750-624
750-624
    WAGO(万可电子)
    COMMUNICATIONS MODULE 0-24V
750-624 数据手册
'DWDVKHHW{_,WHPQXPEHU{‫܅܃܇܁܆܈‬ )LOWHUPRGXOHIRUƮHOGVLGHSRZHUVXSSO\ VXUJH 9'& ZZZZDJRFRP &RORU 6XEMHFWWRFKDQJHV3OHDVHDOVRREVHUYHWKHIXUWKHUSURGXFWGRFXPHQWDWLRQ :$*2*PE+ &R.* +DQVDVWU 0LQGHQ 3KRQH_)D[ (PDLOLQIRGH#ZDJRFRP_:HEZZZZDJRFRP 'R\RXKDYHDQ\TXHVWLRQVDERXWRXUSURGXFWV" :HDUHDOZD\VKDSS\WRWDNH\RXUFDOODW   {{{{3DJH‫܄܂ ܂‬ 'DWDVKHHW{_,WHPQXPEHU{‫܅܃܇܁܆܈‬ ZZZZDJRFRP ,WHPGHVFULSWLRQ 7KH:$*2,26\VWHPFDQDOVREHXVHGLQPDULQHDSSOLFDWLRQVDQGRQVKRUHRƬVKRUHLQVWDOODWLRQV HJSODWIRUPVORDGLQJIDFLOLWLHV 7KLVLV SRVVLEOHYLDFHUWLƮFDWLRQXQGHUWKHVWDQGDUGVRIOHDGLQJDJHQFLHVVXFKDV*HUPDQLVFKHU/OR\GDQG/OR\G V5HJLVWHU7KLVƮOWHUPRGXOHHQVXUHV SURSHU FHUWLƮHG V\VWHPRSHUDWLRQ7KHPRGXOHSURWHFWVDJDLQVWKLJKHQHUJ\GLVWXUEDQFHVRQ'&VXSSO\OLQHVGXHWRVZLWFKLQJRYHUYROWDJHV FDXVHGE\LQGXFWLYHORDGV,WFRQWDLQVDWUDQVLHQWSURWHFWLRQIRUƮHOGVXSSO\ 'DWD 7HFKQLFDOGDWD 6LJQDOW\SH 9ROWDJH 6LJQDOW\SH YROWDJH {9'& 6XSSO\YROWDJH V\VWHP {9'&{YLDGDWDFRQWDFWV 6XSSO\YROWDJH ƮHOG 9'& f YLDSRZHUMXPSHUFRQWDFWV SRZHUVXSSO\YLD EODGHFRQWDFWWUDQVPLVVLRQ VXSSO\YROWDJHƮHOGVLGHRQO\ YLDVSULQJ FRQWDFW ,QGLFDWRUV /(' & JUHHQRSHUDWLQJYROWDJHVWDWXVSRZHUMXPSHUFRQWDFWV 6XEMHFWWRFKDQJHV3OHDVHDOVRREVHUYHWKHIXUWKHUSURGXFWGRFXPHQWDWLRQ :$*2*PE+ &R.* +DQVDVWU 0LQGHQ 3KRQH_)D[ (PDLOLQIRGH#ZDJRFRP_:HEZZZZDJRFRP 'R\RXKDYHDQ\TXHVWLRQVDERXWRXUSURGXFWV" :HDUHDOZD\VKDSS\WRWDNH\RXUFDOODW   {{{{3DJH‫܄܂ ܃‬ 'DWDVKHHW{_,WHPQXPEHU{‫܅܃܇܁܆܈‬ ZZZZDJRFRP ,QGLFDWRUV /(' & JUHHQRSHUDWLQJYROWDJHVWDWXVSRZHUMXPSHUFRQWDFWV 1XPEHURILQFRPLQJSRZHUMXPSHUFRQWDFWV ‫܄‬ 1XPEHURIRXWJRLQJSRZHUMXPSHUFRQWDFWV ‫܄‬ &XUUHQWFDUU\LQJFDSDFLW\ SRZHUMXPSHUFRQWDFWV ‫{ ܁܂‬$ &RQQHFWLRQGDWD &RQQHFWLRQWHFKQRORJ\ƮHOGVXSSO\ [&$*(&/$03‹ &RQQHFWLRQW\SH )LHOGVXSSO\ 6ROLGFRQGXFWRU f{PP{f{$:* )LQHVWUDQGHGFRQGXFWRU f{PP{f{$:* 6WULSOHQJWK f{PP{f{LQFKHV 3K\VLFDOGDWD :LGWK {PP{{LQFKHV +HLJKW {PP{{LQFKHV 'HSWK {PP{{LQFKHV 'HSWKIURPXSSHUHGJHRI',1UDLO {PP{{LQFKHV 0HFKDQLFDO'DWD 0RXQWLQJW\SH ',1UDLO 0DWHULDOGDWD &RORU OLJKWJUD\ +RXVLQJPDWHULDO 3RO\FDUERQDWHSRO\DPLGH )LUHORDG ‫{ ܊܁܁܂‬0- :HLJKW ‫{ ܈܇܅‬J &RQIRUPLW\PDUNLQJ &( (QYLURQPHQWDOUHTXLUHPHQWV $PELHQWWHPSHUDWXUH RSHUDWLRQ f& $PELHQWWHPSHUDWXUH VWRUDJH f& 3URWHFWLRQW\SH ,3 3ROOXWLRQGHJUHH SHU,(& 2SHUDWLQJDOWLWXGH f{PfIW 0RXQWLQJSRVLWLRQ KRUL]RQWDO VWDQGLQJO\LQJ YHUWLFDO 5HODWLYHKXPLGLW\ ZLWKRXWFRQGHQVDWLRQ ‫۽{ ܆܊‬ 9LEUDWLRQUHVLVWDQFH JSHU,(& 6XEMHFWWRFKDQJHV3OHDVHDOVRREVHUYHWKHIXUWKHUSURGXFWGRFXPHQWDWLRQ :$*2*PE+ &R.* +DQVDVWU 0LQGHQ 3KRQH_)D[ (PDLOLQIRGH#ZDJRFRP_:HEZZZZDJRFRP 'R\RXKDYHDQ\TXHVWLRQVDERXWRXUSURGXFWV" :HDUHDOZD\VKDSS\WRWDNH\RXUFDOODW   {{{{3DJH‫܄܂ ܄‬ 'DWDVKHHW{_,WHPQXPEHU{‫܅܃܇܁܆܈‬ ZZZZDJRFRP 9LEUDWLRQUHVLVWDQFH JSHU,(& 6KRFNUHVLVWDQFH JSHU,(& (0&LPPXQLW\WRLQWHUIHUHQFH SHU(1PDULQHDSSOLFDWLRQV (0&HPLVVLRQRILQWHUIHUHQFH SHU(1PDULQHDSSOLFDWLRQV ([SRVXUHWRSROOXWDQWV 3HU,(&DQG,(& 3HUPLVVLEOH+‫ ܃‬6FRQWDPLQDQWFRQFHQWUDWLRQDWDUHODWLYHKXPLGLW\‫܆܈‬ ‫{ ܁܂‬SSP ‫۽‬ 3HUPLVVLEOH62‫ ܃‬FRQWDPLQDQWFRQFHQWUDWLRQDWDUHODWLYHKXPLGLW\‫܆܈‬ ‫{ ܆܃‬SSP ‫۽‬ &RPPHUFLDOGDWD 3URGXFW*URXS  ,26\VWHP H&O#VV ‫܁܂܇܃܅܃܈܃‬ H&O#VV ‫܁܂܇܃܅܃܈܃‬ (7,0 (& (7,0 (& 5HFXSHO7\SH 38 638 {SFV 3DFNDJLQJW\SH ER[ &RXQWU\RIRULJLQ '( *7,1 ‫܇܅܄܇܆܅܂܃܉܁܆܁܅‬ &XVWRPVWDULƬQXPEHU ‫܁܊܉܂܊܁܊܉܄܆܉‬ (QYLURQPHQWDO3URGXFW&RPSOLDQFH &$61R ‫܁܂܆܁܆܆܆܃‬ ‫܂܃܊܊܄܅܈‬ 5($&+&DQGLGDWH/LVW6XEVWDQFH 0HWK\OF\FORKH[DQHGLFDUER[\OLFDQK\GULGH /HDG 5R+6&RPSOLDQFH6WDWXV &RPSOLDQW:LWK([HPSWLRQ 5R+6([HPSWLRQ  D  F ,  F ,, 6&,3QRWLƮFDWLRQQXPEHU $XVWULD HƬEDGDFIHIGHGDFE 6&,3QRWLƮFDWLRQQXPEHU %HOJLXP IHFHEFEGGF 6&,3QRWLƮFDWLRQQXPEHU %XOJDULD IIGEGFDH 6&,3QRWLƮFDWLRQQXPEHU &]HFK5HSXEOLF GDIGHDGDDEE 6&,3QRWLƮFDWLRQQXPEHU 'HQPDUN DGFEDHFHHFDEE 6&,3QRWLƮFDWLRQQXPEHU )LQODQG DFEDFFEEEHH 6&,3QRWLƮFDWLRQQXPEHU )UDQFH FFEDIHED 6XEMHFWWRFKDQJHV3OHDVHDOVRREVHUYHWKHIXUWKHUSURGXFWGRFXPHQWDWLRQ :$*2*PE+ &R.* +DQVDVWU 0LQGHQ 3KRQH_)D[ (PDLOLQIRGH#ZDJRFRP_:HEZZZZDJRFRP 'R\RXKDYHDQ\TXHVWLRQVDERXWRXUSURGXFWV" :HDUHDOZD\VKDSS\WRWDNH\RXUFDOODW   {{{{3DJH‫܄܂ ܅‬ 'DWDVKHHW{_,WHPQXPEHU{‫܅܃܇܁܆܈‬ ZZZZDJRFRP 6&,3QRWLƮFDWLRQQXPEHU )UDQFH FFEDIHED 6&,3QRWLƮFDWLRQQXPEHU *HUPDQ\ IIIEHEEDHDDH 6&,3QRWLƮFDWLRQQXPEHU +XQJDU\ GFFHHEFIHE 6&,3QRWLƮFDWLRQQXPEHU ,WDO\ EDFEHIHFF 6&,3QRWLƮFDWLRQQXPEHU 1HWKHUODQGV FDFIGGIDDHIHF 6&,3QRWLƮFDWLRQQXPEHU 3RODQG DEDEDIEDGDFDHG 6&,3QRWLƮFDWLRQQXPEHU 5RPDQLD HDHFFEF 6&,3QRWLƮFDWLRQQXPEHU 6ZHGHQ DHHHGED $SSURYDOV&HUWLƮFDWHV *HQHUDODSSURYDOV /RJR &HUWLƮFDWH QDPH $SSURYDO $GGLWLRQDO$SSURYDO7H[W ($& %UMDQVNHU=HUWLƮ]LHUXQJVVWHOOH 737& ($&58& '($0 % ‫܊܂‬ .& 1DWLRQDO5DGLR5HVHDUFK$JHQF\ $UWLFOH&ODXVH 06,3 5(0: ,'( 8/ 8/,QWHUQDWLRQDO1HWKHUODQGV%9 25',1$5
750-624
物料型号:750-624
器件简介:WAGO 750-624是一个电源滤波模块,用于保护直流电源线路免受由于感性负载引起的开关过电压造成的高能量干扰。该模块适用于海洋应用和陆上/海上设施,并且通过了德国劳氏船级社和劳埃德船级社等领先机构的认证。
引脚分配:文档中提到了3个输入电源跳线接触点和3个输出电源跳线接触点,每个接触点的电流承载能力为10A。
参数特性: - 信号类型:24VDC - 系统供电电压:5VDC,通过数据接触点供电 - 现场供电电压:24VDC(-25...+30%),通过刀片接触点供电,传输(仅现场侧供电电压)通过弹簧接触点
功能详解:该模块确保了经过认证的系统操作,并保护直流电源线路不受感性负载引起的开关过电压造成的高能量干扰。
应用信息:适用于海洋应用和陆上/海上设施,确保系统在这些环境下的适当运行。
封装信息: - 宽度:12 mm - 高度:100 mm - 深度:69.8 mm - 材料:聚碳酸酯;聚酰胺6.6 - 防火等级:1.009MJ - 重量:46.7g - 符合性标记:CE - 环境要求:工作温度0...+55°C,存储温度-40...+85°C,防护等级IP20
750-624 价格&库存
很抱歉,暂时无法提供与“750-624”相匹配的价格&库存,您可以联系我们找货
