Data sheet | Item number: 2000-410/000-005
Jumper; 10-way; insulated; red
www.wago.com/2000-410/000-005
i
Picture differs from the item.
Color:
Data
Electrical data
Ratings per IEC/EN 60664-1
Nominal voltage (III/3)
800 V
Rated current
14 A
Ex information
Rated current (Ex e II)
12 A
Physical data
Width
34 mm / 1.339 inch
Height
19 mm / 0.748 inch
Depth
4.1 mm / 0.161 inch
Material
data
Subject to changes. Please also observe the further product documentation!
WAGO Canada, Inc.
1550 Yorkton Court - Unit 1
Burlington, ON L7P 5B7
Tel.: +1-888-9246-221
Email: info.ca@wago.com
Do you have any questions about our products?
We are always happy to take your call at +1-888-WAGO-221 (9246-221).
18.01.2021 Page 1/6
Material data
Color
red
Fire load
0.023 MJ
Weight
2.9 g
Commercial data
Product Group
22 (TOPJOB S)
Packaging type
bag
Country of origin
DE
GTIN
4055143698252
Customs tariff number
85366990990
Downloads
Documentation
Bid Text
2000-410/000-005
Feb 19, 2019
xml
2.6 kB
Download
Apr 27, 2017
doc
24.1 kB
Download
Apr 3, 2019
pdf
2.2 MB
Download
URL
Download
EPLAN Data Portal 2000-410/000-005
URL
Download
WSCAD Universe 2000-410/000-005
URL
Download
URL
Download
URL
Download
X81 - Datei
2000-410/000-005
doc - Datei
Additional Information
Technical explanations
CAD/CAE-Data
CAD data
2D/3D Models 2000-410/000-005
CAE data
WAGO Canada, Inc.
18.01.2021 Page 2/6
URL
Download
Installation Notes
Commoning
The push-in type jumper bar system is based
on the common plug and socket principle.
Each terminal block is spring-loaded with a
double socket and a resilient CrNi steel
spring. The jumper contact material is pure
electrolytic copper, which allows for an
extremely small design capable of carrying
the full-rated current of the terminal block.
Ground terminal blocks can also be
commoned using the same jumper system.
Custom jumpers are created by breaking
and removing jumper contacts (2000, 2001,
2002, 2004 Series).
Removing a push-in type jumper bar.
Insert the operating tool between the jumper
and and partition wall of the dual jumper
slots, then lift up the jumper.
Place the operating tool in the center of
jumpers up to five contacts (see above), or
alternately on both sides for jumpers with
more than five contacts.
Commoning
WAGO Canada, Inc.
18.01.2021 Page 3/6
Custom push-in type jumper bars are
created by breaking off jumper contacts.
Marking a push-in type jumper bar using a
felt-tip pen.
500 V
300 V
Commoning
An application example: colored push-in
type jumper bars are used with sensor
terminal blocks.
Commoning
WAGO Canada, Inc.
18.01.2021 Page 4/6
Stepping down via push-in type jumper bar.
Commoning via closed terminal side with
end plate allows jumpering over two crosssection sizes, e.g., from 16 mm² (6 AWG) to
6 mm² (10 AWG) or from 6 mm² (10 AWG) to
2.5 mm² (14 AWG) (see illustration above).
Commoning via open terminal side with end
plate allows jumpering over two crosssection sizes for 16 mm² (6 AWG) and
10 mm² (8 AWG) and one cross-section size
for 6/4/2.5 mm² (10/12/14 AWG). An
example: from 16 mm² (6 AWG) to 6 mm² (10
AWG) (see illustration above) or from 10 mm²
(8 AWG) to 4 mm² (12 AWG).
WAGO Canada, Inc.
18.01.2021 Page 5/6
Note:
The total current of the outgoing circuits
shall not exceed the nominal current of the
step-down jumper/push-in type jumper bar.
Product family
TOPJOB® S
TOPJOB® S: In various industrial applications and modern building installations, WAGO's wide and versatile range of railmount terminal blocks provides more than just reliable electrical connections.
Show all products from the family
WAGO Canada, Inc.
18.01.2021 Page 6/6
很抱歉,暂时无法提供与“2000-410/000-005”相匹配的价格&库存,您可以联系我们找货
