2022-112
2022-112
    WAGO(万可电子)
    P=5.2mm
    接线端子 间距:5.20mm 1x12P 自由悬挂(直插式)
2022-112 数据手册
'DWDVKHHW{_,WHPQXPEHU{‫܃܂܂܃܃܁܃‬ FRQGXFWRUIHPDOHFRQQHFWRU3XVKLQ&$*(&/$03‹PP3LQVSDFLQJ PPSROHPPJUD\ ZZZZDJRFRP L 3LFWXUHGLƬHUVIURPWKHLWHP &RORU 'DWD 1RWHV 6DIHW\LQIRUPDWLRQ $FFRUGLQJWR(1SOXJJDEOHFRQQHFWRUVZLWKRXWFXUUHQW LQWHUUXSWLQJFDSDFLW\PXVWQRWEHPDWHGRUXQPDWHGZKHQOLYHRU 6XEMHFWWRFKDQJHV3OHDVHDOVRREVHUYHWKHIXUWKHUSURGXFWGRFXPHQWDWLRQ :$*2*PE+ &R.* +DQVDVWU 0LQGHQ 3KRQH_)D[ (PDLOLQIRGH#ZDJRFRP_:HEZZZZDJRFRP 'R\RXKDYHDQ\TXHVWLRQVDERXWRXUSURGXFWV" :HDUHDOZD\VKDSS\WRWDNH\RXUFDOODW   {{{{3DJH‫܁܂ ܂‬ 'DWDVKHHW{_,WHPQXPEHU{‫܃܂܂܃܃܁܃‬ ZZZZDJRFRP LQWHUUXSWLQJFDSDFLW\PXVWQRWEHPDWHGRUXQPDWHGZKHQOLYHRU XQGHUORDG (OHFWULFDOGDWD 5DWLQJVSHU,(&(1 5DWLQJVSHU ,(&(1 1RPLQDOYROWDJH ,,, ‫{ ܁܊܇‬9 5DWHGLPSXOVHYROWDJH ,,, ‫{ ܇‬N9 5DWHGFXUUHQW ‫{ ܅܃‬$ &XUUHQWDWFRQGXFWRUFURVVVHFWLRQ PD[ PP ‫{ ܃܄‬$ /HJHQG UDWLQJV ,,, Ε2YHUYROWDJHFDWHJRU\,,,3ROOXWLRQGHJUHH 5DWLQJVSHU8/ $SSURYDOVSHU 8/ 5DWHGYROWDJH8/ 8VH*URXS% ‫{ ܁܁܇‬9 5DWHGFXUUHQW8/ 8VH*URXS% ‫{ ܁܃‬$ 5DWHGYROWDJH8/ 8VH*URXS& ‫{ ܁܁܇‬9 5DWHGFXUUHQW8/ 8VH*URXS& ‫{ ܁܃‬$ 5DWLQJVSHU&6$ $SSURYDOVSHU &6$1R 5DWHGYROWDJH&6$ 8VH*URXS& ‫{ ܁܁܇‬9 5DWHGFXUUHQW&6$ 8VH*URXS& ‫{ ܁܃‬$ &RQQHFWLRQGDWD &RQQHFWLRQSRLQWV ‫܃܂‬ 7RWDOQXPEHURISRWHQWLDOV ‫܃܂‬ &RQQHFWLRQ &RQQHFWLRQWHFKQRORJ\ 3XVKLQ&$*(&/$03‹ $FWXDWLRQW\SH 2SHUDWLQJWRRO &RQQHFWDEOHFRQGXFWRUPDWHULDOV &RSSHU 1RPLQDOFURVVVHFWLRQ PP 6ROLGFRQGXFWRU f{PP{f{$:* 6ROLGFRQGXFWRUSXVKLQWHUPLQDWLRQ f{PP{f{$:* )LQHVWUDQGHGFRQGXFWRU f{PP{f{$:* 6XEMHFWWRFKDQJHV3OHDVHDOVRREVHUYHWKHIXUWKHUSURGXFWGRFXPHQWDWLRQ :$*2*PE+ &R.* +DQVDVWU 0LQGHQ 3KRQH_)D[ (PDLOLQIRGH#ZDJRFRP_:HEZZZZDJRFRP 'R\RXKDYHDQ\TXHVWLRQVDERXWRXUSURGXFWV" :HDUHDOZD\VKDSS\WRWDNH\RXUFDOODW   {{{{3DJH‫܁܂ ܃‬ 'DWDVKHHW{_,WHPQXPEHU{‫܃܂܂܃܃܁܃‬ ZZZZDJRFRP )LQHVWUDQGHGFRQGXFWRU f{PP{f{$:* )LQHVWUDQGHGFRQGXFWRUZLWKLQVXODWHGIHUUXOH f{PP{f{$:* )LQHVWUDQGHGFRQGXFWRUZLWKIHUUXOHSXVKLQWHUPLQDWLRQ f{PP{f{$:* 1RWH FRQGXFWRUFURVVVHFWLRQ 'HSHQGLQJRQWKHFRQGXFWRUFKDUDFWHULVWLFDFRQGXFWRUZLWKD VPDOOHUFURVVVHFWLRQFDQDOVREHLQVHUWHGYLDSXVKLQWHUPLQDWLRQ 6WULSOHQJWK f{PP{f{LQFKHV 3ROHQXPEHU ‫܃܂‬ :LULQJGLUHFWLRQ )URQWHQWU\ZLULQJ 3K\VLFDOGDWD :LGWK {PP{{LQFKHV +HLJKW {PP{{LQFKHV 'HSWK {PP{{LQFKHV 0RGXOHZLGWK {PP{{LQFKHV 0HFKDQLFDO'DWD 9DULDEOHFRGLQJ
2022-112
- 物料型号:WAGO 2022-112 - 器件简介:这是一个12极的1导体女性连接器,使用Push-in CAGE CLAMP技术,导体截面积为4mm²,间距为5.2mm。 - 引脚分配:共有12个连接点,每个极点可以连接一个导体。 - 参数特性: - 额定电压(根据IEC/EN 61984):690V - 额定冲击电压(根据IEC/EN 61984):6kV - 额定电流:24A,对于32mm²的导体截面积最大电流为32A - UL认证的额定电压和电流分别为600V和20A(使用组B和C) - CSA认证的额定电压和电流分别为600V和20A(使用组C) - 功能详解:该连接器支持前入线方式,具有可变编码,侧面标记,以及防旋转保护。 - 应用信息:适用于需要高安全性和可靠性的电气连接场合。 - 封装信息: - 宽度:62.4mm - 高度:40.5mm - 深度:22.4mm - 模块宽度:5.2mm - 材料组:I - 绝缘材料:聚酰胺(PA66) - 阻燃等级:UL94 VO - 重量:40.6g - 环境要求:加工温度范围为-35°C至+85°C,连续工作温度范围为-60°C至+105°C。
2022-112 价格&库存
很抱歉,暂时无法提供与“2022-112”相匹配的价格&库存,您可以联系我们找货
