2020-213
    WAGO(万可电子)
    2-CONDUCTOR FEMALE CONNECTOR; 1.
2020-213 数据手册
'DWDVKHHW{_,WHPQXPEHU{‫܄܂܃܁܃܁܃‬ FRQGXFWRUIHPDOHFRQQHFWRU3XVKLQ&$*(&/$03‹PP3LQ VSDFLQJPPSROHPPJUD\ ZZZZDJRFRP L 3LFWXUHGLƬHUVIURPWKHLWHP &RORU 6XEMHFWWRFKDQJHV3OHDVHDOVRREVHUYHWKHIXUWKHUSURGXFWGRFXPHQWDWLRQ :$*2*PE+ &R.* +DQVDVWU 0LQGHQ 3KRQH_)D[ (PDLOLQIRGH#ZDJRFRP_:HEZZZZDJRFRP 'R\RXKDYHDQ\TXHVWLRQVDERXWRXUSURGXFWV" :HDUHDOZD\VKDSS\WRWDNH\RXUFDOODW   {{{{3DJH‫܊ ܂‬ 'DWDVKHHW{_,WHPQXPEHU{‫܄܂܃܁܃܁܃‬ ZZZZDJRFRP 'DWD 1RWHV 6DIHW\LQIRUPDWLRQ $FFRUGLQJWR(1SOXJJDEOHFRQQHFWRUVZLWKRXWFXUUHQW LQWHUUXSWLQJFDSDFLW\PXVWQRWEHPDWHGRUXQPDWHGZKHQOLYHRU XQGHUORDG 6DIHW\LQIRUPDWLRQ 1RWLFH$QDSSURSULDWHHQGSODWHPXVWEHDSSOLHGWRWKHFDUULHU WHUPLQDOEORFNVDIWHUHDFKIHPDOHSOXJ (OHFWULFDOGDWD 5DWLQJVSHU,(&(1 5DWLQJVSHU ,(&(1 1RPLQDOYROWDJH ,,, ‫{ ܁܁܆‬9 5DWHGLPSXOVHYROWDJH ,,, ‫{ ܇‬N9 5DWHGFXUUHQW ‫{ ܆܄܂‬$ /HJHQG UDWLQJV ,,, Ε2YHUYROWDJHFDWHJRU\,,,3ROOXWLRQGHJUHH 5DWLQJVSHU8/ $SSURYDOVSHU 8/ 5DWHGYROWDJH8/ 8VH*URXS% ‫{ ܁܁܄‬9 5DWHGFXUUHQW8/ 8VH*URXS% ‫{ ܆܂‬$ 5DWHGYROWDJH8/ 8VH*URXS& ‫{ ܁܁܄‬9 5DWHGFXUUHQW8/ 8VH*URXS& ‫{ ܆܂‬$ 5DWHGYROWDJH8/ 8VH*URXS' ‫{ ܁܁܄‬9 5DWHGFXUUHQW8/ 8VH*URXS' ‫{ ܆܂‬$ 5DWLQJVSHU&6$ $SSURYDOVSHU &6$1R 5DWHGYROWDJH&6$ 8VH*URXS% ‫{ ܁܁܄‬9 5DWHGFXUUHQW&6$ 8VH*URXS% ‫{ ܁܂‬$ 5DWHGYROWDJH&6$ 8VH*URXS& ‫{ ܁܁܄‬9 5DWHGFXUUHQW&6$ 8VH*URXS& ‫{ ܁܂‬$ 5DWHGYROWDJH&6$ 8VH*URXS' ‫{ ܁܁܄‬9 5DWHGFXUUHQW&6$ 8VH*URXS' ‫{ ܁܂‬$ 6XEMHFWWRFKDQJHV3OHDVHDOVRREVHUYHWKHIXUWKHUSURGXFWGRFXPHQWDWLRQ :$*2*PE+ &R.* +DQVDVWU 0LQGHQ 3KRQH_)D[ (PDLOLQIRGH#ZDJRFRP_:HEZZZZDJRFRP 'R\RXKDYHDQ\TXHVWLRQVDERXWRXUSURGXFWV" :HDUHDOZD\VKDSS\WRWDNH\RXUFDOODW   {{{{3DJH‫܊ ܃‬ 'DWDVKHHW{_,WHPQXPEHU{‫܄܂܃܁܃܁܃‬ ZZZZDJRFRP &RQQHFWLRQGDWD &RQQHFWLRQSRLQWV ‫܇܃‬ 7RWDOQXPEHURISRWHQWLDOV ‫܄܂‬ &RQQHFWLRQ &RQQHFWLRQWHFKQRORJ\ 3XVKLQ&$*(&/$03‹ $FWXDWLRQW\SH 2SHUDWLQJWRRO &RQQHFWDEOHFRQGXFWRUPDWHULDOV &RSSHU 1RPLQDOFURVVVHFWLRQ PP 6ROLGFRQGXFWRU f{PP{f{$:* 6ROLGFRQGXFWRUSXVKLQWHUPLQDWLRQ f{PP{f{$:* )LQHVWUDQGHGFRQGXFWRU f{PP{f{$:* )LQHVWUDQGHGFRQGXFWRUZLWKLQVXODWHGIHUUXOH f{PP{f{$:* )LQHVWUDQGHGFRQGXFWRUZLWKIHUUXOHSXVKLQWHUPLQDWLRQ f{PP{f{$:* 1RWH FRQGXFWRUFURVVVHFWLRQ 'HSHQGLQJRQWKHFRQGXFWRUFKDUDFWHULVWLFDFRQGXFWRUZLWKD VPDOOHUFURVVVHFWLRQFDQDOVREHLQVHUWHGYLDSXVKLQWHUPLQDWLRQ 6WULSOHQJWK f{PP{f{LQFKHV 3ROHQXPEHU ‫܄܂‬ :LULQJGLUHFWLRQ )URQWHQWU\ZLULQJ 3K\VLFDOGDWD :LGWK {PP{{LQFKHV +HLJKW {PP{{LQFKHV 'HSWK {PP{{LQFKHV 0RGXOHZLGWK {PP{{LQFKHV 0HFKDQLFDO'DWD 9DULDEOHFRGLQJ
2020-213
物料型号: 2020-213
器件简介: - 这是一个2导体的母头连接器,使用Push-in CAGE CLAMP技术,导线截面积为1.5 mm²。 - 引脚间距为3.5 mm,共有13个引脚,每个引脚的间距为1.50 mm。 - 产品颜色为灰色。
引脚分配: - 每个引脚都可以进行Push-in CAGE CLAMP连接,适用于铜导线。 - 导线截面积从1 mm²到1.5 mm²不等。
参数特性: - 电气数据包括: - 额定电压(I/3):500V - 额定脉冲电压(I1/3):6kV - 额定电流:13.5A - 符合IEC/EN61984标准,以及UL和CSA的不同使用组别的额定电压和电流。
功能详解: - 连接器具有Push-in CAGE CLAMP连接技术,允许快速连接铜导线。 - 具有操作工具激活类型,适用于前入线连接方式。 - 物理数据包括宽度46.2mm,高度40.5mm,深度25mm,模块宽度3.5mm。
应用信息: - 适用于需要快速连接和断开的应用场景。 - 连接器可以锁定,以防止意外断开。
封装信息: - 材料数据包括灰色聚酰胺(PA66)绝缘材料,符合UL94的VO级阻燃等级。 - 环境要求包括加工温度-35°C至+85°C,连续工作温度-60°C至+105°C。
其他信息: - 产品符合RoHS标准,无豁免。 - 提供了多种认证和合规声明,包括CE标志和用于海洋应用的认证。
可选配件: - 包括防拔出力板、操作工具、标记配件、保护警告标记、锁定杆和安装配件等。
安装说明: - 插入编码销并转动以进行编码。 - 将编码母头插入X-COM系统端子块组件中。
产品家族: - 属于X-COM S-Mini产品系列。
2020-213 价格&库存
很抱歉,暂时无法提供与“2020-213”相匹配的价格&库存,您可以联系我们找货
