2091-1180
2091-1180
    WAGO(万可电子)
    1-CONDUCTOR THT FEMALE HEADER; 1
2091-1180 数据手册
'DWDVKHHW{_,WHPQXPEHU{‫܁܉܂܂܂܊܁܃‬ FRQGXFWRU7+7IHPDOHFRQQHFWRUVWUDLJKWSXVKEXWWRQ3XVKLQ&$*( &/$03‹PP3LQVSDFLQJPPSROHPPµVROGHUSLQ PPOLJKWJUD\ ZZZZDJRFRP L 3LFWXUHGLƬHUVIURPWKHLWHP &RORU 6XEMHFWWRFKDQJHV3OHDVHDOVRREVHUYHWKHIXUWKHUSURGXFWGRFXPHQWDWLRQ :$*2*PE+ &R.* +DQVDVWU 0LQGHQ 3KRQH_)D[ (PDLOLQIRGH#ZDJRFRP_:HEZZZZDJRFRP 'R\RXKDYHDQ\TXHVWLRQVDERXWRXUSURGXFWV" :HDUHDOZD\VKDSS\WRWDNH\RXUFDOODW   {{{{3DJH‫܁܂ ܂‬ 'DWDVKHHW{_,WHPQXPEHU{‫܁܉܂܂܂܊܁܃‬ ZZZZDJRFRP 'LPHQVLRQVLQ{PP / SROHQR[SLQVSDFLQJ $ PP7+7VROGHUSLQ $ PP7+5VROGHUSLQ ,WHPGHVFULSWLRQ 8QLYHUVDOFRQQHFWLRQIRUDOOFRQGXFWRUW\SHV 6LPSOHSXVKLQWHUPLQDWLRQRIVROLGDQGIHUUXOHGFRQGXFWRUV (DV\WRXVHGHVLJQGRHVQRWUHTXLUHVSHFLDOWRROV $ELOLW\WRZLUHZKLOHPDWHGRUXQPDWHG ,QWHJUDWHGWHVWSRUWVIRUWHVWLQJSDUDOOHOWRFRQGXFWRUHQWU\ &XVWRPLQVWDOOHGVROGHUSLQV 'DWD 1RWHV 6DIHW\LQIRUPDWLRQ 7KHSLFR0$;‹3OXJJDEOH&RQQHFWLRQ6\VWHPLQFOXGHVFRQQHFWRUV ZLWKRXWEUHDNLQJFDSDFLW\LQDFFRUGDQFHZLWK',1(1:KHQ XVHGDVLQWHQGHGWKHVHFRQQHFWRUVPXVWQRWEHFRQQHFWHG GLVFRQQHFWHGZKHQOLYHRUXQGHUORDG7KHFLUFXLWGHVLJQVKRXOG HQVXUHKHDGHUSLQVZKLFKFDQEHWRXFKHGDUHQRWOLYHZKHQ XQPDWHG (OHFWULFDOGDWD 5DWLQJVSHU,(&(1 5DWLQJVSHU ,(&(1 1RPLQDOYROWDJH ,,, ‫{ ܁܇܂‬9 6XEMHFWWRFKDQJHV3OHDVHDOVRREVHUYHWKHIXUWKHUSURGXFWGRFXPHQWDWLRQ :$*2*PE+ &R.* +DQVDVWU 0LQGHQ 3KRQH_)D[ (PDLOLQIRGH#ZDJRFRP_:HEZZZZDJRFRP 'R\RXKDYHDQ\TXHVWLRQVDERXWRXUSURGXFWV" :HDUHDOZD\VKDSS\WRWDNH\RXUFDOODW   {{{{3DJH‫܁܂ ܃‬ 'DWDVKHHW{_,WHPQXPEHU{‫܁܉܂܂܂܊܁܃‬ ZZZZDJRFRP 1RPLQDOYROWDJH ,,, ‫{ ܁܇܂‬9 5DWHGLPSXOVHYROWDJH ,,, ‫{ ܆܃‬N9 5DWHGYROWDJH ,,, ‫{ ܁܇܂‬9 5DWHGLPSXOVHYROWDJH ,,, ‫{ ܆܃‬N9 1RPLQDOYROWDJH ,, ‫{ ܁܃܄‬9 5DWHGVXUJHYROWDJH ,, ‫{ ܆܃‬N9 5DWHGFXUUHQW ‫{ ܁܂‬$ /HJHQG UDWLQJV ,,, Ε2YHUYROWDJHFDWHJRU\,,,3ROOXWLRQGHJUHH 5DWLQJVSHU8/ $SSURYDOVSHU 8/ 5DWHGYROWDJH8/ 8VH*URXS% ‫{ ܁܁܄‬9 5DWHGFXUUHQW8/ 8VH*URXS% ‫{ ܁܂‬$ 5DWHGYROWDJH8/ 8VH*URXS' ‫{ ܁܁܄‬9 5DWHGFXUUHQW8/ 8VH*URXS' ‫{ ܁܂‬$ &RQQHFWLRQGDWD &RQQHFWLRQSRLQWV ‫܁܂‬ 7RWDOQXPEHURISRWHQWLDOV ‫܁܂‬ 1XPEHURIFRQQHFWLRQW\SHV ‫܂‬ 1XPEHURIOHYHOV ‫܂‬ &RQQHFWLRQ &RQQHFWLRQWHFKQRORJ\ 3XVKLQ&$*(&/$03‹ $FWXDWLRQW\SH 3XVKEXWWRQ $FWXDWLRQGLUHFWLRQ 2SHUDWLRQSDUDOOHOWRFRQGXFWRUHQWU\ 6ROLGFRQGXFWRU f{PP{f{$:* )LQHVWUDQGHGFRQGXFWRU f{PP{f{$:* )LQHVWUDQGHGFRQGXFWRUZLWKLQVXODWHGIHUUXOH f{PP )LQHVWUDQGHGFRQGXFWRUZLWKXQLQVXODWHGIHUUXOH f{PP 6WULSOHQJWK f{PP{f{LQFKHV &RQGXFWRUFRQQHFWLRQGLUHFWLRQWR3&% ‫{ ܁܊‬ 3ROHQXPEHU ‫܁܂‬ 3K\VLFDOGDWD 3LQVSDFLQJ {PP{{LQFKHV :LGWK {PP{{LQFKHV 6XEMHFWWRFKDQJHV3OHDVHDOVRREVHUYHWKHIXUWKHUSURGXFWGRFXPHQWDWLRQ :$*2*PE+ &R.* +DQVDVWU 0LQGHQ 3KRQH_)D[ (PDLOLQIRGH#ZDJRFRP_:HEZZZZDJRFRP 'R\RXKDYHDQ\TXHVWLRQVDERXWRXUSURGXFWV" :HDUHDOZD\VKDSS\WRWDNH\RXUFDOODW   {{{{3DJH‫܁܂ ܄‬ 'DWDVKHHW{_,WHPQXPEHU{‫܁܉܂܂܂܊܁܃‬ ZZZZDJRFRP :LGWK {PP{{LQFKHV +HLJKW {PP{{LQFKHV 'HSWK {PP{{LQFKHV 6ROGHUSLQOHQJWK ‫{ ܇܄‬PP 6ROGHUSLQGLDPHWHU ‫{ ܂‬PP 'ULOOHGKROHGLDPHWHUZLWKWROHUDQFH ‫{ ܂܁ۿ {܃܂‬PP 0HFKDQLFDO'DWD 9DULDEOHFRGLQJ 1R $QWLURWDWLRQSURWHFWLRQ
2091-1180
1. 物料型号:2091-1180,是WAGO公司生产的1-conductor THT female connector straight,push-button; Push-in CAGE CLAMP。
2. 器件简介: - 通用连接适用于所有导体类型。 - 简单的push-in端接,适用于实心和带套管的导体。 - 设计易于使用,不需要特殊工具。 - 集成测试端口,可并行测试导体进入。 - 可定制安装的焊锡针。
3. 引脚分配: - 引脚间距为3.5mm,适用于10-pole连接。
4. 参数特性: - 额定电流:10A。 - 额定电压:160V/320V(根据标准不同)。 - 额定脉冲电压:2.5kV。 - 导体截面积:0.2...1.5 mm²/24...14 AWG。
5. 功能详解: - 提供了安全信息和电气数据。 - 符合IEC/EN标准和UL标准。
6. 应用信息: - 可应用于PCB连接,具有90°的引脚连接方向。
7. 封装信息: - 宽度:35mm。 - 高度:14mm。 - 深度:11.4mm。 - 焊锡针长度:3.6mm,直径:1mm。
8. 材料信息: - 绝缘材料:Polyphthalamide (PPA GF)。 - 阻燃等级:UL94 V0。 - 夹持弹簧材料:铬镍弹簧钢(CrNi)。 - 接触材料:电镀铜(Ea),镀锡。
9. 环境要求: - 工作温度范围:-60...+100°C。
10. 商业信息: - 产品组:26 (picoMAX Connectors)。 - 包装类型:盒装,每盒100件。
11. 环境产品合规性: - 符合RoHS标准,有多项认证和批准。
12. 附加信息: - 提供了CAD/CAE数据支持,包括多种EDA格式和3D模型。
2091-1180 价格&库存
很抱歉,暂时无法提供与“2091-1180”相匹配的价格&库存,您可以联系我们找货
