750-457
750-457
    WAGO(万可电子)
    输入模块 DIN 轨道 -10 ~ 10VDC
750-457 数据手册
'DWDVKHHW{_,WHPQXPEHU{‫܈܆܅܁܆܈‬ FKDQQHODQDORJLQSXWŽ9'&6LQJOHHQGHG ZZZZDJRFRP &RORU 6XEMHFWWRFKDQJHV3OHDVHDOVRREVHUYHWKHIXUWKHUSURGXFWGRFXPHQWDWLRQ :$*2*PE+ &R.* +DQVDVWU 0LQGHQ 3KRQH_)D[ (PDLOLQIRGH#ZDJRFRP_:HEZZZZDJRFRP 'R\RXKDYHDQ\TXHVWLRQVDERXWRXUSURGXFWV" :HDUHDOZD\VKDSS\WRWDNH\RXUFDOODW   {{{{3DJH‫܄܂ ܂‬ 'DWDVKHHW{_,WHPQXPEHU{‫܈܆܅܁܆܈‬ ZZZZDJRFRP ,WHPGHVFULSWLRQ 7KLVDQDORJLQSXWPRGXOHSURFHVVHVVWDQGDUGŽ9VLJQDOV 7KHLQSXWVLJQDOLVHOHFWULFDOO\LVRODWHGDQGLVWUDQVPLWWHGZLWKDUHVROXWLRQRIELWV 7KHLQWHUQDOV\VWHPVXSSO\SRZHUVWKHPRGXOH 7KHLQSXWFKDQQHOVRIWKHPRGXOHKDYHDFRPPRQJURXQGSRWHQWLDO 'DWD 7HFKQLFDOGDWD 1XPEHURIDQDORJLQSXWV ‫܅‬ 7RWDOQXPEHURIFKDQQHOV PRGXOH ‫܅‬ 6LJQDOW\SH 9ROWDJH 6LJQDOW\SH YROWDJH f{9'& 6XEMHFWWRFKDQJHV3OHDVHDOVRREVHUYHWKHIXUWKHUSURGXFWGRFXPHQWDWLRQ :$*2*PE+ &R.* +DQVDVWU 0LQGHQ 3KRQH_)D[ (PDLOLQIRGH#ZDJRFRP_:HEZZZZDJRFRP 'R\RXKDYHDQ\TXHVWLRQVDERXWRXUSURGXFWV" :HDUHDOZD\VKDSS\WRWDNH\RXUFDOODW   {{{{3DJH‫܄܂ ܃‬ 'DWDVKHHW{_,WHPQXPEHU{‫܈܆܅܁܆܈‬ ZZZZDJRFRP 6LJQDOW\SH YROWDJH f{9'& 6HQVRUFRQQHFWLRQ [ ZLUH ,QSXWYROWDJH PD[ Ž{9 6LJQDOFKDUDFWHULVWLFV 6LQJOHHQGHG 5HVROXWLRQ>ELW@ ‫{ ܃܂‬ELWV 'DWDZLGWK [ELWGDWD[ELWFRQWUROVWDWXV RSWLRQDO ,QWHUQDOUHVLVWDQFH ‫{ ܁܁܂‬NƳ &RQYHUVLRQWLPH W\S ‫{ ܁܂‬PV 0HDVXUHPHQWHUURU UHIHUHQFHWHPSHUDWXUH ‫&{ ܆܃‬ 0HDVXUHPHQWHUURUGHYLDWLRQ PD[ IURPWKHXSSHUUDQJHYDOXH ‫۽{ ܂܁‬ 7HPSHUDWXUHHUURU PD[ RIWKHXSSHUUDQJHYDOXH ‫{ ܂܁܁‬. 6XSSO\YROWDJH V\VWHP {9'&{YLDGDWDFRQWDFWV &XUUHQWFRQVXPSWLRQ 9V\VWHPVXSSO\ ‫{ ܆܇‬P$ 6XSSO\YROWDJH ƮHOG 9'& f YLDSRZHUMXPSHUFRQWDFWV SRZHUVXSSO\YLD EODGHFRQWDFWWUDQVPLVVLRQ VXSSO\YROWDJHƮHOGVLGHRQO\ YLDVSULQJ FRQWDFW ,VRODWLRQ {9V\VWHPƮHOG ,QGLFDWRUV /(' $' UHG(UURU$,f$, 1XPEHURILQFRPLQJSRZHUMXPSHUFRQWDFWV ‫܃‬ 1XPEHURIRXWJRLQJSRZHUMXPSHUFRQWDFWV ‫܃‬ &XUUHQWFDUU\LQJFDSDFLW\ SRZHUMXPSHUFRQWDFWV ‫{ ܁܂‬$ &RQQHFWLRQGDWD &RQQHFWLRQWHFKQRORJ\LQSXWVRXWSXWV [&$*(&/$03‹ &RQQHFWLRQW\SH ,QSXWV2XWSXWV 6ROLGFRQGXFWRU f{PP{f{$:* )LQHVWUDQGHGFRQGXFWRU f{PP{f{$:* 6WULSOHQJWK f{PP{f{LQFKHV 3K\VLFDOGDWD :LGWK {PP{{LQFKHV +HLJKW {PP{{LQFKHV 'HSWK {PP{{LQFKHV 'HSWKIURPXSSHUHGJHRI',1UDLO {PP{{LQFKHV 0HFKDQLFDO'DWD 0RXQWLQJW\SH ',1UDLO 6XEMHFWWRFKDQJHV3OHDVHDOVRREVHUYHWKHIXUWKHUSURGXFWGRFXPHQWDWLRQ :$*2*PE+ &R.* +DQVDVWU 0LQGHQ 3KRQH_)D[ (PDLOLQIRGH#ZDJRFRP_:HEZZZZDJRFRP 'R\RXKDYHDQ\TXHVWLRQVDERXWRXUSURGXFWV" :HDUHDOZD\VKDSS\WRWDNH\RXUFDOODW   {{{{3DJH‫܄܂ ܄‬ 'DWDVKHHW{_,WHPQXPEHU{‫܈܆܅܁܆܈‬ ZZZZDJRFRP 0DWHULDOGDWD &RORU OLJKWJUD\ +RXVLQJPDWHULDO 3RO\FDUERQDWHSRO\DPLGH )LUHORDG ‫{ ܂܆܆܂‬0- :HLJKW ‫{ ܈܁܆‬J &RQIRUPLW\PDUNLQJ &( (QYLURQPHQWDOUHTXLUHPHQWV $PELHQWWHPSHUDWXUH RSHUDWLRQ f& $PELHQWWHPSHUDWXUH VWRUDJH f& 3URWHFWLRQW\SH ,3 3ROOXWLRQGHJUHH SHU,(& 2SHUDWLQJDOWLWXGH f{PfIW 0RXQWLQJSRVLWLRQ KRUL]RQWDO VWDQGLQJO\LQJ YHUWLFDO 5HODWLYHKXPLGLW\ ZLWKRXWFRQGHQVDWLRQ ‫۽{ ܆܊‬ 9LEUDWLRQUHVLVWDQFH JSHU,(& 6KRFNUHVLVWDQFH JSHU,(& (0&LPPXQLW\WRLQWHUIHUHQFH SHU(1PDULQHDSSOLFDWLRQV (0&HPLVVLRQRILQWHUIHUHQFH SHU(1PDULQHDSSOLFDWLRQV ([SRVXUHWRSROOXWDQWV 3HU,(&DQG,(& 3HUPLVVLEOH+‫ ܃‬6FRQWDPLQDQWFRQFHQWUDWLRQDWDUHODWLYHKXPLGLW\‫܆܈‬ ‫{ ܁܂‬SSP ‫۽‬ 3HUPLVVLEOH62‫ ܃‬FRQWDPLQDQWFRQFHQWUDWLRQDWDUHODWLYHKXPLGLW\‫܆܈‬ ‫{ ܆܃‬SSP ‫۽‬ &RPPHUFLDOGDWD 3URGXFW*URXS  ,26\VWHP H&O#VV ‫܂܁܇܃܅܃܈܃‬ H&O#VV ‫܂܁܇܃܅܃܈܃‬ (7,0 (& (7,0 (& 5HFXSHO7\SH 38 638 {SFV 3DFNDJLQJW\SH ER[ &RXQWU\RIRULJLQ '( *7,1 ‫܆܈܄܆܉܅܅܆܅܆܅܁܅‬ &XVWRPVWDULƬQXPEHU ‫܁܊܊܊܊܁܊܉܄܆܉‬ 6XEMHFWWRFKDQJHV3OHDVHDOVRREVHUYHWKHIXUWKHUSURGXFWGRFXPHQWDWLRQ :$*2*PE+ &R.* +DQVDVWU 0LQGHQ 3KRQH_)D[ (PDLOLQIRGH#ZDJRFRP_:HEZZZZDJRFRP 'R\RXKDYHDQ\TXHVWLRQVDERXWRXUSURGXFWV" :HDUHDOZD\VKDSS\WRWDNH\RXUFDOODW   {{{{3DJH‫܄܂ ܅‬ 'DWDVKHHW{_,WHPQXPEHU{‫܈܆܅܁܆܈‬ ZZZZDJRFRP &XVWRPVWDULƬQXPEHU ‫܁܊܊܊܊܁܊܉܄܆܉‬ (QYLURQPHQWDO3URGXFW&RPSOLDQFH &$61R ‫܃܇܉܄܁܄܂‬ ‫܉܇܄܈܂܄܂‬ ‫܂܃܊܊܄܅܈‬ 5($&+&DQGLGDWH/LVW6XEVWDQFH 'LERURQWULR[LGH /HDG /HDGPRQR[LGH 5R+6&RPSOLDQFH6WDWXV &RPSOLDQW:LWK([HPSWLRQ 5R+6([HPSWLRQ  F  D  F ,  F ,, 6&,3QRWLƮFDWLRQQXPEHU $XVWULD EDGIHHIEE 6&,3QRWLƮFDWLRQQXPEHU %HOJLXP FGHDIDEFH 6&,3QRWLƮFDWLRQQXPEHU %XOJDULD EHGFFHGƬEF 6&,3QRWLƮFDWLRQQXPEHU &]HFK5HSXEOLF EEEEDGDDD 6&,3QRWLƮFDWLRQQXPEHU 'HQPDUN FGHFIDDHG 6&,3QRWLƮFDWLRQQXPEHU )LQODQG GGDDDIHIH 6&,3QRWLƮFDWLRQQXPEHU )UDQFH DFDFFEGGE 6&,3QRWLƮFDWLRQQXPEHU *HUPDQ\ FGEHIGFEDDIDII 6&,3QRWLƮFDWLRQQXPEHU +XQJDU\ FDEDDEEDGGGD 6&,3QRWLƮFDWLRQQXPEHU ,WDO\ DHDDIDFFIFFFEDD 6&,3QRWLƮFDWLRQQXPEHU 1HWKHUODQGV DGEFIFFFID 6&,3QRWLƮFDWLRQQXPEHU 3RODQG FFEGHHFEHHEGDGIGHGG 6&,3QRWLƮFDWLRQQXPEHU 5RPDQLD FGEHFEEGDF 6&,3QRWLƮFDWLRQQXPEHU 6ZHGHQ DGDIEFHDIDGIG $SSURYDOV&HUWLƮFDWHV *HQHUDODSSURYDOV /RJR &HUWLƮFDWH QDPH $SSURYDO $GGLWLRQDO$SSURYDO7H[W ($& %UMDQVNHU=HUWLƮ]LHUXQJVVWHOOH 737& ($&58& '($0 % ‫܊܂‬ .& 1DWLRQDO5DGLR5HVHDUFK$JHQF\ $UWLFOH&ODXVH 06,3 5(0: $,0 8/ 8/ 6XEMHFWWRFKDQJHV3OHDVHDOVRREVHUYHWKHIXUWKHUSURGXFWGRFXPHQWDWLRQ :$*2*PE+ &R.* +DQVDVWU 0LQGHQ 3KRQH_)D[ (PDLOLQIRGH#ZDJRFRP_:HEZZZZDJRFRP ( 'R\RXKDYHDQ\TXHVWLRQVDERXWRXUSURGXFWV" :HDUHDOZD\VKDSS\WRWDNH\RXUFDOODW   {{{{3DJH‫܄܂ ܆‬ 'DWDVKHHW{_,WHPQXPEHU{‫܈܆܅܁܆܈‬ ZZZZDJRFRP 8/ 8/,QWHUQDWLRQDO1HWKHUODQGV%9 25',1$5
750-457
物料型号:750-457
器件简介:这是一个4通道模拟输入模块,用于处理标准的+10V信号。输入信号在电气上是隔离的,并且以12位的分辨率传输。
引脚分配:模块具有共同的接地电位,并且有电源跳线接触点和数据接触点。具体分配如下: - AI1, AI2, AI3, AI4:模拟输入1到4 - Common:公共接地 - 24V:24V电源(270pF电容滤波) - GND:地 - Error:错误指示
参数特性: - 模拟输入数量:4 - 信号类型:-10V至+10V DC - 传感器连接:4x(2线) - 输入电压最大值:±40V - 分辨率:12位 - 数据宽度:4x 16位数据;4x 8位控制/状态(可选) - 内部电阻:100kΩ - 转换时间(典型):10ms - 测量误差(参考温度25°C):最大值0.1% - 温度误差(最大值):0.01%/K - 系统供电电压:5V DC,通过数据接触点 - 电流消耗(5V系统供电):65mA - 现场供电电压:24V DC(-25...+30%),通过电源跳线接触点(仅通过刀片接触点供电)
功能详解:模块内部系统供电,输入通道具有共同的接地电位。输入信号电气隔离,确保安全性和稳定性。
应用信息:适用于需要高精度模拟信号输入的自动化控制系统。
封装信息: - 宽度:12mm - 高度:100mm - 深度:69.8mm - 材料:聚碳酸酯;聚酰胺6.6 - 颜色:浅灰色 - 重量:50.7g - 符合标记:CE
环境要求:包括工作温度、存储温度、防护等级、污染等级、操作高度、安装位置、相对湿度、振动和冲击抵抗等。
商业数据:包括产品组、eCl@ss编号、ETIM编号、回收类型、包装类型、原产国和GTIN。
合规性:包括REACH候选清单物质、RoHS合规性状态和SCIP通知编号。
认证/证书:包括通用认证、国家无线电研究机构认证和针对海洋应用的认证。
可选配件:包括安装轨、标记配件和屏蔽压接鞍。
系统外壳:提供不同尺寸和材料的IP65防护等级外壳。
CAD/CAE数据:提供2D/3D模型和设备文件,以便于设计和集成。
750-457 价格&库存
很抱歉,暂时无法提供与“750-457”相匹配的价格&库存,您可以联系我们找货
  • 1+2605.800511+337.54230
  • 1+6967.830181+902.57770
    库存:1
