory and loaded from data memory, thus allowing the status of the machine to be saved and restored for subroutines. The load-status register (LST) instruction is used to write to ST0 and ST1 (except the INTM bit which is not affected by the LST instruction). The store-status register (SST) instruction is used to read from the ST0 and ST1. The individual bits of these registers can be set or cleared by the SETC and CLRC instructions. Figure 1 shows the organization of status registers ST0 and ST1, indicating all status bits contained in each. Several bits in the status registers are reserved and are read as logic 1s. See Table 4 for status-register field definitions. ST0 ST1 15 −13 12 11 10 9 8 7 6 5 4 3 2 1 0 ARP OV OVM 1 INTM 15 −13 12 11 10 9 8 7 6 5 4 3 2 1 −0 ARB CNF TC SXM C 1 1 1 1 XF 1 1 PM DP Figure 1. Status and Control Register Organization POST OFFICE BOX 1443 • HOUSTON, TEXAS 77251−1443 11        SPRS065B − JUNE 1998 − REVISED JANUARY 1999 status and control registers (continued) Table 4. Status Register Field Definitions FIELD FUNCTION ARB Auxiliary register pointer buffer. Whenever the ARP is loaded, the old ARP value is copied to the ARB except during an LST instruction. When the ARB is loaded by an LST #1 instruction, the same value is also copied to the ARP. ARP Auxiliary register pointer. ARP selects the auxiliary register (AR) to be used in indirect addressing. When the ARP is loaded, the old ARP value is copied to the ARB register. ARP can be modified by memory-reference instructions when using indirect addressing, and by the LARP, MAR, and LST instructions. The ARP is also loaded with the same value as ARB when an LST #1 instruction is executed. C Carry bit. C is set to 1 if the result of an addition generates a carry, or reset to 0 if the result of a subtraction generates a borrow. Otherwise, C is reset after an addition or set after a subtraction, except if the instruction is ADD or SUB with a 16-bit shift. In these cases, the ADD can only set and the SUB only reset the carry bit, but cannot affect it otherwise. The single-bit shift and rotate instructions also affect C, as well as the SETC, CLRC, and LST #1 instructions. Branch instructions have been provided to branch on the status of C. C is set to 1 on a reset. CNF On-chip RAM configuration-control bit. If CNF is set to 0, the reconfigurable data DARAM blocks are mapped to data space; otherwise, they are mapped to program space. The CNF can be modified by the SETC CNF, CLRC CNF, and LST #1 instructions. RS sets the CNF to 0. DP Data memory page pointer. The 9-bit DP register is concatenated with the seven LSBs of an instruction word to form a direct memory address of 16 bits. DP can be modified by the LST and LDP instructions. INTM Interrupt-mode bit. When INTM is set to 0, all unmasked interrupts are enabled. When set to 1, all maskable interrupts are disabled. INTM is set and reset by the SETC INTM and CLRC INTM instructions. INTM has no effect on the nonmaskable RS and NMI interrupts. Note that INTM is unaffected by the LST instruction. This bit is set to 1 when a maskable interrupt is acknowledged or when RS is asserted. OV Overflow-flag bit. As a latched overflow signal, OV is set to 1 when overflow occurs in the ALU. Once an overflow occurs, the OV remains set until a reset, BCND/D on OV/NOV, or LST instruction clears OV. OVM Overflow-mode bit. When OVM is set to 0, overflowed results overflow normally in the accumulator. When set to 1, the accumulator is set to either its most positive or negative value upon encountering an overflow. The SETC and CLRC instructions set and reset this bit, respectively. LST also can be used to modify the OVM. PM Product-shift mode. If these two bits are 00, the multiplier’s 32-bit product is loaded into the ALU with no shift. If PM = 01, the PREG output is left-shifted one place and loaded into the ALU, with the LSB zero-filled. If PM = 10, the PREG output is left-shifted by four bits and loaded into the ALU, with the LSBs zero-filled. PM = 11 produces a right shift of six bits, sign-extended. Note that the PREG contents remain unchanged. The shift takes place when transferring the contents of the PREG to the ALU. PM is loaded by the SPM and LST #1 instructions. PM is cleared by RS. SXM Sign-extension mode bit. SXM = 1 produces sign extension on data as it is passed into the accumulator through the scaling shifter. SXM = 0 suppresses sign extension. SXM does not affect the definitions of certain instructions; for example, the ADDS instruction suppresses sign extension regardless of SXM. SXM is set by the SETC SXM and reset by the CLRC SXM instructions, and can be loaded by the LST #1. SXM is set to 1 by reset. TC Test /control flag bit. TC is affected by the BIT, BITT, CMPR, LST #1, and NORM instructions. TC is set to a 1 if a bit tested by BIT or BITT is a 1, if a compare condition tested by CMPR exists between AR (ARP) and AR0, if the exclusive-OR function of the two MSBs of the accumulator is true when tested by a NORM instruction. The conditional branch, call, and return instructions can execute, based on the condition of TC. XF XF pin status bit. XF indicates the state of the XF pin, a general-purpose output pin. XF is set by the SETC XF and reset by the CLRC XF instructions. XF is set to 1 by reset. central processing unit The TMS320C206/TMS320LC206 central processing unit (CPU) contains a 16-bit scaling shifter, a 16 x16-bit parallel multiplier, a 32-bit central arithmetic logic unit (CALU), a 32-bit accumulator, and additional shifters at the outputs of both the accumulator and the multiplier. This section describes the CPU components and their functions. The functional block diagram shows the components of the CPU. 12 POST OFFICE BOX 1443 • HOUSTON, TEXAS 77251−1443        SPRS065B − JUNE 1998 − REVISED JANUARY 1999 input scaling shifter The TMS320C206/TMS320LC206 provides a scaling shifter with a 16-bit input connected to the data bus and a 32-bit output connected to the CALU. This shifter operates as part of the path of data coming from program or data space to the CALU, and requires no cycle overhead. It is used to align the 16-bit data coming from memory to the 32-bit CALU. This is necessary for scaling arithmetic as well as aligning masks for logical operations. The scaling shifter produces a left shift of 0 to 16 on the input data. The LSBs of the output are filled with zeros; the MSBs may either be filled with zeros or sign-extended, depending upon the value of the SXM bit (sign-extension mode) of status register ST1. The shift count is specified by a constant embedded in the instruction word or by a value in TREG. The shift count in the instruction allows for specific scaling or alignment operations specific to that point in the code. The TREG base shift allows the scaling factor to adapt to the performance of the system. multiplier The TMS320C206/TMS320LC206 uses a 16 x16-bit hardware multiplier that is capable of computing a signed or an unsigned 32-bit product in a single machine cycle. All multiply instructions, except the MPYU (multiply unsigned) instruction, perform a signed-multiply operation. That is, two numbers being multiplied are treated as 2s-complement numbers, and the result is a 32-bit 2s-complement number. There are two registers associated with the multiplier: D a 16-bit temporary register (TREG) that holds one of the operands for the multiplier, and D a 32-bit product register (PREG) that holds the product. Four product shift modes (PM) are available at the PREG output (PSCALE). These shift modes are useful for performing multiply/accumulate operations, performing fractional arithmetic, or justifying fractional products. The PM field of status register ST1 specifies the PM shift mode, as shown in Table 5. Table 5. PSCALE Product Shift Modes PM SHIFT 00 no shift DESCRIPTION 01 left 1 Removes the extra sign bit generated in a 2s-complement multiply to produce a Q31 product 10 left 4 Removes the extra four sign bits generated in a 16 x13 2s-complement multiply to a produce a Q31 product when using the multiply by a 13-bit constant 11 right 6 Product fed to CALU or data bus with no shift Scales the product to allow up to 128 product accumulation without the possibility of accumulator overflow The product can be shifted one bit to compensate for the extra sign bit gained in multiplying two 16-bit 2s-complement numbers (MPY). A four-bit shift is used in conjunction with the MPY instruction with a short immediate value (13 bits or less) to eliminate the four extra sign bits gained in multiplying a 16-bit number by a 13-bit number. Finally, the output of PREG can be right-shifted six bits to enable the execution of up to 128 consecutive multiply/accumulates without the possibility of overflow. The LT (load TREG) instruction normally loads TREG to provide one operand (from the data bus), and the MPY (multiply) instruction provides the second operand (also from the data bus). A multiplication can also be performed with a 13-bit immediate operand when using the MPY instruction. A product is then obtained every two cycles. For efficient implementation of multiple products, or multiple sums of products, the CPU provides pipelining of the TREG load operation with certain CALU operations which use the PREG. These operations include: load ACC with PREG (LTP); add PREG to ACC (LTA); add PREG to ACC and shift TREG input data to next address in data memory (LTD); and subtract PREG from ACC (LTS). POST OFFICE BOX 1443 • HOUSTON, TEXAS 77251−1443 13        SPRS065B − JUNE 1998 − REVISED JANUARY 1999 multiplier (continued) Two multiply/accumulate instructions (MAC and MACD) fully utilize the computational bandwidth of the multiplier, allowing both operands to be processed simultaneously. The data for these operations can be transferred to the multiplier each cycle by way of the program and data buses. This facilitates single-cycle multiply/accumulates when used with the repeat (RPT) instruction. In these instructions, the coefficient addresses are generated by program-address generation (PAGEN), while the data addresses are generated by data-address generation (DAGEN). This allows the repeated instruction to access the values sequentially from the coefficient table and step through the data in any of the indirect addressing modes. The MACD instruction, when repeated, supports filter constructs (weighted running averages) so that as the sum-of-products is executed, the sample data is shifted in memory to make room for the next sample and to discard the oldest sample. The MPYU instruction performs an unsigned multiplication, which greatly facilitates extended-precision arithmetic operations. The unsigned contents of TREG are multiplied by the unsigned contents of the addressed data-memory location, with the result placed in PREG. This allows the operands of greater than 16 bits to be broken down into 16-bit words and processed separately to generate products of greater than 32 bits. The SQRA (square/add) and SQRS (square/subtract) instructions pass the same value to both inputs of the multiplier for squaring a data-memory value. After the multiplication of two 16-bit numbers, the 32-bit product is loaded into the 32-bit product register (PREG). The product from PREG can be transferred to the CALU or to data memory through the SPH (store product high) and SPL (store product low) instructions. Note: the transfer of PREG to either the CALU or data memory passes through the PSCALE shifter and is therefore, affected by the product-shift mode value defined by the PM bits in the ST1 register. This is important when saving PREG in an interrupt-service routine context save as the PSCALE shift effects cannot be modeled in the restore operation. PREG can be cleared by executing the MPY #0 instruction. The product register can be restored by loading the saved low half into TREG and executing a MPY #1 instruction. The high half is then loaded using the LPH instruction. central arithmetic logic unit The TMS320C206/TMS320LC206 CALU implements a wide range of arithmetic and logical functions, the majority of which execute in a single clock cycle. This arithmetic/logic unit (ALU) is referred to as central to differentiate it from a second ALU used for indirect address generation called the auxiliary register arithmetic unit (ARAU). Once an operation is performed in the CALU, the result is transferred to the accumulator (ACC) where additional operations, such as shifting, may occur. Data that is input to the CALU can be scaled by ISCALE when coming from one of the data buses (DRDB or PRDB) or scaled by PSCALE when coming from the multiplier. The CALU is a general-purpose ALU unit that operates on 16-bit words taken from data memory or derived from immediate instructions. In addition to arithmetic operations, the CALU can perform Boolean operations, facilitating the bit-manipulation ability required for a high-speed controller. One input to the CALU is always provided from the accumulator, and the other input can be provided from the product register (PREG) of the multiplier or from the output of the scaling shifter (that has been read from data memory or from the ACC). After the CALU has performed the arithmetic or logical operation, the result is stored in the accumulator. The TMS320C206/TMS320LC206 supports floating-point operations for applications requiring a large dynamic range. The NORM (normalization) instruction is used to normalize fixed-point numbers contained in the accumulator by performing left shifts. The four bits of the TREG define a variable shift through the scaling shifter for the LACT/ADDT/SUBT (load/add to/subtract from accumulator with shift specified by TREG) instructions. These instructions are useful in floating-point arithmetic where denormalization of a number is required (that is, floating-point to fixed-point conversion). They are also useful in the implementation of automatic-gain control (AGC) at the input of a filter. The BITT (bit test) instruction provides testing of a single bit of a word in data memory based on the value contained in the four LSBs of TREG. 14 POST OFFICE BOX 1443 • HOUSTON, TEXAS 77251−1443        SPRS065B − JUNE 1998 − REVISED JANUARY 1999 central arithmetic logic unit (continued) The CALU overflow-saturation mode can be enabled/disabled by setting/resetting the OVM bit of ST0. Setting the OVM status-register bit selects the overflow-saturation mode. When the CALU is in the overflow-saturation mode and an overflow occurs, the overflow flag is set and the accumulator is loaded with either the most positive or the most negative value representable in the accumulator, depending upon the direction of the overflow. The value of the accumulator upon saturation is 07FFFFFFFh (positive) or 080000000h (negative). If the OVM (overflow mode) status register bit is reset and an overflow occurs, the overflowed results are loaded into the accumulator without modification. (Logical operations cannot result in overflow.) The CALU can execute a variety of branch instructions that depend on the status of the CALU and accumulator. These instructions can be executed conditionally, based on various combinations of the associated status bits. For overflow management, these conditions include the OV (branch on overflow) and EQ (branch on accumulator equal to zero). In addition, the BACC (branch to address in accumulator) instruction provides the ability to branch to an address specified by the accumulator (computed goto). Bit-test instructions (BIT and BITT), which do not affect the accumulator, allow the testing of a specified bit of a word in data memory. The CALU also has a carry bit (bit 9 of status register ST1) that facilitates efficient computation of extended-precision products and additions or subtractions. The carry bit is also useful in overflow management. The carry bit is affected by the following operations: D Additions to and subtractions from the accumulator: C = 0: When the result of a subtraction generates a borrow. When the result of an addition does not generate a carry. (Exception: When the ADD instruction is used with a shift of 16 and no carry is generated, the ADD instruction has no effect on C.) C = 1: When the result of an addition generates a carry. When the result of a subtraction does not generate a borrow. (Exception: When the SUB instruction is used with a shift of 16 and no borrow is generated, the SUB instruction has no effect on C.) D Single-bit shifts and rotations of the accumulator value. During a left shift or rotation, the most significant bit of the accumulator is passed to C; during a right shift or rotation, the least significant bit is passed to C. Note: the carry bit is set to “1” on a hardware reset. The ADDC (add to accumulator with carry) and SUBB (subtract from accumulator with borrow) instructions use the previous value of carry in their addition/subtraction operation. accumulator The 32-bit accumulator is the registered output of the CALU. It can be split into two 16-bit segments for storage in data memory. Shifters at the output of the accumulator provide a left shift of 0 to 7 places. This shift is performed while the data is being transferred to the data bus for storage. The contents of the accumulator remain unchanged. When the post-scaling shifter is used on the high word of the accumulator (bits 16−31), the MSBs are lost and the LSBs are filled with bits shifted in from the low word (bits 0−15). When the postscaling shifter is used on the low word, the LSBs are zero-filled. The SFL and SFR (in-place one-bit shift to the left / right) instructions and the ROL and ROR (rotate to the left/right) instructions implement shifting or rotating of the accumulator contents through the carry bit. The SXM bit affects the definition of the SFR (shift accumulator right) instruction. When SXM = 1, SFR performs an arithmetic right shift, maintaining the sign of the accumulator data. When SXM = 0, SFR performs a logical shift, shifting out the LSBs and shifting in a zero for the MSB. The SFL (shift accumulator left) instruction is not affected by the SXM bit and behaves the same way in both cases, shifting out the MSB and shifting in a zero. Repeat (RPT) instructions can be used with the shift and rotate instructions for multiple-bit shifts. POST OFFICE BOX 1443 • HOUSTON, TEXAS 77251−1443 15        SPRS065B − JUNE 1998 − REVISED JANUARY 1999 auxiliary registers and auxiliary-register arithmetic unit (ARAU) The ’C206 provides a register file containing eight auxiliary registers (AR0−AR7). The auxiliary registers are used for indirect addressing of the data memory or for temporary data storage. For indirect data-memory addressing, the address of the desired memory location is placed into the selected auxiliary register. These registers are referenced with a 3-bit auxiliary register pointer (ARP) that is loaded with a value from 0 through 7, designating AR0 through AR7, respectively. The auxiliary registers and the ARP can be loaded from data memory, the ACC, the product register, or by an immediate operand defined in the instruction. The contents of these registers can also be stored in data memory or used as inputs to the CALU. The auxiliary register file (AR0−AR7) is connected to the auxiliary register arithmetic unit (ARAU). The ARAU can autoindex the current auxiliary register while the data-memory location is being addressed. Indexing either by ±1 or by the contents of the AR0 register can be performed. As a result, accessing tables of information does not require the CALU for address manipulation; thus, the CALU is free for other operations in parallel. memory The ’C206 implements three separate address spaces for program memory, data memory, and I/O. Each space accommodates a total of 64K 16-bit words. Within the 64K words of data space, the 256 to 32K words at the top of the address range can be defined to be external global-memory in increments of powers of two, as specified by the contents of the global-memory allocation register (GREG). Access to global memory is arbitrated using the global-memory bus request (BR) signal. On the ’C206, the first 96 (0 −5Fh) data-memory locations are allocated for memory-mapped registers or reserved. This memory-mapped register space contains various control and status registers including those for the CPU. The on-chip memory of the ’C206 includes 544 x 16 words of dual-access RAM (DARAM), 4K x 16 single-access RAM (SARAM), and 32K x 16 program ROM memory. Table 6 shows the mapping of these memory blocks and the appropriate control bits and pins. Figure 2 shows the effects of the memory control pin MP/MC and the control bit CNF on the mapping of the respective memory spaces to on-chip or off-chip. The PON and DON bits select the SARAM (4K) mapping in program, data, or both. See Table 9 for details on the PMST register, the PON bit, and the DON bit. At reset, these bits are 11, and the on-chip SARAM is mapped in both the program and data space. The SARAM addresses (800h in data and 8000h in program memory) are accessible in external memory space, if the on-chip SARAM is not enabled. At reset, if the MP/MC pin is held high, the device starts in microprocessor mode and branches to 0000h in external program space. The MP/MC pin status is latched in the PMST register (bit 0). As long as this bit remains high, the device is in microprocessor mode. PMST register bits can be read and modified in software. If bit 0 is cleared to 0, the device enters microcomputer mode and program memory addresses from 0000h to 7FFFh map to on-chip ROM. If the MP/MC pin is held low during reset, the device starts in microcomputer mode and branches to 0000h in the on-chip ROM mapped in program space. The on-chip ROM could either contain the bootloader or customer-specific application code which is then executed. The on-chip data memory blocks B0 and B1 are 256  16 words each. When CNF = 0, B0 is mapped in data space at addresses 0200−02FFh. When CNF = 1, B0 is mapped in program space at addresses 0FF00−0FFFFh. The B1 block is always mapped in data space at addresses 0300−03FFh, and B2 block is always mapped in a data space at addresses 60−7Fh. 16 POST OFFICE BOX 1443 • HOUSTON, TEXAS 77251−1443        SPRS065B − JUNE 1998 − REVISED JANUARY 1999 memory (continued) Hex PROGRAM Hex PROGRAM Hex DATA Hex 0000 Interrupt Vectors 0000 Interrupt Vectors 0000 Memory-Mapped 0000 ------------- ------------- Registers and Bootloader Code ------------- External I/O SPACE 005F Reserved Addresses A-law table 0060 On-Chip ------------- 007F DARAM B2 µ- law table 0080 Reserved ------------- 01FF 0200 7EFF Unused On-Chip DARAM B0 (CNF = 0) ------------7FFF 8000 8FFF On-Chip 7F00 Reserved For 7FFF ROM Test Code (CNF = 1) 02FF On-Chip 0300 On-Chip SARAM 4K SARAM 4K 03FF DARAM B1 Internal (PON = 1) Internal (PON = 1) 0400 External (PON = 0) 9000 8000 Reserved 8FFF External (PON = 0) External I/O Space Reserved 07FF 9000 0800 On-Chip SARAM 4K Internal (DON = 1) External 17FF External FDFF FE00 External 1800 FDFF Reserved FE00 (DON = 0) External Reserved (CNF = 1) (CNF = 1) FEFF External External FF00 Reserved FEFF (CNF = 0) FEFF (CNF = 0) FF00 On-Chip DARAM FF00 On-Chip DARAM FF0F Test B0 (CNF = 1) FF10 On-Chip I/O B0 (CNF = 1) External FFFF (CNF = 0) Microprocessor Mode (MP/MC = 1) for External FFFF Peripheral (CNF = 0) FFFF FFFF Registers Microcomputer Mode (MP/MC = 0) On-chip ROM† † Standard ROM devices will come with boot code and the A-law, µ-law table. Figure 2. TMS320C206/TMS320LC206 Memory Map Configurations POST OFFICE BOX 1443 • HOUSTON, TEXAS 77251−1443 17        SPRS065B − JUNE 1998 − REVISED JANUARY 1999 memory (continued) Table 6. TMS320C206/TMS320LC206 Memory Map DATA MEMORY ADDRESS PROG MEMORY ADDRESS MP/MC† DON† PON† CNF BIT† 200h − 2FFh − x x x 0 256 x 16 word DARAM (B0) − FF00h − FFFFh x x x 1 256 x 16 word DARAM (B1) 300h − 3FFh − x x x x 32 x 16 word DARAM (B2) 60h − 7Fh − x x x x 32K x 16 word on-chip program memory (ROM) − 0000h − 7FFFh 0 x x x 32K x 16 word external program memory − 0000h − 7FFFh 1 x x x 32K x 16 word external program memory, if CNF=0 and MP/MC =0 − 8000h − FFFFh 0 x 0 0 External program memory, if CNF=1 − 8000h − FDFFh 0 x 0 1 4K x 16 word on-chip SARAM (data) 800h − 17FFh x 1 0 x DESCRIPTION OF MEMORY BLOCK 256 x 16 word dual-access RAM (DARAM) (B0) 4K x 16 word on-chip SARAM (program) 4K x 16 word program and data on-chip SARAM‡ − 8000h − 8FFFh x 0 1 x 800h − 17FFh 8000h − 8FFFh x 1 1 x x 0 0 x 4K x 16 word on-chip SARAM not available not available † The “x” denotes a “don’t care” condition. ‡ The single 4K on-chip SARAM block is accessible from both data and program memory space. on-chip ROM The mask-programmable ROM is located in program memory space. Customers can arrange to have this ROM programmed with contents unique to any particular application. The ROM is enabled or disabled by the state of the MP/MC control input upon resetting the device. In microcomputer mode (MP/MC = 0), the ROM occupies the block of program memory from addresses 0000−7FFFh. (Note: the last 100h words, 7F00−7FFFh, are reserved for test.) When in microprocessor mode (MP/MC = 1), addresses 0000h−7FFFh are located in the device’s external program memory space. bootloader A bootloader is available in the standard ’C206/’LC206 on-chip ROM. This bootloader can be used to automatically transfer user code from an external source to program memory at power up. If MP/MC of the device is sampled low during a hardware reset, execution begins at location 0000h of the on-chip ROM. This location contains a branch instruction to the start of the bootloader program. User code can be transferred to the DSP program memory using any one of the following options: D D D D D 8-bit transfer through the Synchronous Serial Port (SSP) 8-bit transfer through the Asynchronous Serial Port (ASP) 8/16-bit external EPROM 8/16-bit parallel port mapped to I/O space address 0001h of the DSP Warm boot option The standard ’C206/’LC206 on-chip ROM also contains the A-law, µ-law table in addition to the bootloader. (The A-law table starts at 0400h, and the µ-law table starts at 0500h.) 18 POST OFFICE BOX 1443 • HOUSTON, TEXAS 77251−1443        SPRS065B − JUNE 1998 − REVISED JANUARY 1999 bootloader (continued) The required option is chosen by the state of the EXT8 pin during power up and with the help of a boot routine selection (BRS) word, which is read from I/O address 0000h. The lower 8 bits of the word specify which bootloader option is to be executed. The BRS word uses a 6-bit source address field (SRCE_AD) in parallel EPROM mode and a 6-bit entry address field (ADDR_bb) in warm boot mode to arrive at the starting address of the code. The state of the MP/MC and EXT8 pins is copied into the PMST register. Table 7 describes the bootloader options that can be chosen by the EXT8 pin. Table 8 describes the options available in the ’C206 enhanced bootloader and the bit values of the BRS word to select modes. Table 7. Bootloader Pin Configurations MP/MC EXT8 OPTION MODES 0 0 Use ’C203 style bootloader 1 0 1 Use ’C206 enhanced bootloader 2 to 9 1 0 EXT8 has no effect − 1 1 EXT8 has no effect − Table 8. ’C206 Bootloader Options BOOTLOADER OPTION MODE xxxxxxxx BRS WORD AT I/O 0000h xxx0 0000 8-bit serial SSP, ext FSX, CLKX 2 xxxxxxxx xxx0 0100 16-bit serial SSP, ext FSX, CLKX 3 xxxxxxxx xxx0 1000 8-bit parallel I/O 4 xxxxxxxx xxx0 1100 16-bit parallel I/O 5 xxxxxxxx xxx1 0000 8-bit ASP/UART 6 xxxxxxxx SRCE AD01 8-bit EPROM 7 xxxxxxxx SRCE AD10 16-bit EPROM 8 xxxxxxxx ADDR bb11 Warm boot 9 Figure 3 shows the program flow of the ’C206 bootloader. See the TMS320C20x User’s Guide (literature number SPRU127) for more information about the ’C206 bootloader. POST OFFICE BOX 1443 • HOUSTON, TEXAS 77251−1443 19        SPRS065B − JUNE 1998 − REVISED JANUARY 1999 bootloader (continued) Start C203 Style Loader? (LEVEXT8 = 0?) Yes Perform C203 Style Bootloading Warm Boot (2 LSBs = 11) No Serial/ Parallel Load? (2 LSBs of BRS = 00?) No No Yes Perform UART/ Asynchronous Serial Load Yes 8-Bit EPROM? (2 LSBs = 01?) No Yes UART/ Asynchronous Serial Load? (Bit 4 of BRS = 1?) 16-Bit EPROM? (2 LSBs = 10?) Yes Perform 16-Bit EPROM Perform 8-Bit EPROM Yes Parallel I/O Load? (Bit 3 of BRS = 1?) No Perform 8-Bit Synchronous Serial Load (Bit 2 of BRS = 0) Yes 8-Bit Synchronous Serial Load? (Bit 2 of BRS = 0?) Yes 8-Bit Parallel I/O? (Bit 2 of BRS = 0?) Yes Perform 8-Bit Parallel I/O No Perform 16-Bit Synchronous Serial Load (Bit 2 of BRS = 1) Figure 3. ’C206 Bootloader Program Flow 20 POST OFFICE BOX 1443 • HOUSTON, TEXAS 77251−1443 No Perform 16-Bit Parallel I/O (Bit 2 of BRS = 1)        SPRS065B − JUNE 1998 − REVISED JANUARY 1999 on-chip registers The TMS320C206/TMS320LC206 includes three registers mapped to internal data space and sixteen (16) registers mapped to internal I/O space. Table 9 describes these registers and shows their respective addresses. In the table, DS† refers to data space and IS† refers to I/O space. Table 9. On-Chip Memory and I/O Mapped Registers NAME ADDRESS† VALUE AT RESET‡ DESCRIPTION IMR DS@0004 0000h Interrupt-mask register. This seven-bit register individually masks or enables the seven interrupts. Bit 0 shares external interrupt INT1 and HOLD. INT2 and INT3 share bit 1. Bit 2 ties to the timer interrupt, TINT. Bits 3 and 4, RINT and XINT, respectively, are for the synchronous serial port, SSP. Bit 5, TXRXINT, shares the transmit and receive interrupts for the asynchronous serial port, ASP. Bit 6 is reserved for monitor-mode-emulation operations and must always be set to 0 except in conjunction with emulation-monitor operations. Bits 7 −15 are not used in the TMS320C206/TMS320LC206. IMR is set to 0 at reset. A bit value of 0 disables an interrupt, and a value of 1 enables an interrupt. GREG DS@0005 0000h Global-memory allocation register. This 8-bit register specifies the size of the global memory space. GREG is set to 0 at reset. 0000h Interrupt-flag register. The seven-bit IFR indicates that the TMS320C206/TMS320LC206 has latched an interrupt from one of the seven maskable interrupts. Bit 0 shares external interrupt INT1 and HOLD. INT2 and INT3 share bit 1. Bit 2 ties to the timer interrupt, TINT. Bits 3 and 4, RINT and XINT, respectively, are for the SSP. Bit 5, TXRXINT, shares the transmit and receive interrupts for the ASP. Bit 6 is reserved for monitor-mode-emulation operations and must always be set to 0 except in conjunction with emulation-monitor operations. Writing a 1 to the respective interrupt bit clears an active flag and the respective pending interrupt. Writing a 1 to an inactive flag has no effect. Bits 7 −15 are not used in the TMS320C206/TMS320LC206. IFR is set to 0 at reset. IFR DS@0006 Bit 0 - Processor mode status bit (PMST). latches in the MP/MC pin at reset. This bit can be written to configure microprocessor (1) or microcomputer mode (0). Bits 1 and 2 configure the SARAM mapping either in program memory, data memory, or both. At reset, these bits are 11, the SARAM is mapped in both program and data space. DON (bit 2) PON (bit 1) 0 0 - SARAM not mapped, address in external memory 0 1 - SARAM in on-chip program memory at 0x8000h 1 0 - SARAM in on-chip data memory at 0x800h 1 1 - SARAM in on-chip program and data memory (reset value) Bit 3 - LEVEXT8 bit. This bit captures the status of the EXT8 pin 1 at reset only. Bit 15 − Fast RD, FRDN. This bit provides software control to select an inverted R/W signal in place of the RD signal (pin 45). This is intended to help achieve zero wait-state memory interface with slow memory devices. At reset, this bit is 0 and selects RD as the signal at pin 45. If the FRDN bit is written with a 1, the read signal at pin 45 is replaced with the inverted R/W signal. PMST IS@FFE4 0006h CLK IS@FFE8 0000h CLKOUT1 on or off. At reset, this bit is configured as a zero for the CLKOUT1 pin to be active. If this bit is a 1, CLKOUT1 pin is turned off. 0000h Interrupt-control register. This register is used to determine which interrupt is active since INT1 and HOLD share the same interrupt vector as INT2 and INT3. A portion of this register is for mask/unmask (similar to IFR). At reset, all bits are zeroed, thereby allowing the HOLD mode to be enabled. The MODE bit is used by the hold-generating circuit to determine if a HOLD or INT1 is active. ICR IS@FFEC † DS = data space and IS = input/output ports ‡ ‘x’ indicates undefined or value based on the pin levels at reset. POST OFFICE BOX 1443 • HOUSTON, TEXAS 77251−1443 21        SPRS065B − JUNE 1998 − REVISED JANUARY 1999 on-chip registers (continued) Table 9. On-Chip Memory and I/O Mapped Registers (Continued) NAME ADDRESS† VALUE AT RESET‡ SDTR IS@FFF0 xxxxh Synchronous serial port (SSP) transmit and receive register SSPCR IS@FFF1 0030h Synchronous serial-port control register. This register controls serial-port operation as defined by the register bits. SSPST IS@FFF2 0000h Synchronous serial-port status register SSPMC IS@FFF3 0000h Synchronous serial-port multichannel register ADTR IS@FFF4 xxxxh Asynchronous serial port (ASP) transmit and receive register ASPCR IS@FFF5 0000h Asynchronous serial-port control register. This register controls the asynchronous serial-port operation. IOSR IS@FFF6 18xxh I/O-status register. IOSR is used for detecting current levels on pins IO0 −IO3 when defined as inputs. BRD IS@FFF7 0001h Baud-rate generator. 16-bit register used to determine baud rate of UART. No data is transmitted/received if BRD is zero. DESCRIPTION TCR IS@FFF8 0000h Timer-control register. This ten-bit register contains the control bits that define the divide-down ratio, start/stop the timer, and reload the period. Also contained in this register is the current count in the prescaler. Reset initializes the timer divide-down ratio to 0 and starts the timer. PRD IS@FFF9 FFFFh Timer-period register. This 16-bit register contains the 16-bit period that is loaded into the timer counter when the counter borrows or when the reload bit is activated. Reset initializes the PRD to 0xFFFF. TIM IS@FFFA FFFFh Timer-counter register. This 16-bit register contains the current 16-bit count of the timer. Reset initializes the TIM to 0xFFFF. SSPCT IS@FFFB 0000h Synchronous serial-port counter register. WSGR IS@FFFC 0FFFh Wait-state generator register. This register contains 12 control bits to enable 0 to 7 wait states to program, data, and I/O space. Reset initializes WSGR to 0x0FFFh. † DS = data space and IS = input/output ports ‡ ‘x’ indicates undefined or value based on the pin levels at reset. external interface The ’C206 devices can address up to 64K × 16 words of memory (or registers) in each of the program, data, and I/ O spaces. On-chip memory, when enabled, occupies some of this off-chip range. In data space, the high 32K words can be mapped dynamically either locally or globally using the GREG register as described in the TMS320C20x User’s Guide (literature number SPRU127). A data-memory access that is mapped as global asserts BR low ( with timing similar to the address bus). The CPU of the ’C206 schedules a program fetch, data read, and data write on the same machine cycle. This is because from on-chip memory, the CPU can execute all three of these operations in the same cycle. However, the external interface multiplexes the internal buses to one address and one data bus. The external interface sequences these operations to complete first the data write, then the data read, and finally the program read. The ’C206 supports a wide range of system-interfacing requirements. Program, data, and I/O address spaces provide interface to memory and I/O, thus maximizing system throughput. The full 16-bit address and data bus, along with the PS, DS, and IS space-select signals, allow addressing of 64K 16-bit words in each of the three spaces. I/O design is simplified by having I/O treated the same way as memory. I/O devices are mapped into the I/O address space using the processor’s external address and data buses in the same manner as memory-mapped devices. 22 POST OFFICE BOX 1443 • HOUSTON, TEXAS 77251−1443        SPRS065B − JUNE 1998 − REVISED JANUARY 1999 external interface (continued) The ’C206 external parallel interface provides various control signals to facilitate interfacing to the device. The R/W output signal is provided to indicate whether the current cycle is a read or a write. The STRB output signal provides a timing reference for all external cycles. For convenience, the device also provides the RD and the WE output signals, which indicate a read and a write cycle, respectively, along with timing information for those cycles. The availability of these signals minimizes external gating necessary for interfacing external devices to the ’C206. Interface to memory and I/O devices of varying speeds is accomplished by using the READY line. When transactions are made with slower devices, the ’C206 processor waits until the other device completes its function and then signals the processor via the READY line. Once a ready indication is provided back to the ’C206 from the external device, execution continues. The bus request (BR) signal is used in conjunction with the other ’C206 interface signals to arbitrate external global memory accesses. Global memory is external data-memory space in which the BR signal is asserted at the beginning of the access. When an external global memory device receives the bus request, it responds by asserting the READY signal after the global memory access is arbitrated and the global access is completed. The TMS320C206/TMS320LC206 supports zero-wait-state reads on the external interface. However, to avoid bus conflicts, writes take two cycles. This allows the TMS320C206/TMS320LC206 to buffer the transition of the data bus from input to output (or from output to input) by a half cycle. In most systems, TMS320C206/TMS320LC206 ratio of reads to writes is significantly large to minimize the overhead of the extra cycle on writes. Wait states can be generated when accessing slower external resources. The wait states operate on machine-cycle boundaries and are initiated either by using READY or by using the software wait-state generator. READY can be used to generate any number of wait states. interrupts and subroutines The ’C206 implements three general-purpose interrupts, INT3−INT1, along with reset (RS), and the nonmaskable interrupt (NMI), which are available for external devices to request the attention of the processor. Internal interrupts are generated by the synchronous serial port (RINT and XINT), by the timer (TINT), UART, (TXRXINT), and by the software-interrupt (TRAP, INTR and NMI) instructions. Interrupts are prioritized, with RS having the highest priority, (followed by NMI), and UART having the lowest priority. Additionally, any interrupt except RS and NMI can be individually masked with a dedicated bit in the interrupt mask register (IMR) and can be cleared, set, or tested using its own dedicated bit in the interrupt flag register (IFR). The reset and NMI functions are not maskable. All interrupt vector locations are on two-word boundaries so that branch instructions can be accommodated in those locations if desired. A built-in mechanism protects multicycle instructions from interrupts. If an interrupt occurs during a multicycle instruction, the interrupt is not processed until the instruction completes execution. This mechanism applies to instructions that are repeated (using the RPT instruction) and to instructions that become multicycle because of wait states. Each time an interrupt is serviced or a subroutine is entered, the program counter (PC) is pushed onto an internal hardware stack, providing a mechanism for returning to the previous context. The stack contains eight locations, allowing interrupts or subroutines to be nested up to eight levels deep. POST OFFICE BOX 1443 • HOUSTON, TEXAS 77251−1443 23        SPRS065B − JUNE 1998 − REVISED JANUARY 1999 reset The ’C206 utilizes an active-low reset (RS and PLLRS) input for the core, peripherals, and PLL. A minimum pulse duration of six cycles ensures that an asynchronous reset signal properly resets the device. The ’C206 fetches its first instruction approximately sixteen cycles after the rising edge of RS. The reset action halts all operations whether they are complete or not; therefore, the state of the system and its data cannot be maintained through the reset operation. For example, if the device is writing to an external resource when the reset is initiated, the write is aborted; this may corrupt the contents or configuration of system resources. Therefore, it is necessary to reinitialize the system after a reset. power-down modes The ’C206 implements a power-down mode in which the ’C206 core enters a dormant state and dissipates less power. The power-down mode is invoked by executing an IDLE instruction. While the device is in power-down mode, the on-chip peripherals continue to operate. While the ’C206 is in a power-down mode, all of its internal contents are maintained; this allows operation to continue unaltered when the power-down mode is terminated. All CPU activities are halted when the IDLE instruction is executed, but the CLKOUT1 pin remains active depending on the status of the CLKOUT1-pin control register (CLK). The peripheral circuits continue to operate, allowing peripherals such as serial ports and timers to take the CPU out of its powered-down state. The power-down mode, when initiated by an IDLE instruction, is terminated upon receipt of an interrupt. software-controlled wait-state generator Due to the fast cycle time of the ’C206 devices, it is often necessary to operate with wait states to interface with external logic or memory. For many systems, one wait state is adequate. The software wait-state generator can be programmed to generate between zero and seven wait states for a given space. Software wait states are configured by way of the wait-state generator register (WSGR). The WSGR includes four 3-bit fields to configure wait states for the following external memory spaces: data space (DSWS), upper program space (PSUWS), lower program space (PSLWS), and I/O space (ISWS). The wait-state generator enables wait states for a given memory space based on the value of the corresponding three bits, regardless of the condition of the READY signal. The READY signal can be used to generate additional wait states. All bits of the WSGR are set to 1 at reset, so that the device can operate from slow memory immediately after reset.The WSGR register (shown in Figure 4) resides at I/O port FFFCh. See Table 7 for the bit settings of the various fields in the WSGR for wait-state programming. See Table 8 for a description of the various WSGR fields. 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 Reserved ISWS DSWS PSUWS PSLWS 0 R/W−111 R/W−111 R/W−111 R/W−111 LEGEND: 0 = Always read as zeros, R = Read Access, W= Write Access, − n = Value after reset Figure 4. TMS320C206/TMS320LC206 Wait-State Generator Register ( WSGR) 24 POST OFFICE BOX 1443 • HOUSTON, TEXAS 77251−1443 0        SPRS065B − JUNE 1998 − REVISED JANUARY 1999 software-controlled wait-state generator (continued) Table 10. TMS320C206/TMS320LC206 Wait-State(s) Programming ISWS, DSWS, PSUWS, OR PSLWS BITS WAIT STATES FOR I / O, DATA, OR PROGRAM 000 0 001 1 010 2 011 3 100 4 101 5 110 6 111 7 Table 11. ’C206 Wait-State Generator Register ( WSGR) BITS NAME DESCRIPTION PSLWS External program-space wait states (lower). PSLWS determines that between 0 to 7 wait states are applied to all reads and writes to off-chip lower program-space address (0h−7FFFh). The memory cycle can be further extended using the READY signal. The READY signal does not override the wait states generated by PSLWS. These bits are set to 1 (active) by reset (RS). 5 −3 PSUWS External program-space wait states (upper). PSUWS determines that between 0 to 7 wait states are applied to all reads and writes to off-chip upper program space address (8000h−0FFFFh). The memory cycle can be further extended using the READY signal. The READY signal does not override the wait states generated by PSUWS. These bits are set to 1 (active) by reset (RS). 8 −6 DSWS External data space wait states. DSWS determines that between 0 to 7 wait states are applied to all reads and writes to off-chip data space. The memory cycle can be further extended using the READY signal. The READY signal does not override the wait states generated by DSWS. These bits are set to 1 (active) by reset (RS). 11 −9 ISWS External input / output-space wait state. ISWS determines that between 0 to 7 wait states are applied to all reads and writes to off-chip I / O space. The memory cycle can be further extended using the READY signal. The READY signal does not override the wait states generated by ISWS. These bits are set to 1 (active) by reset (RS). 15 −12 Reserved 2 −0 Don’t care. Always read as 0. timer The TMS320C206/TMS320LC206 includes a 20-bit timer, implemented with a 16-bit main counter (TIM), and a 4-bit prescaler counter (PSC). The count values are written into the 16-bit period register (PRD), and the 4-bit timer divide-down register (TDDR). The TIM and the PRD are 16-bit registers mapped to I/O space, while the PSC and the TDDR are 4-bit fields of the timer control register (TCR). The TCR is an I/O mapped register which also includes other control bits for the timer (see Table 9). When the timer is started, the TIM is loaded with the contents of PRD, and the PSC is loaded with the contents of the TDDR. The PSC is decremented by one at each CLKOUT1 cycle. On the CLKOUT1 cycle after the PSC decrements to zero, the PSC is reloaded with the contents of TDDR, and the TIM is decremented by one. That is, every (TDDR+1) CLKOUT1 cycles, the TIM is decremented by one. When the TIM decrements to zero, it is reloaded with the contents of the PRD on the following CLKOUT1 cycle, and a new timer interval begins. Therefore, the timer interrupt rate is defined as follows: CLKOUT1 frequency/[(TDDR+1) (PRD+1)]. The timer can be used to generate periodic CPU interrupts based on CLKOUT1. Each time the TIM decrements to zero, a timer interrupt (TINT) is generated, and a pulse equal to the duration of a CLKOUT1 cycle is generated on the TOUT pin. The timer provides a convenient means of performing periodic I/O, context switching , or other functions. POST OFFICE BOX 1443 • HOUSTON, TEXAS 77251−1443 25        SPRS065B − JUNE 1998 − REVISED JANUARY 1999 input clock options The TMS320C206/TMS320LC206 provides multiple clock modes of divide-by-two and multiply-by-one, -two, or -four. The clock mode configuration cannot be dynamically changed without executing another reset. synchronous serial port A full duplex (bidirectional) 8-bit or 16-bit on-chip synchronous serial port provides direct communication with serial devices such as codecs, serial A/ D (analog-to-digital) converters, and other serial systems. The interface signals are compatible with codecs and many other serial devices. The serial port can also be used for intercommunication between processors in multiprocessing applications. For data transmission, three signals are necessary to connect the transmit pins of the transmitting device with the receive pins of the receiving device. The transmitted serial data signal (DX) sends the actual data. The transmit frame synchronization signal (FSX) initiates the transfer (at the beginning of the packet), and the transmit clock signal (CLKX) clocks the bit transfer. The corresponding pins on the receive device are DR, FSR and CLKR, respectively. When the serial port is not used, the device can be configured to shut off the serial port internal clocks, allowing the device to run in a lower power mode of operation. The continuous mode of the synchronous serial port (SSP) provides operation that, once initiated, requires no further frame synchronization pulses when transmitting at maximum frequency. Both receive and transmit operations have a four-word deep first-in first-out (FIFO) buffer. The advantage of having a FIFO is to alleviate the CPU from being loaded with the task of servicing a receive- or transmit-data operation after each word, allowing a continuous communications stream of 16-bit data packets. The maximum transmission rate for both transmit and receive operations is CPU divided by two or CLKOUT1(frequency)/2. Therefore, the maximum rate at 40 million instructions per second (MIPS) is 20 megabits per second (Mbps). The serial port is fully static and functions at arbitrarily low clocking frequencies. When the serial ports are in reset, the device can be configured to shut off the serial port internal clocks, allowing the device to run in a lower power mode of operation. The synchronous serial port also has capabilities to facilitate a glueless interface with multiple codecs and other peripherals. The SSP registers are complemented with three registers—status register (SSPST), multichannel register (SSPMC), and counter register (SSPCT). The SSPST includes control and status bits. Additional control bits are provided in the SSPMC to control the multichannel and prescaled clocks/frames features. The SSPCT register contains the two 8-bit prescalers to provide variable synchronous shift clock (CLKX) and frame syncs (FSX). asynchronous serial port The asynchronous serial port is full-duplexed and transmits and receives 8-bit data only. For transmit and receive operations, there is one start bit and one or two configurable stop bits by way of the asynchronous serial-port control register (ASPCR). Double-buffering of transmit/ receive data is used in all modes. Baud rate generation is accomplished via the baud rate divisor (BRD) register. This port also features an auto-baud-detection logic. scan-based emulation TMS320C206/TMS320LC206 devices incorporate scan-based emulation logic for code-development and hardware-development support. Scan-based emulation allows the emulator to control the processor in the system without the use of intrusive cables to the full pinout of the device. The scan-based emulator communicates with the ’C206 by way of the IEEE 1149.1 compatible (JTAG) interface. The TMS320C206 and TMS320LC206 DSPS, like the TMS320F206, TMS320C203, and TMS320LC203, do not include boundary scan. The scan chain of these devices is useful for emulation function only. 26 POST OFFICE BOX 1443 • HOUSTON, TEXAS 77251−1443        SPRS065B − JUNE 1998 − REVISED JANUARY 1999 multiprocessing The flexibility of the ’C206 allows configurations to satisfy a wide range of system requirements; the device can be used in a variety of system configurations, including but not limited to the following: D D D D A standalone processor A multiprocessor with devices in parallel A slave/host multiprocessor with global memory space A peripheral processor interfaced via processor-controlled signals to another device For multiprocessing applications, the ’C206 has the capability of allocating global memory space and communicating with that space via the BR and ready control signals. Global memory is data memory shared by more than one device. Global-memory access must be arbitrated. The 8-bit memory-mapped global memory allocation register (GREG) specifies part of the ’C206’s data memory as global external memory. The contents of the register determine the size of the global memory space. If the current instruction addresses an operand within that space, BR is asserted to request control of the bus. The length of the memory cycle is controlled by the READY line. The TMS320C206/TMS320LC206 supports direct memory access (DMA) to its local (off-chip) program, data, and I/O spaces. Two signals, HOLD/INT1, an input to the device, and HOLDA, an output, control this mechanism. The Hold feature is enabled by clearing the mode bit in the interrupt control register (ICR IS@FFECh). When the Hold feature is enabled, and HOLD/INT1 is asserted, executing an IDLE instruction puts the address, data, and memory control signals (PS, DS, IS, STRB, R/W, and WE) in a high-impedance state. When this occurs, the HOLDA signal is asserted, acknowledging that the processor has relinquished control of the external bus. It is important to note that when the mode bit is set to one, the Hold feature is disabled, and the HOLD/INT1 pin functions as a general-purpose interrupt (INT1). That is, when the Hold feature is disabled, and HOLD/INT1 is asserted, the IDLE instruction does not cause the memory interface signals to enter the high-impedance mode, and it does not cause the assertion of HOLDA. At reset, the mode bit is cleared to zero, and the Hold feature is enabled. instruction set The ’C206 microprocessor implements a comprehensive instruction set that supports both numeric-intensive signal-processing operations and general-purpose applications, such as multiprocessing and high-speed control. Source code for the ’C1x and ’C2x DSPs is upwardly compatible with the ’C206. For maximum throughput, the next instruction is prefetched while the current one is being executed. Because the same data lines are used to communicate to external data, program, or I/O space, the number of cycles an instruction requires to execute varies depending upon whether the next data operand fetch is from internal or external memory. Highest throughput is achieved by maintaining data memory on chip and using either internal or fast external program memory. addressing modes The ’C206 instruction set provides four basic memory-addressing modes: direct, indirect, immediate, and register. In direct addressing, the instruction word contains the lower seven bits of the data memory address. This field is concatenated with the nine bits of the data-memory-page pointer (DP) to form the 16-bit data memory address. Thus, in the direct-addressing mode, data memory is effectively paged with a total of 512 pages, each page containing 128 words. Indirect addressing accesses data memory through the auxiliary registers. In this addressing mode, the address of the instruction operand is contained in the currently selected auxiliary register. Eight auxiliary registers (AR0−AR7) provide flexible and powerful indirect addressing. To select a specific auxiliary register, the auxiliary register pointer (ARP) is loaded with a value from 0 to 7 for AR0 through AR7, respectively. POST OFFICE BOX 1443 • HOUSTON, TEXAS 77251−1443 27        SPRS065B − JUNE 1998 − REVISED JANUARY 1999 addressing modes (continued) There are seven types of indirect addressing: autoincrement or autodecrement, postindexing by either adding or subtracting the contents of AR0, single-indirect addressing with no increment or decrement, and bit-reversed addressing [used in Fast Fourier Transforms (FFTs)] with increment or decrement. All operations are performed on the current auxiliary register in the same cycle as the original instruction, following which the current auxiliary register and ARP can be modified. In immediate addressing, the actual operand data is provided in a portion of the instruction word or words. There are two types of immediate addressing: long and short. In short-immediate addressing, the data is contained in a portion of the bits in a single-word instruction. In long-immediate addressing, the data is contained in the second word of a two-word instruction. The immediate-addressing mode is useful for data that does not need to be stored or used more than once during the course of program execution, such as initialization values, constants, etc. The register-addressing mode uses operands in CPU registers either explicitly, such as with a direct reference to a specific register, or implicitly, with instructions that intrinsically reference certain registers. In either case, operand reference is simplified because 16-bit values can be used without specifying a full 16-bit operand address or immediate value. repeat feature The repeat function can be used with instructions (as defined in Table 13) such as multiply/accumulates (MAC and MACD), block moves (BLDD and BLPD), I/O transfers (IN/OUT), and table read/writes (TBLR/TBLW ). These instructions, although normally multicycle, are pipelined when the repeat feature is used, and they effectively become single-cycle instructions. For example, the table-read instruction may take three or more cycles to execute, but when the instruction is repeated, a table location can be read every cycle. When using the repeat feature, the repeat counter (RPTC) is loaded with the addressed-data-memory location if direct or indirect addressing is used, or an 8-bit immediate value if short-immediate addressing is used. The RPTC register is loaded by the RPT instruction. This results in a maximum of N + 1 executions of a given instruction when RPTC is loaded with N. RPTC is cleared by reset. Once a repeat instruction (RPT) is decoded, all interrupts, including NMI (except reset), are masked until the completion of the repeat loop. instruction set summary This section summarizes the opcodes of the instruction set for the ’C206 digital signal processor. This instruction set is a superset of the ’C1x and ’C2x instruction sets. The instructions are arranged according to function and are alphabetized by mnemonic within each category. The symbols in Table 12 are used in the instruction set summary table (Table 13). The Texas Instruments ’C20x assembler accepts ’C2x instructions. The number of words that an instruction occupies in program memory is specified in column 3 of Table 13. Several instructions specify two values separated by a slash mark (/ ) for the number of words. In these cases, different forms of the instruction occupy a different number of words. For example, the ADD instruction occupies one word when the operand is a short-immediate value or two words if the operand is a long-immediate value. The number of cycles that an instruction requires to execute is in column 3 of Table 13. All instructions are assumed to be executed from internal program memory (RAM) and internal data dual-access memory. The cycle timings are for single-instruction execution, not for repeat mode. 28 POST OFFICE BOX 1443 • HOUSTON, TEXAS 77251−1443        SPRS065B − JUNE 1998 − REVISED JANUARY 1999 instruction set summary (continued) Table 12. Opcode Symbols SYMBOL DESCRIPTION A Address ACC Accumulator ACCB Accumulator buffer ARx Auxiliary register value (0 −7) BITx 4-bit field specifies which bit to test for the BIT instruction BMAR Block-move address register DBMR Dynamic bit-manipulation register I Addressing-mode bit II...II Immediate operand value INTM Interrupt-mode flag bit INTR# Interrupt vector number K Constant PREG Product register PROG Program memory RPTC Repeat counter SHF, SHFT 3/4-bit shift value TC Test-control bit Two bits used by the conditional execution instructions to represent the conditions TC, NTC, and BIO. T P Meaning TP 00 01 10 11 BIO low TC = 1 TC = 0 None of the above conditions TREGn Temporary register n (n = 0, 1, or 2) ZLVC 4-bit field representing the following conditions: Z: ACC = 0 L: ACC < 0 V: Overflow C: Carry A conditional instruction contains two of these 4-bit fields. The 4-LSB field of the instruction is a 4-bit mask field. A 1 in the corresponding mask bit indicates that the condition is being tested. The second 4-bit field (bits 4 −7) indicates the state of the conditions designated by the mask bits as being tested. For example, to test for ACC ≥ 0, the Z and L fields are set while the V and C fields are not set. The next 4-bit field contains the state of the conditions to test. The Z field is set to indicate testing of the condition ACC = 0, and the L field is reset to indicate testing of the condition ACC ≥ 0. The conditions possible with these 8 bits are shown in the BCND and CC instructions. To determine if the conditions are met, the 4-LSB bit mask is ANDed with the conditions. If any bits are set, the conditions are met. POST OFFICE BOX 1443 • HOUSTON, TEXAS 77251−1443 29        SPRS065B − JUNE 1998 − REVISED JANUARY 1999 instruction set summary (continued) Table 13. TMS320C206/TMS320LC206 Instruction Set Summary ’x20x MNEMONIC ABS ADD OPCODE WORDS/ CYCLES MSB Absolute value of accumulator 1/1 1011 1110 0000 0000 Add to accumulator with shift 1/1 0010 SHFT IADD RESS Add to high accumulator 1/1 0110 0001 IADD RESS Add to accumulator short immediate 1/1 1011 1000 KKKK KKKK DESCRIPTION LSB Add to accumulator long immediate with shift 2/2 1011 1111 1001 SHFT ADDC Add to accumulator with carry 1/1 0110 0000 IADD RESS ADDS Add to low accumulator with sign extension suppressed 1/1 0110 0010 IADD RESS ADDT Add to accumulator with shift specified by T register 1/1 0110 0011 IADD RESS ADRK Add to auxiliary register short immediate 1/1 0111 1000 KKKK KKKK AND with accumulator 1/1 0110 1110 IADD RESS AND immediate with accumulator with shift 2/2 AND immediate with accumulator with shift of 16 2/2 Add P register to accumulator 1/1 AND APAC B Branch unconditionally 2/4 BACC Branch to address specified by accumulator 1/4 BANZ Branch on auxiliary register not zero 2/4/2 Branch if TC bit ≠ 0 2/4/2 Branch if TC bit = 0 2/4/2 Branch on carry 2/4/2 Branch if accumulator ≥ 0 2/4/2 Branch if accumulator > 0 2/4/2 Branch on I/O status low 2/4/3 Branch if accumulator ≤ 0 2/4/2 Branch if accumulator < 0 2/4/2 Branch on no carry 2/4/2 BCND 1011 1111 1011 SHFT 16-Bit Constant 1011 1110 1000 16-Bit Constant 1011 0111 1011 POST OFFICE BOX 1443 • HOUSTON, TEXAS 77251−1443 1110 0010 0000 1110 0001 0000 Branch Address 0000 1110 0010 0000 Branch Address 0000 1110 0011 0001 Branch Address 0001 1110 0011 1000 Branch Address 1100 1110 0011 0000 Branch Address 0100 1110 0000 0000 Branch Address 0000 1110 0011 1100 Branch Address 1100 0011 0100 0100 Branch Address 0011 0000 0001 Branch Address 1110 30 0100 1011 IADD RESS Branch Address 1110 2/4/2 0000 1001 IADD RESS Branch Address 0111 1110 Branch if no overflow 1110 0001 0011 0000 Branch Address 0010        SPRS065B − JUNE 1998 − REVISED JANUARY 1999 instruction set summary (continued) Table 13. TMS320C206/TMS320LC206 Instruction Set Summary (Continued) ’x20x MNEMONIC WORDS/ CYCLES DESCRIPTION OPCODE MSB 1110 Branch if accumulator ≠ 0 2/4/2 Branch on overflow 2/4/2 0000 1000 0011 0010 0010 Branch Address 1110 Branch if accumulator = 0 0011 Branch Address 1110 BCND LSB 2/4/2 0011 1000 1000 Branch Address BIT Test bit 1/1 0100 BITx IADD RESS BITT Test bit specified by TREG 1/1 0110 1111 IADD RESS 1000 IADD RESS Block move from data memory to data memory source immediate 2/3 Block move from data memory to data memory destination immediate 2/3 1010 BLDD† Branch Address 1010 Block move from program memory to data memory 2/3 CALA Call subroutine indirect 1/4 CALL Call subroutine CC Conditional call subroutine RESS 0101 IADD RESS Branch Address 1011 1110 0011 0000 0111 1010 IADD RESS 2/4 Routine Address 1110 CLRC IADD Branch Address 1010 BLPD 1001 2/4/2 10TP ZLVC ZLVC Routine Address Configure block as data memory 1/1 1011 1110 0100 0100 Enable interrupt 1/1 1011 1110 0100 0000 Reset carry bit 1/1 1011 1110 0100 1110 Reset overflow mode 1/1 1011 1110 0100 0010 Reset sign-extension mode 1/1 1011 1110 0100 0110 Reset test / control flag 1/1 1011 1110 0100 1010 Reset external flag 1/1 1011 1110 0100 1100 CMPL Complement accumulator 1/1 1011 1110 0000 0001 CMPR Compare auxiliary register with auxiliary register AR0 1/1 1011 1111 0100 01CM DMOV Data move in data memory 1/1 0111 0111 IADD RESS IDLE Idle until interrupt 1/1 1011 1110 0010 0010 1010 1111 IADD RESS IN Input data from port 2/2 16BIT I/O PORT ADRS INTR Software-interrupt 1/4 1011 1110 011K KKKK Load accumulator with shift 1/1 0001 SHFT IADD RESS 1111 1000 SHFT Load accumulator long immediate with shift 2/2 1011 LACC Zero low accumulator and load high accumulator 1/1 0110 † In ’C20x devices, the BLDD instruction cannot be used with memory-mapped registers IMR, IFR, and GREG. POST OFFICE BOX 1443 • HOUSTON, TEXAS 77251−1443 16-Bit Constant 1010 IADD RESS 31        SPRS065B − JUNE 1998 − REVISED JANUARY 1999 instruction set summary (continued) Table 13. TMS320C206/TMS320LC206 Instruction Set Summary (Continued) ’x20x MNEMONIC LACL LACT OPCODE WORDS/ CYCLES MSB Load accumulator immediate short 1/1 1011 1001 KKKK Zero accumulator 1/1 1011 1001 0000 0000 Zero low accumulator and load high accumulator 1/1 0110 1010 IADD RESS Zero low accumulator and load low accumulator with no sign extension 1/1 0110 1001 IADD RESS Load accumulator with shift specified by T register 1/1 0110 1011 IADD RESS Load auxiliary register 1/2 0000 0ARx IADD RESS Load auxiliary register short immediate 1/2 1011 0ARx KKKK KKKK 1011 1111 0000 1ARx DESCRIPTION LAR LSB KKKK Load auxiliary register long immediate 2/2 Load data-memory page pointer 1/2 0000 1101 IADD RESS Load data-memory page pointer immediate 1/2 1011 110P AGEP OINT Load high-P register 1/1 0111 0101 IADD RESS Load status register ST0 1/2 0000 1110 IADD RESS Load status register ST1 1/2 0000 1111 IADD RESS LT Load TREG 1/1 0111 0011 IADD RESS LTA Load TREG and accumulate previous product 1/1 0111 0000 IADD RESS LTD Load TREG, accumulate previous product, and move data 1/1 0111 0010 IADD RESS LTP Load TREG and store P register in accumulator 1/1 0111 0001 IADD RESS LTS Load TREG and subtract previous product 1/1 0111 0100 IADD RESS 0010 IADD RESS MAC Multiply and accumulate 2/3 MACD Multiply and accumulate with data move 2/3 Load auxiliary register pointer 1/1 1000 1011 1000 1ARx Modify auxiliary register 1/1 1000 1011 IADD RESS Multiply (with TREG, store product in P register) 1/1 0101 0100 IADD RESS Multiply immediate 1/1 110C KKKK KKKK KKKK MPYA Multiply and accumulate previous product 1/1 0101 0000 IADD RESS MPYS Multiply and subtract previous product 1/1 0101 0001 IADD RESS MPYU Multiply unsigned 1/1 0101 0101 IADD RESS NEG Negate accumulator 1/1 1011 1110 0000 0010 NMI Nonmaskable interrupt 1/4 1011 1110 0101 0010 NOP No operation 1/1 1000 1011 0000 0000 NORM Normalize contents of accumulator 1/1 1010 0000 IADD RESS OR with accumulator 1/1 0110 1101 IADD RESS 1011 1111 1100 SHFT LDP LPH LST 16-Bit Constant 1010 16-Bit Constant 1010 MAR MPY 0011 IADD RESS 16-Bit Constant OR immediate with accumulator with shift 2/2 OR immediate with accumulator with shift of 16 2/2 OUT Output data to port 2/3 0000 16BIT 1100 I/O IADD PORT RESS ADRS PAC Load accumulator with P register 1/1 1011 1110 0000 0011 OR 16-Bit Constant 1011 32 POST OFFICE BOX 1443 • HOUSTON, TEXAS 77251−1443 1110 1000 0010 16-Bit Constant        SPRS065B − JUNE 1998 − REVISED JANUARY 1999 instruction set summary (continued) Table 13. TMS320C206/TMS320LC206 Instruction Set Summary (Continued) ’x20x MNEMONIC WORDS/ CYCLES DESCRIPTION OPCODE MSB LSB POP Pop top of stack to low accumulator 1/1 1011 1110 0011 0010 POPD Pop top of stack to data memory 1/1 1000 1010 IADD RESS PSHD Push data-memory value onto stack 1/1 0111 0110 IADD RESS PUSH Push low accumulator onto stack 1/1 1011 1110 0011 1100 RET Return from subroutine 1/4 1110 1111 0000 0000 RETC Conditional return from subroutine 1/4/2 1110 11TP ZLVC ZLVC ROL Rotate accumulator left 1/1 1011 1110 0000 1100 ROR Rotate accumulator right 1/1 1011 1110 0000 1101 Repeat instruction as specified by data-memory value 1/1 0000 1011 IADD RESS RPT Repeat instruction as specified by immediate value 1/1 1011 1011 KKKK KKKK SACH Store high accumulator with shift 1/1 1001 1SHF IADD RESS SACL Store low accumulator with shift 1/1 1001 0SHF IADD RESS SAR Store auxiliary register 1/1 1000 0ARx IADD RESS SBRK Subtract from auxiliary register short immediate 1/1 0111 1100 KKKK KKKK Set carry bit 1/1 1011 1110 0100 1111 Configure block as program memory 1/1 1011 1110 0100 0101 Disable interrupt 1/1 1011 1110 0100 0001 Set overflow mode 1/1 1011 1110 0100 0011 Set test / control flag 1/1 1011 1110 0100 1011 Set external flag XF 1/1 1011 1110 0100 1101 SETC Set sign-extension mode 1/1 1011 1110 0100 0111 SFL Shift accumulator left 1/1 1011 1110 0000 1001 SFR Shift accumulator right 1/1 1011 1110 0000 1010 SPAC Subtract P register from accumulator 1/1 1011 1110 0000 0101 SPH Store high-P register 1/1 1000 1101 IADD RESS SPL Store low-P register 1/1 1000 1100 IADD RESS SPM Set P register output shift mode 1/1 1011 1111 IADD RESS SQRA Square and accumulate 1/1 0101 0010 IADD RESS SQRS Square and subtract previous product from accumulator 1/1 0101 0011 IADD RESS Store status register ST0 1/1 1000 1110 IADD RESS Store status register ST1 1/1 1000 1111 IADD RESS 1110 IADD RESS Store long immediate to data memory 2/2 Subtract from accumulator long immediate with shift 2/2 Subtract from accumulator with shift 1/1 0011 SHFT Subtract from high accumulator 1/1 0110 Subtract from accumulator short immediate 1/1 1011 SST 1010 SPLK 16-Bit Constant 1011 SUB POST OFFICE BOX 1443 • HOUSTON, TEXAS 77251−1443 1111 1010 SHFT 16-Bit Constant IADD RESS 0101 IADD RESS 1010 KKKK KKKK 33        SPRS065B − JUNE 1998 − REVISED JANUARY 1999 instruction set summary (continued) Table 13. TMS320C206/TMS320LC206 Instruction Set Summary (Continued) ’x20x MNEMONIC WORDS/ CYCLES DESCRIPTION OPCODE MSB LSB SUBB Subtract from accumulator with borrow 1/1 0110 0100 IADD RESS SUBC Conditional subtract 1/1 0000 1010 IADD RESS SUBS Subtract from low accumulator with sign extension suppressed 1/1 0110 0110 IADD RESS SUBT Subtract from accumulator with shift specified by TREG 1/1 0110 0111 IADD RESS TBLR Table read 1/3 1010 0110 IADD RESS TBLW Table write 1/3 1010 0111 IADD RESS TRAP Software interrupt 1/4 1011 1110 0101 0001 Exclusive-OR with accumulator 1/1 0110 1100 IADD RESS 1111 1101 SHFT Exclusive-OR immediate with accumulator with shift 2/2 Exclusive-OR immediate with accumulator with shift of 16 2/2 Zero low accumulator and load high accumulator with rounding 1/1 1011 XOR 16-Bit Constant 1011 ZALR 1110 1000 0011 16-Bit Constant 0110 1000 IADD RESS development support Texas Instruments offers an extensive line of development tools for the ’x20x generation of DSPs, including tools to evaluate the performance of the processors, generate code, develop algorithm implementations, and fully integrate and debug software and hardware modules. The following products support development of ’x20x-based applications: Software Development Tools: Assembler/Linker Simulator Optimizing ANSI C Compiler Application Algorithms C/Assembly Debugger and Code Profiler† Hardware Development Tools: Emulator XDS510 (supports ’x20x multiprocessor system debug) The TMS320 Family Development Support Reference Guide (literature number SPRU011) contains information about development-support products for all TMS320 family member devices, including documentation. Refer to this document for further information about TMS320 documentation or any other TMS320 support products from Texas Instruments. There is also an additional document, the TMS320 Third-Party Support Reference Guide (literature number SPRU052), which contains information about TMS320-related products from other companies in the industry. To receive copies of TMS320 literature, contact the Literature Response Center at 800/477-8924. See Table 14 for complete listings of development-support tools for the ’C20x. For information on pricing and availability, contact the nearest TI field sales office or authorized distributor. † The Texas Instruments C Source Debugger, Revision 1.00.01, is not compatible with ’C206/’LC206 silicon revisions. Contact TI for more information regarding the most recent debugger revision and release. XDS510 is a trademark of Texas Instruments Incorporated. 34 POST OFFICE BOX 1443 • HOUSTON, TEXAS 77251−1443        SPRS065B − JUNE 1998 − REVISED JANUARY 1999 development support (continued) Table 14. ’C206 Development-Support Tools DEVELOPMENT TOOL PLATFORM PART NUMBER Software Compiler/Assembler/Linker SPARC, HP TMDS3242555-08 Compiler/Assembler/Linker PC-DOS, OS/2 TMDS3242855-02 Assembler/Linker PC-DOS, OS/2 TMDS3242850-02 Simulator PC-DOS, WIN TMDS3245851-02 Simulator SPARC TMDS3245551-09 Digital Filter Design Package PC-DOS DFDP Debugger/Emulation Software PC-DOS, OS/2, WIN TMDS3240120 Debugger/Emulation Software SPARC TMDS3240620 Code Composer Debugger Windows CCMSP5XWIN Hardware ’C20x Evaluation Module PC-DOS XDS510XL Emulator PC-DOS, OS/2 XDS510WS Emulator SPARC TMDS32600XX TMDS00510 TMDS00510WS device and development-support tool nomenclature To designate the stages in the product development cycle, Texas Instruments assigns prefixes to the part numbers of all TMS320 devices and support tools. Each TMS320 member has one of three prefixes: TMX, TMP, and TMS. Texas Instruments recommends two of three possible prefix designators for its support tools: TMDX and TMDS. These prefixes represent evolutionary stages of product development from engineering prototypes (TMX/ TMDX) through fully qualified production devices/tools (TMS/TMDS). This development flow is defined below. Device Development Evolutionary Flow: TMX Experimental device that is not necessarily representative of the final device’s electrical specifications TMP Final silicon die that conforms to the device’s electrical specifications but has not completed quality and reliability verification TMS Fully qualified production device Support Tool Development Evolutionary Flow: TMDX Development-support product that has not yet completed Texas Instruments internal qualification testing TMDS Fully qualified development-support product TMX and TMP devices and TMDX development-support tools are shipped against the following disclaimer: “Developmental product is intended for internal evaluation purposes.” TMS devices and TMDS development-support tools have been fully characterized, and the quality and reliability of the device have been fully demonstrated. Texas Instruments standard warranty applies. Predictions show that prototype devices (TMX or TMP) will have a greater failure rate than the standard production devices. Texas Instruments recommends that these devices not be used in any production system WIN and Windows are trademarks of Microsoft Corporation. Code Composer is a trademark of Go DSP Inc. SPARC is a trademark of SPARC International, Inc. PC-DOS and OS/2 are trademarks of International Business Machines Corp. HP is a trademark of Hewlett-Packard Company. XDS510XL and XDS510WS are trademarks of Texas Instruments Incorporated. POST OFFICE BOX 1443 • HOUSTON, TEXAS 77251−1443 35        SPRS065B − JUNE 1998 − REVISED JANUARY 1999 device and development-support tool nomenclature (continued) because their expected end-use failure rate is still undefined. Only qualified production devices are to be used. TI device nomenclature also includes a suffix with the device family name. This suffix indicates the package type (for example, PZ) and temperature range (for example, A). The following figures provide a legend for reading the complete device name for any TMS320 family member. TMS 320 (B) C 206 PZ PREFIX TMX = Experimental device TMP = Prototype device TMS = Qualified device (A) TEMPERATURE RANGE (DEFAULT: 0°C TO 70°C) L = 0°C to 70°C† A = −40°C to 85°C PACKAGE TYPE‡ PZ = 100-pin plastic TQFP PN = 80-pin TQFP DEVICE FAMILY 320 = TMS320 family BOOTLOADER OPTION§ DEVICE ’20x DSP TECHNOLOGY C = CMOS (5-V, 3.3-V core) E = CMOS EPROM F = CMOS Flash EEPROM LC = Low-Voltage CMOS (3.3 V) VC = Low-Voltage CMOS (3 V) 203§ 206 209 † For TMS320C206PZ, TMS320LC206PZ devices with this temperature range, L is not printed on package. ‡ TQFP = Thin Quad Flat Package § The TMS320C203 is a bootloader device without the B option. Figure 5. TMS320x20x Device Nomenclature documentation support Extensive documentation supports all of the TMS320 family generations of devices from product announcement through applications development. The types of documentation available include: data sheets, such as this document, with design specifications; complete user’s guides for all devices and development-support tools; and hardware and software applications. For general background information on DSPs and TI devices, see the three-volume publication Digital Signal Processing Applications With the TMS320 Family (literature numbers SPRA012, SPRA016, and SPRA017). Also available is the Calculation of TMS320C20x Power Dissipation application report (literature number SPRA088). For further information regarding the ’C206 and ’LC206, please refer to the TMS320C20x User’s Guide (literature number SPRU127) and the TMS320 DSP Development Support Reference Guide (literature number SPRU011F). A series of DSP textbooks is published by Prentice-Hall and John Wiley & Sons to support DSP research and education. The TMS320 newsletter, Details on Signal Processing, is published quarterly and distributed to update TMS320 customers on product information. The TMS320 DSP bulletin board service (BBS) provides access to information pertaining to the TMS320 family, including documentation, source code, and object code for many DSP algorithms and utilities. The BBS can be reached at 281/274-2323. Information regarding TI DSP products is also available on the Worldwide Web at http://www.ti.com uniform resource locator (URL). To send comments regarding the ’C206/’LC206 datasheet (SPRS065B), use the comments@books.sc.ti.com email address, which is a repository for feedback. For questions and support, contact the Product Information Center listed at the back of the datasheet. 36 POST OFFICE BOX 1443 • HOUSTON, TEXAS 77251−1443        SPRS065B − JUNE 1998 − REVISED JANUARY 1999 absolute maximum ratings over operating free-air temperature range (unless otherwise noted)† Supply voltage range, VDD (see Note 1) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . − 0.3 V to 4.6 V Supply voltage range, VDD5 (see Note 1) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . − 0.3 V to 7 V Input voltage range . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . − 0.3 V to 4.6 V Output voltage range, ’LC206 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . − 0.3 V to 4.6 V Output voltage range, ’C206 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . − 0.3 V to 7 V Operating free-air temperature range, TA (TMS320C206PZ, TMS320LC206PZ) . . . . . . . . . . . 0°C to 70°C (TMS320C206PZA, TMS320LC206PZA) . . . . . . − 40°C to 85°C Storage temperature range, Tstg . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . − 55°C to 150°C † Stresses beyond those listed under “absolute maximum ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated under “recommended operating conditions” is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. NOTE 1: All voltage values are with respect to VSS. recommended operating conditions‡ MIN NOM MAX UNIT VDD VDD5 Supply voltage 3.3-V operation 2.7 3.3 3.6 V Supply voltage (’C206 only) 5-V operation (3.3-V core) 4.5 5 5.5 V VSS Supply voltage High-level input voltage, 3.3 V VIH High-level input voltage, 5 V (3.3-core) 0 CLKIN/X2 2.5 RS, CLKR, CLKX, RX 2.3 TRST, TCK 2.5 All other inputs 2.0 CLKIN/X2 3.0 RS, CLKR, CLKX, RX 2.3 TRST, TCK 3.0 All other inputs 2.0 CLKIN/X2 VIL Low-level input voltage RS, CLKR, CLKX, RX All other inputs V VDD + 0.3 VDD + 0.3 VDD + 0.3 VDD + 0.3 VDD5 + 0.3 VDD5 + 0.3 VDD5 + 0.3 VDD5 + 0.3 V V ’C206 − 0.3 0.6 V ’LC206 − 0.3 0.6 V ’C206 − 0.3 0.6 V ’LC206 − 0.3 0.6 V ’C206 − 0.3 0.6 V ’LC206 − 0.3 0.7 V IOH High-level output current − 300 µA IOL Low-level output current 2 mA TA Operating free-air temperature TMS320C206PZ, TMS320LC206PZ 0 70 − 40 85 °C TMS320C206PZA, TMS320LC206PZA ‡ Refer to the mechanical data package page for thermal resistance values, ΘJA (junction-to-ambient) and ΘJC (junction-to-case). POST OFFICE BOX 1443 • HOUSTON, TEXAS 77251−1443 37        SPRS065B − JUNE 1998 − REVISED JANUARY 1999 electrical characteristics over recommended ranges of supply voltage and operating free-air temperature PARAMETER VOH VOL High-level output voltage Low-level output voltage TEST CONDITIONS MIN 3.3-V operation, IOH = MAX All other inputs/X1 2.4/2.0 5-V operation, IOH = MAX All other inputs/X1 2.4/2.0 IOZ IDD 0.6 Output current, high-impedance 3.3-V/5-V operation,VO = VDD or 0 V state (off-state) Supply current UNIT 0.6 Input current −Device running with external clock in PLLx1 mode −Dummy code execution in B0 RAM (NOPS and MACD) MAX V 3.3-V operation, IOL = MAX 5-V operation, IOL = MAX 3.3-V/5-V operation, VI = VDD or 0 V II TYP 3.3-V operation fCLKOUT = 40 MHz ’LC206 5-V/3.3-V fCLKOUT = 40 MHz ’C206 CLKIN/X2 −300 300 FSX, FSR, CLKR, CLKX, TRST (with internal pulldown) − 10 250 PLLRS, TCK TDI, TMS −200 10 EMU0, EMU1 (with internal pullup) −200 10 All other inputs − 10 10 EMU0, EMU1 (with internal pullup) −200 10 FSX, FSR, CLKR, CLKX, TRST (with internal pull down) −10 250 All other 3-state outputs −10 10 V µA A µA 50 CPU − (3.3 V) 45 I/O - (5V) 10 mA Ci Input capacitance 15 pF Co Output capacitance 15 pF 38 POST OFFICE BOX 1443 • HOUSTON, TEXAS 77251−1443        SPRS065B − JUNE 1998 − REVISED JANUARY 1999 PARAMETER MEASUREMENT INFORMATION IOL Tester Pin Electronics 50 Ω VLOAD Output Under Test CT IOH Where: IOL IOH VLOAD CT = = = = 2 mA (all outputs) 300 µA (all outputs) 1.5 V 40-pF typical load-circuit capacitance Figure 6. Test Load Circuit POST OFFICE BOX 1443 • HOUSTON, TEXAS 77251−1443 39        SPRS065B − JUNE 1998 − REVISED JANUARY 1999 PARAMETER MEASUREMENT INFORMATION signal-transition levels The data in this section is shown for the 3.3-V and 5-V versions of the ’x20x. Note that some of the signals use different reference voltages, see the recommended operating conditions table. TTL-output levels are driven to a minimum logic-high level of 2.4 V and to a maximum logic-low level of 0.6 V. Figure 7 shows the TTL-level outputs. 2.4 V (VOH) 80% 20% 0.6 V (VOL) Figure 7. TTL-Level Outputs TTL-output transition times are specified as follows: D For a high-to-low transition, the level at which the output is said to be no longer high is below 80% of the total voltage range and lower and the level at which the output is said to be low is 20% of the total voltage range and lower. D For a low-to-high transition, the level at which the output is said to be no longer low is 20% of the total voltage range and higher and the level at which the output is said to be high is 80% of the total voltage range and higher. Figure 8 shows the TTL-level inputs. 2.0 V (VIH) 90% 10% 0.8 V (VIL) Figure 8. TTL-Level Inputs TTL-compatible input transition times are specified as follows: D For a high-to-low transition on an input signal, the level at which the input is said to be no longer high is 90% of the total voltage range and lower and the level at which the input is said to be low is 10% of the total voltage range and lower. D For a low-to-high transition on an input signal, the level at which the input is said to be no longer low is 10% of the total voltage range and higher and the level at which the input is said to be high is 90% of the total voltage range and higher. 40 POST OFFICE BOX 1443 • HOUSTON, TEXAS 77251−1443        SPRS065B − JUNE 1998 − REVISED JANUARY 1999 PARAMETER MEASUREMENT INFORMATION timing parameter symbology Timing parameter symbols used are created in accordance with JEDEC Standard 100-A. To shorten the symbols, some of the pin names and other related terminology have been abbreviated as follows: A Address or A [15 : 0] M Address, data, and control signals: (A, D, MS, S. BR, RD, W, and R/W) CI CLKIN / X2 MS Memory strobe pins IS, DS, or PS CLKR Serial-port receive clock R READY CLKX Seria-port transmit clock RD Read cycle or RD CO CLKOUT1 RS RESET pins RS or RS D Data or D [15:0] S STRB or synchronous FR FSR TP Transitory phase FX FSX W Write cycle or WE H HOLD HA HOLDA IN INTN: BIO, INT1 −INT3, NMI IO IOx: IO0, IO1, IO2, or IO3 Lowercase subscripts and their meanings are: The following letters and symbols and their meanings are: a access time H High c cycle time (period) L Low d delay time IV Invalid dis disable time HZ High impedance en enable time X Unknown, changing, or don’t care level f fall time h hold time r rise time su setup time t transition time v valid time w pulse duration (width) general notes on timing parameters All output signals from the TMS320x206 devices (including CLKOUT1) are specified from an internal clock such that all output transitions for a given half cycle occur with a minimum of skewing relative to each other. The signal combinations shown in the following timing diagrams may not necessarily represent actual cycles. For actual cycle examples, refer to the appropriate cycle description section of this data sheet. POST OFFICE BOX 1443 • HOUSTON, TEXAS 77251−1443 41        SPRS065B − JUNE 1998 − REVISED JANUARY 1999 CLOCK CHARACTERISTICS AND TIMING clock options PARAMETER DIV2 DIV1 Internal divide-by-two with external crystal or external oscillator 0 0 PLL multiply-by-one 0 1 PLL multiply-by-two 1 0 PLL multiply-by-four 1 1 internal divide-by-two clock option with external crystal† The internal oscillator is enabled by connecting a crystal across X1 and CLKIN/X2. The crystal should be in either fundamental or overtone operation and parallel resonant, with an effective series resistance of 30 Ω and a power dissipation of 1 mW; it should be specified at a load capacitance of 20 pF. Note that overtone crystals require an additional tuned-LC circuit. Figure 9 shows an external crystal (fundamental frequency) connected to the on-chip oscillator. X1 CLKIN/X2 Crystal C1 C2 NOTE A: Texas Instruments encourages customers to submit samples of the device to the resonator/crystal vendor for full characterization. Figure 9. Internal Clock Option † PLL modes can also be used with the on-chip oscillator. However, in this case, the PLL lock time should be based on stable clock from the on-chip oscillator. 42 POST OFFICE BOX 1443 • HOUSTON, TEXAS 77251−1443        SPRS065B − JUNE 1998 − REVISED JANUARY 1999 timing at VDD = 3.3 V/5 V with the PLL circuit disabled, divide-by-two mode (’C206, ’LC206)† PARAMETER fx TEST CONDITIONS Input clock frequency TA = −40°C to 85°C, 3.3 V/5 V MIN 0† NOM MAX UNIT 80.0 MHz † This device is implemented in static logic and therefore can operate with tc(CI) approaching ∞. The device is characterized at 340 ns cycle. switching characteristics over recommended operating conditions [H = 0.5tc(CO)] (see Figure 10) ’320C206-80 ’320LC206-80 PARAMETER MIN TYP 25 2tc(CI) UNIT MAX † ns 18 ns tc(CO) td(CIH-CO) Cycle time, CLKOUT1 tf(CO) tr(CO) Fall time, CLKOUT1 5 ns Rise time, CLKOUT1 5 ns Delay time, CLKIN high to CLKOUT1 high/low 1 tw(COL) Pulse duration, CLKOUT1 low H−3 H +3 ns tw(COH) Pulse duration, CLKOUT1 high H−3 H+3 ns † This device is implemented in static logic and therefore can operate with tc(CI) approaching ∞. The device is characterized at 340 ns cycle. timing requirements (see Figure 10) ’320C206-80 ’320LC206-80 MIN 12.5 UNIT MAX † ns tc(CI) tf(CI) Cycle time, CLKIN Fall time, CLKIN 5 ns tr(CI) tw(CIL) Rise time, CLKIN 5 † ns Pulse duration, CLKIN low 5 ns † tw(CIH) Pulse duration, CLKIN high 5 ns † This device is implemented in static logic and therefore can operate with tc(CI) approaching ∞. The device is characterized at 340 ns cycle. tw(CIH) tc(CI) tw(CIL) CLKIN td(CIH-CO) tf(CI) tr(CI) tc(CO) tw(COL) tw(COH) CLKOUT1 tr(CO) tf(CO) Figure 10. CLKIN-to-CLKOUT1 Timing Without PLL ( using ÷2 clock option ) POST OFFICE BOX 1443 • HOUSTON, TEXAS 77251−1443 43        SPRS065B − JUNE 1998 − REVISED JANUARY 1999 timing at VDD = 3.3 V/5 V with the PLL circuit enabled (’C206/’LC206) PARAMETER TEST CONDITIONS MIN MAX 4 40.96 4 20.48 4 10.24 Input clock frequency, multiply-by-one fx Input clock frequency, multiply-by-two TA = −40 −40°C C to 85°C, 85 C, 3.3 V/5 V Input clock frequency, multiply-by-four UNIT MHz switching characteristics over recommended operating conditions [H = 0.5tc(CO)] (see Figure 11) ’320C206-80 ’320LC206-80 PARAMETER MIN TYP 25 UNIT MAX † tc(CO) tf(CO) Cycle time, CLKOUT1 ns Fall time, CLKOUT1 5 tr(CO) tw(COL) Rise time, CLKOUT1 5 Pulse duration, CLKOUT1 low H−3 H H+3 ns tw(COH) Pulse duration, CLKOUT1 high H−3 H H+3 ns td(TP) Delay time, transitory phase—PLL synchronized after CLKIN supplied 5000 cycles ns ns † Static design tc(CI) can approach ∞ timing requirements (see Figure 11) ’320C206-80 ’320LC206-80 MIN Cycle time, CLKIN multiply-by-one tc(CI) UNIT MAX 25 ns Cycle time, CLKIN multiply-by-two 50 ns Cycle time, CLKIN multiply-by-four 100 ns tf(CI) tr(CI) Fall time, CLKIN tw(CIL) tw(CIH) Pulse duration, CLKIN low 12 Pulse duration, CLKIN high 12 125 ns Rise time, CLKIN 4 ns 4 ns 125 ns tw(CIH) tc(CI) tw(CIL) CLKIN tf(CI) tw(COH) tr(CI) tf(CO) tc(CO) tw(COL) tr(CO) CLKOUT1 Figure 11. CLKIN-to-CLKOUT1 Timing With PLL ( Enabled ) 44 POST OFFICE BOX 1443 • HOUSTON, TEXAS 77251−1443        SPRS065B − JUNE 1998 − REVISED JANUARY 1999 MEMORY AND PERIPHERAL INTERFACE TIMING memory and parallel I/O interface read timing A15−A0, PS, DS, IS, R/W, and BR timings are all included in the timings referenced to A15 −A0 except when in transition between a read operation following a write operation or a write operation following a read operation, where PS, DS, and IS pulse high [see tw(MS)]. switching characteristics over recommended operating conditions [H = 0.5tc(CO)] (see Figure 12) ALTERNATE SYMBOLS PARAMETER tsu(A-RD) th(RD-A) Setup time, address valid before RD low tsu(A)RD th(A)RD Hold time, address valid after RD high td(COL-A) Delay time, CLKOUT1 low to read address valid th(COL-A)RD Hold time, read address valid after CLKOUT1 low td(CO-RD) td(COL-S) Delay time, CLKOUT1 high / low to RD low / high tw(RDL) tw(RDH) ’320C206-80 MIN ’320LC206-80 MAX H−4 MIN H−5 −6 −4 UNIT ns −7 6 th(A)COLRD MAX ns 6 −5 ns ns −1 6 −2 5 ns 0 7 0 6 ns Pulse duration, RD low (no wait states) H−3 H+3 H−3 H+3 ns Pulse duration, RD high H−3 H+3 H−3 H+3 ns Delay time, CLKOUT1 low to STRB low / high timing requirements [H = 0.5tc(CO)] (see Figure 12) ALTERNATE SYMBOLS ’320C206-80 ’320LC206-80 MIN MIN MAX MAX UNIT ta(A) Access time, from address valid to read data 2H − 15 2H − 15 ns ta(C) Access time, from control IS, PS, DS valid to read data 2H − 16 2H − 15 ns tsu(D-RD) th(RD-D) th(AIV-D) Setup time, read data before RD high Hold time, read data after RD high Hold time, read data from address invalid tsu(D)RD th(D)RD th(D)A 15 14 ns 0 0 ns 0°C to 70°C 0 1 ns − 40°C to 85°C 2 2 ns 10 ns Setup time, read data before CLKOUT1 low tsu(DCOL)RD 11 th(COL-D)RD ta(RD) Hold time, read data after CLKOUT1 low th(DCOL)RD 1 ta(S) Access time, from STRB low to read data tsu(D-COL)RD Access time, from RD low to read data POST OFFICE BOX 1443 • HOUSTON, TEXAS 77251−1443 1 ns H − 14 H − 12 ns 2H − 15 2H − 16 ns 45        SPRS065B − JUNE 1998 − REVISED JANUARY 1999 MEMORY AND PERIPHERAL INTERFACE TIMING (CONTINUED) CLKOUT1 td(COL −A) th(COL-A)RD A0 −A15 td(CO −RD) td(CO −RD) tsu(A-RD) th(AIV-D) th(RD-A) tw(RDL) RD tw(RDH) ta(RD) th(RD-D) ta(A) tsu(D−COL)RD tsu(D-RD) th(COL-D)RD D0 −D15 (data in) R/W Inverted R / W† td(COL −S) STRB † If the FRDN bit in the PMST register (FFE4h) is a 1, then the signal issued from the RD pin (pin 45) is an inverted R/W signal (or fast RD) replacing the RD signal. Figure 12. Memory Interface Read Timing 46 POST OFFICE BOX 1443 • HOUSTON, TEXAS 77251−1443        SPRS065B − JUNE 1998 − REVISED JANUARY 1999 MEMORY AND PERIPHERAL INTERFACE TIMING (CONTINUED) memory and parallel I/O interface write timing A15−A0, PS, DS, IS, R/W, and BR timings are all included in the timings referenced to A15 −A0 except when in transition between a read operation following a write operation or a write operation following a read operation, where PS, DS, and IS pulse high [see tw(MS)]. switching characteristics over recommended operating conditions [H = 0.5tc(CO)] (see Figure 13) ALTERNATE SYMBOLS PARAMETER tsu(A-W) th(W-A) Setup time, address valid before WE low tsu(A-COL) th(COL-A)W Setup time, write address valid before CLKOUT1 low ’320C206-80 MIN ’320LC206-80 MAX MIN MAX UNIT tsu(A)W th(A)W H−6 H−6 ns H−8 H−8 ns H−7 H−7 ns Hold time, write address valid after CLKOUT1 low tsu(A)CO th(A)COLW H−5 H−5 ns tw(MS) tw(WL) Pulse duration, IS, DS, PS inactive high tw(NSN) Pulse duration, WE low (no wait states) 2H − 2 tw(WH) td(COL-W) Pulse duration, WE high 2H − 4 td(RD-W) td(W-RD) Delay time, RD high to WE low td(FRDN) tsu(D-W) Delay time, FRDN signal with respect to R/W th(W-D) tsu(D-COL)W Hold time, write data valid after WE high th(COL-D)W ten(D-W) tdis(W-D) Disable time, WE high to data bus high impedance Hold time, address valid after WE high H−2 Delay time, CLKOUT1 low to WE low / high −1 td(RDW) td(WRD) Delay time, WE high to RD low Setup time, write data valid before WE high H−1 2H + 4 2H − 2 ns 2H + 4 2H − 4 6 −1 ns ns 6 ns 2H − 7 2H − 7 ns 3H − 7 3H − 7 ns −1 −1 ns tsu(D)W th(D)W 2H − 14 2 2 ns 2H − 17 2H − 17 ns Hold time, write data valid after CLKOUT1 low tsu(DCOL)W th(DCOL)W 3 3 ns Enable time, data bus driven from WE ten(D)W 1 1 ns Setup time, write data valid before CLKOUT1 low POST OFFICE BOX 1443 • HOUSTON, TEXAS 77251−1443 2H 8 2H − 14 2H 8 ns ns 47        SPRS065B − JUNE 1998 − REVISED JANUARY 1999 MEMORY AND PERIPHERAL INTERFACE TIMING (CONTINUED) CLKOUT1 RD td(RD-W) td(W-RD) STRB tw(MS) tsu(A-COL) IS, DS or PS th(COL-A)W th(W-A) A0−A15 td(FRDN) R/W tsu(A-W) Inverted R / W† td(COL−W) td(COL−W) WE tw(WL) tsu(D-COL)W tw(WH) tsu(D-W) ten(D-W) th(W-D) th(COL-D)W tdis(W-D) D0−D15 (data out) † If the FRDN bit in the PMST register (FFE4h) is a 1, then the signal issued from the RD pin (pin 45) is an inverted R/W signal (or fast RD) replacing the RD signal. Figure 13. Memory Interface Write Timing 48 POST OFFICE BOX 1443 • HOUSTON, TEXAS 77251−1443        SPRS065B − JUNE 1998 − REVISED JANUARY 1999 MEMORY AND PERIPHERAL INTERFACE TIMING (CONTINUED) READY timing timing requirements [H = 0.5tc(CO)] (see Figure 14) ALTERNATE SYMBOL tsu(R-CO) Setup time, READY before CLKOUT1 rising edge th(CO-R) Hold time, READY after CLKOUT1 rising edge tsu(R-RD) Setup time, READY before RD falling edge th(RD-R) Hold time, READY after RD falling edge tsu(R)RD th(R)RD tv(R-W) th(W-R) tv(R)W th(R)W Valid time, READY after WE falling edge Hold time, READY after WE falling edge tv(R-A)RD Valid time, READY after address valid on read tv(R-A)W Valid time, READY after address valid on write ’320C206-80 ’320LC206-80 MIN MIN MAX MAX UNIT 12 12 ns 0 0 ns 14 14 ns −2 −2 H − 14 H+3 tv(R)ARD tv(R)AW ns H − 14 H+3 ns ns H − 16 H − 16 ns 2H − 16 2H − 16 ns CLKOUT1 RD WE tsu(R-CO) th(W-R) tv(R-W) th(CO-R) tsu(R-RD) th(RD-R) READY tv(R-A)RD tv(R-A)W A0 −A15 Figure 14. READY Timing POST OFFICE BOX 1443 • HOUSTON, TEXAS 77251−1443 49        SPRS065B − JUNE 1998 − REVISED JANUARY 1999 XF, TOUT, RS, INT1 − INT3, NMI, and BIO timing switching characteristics over recommended operating conditions [H = 0.5tc(CO)] (see Figure 15) ALTERNATE SYMBOL PARAMETER td(COH-XF) td(COH-TOUT) Delay time, CLKOUT1 high to XF valid tw(TOUT) Pulse duration, TOUT high ’320C206-80 UNIT MAX MIN MAX 1 6 1 6 ns 1 7 1 7 ns td(XF) td(TOUT) Delay time, CLKOUT1 high to TOUT high / low ’320LC206-80 MIN 2H − 5 2H − 5 ns CLKOUT1 td(COH-XF) XF td(COH-TOUT) tw(TOUT) TOUT Figure 15. XF and TOUT Timing timing requirements† [H = 0.5tc(CO)] (see Figure 16 and Figure 17) ALTERNATE SYMBOL tsu(RS-CIL) tsu(RS-COL) tw(RSL) td(RS-RST) tsu(IN-COLS) th(COLS-IN) Setup time, RS before CLKIN low tsu(RS)CIL tsu(RS)COL Setup time, RS before CLKOUT1 low Pulse duration, RS low‡ Delay time, RS high to reset-vector fetch Setup time, INTN before CLKOUT1 low (synchronous) td(EX) tsu(IN)COL Hold time, INTN after CLKOUT1 low (synchronous) th(IN)COL tw(IN) Pulse duration, INTN low td(IN-INT) Delay time, INTN low to interrupt-vector fetch † INTN: BIO, INT1 − INT3, NMI ‡ This parameter assumes the CLKIN to be stable before RS goes active. 50 POST OFFICE BOX 1443 td(IN) • HOUSTON, TEXAS 77251−1443 ’320C206-80 MIN MAX ’320LC206-80 MIN MAX UNIT 9 9 ns 12 12 ns 12H 12H ns 34H 34H ns 10 10 ns 0 0 ns 2H + 18 2H + 18 ns 12H 12H ns        SPRS065B − JUNE 1998 − REVISED JANUARY 1999 XF, TOUT, RS, INT1 − INT3, NMI, and BIO timing (continued) CLKIN/X2 tsu(RS-CIL) RS tw(RSL) +x† td(RS-RST) tsu(RS-COL) CLKOUT1 A0 −A15 PLLRS Case A. RS and PLLRS Activated at the Same Time During Power-on Reset CLKIN/X2 tsu(RS-CIL) RS tw(RSL) +x† td(RS-RST) tsu(RS-COL) CLKOUT1 A0 −A15 PLLRS Case B. PLLRS Always Tied Low CLKIN/X2 tsu(RS-CIL) RS tw(RSL) +x† td(RS-RST) tsu(RS-COL) CLKOUT1 A0 −A15 PLLRS Case C. Core Reset After Power Up, With PLLRS Tied High † The value of x depends on the reset condition as follows: Divide-by-two Mode: In this mode, the PLL is bypassed. Assuming CLKIN is stable, x=0. If the internal oscillator is used (i.e. a crystal is connected to X1 and X2 pins), x=oscillator lock-up time. The state of the PLLRS is not applicable for 2 mode and should always be tied high or low. PLL enabled: Assuming CLKIN is stable, x=PLL lock-up time. If the internal oscillator is used, x=oscillator lock-up time + PLL lock-up time. In case of resets after power on reset, x=0, i.e. tw(RSL)=12 H ns only. Figure 16. Reset Timings: Cases A, B, and C CLKOUT1 tsu(IN-COLS) th(COLS-IN) tw(IN) INTN‡ ‡ INTN: BIO, INT1 − INT3, NMI Figure 17. Interrupts and BIO Timing POST OFFICE BOX 1443 • HOUSTON, TEXAS 77251−1443 51        SPRS065B − JUNE 1998 − REVISED JANUARY 1999 external DMA timing switching characteristics over recommended operating conditions [H = 0.5tc(CO)] (see Figure 18) ALTERNATE SYMBOL PARAMETER ’320C206-80 MIN ’320LC206-80 MAX MIN 9 MAX td(CO-HA) td(HL-HAL) Delay time, CLKOUT1 rising to HOLDA Delay time, HOLD low to HOLDA low† 4H 4H ns td(HH-HAH) thz(M-HAL) Delay time, HOLD high to HOLDA high 10H 10H ns Address high impedance before HOLDA low‡ 9 UNIT ns tz(M-HAL) H−5 H−5 ns ten(HAH-M) Enable time, address driven from HOLDA high H−5 H−5 ns † The delay values will change based on the software logic (IDLE instruction) that activates HOLDA. See the TMS320C20x User’s Guide (literature number SPRU127) for functional description of HOLD logic. ‡ This parameter includes all memory control lines. td(CO-HA) CLKOUT1 HOLD/INT1 td(HH-HAH) td(HL-HAL) HOLDA ten(HAH-M) thz(M-HAL) Address Bus/ Data Bus/ Control Signals Figure 18. External DMA Timing 52 POST OFFICE BOX 1443 • HOUSTON, TEXAS 77251−1443        SPRS065B − JUNE 1998 − REVISED JANUARY 1999 serial-port receive timing timing requirements over recommended ranges of supply voltage and operating free-air temperature [H = 0.5tc(CO)] (see Figure 19) ALTERNATE SYMBOL tc(CLKR) tf(CLKR) Cycle time, serial-port clock (CLKR) tr(CLKR) tw(CLKR) Rise time, serial-port clock (CLKR) tsu(FR-CLKR) tsu(DR-CLKR) Setup time, FSR before CLKR falling edge th(CLKR-FR) th(CLKR-DR) Hold time, FSR after CLKR falling edge tc(SCK) tf(SCK) Fall time, serial-port clock (CLKR) Pulse duration, serial-port clock (CLKR) low/high ’320C206-80 MIN 4H tr(SCK) tw(SCK) th(FS) th(DR) Hold time, DR after CLKR falling edge MIN MAX 4H UNIT ns 8 8 ns 8 8 ns 2H 2H ns 7 7 ns 7 7 ns 7 7 ns 10 10 ns tsu(FS) tsu(DR) Setup time, DR before CLKR falling edge ’320LC206-80 MAX tc(CLKR) tf(CLKR) tw(CLKR) CLKR th(CLKR-FR) tw(CLKR) tr(CLKR) tsu(FR-CLKR) tsu(DR-CLKR) FSR th(CLKR-DR) DR 1 2 15/7 16/8 Figure 19. Serial-Port Receive Timing POST OFFICE BOX 1443 • HOUSTON, TEXAS 77251−1443 53        SPRS065B − JUNE 1998 − REVISED JANUARY 1999 serial-port transmit timings (note: timings are for all SSP modes unless otherwise specified) switching characteristics over recommended operating conditions [H = 0.5tc(CO)] (see Figure 20) ALTERNATE SYMBOL PARAMETER td(CLKX-DX) Delay time, CLKX high to DX valid ’320C206-80 ’320LC206-80 UNIT MIN TYP MAX MIN TYP MAX Internal CLKX and internal FSX Internal CLKX and external FSX td(DX) −5 22 −5 22 External CLKX and internal FSX External CLKX and external FSX td(DX) 0 20 0 20 Multichannel mode −5 25 −5 25 SPI mode −5 4 −5 4 ns tdis(DX-CLKX) Disable time, DX valid from CLKX high tdis(DX) th(CLKX-DX) Hold time, DX valid after CLKX high th(DX) tc(CLKX) Cycle time, serial-port clock (CLKX) Internal CLKX tc(SCK) 4H 4H ns tf(CLKX) Fall time, serial-port clock (CLKX) Internal CLKX tf(SCK) 5 5 ns tr(CLKX) Rise time, serial-port clock (CLKX) Internal CLKX tr(SCK) 5 5 ns tw(CLKX) Pulse duration, serial-port clock (CLKX) low/high Internal CLKX tw(SCK) Internal CLKX and internal FSX External CLKX and internal FSX td(FS) td(CLKX-FX) Delay time, CLKX rising edge to FSX 10 −6 SPI mode th(CLKXH-FX) Internal FSX −5 ns 14 th(FS)H 5 18 5 18 −5 4 −5 4 −5 † These timings also apply to the following pins in multichannel mode: CLKR, FSR, IO0. 54 ns 2H − 10 14 ns ns Multichannel mode† Hold time, FSX after CLKX rising edge −6 2H − 10 −5 10 POST OFFICE BOX 1443 • HOUSTON, TEXAS 77251−1443 −5 ns        SPRS065B − JUNE 1998 − REVISED JANUARY 1999 serial-port transmit timings (note: timings are for all SSP modes unless otherwise specified) (continued) timing requirements over recommended ranges of supply voltage and operating free-air temperature [H = 0.5tc(CO)] (see Figure 20) ’320C206-80 ALTERNATE SYMBOL MIN ’320LC206-80 MAX MIN MAX UNIT tc(CLKX) Cycle time, serial-port clock (CLKX) External CLKX tc(SCK) tf(CLKX) Fall time, serial-port clock (CLKX) External CLKX tf(SCK) 8 8 ns tr(CLKX) Rise time, serial-port clock (CLKX) External CLKX tr(SCK) 8 8 ns tw(CLKX) Pulse duration, serial-port clock (CLKX) low/high External CLKX tw(SCK) td(CLKX-FX) Delay time, CLKX rising edge high to FSX Internal CLKX and external FSX External CLKX and external FSX td(FS) th(CLKXL-FX) Hold time, FSX after CLKX falling edge low External FSX th(FS) th(CLKXH-FX) Hold time, FSX after CLKX rising edge high External FSX th(FS)H 4H 4H 2H ns 2H 2H − 8 7 ns 2H − 8 7 2H − 10 ns ns 2H − 10 ns tf(CLKX) tc(CLKX) tw(CLKX) CLKX td(CLKX-FX) tw(CLKX) th(CLKXH-FX) tr(CLKX) th(CLKXL-FX) FSX td(CLKX-DX) th(CLKX-DX) tdis(DX-CLKX) DX 1 2 15/7 16/8 Figure 20. Serial-Port Transmit Timings POST OFFICE BOX 1443 • HOUSTON, TEXAS 77251−1443 55        SPRS065B − JUNE 1998 − REVISED JANUARY 1999 general-purpose input/output (I/O) pin timings switching characteristics over recommended operating conditions (see Figure 21) ALTERNATE SYMBOL PARAMETER td(CO-IO) th(CO-IO)f Delay time, CLKOUT1 falling edge to IOx output valid Hold time, IOx output valid after CLKOUT1 falling edge ’320C206-80 td(IO) th(IO)out MIN MAX ’320LC206-80 MIN MAX 13 −2 13 −2 UNIT ns ns timing requirements (see Figure 21) ALTERNATE SYMBOL tsu(IO-CO) th(CO-IO)r Setup time, IOx input valid before CLKOUT1 rising edge Hold time, IOx input valid after CLKOUT1 rising edge tsu(IO) th(IO)in ’320C206-80 MIN MAX ’320LC206-80 MIN MAX 9 9 ns 5 5 ns CLKOUT1 th(IO)out td(IO) IOx Output Mode† tsu(IO) th(IO)in IOx Input Mode† † IOx represents IO0, IO1, IO2, or IO3 input/output pins. Figure 21. General-Purpose I/O Timings 56 POST OFFICE BOX 1443 • HOUSTON, TEXAS 77251−1443 UNIT        SPRS065B − JUNE 1998 − REVISED JANUARY 1999 MECHANICAL DATA PZ (S-PQFP-G100) PLASTIC QUAD FLATPACK 0,27 0,17 0,50 75 0,08 M 51 76 50 100 26 1 0,13 NOM 25 12,00 TYP Gage Plane 14,20 SQ 13,80 16,20 SQ 15,80 0,05 MIN 1,45 1,35 0,25 0°−ā 7° 0,75 0,45 Seating Plane 0,08 1,60 MAX 4040149 / B 10/94 NOTES: A. All linear dimensions are in millimeters. B. This drawing is subject to change without notice. C. Falls within JEDEC MO-136 Thermal Resistance Characteristics PARAMETER DESCRIPTION °C / W ΘJA Junction-to-ambient 58 ΘJC Junction-to-case 10 POST OFFICE BOX 1443 • HOUSTON, TEXAS 77251−1443 57 PACKAGE OPTION ADDENDUM www.ti.com 10-Dec-2020 PACKAGING INFORMATION Orderable Device Status (1) Package Type Package Pins Package Drawing Qty Eco Plan (2) Lead finish/ Ball material MSL Peak Temp Op Temp (°C) (3) Device Marking (4/5) (6) TMS320C206PZ80 ACTIVE LQFP PZ 100 90 RoHS & Green NIPDAU Level-1-260C-UNLIM TMS320C206PZ 80 TMS320C206PZA80 ACTIVE LQFP PZ 100 90 RoHS & Green NIPDAU Level-1-260C-UNLIM TMS320C206PZA 80 TMS320LC206PZ80 ACTIVE LQFP PZ 100 90 RoHS & Green NIPDAU Level-1-260C-UNLIM TMS320LC206PZ 80 TMS320LC206PZA80 ACTIVE LQFP PZ 100 90 RoHS & Green NIPDAU Level-1-260C-UNLIM TMS320LC206PZA 80 (1) The marketing status values are defined as follows: ACTIVE: Product device recommended for new designs. LIFEBUY: TI has announced that the device will be discontinued, and a lifetime-buy period is in effect. NRND: Not recommended for new designs. Device is in production to support existing customers, but TI does not recommend using this part in a new design. PREVIEW: Device has been announced but is not in production. Samples may or may not be available. OBSOLETE: TI has discontinued the production of the device. (2) RoHS: TI defines "RoHS" to mean semiconductor products that are compliant with the current EU RoHS requirements for all 10 RoHS substances, including the requirement that RoHS substance do not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, "RoHS" products are suitable for use in specified lead-free processes. TI may reference these types of products as "Pb-Free". RoHS Exempt: TI defines "RoHS Exempt" to mean products that contain lead but are compliant with EU RoHS pursuant to a specific EU RoHS exemption. Green: TI defines "Green" to mean the content of Chlorine (Cl) and Bromine (Br) based flame retardants meet JS709B low halogen requirements of
TMS320C206PZA80 价格&库存
很抱歉,暂时无法提供与“TMS320C206PZA80”相匹配的价格&库存,您可以联系我们找货
