2092-3374
2092-3374
    WAGO(万可电子)
    1-CONDUCTOR THT FEMALE HEADER; 1
2092-3374 数据手册
'DWDVKHHW{_,WHPQXPEHU{‫܅܈܄܄܃܊܁܃‬ FRQGXFWRU7+7IHPDOHFRQQHFWRUDQJOHGSXVKEXWWRQ3XVKLQ&$*( &/$03‹PP3LQVSDFLQJPPSROHPPµVROGHUSLQ PPOLJKWJUD\ ZZZZDJRFRP L 3LFWXUHGLƬHUVIURPWKHLWHP &RORU 6XEMHFWWRFKDQJHV3OHDVHDOVRREVHUYHWKHIXUWKHUSURGXFWGRFXPHQWDWLRQ :$*2*PE+ &R.* +DQVDVWU 0LQGHQ 3KRQH_)D[ (PDLOLQIRGH#ZDJRFRP_:HEZZZZDJRFRP 'R\RXKDYHDQ\TXHVWLRQVDERXWRXUSURGXFWV" :HDUHDOZD\VKDSS\WRWDNH\RXUFDOODW   {{{{3DJH‫܊ ܂‬ 'DWDVKHHW{_,WHPQXPEHU{‫܅܈܄܄܃܊܁܃‬ ZZZZDJRFRP 'LPHQVLRQVLQ{PP /  SROHQRs [SLQVSDFLQJPP $ PP7+7VROGHUSLQ $ PP7+5VROGHUSLQ ,WHPGHVFULSWLRQ 8QLYHUVDOFRQQHFWLRQIRUDOOFRQGXFWRUW\SHV 6LPSOHSXVKLQWHUPLQDWLRQRIVROLGDQGIHUUXOHGFRQGXFWRUV (DV\WRXVHGHVLJQGRHVQRWUHTXLUHVSHFLDOWRROV $ELOLW\WRZLUHZKLOHPDWHGRUXQPDWHG ,QWHJUDWHGWHVWSRUWVIRUWHVWLQJSDUDOOHOWRFRQGXFWRUHQWU\ &XVWRPLQVWDOOHGVROGHUSLQV 'DWD 1RWHV 6DIHW\LQIRUPDWLRQ 7KHSLFR0$;‹3OXJJDEOH&RQQHFWLRQ6\VWHPLQFOXGHVFRQQHFWRUV ZLWKRXWEUHDNLQJFDSDFLW\LQDFFRUGDQFHZLWK',1(1:KHQ XVHGDVLQWHQGHGWKHVHFRQQHFWRUVPXVWQRWEHFRQQHFWHG GLVFRQQHFWHGZKHQOLYHRUXQGHUORDG7KHFLUFXLWGHVLJQVKRXOG HQVXUHKHDGHUSLQVZKLFKFDQEHWRXFKHGDUHQRWOLYHZKHQ XQPDWHG (OHFWULFDOGDWD 6XEMHFWWRFKDQJHV3OHDVHDOVRREVHUYHWKHIXUWKHUSURGXFWGRFXPHQWDWLRQ :$*2*PE+ &R.* +DQVDVWU 0LQGHQ 3KRQH_)D[ (PDLOLQIRGH#ZDJRFRP_:HEZZZZDJRFRP 'R\RXKDYHDQ\TXHVWLRQVDERXWRXUSURGXFWV" :HDUHDOZD\VKDSS\WRWDNH\RXUFDOODW   {{{{3DJH‫܊ ܃‬ 'DWDVKHHW{_,WHPQXPEHU{‫܅܈܄܄܃܊܁܃‬ ZZZZDJRFRP 5DWLQJVSHU,(&(1 5DWLQJVSHU ,(&(1 1RPLQDOYROWDJH ,,, ‫{ ܁܁܅‬9 5DWHGLPSXOVHYROWDJH ,,, ‫{ ܇‬N9 5DWHGYROWDJH ,,, ‫{ ܁܄܇‬9 5DWHGLPSXOVHYROWDJH ,,, ‫{ ܇‬N9 1RPLQDOYROWDJH ,, ‫{ ܁܁܁܂‬9 5DWHGVXUJHYROWDJH ,, ‫{ ܇‬N9 5DWHGFXUUHQW ‫{ ܇܂‬$ /HJHQG UDWLQJV ,,, Ε2YHUYROWDJHFDWHJRU\,,,3ROOXWLRQGHJUHH 5DWLQJVSHU8/ $SSURYDOVSHU 8/ 5DWHGYROWDJH8/ 8VH*URXS% ‫{ ܁܁܄‬9 5DWHGFXUUHQW8/ 8VH*URXS% ‫{ ܆܂‬$ 5DWHGYROWDJH8/ 8VH*URXS' ‫{ ܁܁܄‬9 5DWHGFXUUHQW8/ 8VH*URXS' ‫{ ܁܂‬$ &RQQHFWLRQGDWD &RQQHFWLRQSRLQWV ‫܅‬ 7RWDOQXPEHURISRWHQWLDOV ‫܅‬ 1XPEHURIFRQQHFWLRQW\SHV ‫܂‬ 1XPEHURIOHYHOV ‫܂‬ &RQQHFWLRQ &RQQHFWLRQWHFKQRORJ\ 3XVKLQ&$*(&/$03‹ $FWXDWLRQW\SH 3XVKEXWWRQ $FWXDWLRQGLUHFWLRQ 2SHUDWLRQSDUDOOHOWRFRQGXFWRUHQWU\ 6ROLGFRQGXFWRU f{PP{f{$:* )LQHVWUDQGHGFRQGXFWRU f{PP{f{$:* )LQHVWUDQGHGFRQGXFWRUZLWKLQVXODWHGIHUUXOH f{PP )LQHVWUDQGHGFRQGXFWRUZLWKXQLQVXODWHGIHUUXOH f{PP 6WULSOHQJWK f{PP{f{LQFKHV &RQGXFWRUFRQQHFWLRQGLUHFWLRQWR3&% ‫{ ܁‬ 3ROHQXPEHU ‫܅‬ 6XEMHFWWRFKDQJHV3OHDVHDOVRREVHUYHWKHIXUWKHUSURGXFWGRFXPHQWDWLRQ :$*2*PE+ &R.* +DQVDVWU 0LQGHQ 3KRQH_)D[ (PDLOLQIRGH#ZDJRFRP_:HEZZZZDJRFRP 'R\RXKDYHDQ\TXHVWLRQVDERXWRXUSURGXFWV" :HDUHDOZD\VKDSS\WRWDNH\RXUFDOODW   {{{{3DJH‫܊ ܄‬ 'DWDVKHHW{_,WHPQXPEHU{‫܅܈܄܄܃܊܁܃‬ ZZZZDJRFRP 3K\VLFDOGDWD 3LQVSDFLQJ {PP{{LQFKHV :LGWK {PP{{LQFKHV +HLJKW {PP{{LQFKHV 'HSWK {PP{{LQFKHV 6ROGHUSLQOHQJWK ‫{ ܇܄‬PP 6ROGHUSLQGLDPHWHU ‫{ ܅܂‬PP 'ULOOHGKROHGLDPHWHUZLWKWROHUDQFH ‫{ ܂܁ۿ {܇܂‬PP 0HFKDQLFDO'DWD 9DULDEOHFRGLQJ 1R $QWLURWDWLRQSURWHFWLRQ
2092-3374
物料型号:WAGO 2092-3374
器件简介: - 这是一款1路THT(Through-Hole Technology)有角度的女头连接器,具有按钮式推入式笼夹固定方式。 - 它适用于所有导线类型,实现了简单、推入式终止实心和套管导线。 - 设计易于使用,不需要特殊工具,可以带或不带配对器进行配线。 - 集成测试端口,便于并行于导线进入处进行测试。
引脚分配: - 引脚间距为7.5mm,共有4个引脚。
参数特性: - 额定电压为400V,额定冲击电压为6kV。 - 额定电流为16A,适用于IEC/EN和UL标准。
功能详解: - 该连接器允许在连接状态下进行测试,并且支持定制安装的焊针。 - 它还具有防旋转保护和直插式连接。
应用信息: - 适用于PCB连接,可以用于各种环境要求,包括温度范围从-60°C到+100°C。
封装信息: - 尺寸数据包括宽度27.5mm,高度13.4mm,深度16.2mm。 - 焊针长度3.6mm,直径1.4mm。 - 材料包括聚邻苯二甲酰胺(PPA GF)绝缘材料和镀铬镍弹簧钢制的夹持弹簧。
2092-3374 价格&库存
很抱歉,暂时无法提供与“2092-3374”相匹配的价格&库存,您可以联系我们找货
