262-153
262-153
    WAGO(万可电子)
    2-CONDUCTOR TERMINAL STRIP; 3-PO
262-153 数据手册
'DWDVKHHW{_,WHPQXPEHU{‫܄܆܂܃܇܃‬ FRQGXFWRUWHUPLQDOVWULSZLWKRXWSXVKEXWWRQVZLWKVQDSLQPRXQWLQJ IHHWSROHIRUSODWHWKLFNQHVVPP)L[LQJKROHPPµPP &$*(&/$03‹PPJUD\ ZZZZDJRFRP L 3LFWXUHGLƬHUVIURPWKHLWHP &RORU 'DWD (OHFWULFDOGDWD 5DWLQJVSHU,(&(1 1RPLQDOYROWDJH ,,, ‫{ ܁܄܇‬9 5DWHGLPSXOVHYROWDJH ,,, ‫{ ܉‬N9 5DWHGFXUUHQW ‫{ ܅܃‬$ /HJHQG UDWLQJV ,,, Ε2YHUYROWDJHFDWHJRU\,,,3ROOXWLRQGHJUHH 5DWLQJVSHU8/ $SSURYDOVSHU 8/ 5DWHGYROWDJH8/ 8VH*URXS% ‫{ ܁܁܄‬9 5DWHGFXUUHQW8/ 8VH*URXS% ‫{ ܁܃‬$ 5DWHGYROWDJH8/ 8VH*URXS& ‫{ ܁܁܄‬9 5DWHGFXUUHQW8/ 8VH*URXS& ‫{ ܁܃‬$ 5DWHGYROWDJH8/ 8VH*URXS' ‫{ ܁܁܄‬9 5DWHGFXUUHQW8/ 8VH*URXS' ‫{ ܁܂‬$ 6XEMHFWWRFKDQJHV3OHDVHDOVRREVHUYHWKHIXUWKHUSURGXFWGRFXPHQWDWLRQ :$*2*PE+ &R.* +DQVDVWU 0LQGHQ 3KRQH_)D[ (PDLOLQIRGH#ZDJRFRP_:HEZZZZDJRFRP 'R\RXKDYHDQ\TXHVWLRQVDERXWRXUSURGXFWV" :HDUHDOZD\VKDSS\WRWDNH\RXUFDOODW   {{{{3DJH‫܂܂ ܂‬ 'DWDVKHHW{_,WHPQXPEHU{‫܄܆܂܃܇܃‬ ZZZZDJRFRP 5DWHGFXUUHQW8/ 8VH*URXS' ‫{ ܁܂‬$ 5DWLQJVSHU&6$ $SSURYDOVSHU &6$1R 5DWHGYROWDJH&6$ 8VH*URXS% ‫{ ܁܁܇‬9 5DWHGFXUUHQW&6$ 8VH*URXS% ‫{ ܆‬$ 5DWHGYROWDJH&6$ 8VH*URXS& ‫{ ܁܁܄‬9 5DWHGFXUUHQW&6$ 8VH*URXS& ‫{ ܆܃‬$ 5DWHGYROWDJH&6$ 8VH*URXS' ‫{ ܁܁܇‬9 5DWHGFXUUHQW&6$ 8VH*URXS' ‫{ ܆‬$ &RQQHFWLRQGDWD &RQQHFWLRQSRLQWV ‫܇‬ 7RWDOQXPEHURISRWHQWLDOV ‫܄‬ 1XPEHURIOHYHOV ‫܂‬ &RQQHFWLRQ &RQQHFWLRQWHFKQRORJ\ &$*(&/$03‹ $FWXDWLRQW\SH 2SHUDWLQJWRRO &RQQHFWDEOHFRQGXFWRUPDWHULDOV &RSSHU 6ROLGFRQGXFWRU f{PP{f{$:* )LQHVWUDQGHGFRQGXFWRU f{PP{f{$:* 6WULSOHQJWK f{PP{f{LQFKHV 3ROHQXPEHU ‫܄‬ :LULQJGLUHFWLRQ 6LGHHQWU\ZLULQJ 3K\VLFDOGDWD :LGWK {PP{{LQFKHV +HLJKWIURPWKHVXUIDFH {PP{{LQFKHV 'HSWK {PP{{LQFKHV 0RGXOHZLGWK {PP{{LQFKHV 0HFKDQLFDO'DWD 'HVLJQ KRUL]RQWDOW\SH 0RXQWLQJW\SH 6QDSLQIRRW 0DUNLQJOHYHO 6LGHPDUNLQJ 6XEMHFWWRFKDQJHV3OHDVHDOVRREVHUYHWKHIXUWKHUSURGXFWGRFXPHQWDWLRQ :$*2*PE+ &R.* +DQVDVWU 0LQGHQ 3KRQH_)D[ (PDLOLQIRGH#ZDJRFRP_:HEZZZZDJRFRP 'R\RXKDYHDQ\TXHVWLRQVDERXWRXUSURGXFWV" :HDUHDOZD\VKDSS\WRWDNH\RXUFDOODW   {{{{3DJH‫܂܂ ܃‬ 'DWDVKHHW{_,WHPQXPEHU{‫܄܆܂܃܇܃‬ ZZZZDJRFRP 0DWHULDOGDWD 1RWH PDWHULDOGDWD ,QIRUPDWLRQRQPDWHULDOVSHFLƮFDWLRQVFDQEHIRXQGKHUH &RORU JUD\ 0DWHULDOJURXS , ,QVXODWLRQPDWHULDO 3RO\DPLGH 3$ )ODPPDELOLW\FODVVSHU8/ 9 )LUHORDG ‫{ ܄܈܃܁‬0- +DORJHQIUHH
262-153
物料型号:262-153
器件简介:这是一个2导体的接线端子排,没有按钮,带有卡扣式安装脚和3极,适用于0.6-1.2mm的板材厚度,固定孔径为3.5mm,额定电流为24A。
引脚分配:共有6个连接点,3个总电位,1个层次。
参数特性: - 额定电压(IEC/EN):630V - 额定冲击电压(IEC/EN):8kV - 额定电流(IEC/EN):24A - 额定电压(UL):300V(使用组B、C、D) - 额定电流(UL):20A(使用组B、C)和5A(使用组D) - 接线技术:CAGE CLAMP笼式夹紧 - 可接导体材料:铜 - 固体导体尺寸:0.08至4mm²/28至12AWG - 细丝导体尺寸:0.08至4mm²/28至12AWG - 条长度:9至10mm/0.35至0.39英寸 - 极数:3 - 接线方向:侧面进线
功能详解:该端子排采用侧面进线方式,具有卡扣式安装脚,适用于水平安装,侧面标记。
应用信息:适用于需要接线的电气控制系统,如自动化设备、电源分配系统等。
封装信息: - 宽度:24mm/0.945英寸 - 从表面到高度:23.1mm/0.909英寸 - 深度:33.5mm/1.319英寸 - 模块宽度:7mm/0.276英寸
262-153 价格&库存
很抱歉,暂时无法提供与“262-153”相匹配的价格&库存,您可以联系我们找货
