2092-1374/000-5000
2092-1374/000-5000
    WAGO(万可电子)
    1-CONDUCTOR THT FEMALE HEADER; 1
2092-1374/000-5000 数据手册
'DWDVKHHW{_,WHPQXPEHU{‫܁܁܁܆܁܁܁܅܈܄܂܃܊܁܃‬ FRQGXFWRU7+7IHPDOHFRQQHFWRUDQJOHGSXVKEXWWRQ3XVKLQ&$*( &/$03‹PP3LQVSDFLQJPPSROHPPµVROGHUSLQGLUHFW PDUNLQJPPOLJKWJUD\ ZZZZDJRFRP L 3LFWXUHGLƬHUVIURPWKHLWHP &RORU 6XEMHFWWRFKDQJHV3OHDVHDOVRREVHUYHWKHIXUWKHUSURGXFWGRFXPHQWDWLRQ :$*2*PE+ &R.* +DQVDVWU 0LQGHQ 3KRQH_)D[ (PDLOLQIRGH#ZDJRFRP_:HEZZZZDJRFRP 'R\RXKDYHDQ\TXHVWLRQVDERXWRXUSURGXFWV" :HDUHDOZD\VKDSS\WRWDNH\RXUFDOODW   {{{{3DJH‫܉ ܂‬ 'DWDVKHHW{_,WHPQXPEHU{‫܁܁܁܆܁܁܁܅܈܄܂܃܊܁܃‬ ZZZZDJRFRP 'LPHQVLRQVLQ{PP / SROHQR[SLQVSDFLQJ $ PP7+7VROGHUSLQ $ PP7+5VROGHUSLQ ,WHPGHVFULSWLRQ 8QLYHUVDOFRQQHFWLRQIRUDOOFRQGXFWRUW\SHV 6LPSOHSXVKLQWHUPLQDWLRQRIVROLGDQGIHUUXOHGFRQGXFWRUV (DV\WRXVHGHVLJQGRHVQRWUHTXLUHVSHFLDOWRROV $ELOLW\WRZLUHZKLOHPDWHGRUXQPDWHG ,QWHJUDWHGWHVWSRUWVIRUWHVWLQJSDUDOOHOWRFRQGXFWRUHQWU\ &XVWRPLQVWDOOHGVROGHUSLQV 'DWD 1RWHV 6DIHW\LQIRUPDWLRQ 7KHSLFR0$;‹3OXJJDEOH&RQQHFWLRQ6\VWHPLQFOXGHVFRQQHFWRUV ZLWKRXWEUHDNLQJFDSDFLW\LQDFFRUGDQFHZLWK',1(1:KHQ XVHGDVLQWHQGHGWKHVHFRQQHFWRUVPXVWQRWEHFRQQHFWHG GLVFRQQHFWHGZKHQOLYHRUXQGHUORDG7KHFLUFXLWGHVLJQVKRXOG HQVXUHKHDGHUSLQVZKLFKFDQEHWRXFKHGDUHQRWOLYHZKHQ XQPDWHG (OHFWULFDOGDWD 5DWLQJVSHU,(&(1 5DWLQJVSHU ,(&(1 1RPLQDOYROWDJH ,,, ‫{ ܁܆܃‬9 6XEMHFWWRFKDQJHV3OHDVHDOVRREVHUYHWKHIXUWKHUSURGXFWGRFXPHQWDWLRQ :$*2*PE+ &R.* +DQVDVWU 0LQGHQ 3KRQH_)D[ (PDLOLQIRGH#ZDJRFRP_:HEZZZZDJRFRP 'R\RXKDYHDQ\TXHVWLRQVDERXWRXUSURGXFWV" :HDUHDOZD\VKDSS\WRWDNH\RXUFDOODW   {{{{3DJH‫܉ ܃‬ 'DWDVKHHW{_,WHPQXPEHU{‫܁܁܁܆܁܁܁܅܈܄܂܃܊܁܃‬ ZZZZDJRFRP 1RPLQDOYROWDJH ,,, ‫{ ܁܆܃‬9 5DWHGLPSXOVHYROWDJH ,,, ‫{ ܅‬N9 5DWHGYROWDJH ,,, ‫{ ܁܃܄‬9 5DWHGLPSXOVHYROWDJH ,,, ‫{ ܅‬N9 1RPLQDOYROWDJH ,, ‫{ ܁܄܇‬9 5DWHGVXUJHYROWDJH ,, ‫{ ܅‬N9 5DWHGFXUUHQW ‫{ ܇܂‬$ /HJHQG UDWLQJV ,,, Ε2YHUYROWDJHFDWHJRU\,,,3ROOXWLRQGHJUHH 5DWLQJVSHU8/ $SSURYDOVSHU 8/ 5DWHGYROWDJH8/ 8VH*URXS% ‫{ ܁܁܄‬9 5DWHGFXUUHQW8/ 8VH*URXS% ‫{ ܆܂‬$ 5DWHGYROWDJH8/ 8VH*URXS' ‫{ ܁܁܄‬9 5DWHGFXUUHQW8/ 8VH*URXS' ‫{ ܁܂‬$ &RQQHFWLRQGDWD &RQQHFWLRQSRLQWV ‫܅‬ 7RWDOQXPEHURISRWHQWLDOV ‫܅‬ 1XPEHURIFRQQHFWLRQW\SHV ‫܂‬ 1XPEHURIOHYHOV ‫܂‬ &RQQHFWLRQ &RQQHFWLRQWHFKQRORJ\ 3XVKLQ&$*(&/$03‹ $FWXDWLRQW\SH 3XVKEXWWRQ $FWXDWLRQGLUHFWLRQ 2SHUDWLRQSDUDOOHOWRFRQGXFWRUHQWU\ 6ROLGFRQGXFWRU f{PP{f{$:* )LQHVWUDQGHGFRQGXFWRU f{PP{f{$:* )LQHVWUDQGHGFRQGXFWRUZLWKLQVXODWHGIHUUXOH f{PP )LQHVWUDQGHGFRQGXFWRUZLWKXQLQVXODWHGIHUUXOH f{PP 6WULSOHQJWK f{PP{f{LQFKHV &RQGXFWRUFRQQHFWLRQGLUHFWLRQWR3&% ‫{ ܁‬ 3ROHQXPEHU ‫܅‬ 3K\VLFDOGDWD 3LQVSDFLQJ {PP{{LQFKHV :LGWK {PP{{LQFKHV 6XEMHFWWRFKDQJHV3OHDVHDOVRREVHUYHWKHIXUWKHUSURGXFWGRFXPHQWDWLRQ :$*2*PE+ &R.* +DQVDVWU 0LQGHQ 3KRQH_)D[ (PDLOLQIRGH#ZDJRFRP_:HEZZZZDJRFRP 'R\RXKDYHDQ\TXHVWLRQVDERXWRXUSURGXFWV" :HDUHDOZD\VKDSS\WRWDNH\RXUFDOODW   {{{{3DJH‫܉ ܄‬ 'DWDVKHHW{_,WHPQXPEHU{‫܁܁܁܆܁܁܁܅܈܄܂܃܊܁܃‬ ZZZZDJRFRP :LGWK {PP{{LQFKHV +HLJKW {PP{{LQFKHV 'HSWK {PP{{LQFKHV 6ROGHUSLQOHQJWK ‫{ ܇܄‬PP 6ROGHUSLQGLDPHWHU ‫{ ܅܂‬PP 'ULOOHGKROHGLDPHWHUZLWKWROHUDQFH ‫{ ܂܁ۿ {܇܂‬PP 0HFKDQLFDO'DWD 9DULDEOHFRGLQJ 1R 0DUNLQJW\SH 1XPEHUV $QWLURWDWLRQSURWHFWLRQ
2092-1374/000-5000
1. 物料型号:2092-1374/000-5000,是WAGO品牌的1-导体TH型女性连接器,带按压式按钮和Push-in CAGE CLAMP。
2. 器件简介:该连接器适用于所有导体类型,具有简单的推入式终止方式,无需特殊工具,可进行带电或不带电的接线。
3. 引脚分配:4极,引脚间距为5mm。
4. 参数特性: - 额定电压:250V(Il/3),320V(/2),630V(I/2) - 额定脉冲电压:4kV - 额定电流:16A - 导体额定电流:根据EN 60512-5-2标准,有0.8的降额因子。
5. 功能详解:包括通用连接、易于使用的推入式终止、集成测试端口、定制安装的焊针等。
6. 应用信息:适用于PCB连接,具有防误插保护,支持多种CAD/CAE数据格式,便于集成到开发环境中。
7. 封装信息: - 尺寸:宽度20mm,高度13.4mm,深度15.4mm - 焊针长度3.6mm,直径1.4mm - 材料:绝缘材料为Polyphthalamide (PPA GF),阻燃等级为UL94 VO
8. 环境要求:工作温度范围-60°C至+105°C,加工温度范围-35°C至+60°C。
9. 环境产品合规性:符合RoHS标准,无豁免。
10. 附加信息:提供了CAD/CAE数据支持,包括多种EDA软件格式,以及3D STEP目标和PCB组件库。
2092-1374/000-5000 价格&库存
很抱歉,暂时无法提供与“2092-1374/000-5000”相匹配的价格&库存,您可以联系我们找货
