engineered to light up your design
www.vcclite.com
1.800.522.5546
5693F-A Series PC Board, 3-Up T-1 LEDs
Description and Features
HOUS ING :
MAT'L: BLAC K THE R MOP LAS TIC
P OLYE S TE R UL 94-VO
.140±.025
.348
.190
LE D
S E E TABLE
P OS . 1
P OS . 2
IDI
.600
.500
P OS . 3
.300
.100
Features
• 3 T-1 LEDs tack mounted in single block
saves space and as sembly time.
• High Brite and Super Brite light output.
• Standoffs prevent flux entrapment.
• Black plastic mounting block for
high contrast ratio.
• Meets UL 94V-O and Bellcore
flammability specifications .
• RoHS Compliant
Available options :
• Low current, 5V and 12V built-in resistors .
• Bi-color and blue LEDs also offered.
• Call factory for ordering information.
Refer to “Mounting Hole Pattern 1.pdf”
.145±.015
ANODE (+)
.020 S Q. TYP .
.10
TYP .
.110
.075 TYP .
All dimensions in inches.
Ordering Information: Use chart below to determine model number.
LE D
R ed
1
Amber
3
Model No. is as follows: 5693F
P os. 1
G reen
5
_
Y ellow
7
P os. 2
_
P os. 3
-A
E xample: P osition 1 is red, position 2 is yellow, position 3 is green. The part number is 5693F 1_7_5-A.
Electro-Optical Characteristics and Ratings
P art Number
5693F 1_1_1_1-A
5693F 3_3_3_3-A
5693F 5_5_5_5-A
5693F 7_7_7_7-A
E mitted
C olor
R ed
Amber
G reen
Y ellow
R ated
C urrent
(mA)
10
10
10
10
T yp.
Intensity
(mcd)
10.0
7.0
16.0
6.3
C ontinuous
F orward
C urrent Max.
(mA)
T yp.
(V )
Max.
(V )
R everse
B reakdown
V oltage Min.(V )
P eak
Wavelength
(nm)
30
30
30
30
2.0
2.2
2.2
2.1
3.0
3.0
3.0
3.0
5.0
5.0
5.0
5.0
650
603
562
585
F orward V oltage
CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC.
