2092-1126/000-5000
2092-1126/000-5000
    WAGO(万可电子)
    P=5mm
    接线端子 间距:5.00mm 1x6P 自由悬挂(直插式)
2092-1126/000-5000 数据手册
'DWDVKHHW{_,WHPQXPEHU{‫܁܁܁܆܁܁܁܇܃܂܂܃܊܁܃‬ FRQGXFWRUIHPDOHFRQQHFWRUSXVKEXWWRQ3XVKLQ&$*(&/$03‹ PP3LQVSDFLQJPPSROHGLUHFWPDUNLQJPPOLJKWJUD\ ZZZZDJRFRP L 3LFWXUHGLƬHUVIURPWKHLWHP &RORU 'LPHQVLRQVLQ{PP / SROHQR[SLQVSDFLQJ 6XEMHFWWRFKDQJHV3OHDVHDOVRREVHUYHWKHIXUWKHUSURGXFWGRFXPHQWDWLRQ :$*2*PE+ &R.* +DQVDVWU 0LQGHQ 3KRQH_)D[ (PDLOLQIRGH#ZDJRFRP_:HEZZZZDJRFRP 'R\RXKDYHDQ\TXHVWLRQVDERXWRXUSURGXFWV" :HDUHDOZD\VKDSS\WRWDNH\RXUFDOODW   {{{{3DJH‫܊ ܂‬ 'DWDVKHHW{_,WHPQXPEHU{‫܁܁܁܆܁܁܁܇܃܂܂܃܊܁܃‬ ZZZZDJRFRP ,WHPGHVFULSWLRQ 8QLYHUVDOFRQQHFWLRQRIDOOFRQGXFWRUW\SHV 6LPSOHSXVKLQWHUPLQDWLRQRIVROLGDQGIHUUXOHGFRQGXFWRUV (DV\WRXVHGHVLJQGRHVQRWUHTXLUHVSHFLDOWRROV $ELOLW\WRZLUHZKLOHPDWHGRUXQPDWHG 7HVWLQJSDUDOOHOWRFRQGXFWRUHQWU\sWLSFRQWDFW $OVRDYDLODEOHZLWKJULSSLQJSODWHV ,QWHJUDWHGORFNLQJODWFKHVSUHYHQWDFFLGHQWDOGLVFRQQHFWLRQ 'DWD 1RWHV 6DIHW\LQIRUPDWLRQ 7KHSLFR0$;‹3OXJJDEOH&RQQHFWLRQ6\VWHPLQFOXGHVFRQQHFWRUV ZLWKRXWEUHDNLQJFDSDFLW\LQDFFRUGDQFHZLWK',1(1:KHQ XVHGDVLQWHQGHGWKHVHFRQQHFWRUVPXVWQRWEHFRQQHFWHG GLVFRQQHFWHGZKHQOLYHRUXQGHUORDG7KHFLUFXLWGHVLJQVKRXOG HQVXUHKHDGHUSLQVZKLFKFDQEHWRXFKHGDUHQRWOLYHZKHQ XQPDWHG 9DULDQWV 'LUHFWPDUNLQJ 2WKHUYHUVLRQV RUYDULDQWV FDQEHUHTXHVWHGIURP:$*26DOHVRU FRQƮJXUHGDWKWWSVFRQƮJXUDWRUZDJRFRP (OHFWULFDOGDWD 5DWLQJVSHU,(&(1 5DWLQJVSHU ,(&(1 1RPLQDOYROWDJH ,,, ‫{ ܁܆܃‬9 5DWHGLPSXOVHYROWDJH ,,, ‫{ ܅‬N9 5DWHGYROWDJH ,,, ‫{ ܁܃܄‬9 5DWHGLPSXOVHYROWDJH ,,, ‫{ ܅‬N9 1RPLQDOYROWDJH ,, ‫{ ܁܄܇‬9 5DWHGVXUJHYROWDJH ,, ‫{ ܅‬N9 5DWHGFXUUHQW ‫{ ܇܂‬$ /HJHQG UDWLQJV ,,, Ε2YHUYROWDJHFDWHJRU\,,,3ROOXWLRQGHJUHH 5DWLQJVSHU8/ $SSURYDOVSHU 8/ 5DWHGYROWDJH8/ 8VH*URXS% ‫{ ܁܁܄‬9 6XEMHFWWRFKDQJHV3OHDVHDOVRREVHUYHWKHIXUWKHUSURGXFWGRFXPHQWDWLRQ :$*2*PE+ &R.* +DQVDVWU 0LQGHQ 3KRQH_)D[ (PDLOLQIRGH#ZDJRFRP_:HEZZZZDJRFRP 'R\RXKDYHDQ\TXHVWLRQVDERXWRXUSURGXFWV" :HDUHDOZD\VKDSS\WRWDNH\RXUFDOODW   {{{{3DJH‫܊ ܃‬ 'DWDVKHHW{_,WHPQXPEHU{‫܁܁܁܆܁܁܁܇܃܂܂܃܊܁܃‬ ZZZZDJRFRP 5DWHGYROWDJH8/ 8VH*URXS% ‫{ ܁܁܄‬9 5DWHGFXUUHQW8/ 8VH*URXS% ‫{ ܆܂‬$ 5DWHGYROWDJH8/ 8VH*URXS' ‫{ ܁܁܄‬9 5DWHGFXUUHQW8/ 8VH*URXS' ‫{ ܁܂‬$ &RQQHFWLRQGDWD &RQQHFWLRQSRLQWV ‫܇‬ 7RWDOQXPEHURISRWHQWLDOV ‫܇‬ 1XPEHURIFRQQHFWLRQW\SHV ‫܂‬ 1XPEHURIOHYHOV ‫܂‬ &RQQHFWLRQ &RQQHFWLRQWHFKQRORJ\ 3XVKLQ&$*(&/$03‹ $FWXDWLRQW\SH 3XVKEXWWRQ $FWXDWLRQGLUHFWLRQ 2SHUDWLRQSDUDOOHOWRFRQGXFWRUHQWU\ 6ROLGFRQGXFWRU f{PP{f{$:* )LQHVWUDQGHGFRQGXFWRU f{PP{f{$:* )LQHVWUDQGHGFRQGXFWRUZLWKLQVXODWHGIHUUXOH f{PP )LQHVWUDQGHGFRQGXFWRUZLWKXQLQVXODWHGIHUUXOH f{PP 6WULSOHQJWK f{PP{f{LQFKHV 3ROHQXPEHU ‫܇‬ 3K\VLFDOGDWD 3LQVSDFLQJ {PP{{LQFKHV :LGWK {PP{{LQFKHV +HLJKW {PP{{LQFKHV 'HSWK {PP{{LQFKHV 0HFKDQLFDO'DWD 9DULDEOHFRGLQJ
2092-1126/000-5000
物料型号为2092-1126/000-5000,是WAGO公司生产的一导体母连接器,具有推入式笼式夹紧结构,2.5平方毫米的导线截面积,5毫米的针距,6个插针,直接标记为2.50平方毫米,颜色为浅灰色。
器件简介:该连接器适用于所有导线类型的通用连接,支持插入式笼式夹紧结构,可简单推入实心和带压接管的导线,设计易于使用,无需特殊工具,支持带插合或未插合状态下接线,具有集成锁定扣,防止意外断开。
引脚分配:6个插针,每个插针间距为5毫米。
参数特性:额定电压250V,额定脉冲电压4kV,额定电流16A,符合IEC/EN60664-1标准,UL认证的额定电压为300V,额定电流为15A(使用组B)和10A(使用组D)。
功能详解:支持并联测试,可在导线进入时进行测试,也提供带夹持板的版本。
应用信息:适用于需要可靠电气连接和简单操作的场合,如工业自动化、控制柜布线等。
封装信息:颜色为浅灰色,材料组为1,绝缘材料为聚酰亚胺(PPA GF),阻燃等级为UL94 V0,夹紧弹簧材料为铬镍弹簧钢(CrNi),接触材料为电解铜(E),接触镀层为锡,重量为5.2克。
环境要求:工作温度范围为-60至+100°C,加工温度范围为-35至+60°C。
商业数据:eCl@ss10.0和9.0分类为27-14-11-06,ETIM8.0和7.0分类为EC001284,PU(SPU)为100件/盒,原产国为德国,GTIN为4050821358121,海关关税编号为85366990990。
环境产品合规性:符合RoHS标准,无豁免。
2092-1126/000-5000 价格&库存
很抱歉,暂时无法提供与“2092-1126/000-5000”相匹配的价格&库存,您可以联系我们找货
