5693F3_3_3-A
5693F3_3_3-A
    VCC
    CBI 3MM 3 POSITIONS VERTICAL AMB
5693F3_3_3-A 数据手册
engineered to light up your design www.vcclite.com 1.800.522.5546 5693F-A Series PC Board, 3-Up T-1 LEDs Description and Features HOUS ING : MAT'L: BLAC K THE R MOP LAS TIC P OLYE S TE R UL 94-VO .140±.025 .348 .190 LE D S E E TABLE P OS . 1 P OS . 2 IDI .600 .500 P OS . 3 .300 .100 Features • 3 T-1 LEDs tack mounted in single block saves space and as sembly time. • High Brite and Super Brite light output. • Standoffs prevent flux entrapment. • Black plastic mounting block for high contrast ratio. • Meets UL 94V-O and Bellcore flammability specifications . • RoHS Compliant Available options : • Low current, 5V and 12V built-in resistors . • Bi-color and blue LEDs also offered. • Call factory for ordering information. Refer to “Mounting Hole Pattern 1.pdf” .145±.015 ANODE (+) .020 S Q. TYP . .10 TYP . .110 .075 TYP . All dimensions in inches. Ordering Information: Use chart below to determine model number. LE D R ed 1 Amber 3 Model No. is as follows: 5693F P os. 1 G reen 5 _ Y ellow 7 P os. 2 _ P os. 3 -A E xample: P osition 1 is red, position 2 is yellow, position 3 is green. The part number is 5693F 1_7_5-A. Electro-Optical Characteristics and Ratings P art Number 5693F 1_1_1_1-A 5693F 3_3_3_3-A 5693F 5_5_5_5-A 5693F 7_7_7_7-A E mitted C olor R ed Amber G reen Y ellow R ated C urrent (mA) 10 10 10 10 T yp. Intensity (mcd) 10.0 7.0 16.0 6.3 C ontinuous F orward C urrent Max. (mA) T yp. (V ) Max. (V ) R everse B reakdown V oltage Min.(V ) P eak Wavelength (nm) 30 30 30 30 2.0 2.2 2.2 2.1 3.0 3.0 3.0 3.0 5.0 5.0 5.0 5.0 650 603 562 585 F orward V oltage CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC.
5693F3_3_3-A 价格&库存
很抱歉,暂时无法提供与“5693F3_3_3-A”相匹配的价格&库存,您可以联系我们找货
