753-440
753-440
    WAGO(万可电子)
    输入模块 DIN 轨道 120VAC
753-440 数据手册
'DWDVKHHW{_,WHPQXPEHU{‫܁܅܅܄܆܈‬ FKDQQHOGLJLWDOLQSXW9$& ZZZZDJRFRP &RORU 6XEMHFWWRFKDQJHV3OHDVHDOVRREVHUYHWKHIXUWKHUSURGXFWGRFXPHQWDWLRQ :$*2*PE+ &R.* +DQVDVWU 0LQGHQ 3KRQH_)D[ (PDLOLQIRGH#ZDJRFRP_:HEZZZZDJRFRP 'R\RXKDYHDQ\TXHVWLRQVDERXWRXUSURGXFWV" :HDUHDOZD\VKDSS\WRWDNH\RXUFDOODW   {{{{3DJH‫܃܂ ܂‬ 'DWDVKHHW{_,WHPQXPEHU{‫܁܅܅܄܆܈‬ ZZZZDJRFRP ,WHPGHVFULSWLRQ 7KLVGLJLWDOLQSXWPRGXOHUHFHLYHVFRQWUROVLJQDOVIURPƮHOGGHYLFHV HJVHQVRUV  7KHPRGXOHKDVIRXULQSXWFKDQQHOVDQGGLUHFWO\FRQQHFWVWRIRXUZLUHVHQVRUV )LHOGDQGV\VWHPOHYHOVDUHHOHFWULFDOO\LVRODWHG 1RWLFH $QDGGLWLRQDOVXSSO\PRGXOHPXVWEHDGGHGIRU  {9$&VXSSO\ 'DWD 1RWHV 1RWH 6XEMHFWWRFKDQJHV3OHDVHDOVRREVHUYHWKHIXUWKHUSURGXFWGRFXPHQWDWLRQ :$*2*PE+ &R.* +DQVDVWU 0LQGHQ 3KRQH_)D[ (PDLOLQIRGH#ZDJRFRP_:HEZZZZDJRFRP 'R\RXKDYHDQ\TXHVWLRQVDERXWRXUSURGXFWV" :HDUHDOZD\VKDSS\WRWDNH\RXUFDOODW   {{{{3DJH‫܃܂ ܃‬ 'DWDVKHHW{_,WHPQXPEHU{‫܁܅܅܄܆܈‬ ZZZZDJRFRP 3OXJJDEOHFRQQHFWRUVDQGFRGLQJƮQJHUV 6HULHV DUHQRW LQFOXGHG 7HFKQLFDOGDWD 1XPEHURIGLJLWDOLQSXWV ‫܅‬ 7RWDOQXPEHURIFKDQQHOV PRGXOH ‫܅‬ 6LJQDOW\SH 'LJLWDO 6LJQDOW\SH YROWDJH {9$& 6HQVRUVXSSO\ $&9 6HQVRUFRQQHFWLRQ [ ZLUH ,QSXWFKDUDFWHULVWLF KLJKVLGHVZLWFKLQJ ,QSXWƮOWHU GLJLWDO ‫{ ܁܂‬PV ,QSXWFXUUHQWDWVSHFLƮFLQSXWYROWDJH {P${DW{{9 ,QSXWFXUUHQWDWVSHFLƮFLQSXWYROWDJH  {P$EHL{9 3URWHFWLRQDJDLQVWLQFRUUHFWZLULQJ 2YHUYROWDJHSURWHFWLRQ 9 YLDYDULVWRU 9ROWDJHUDQJHIRUVLJQDO  f9$& 9ROWDJHUDQJHIRUVLJQDO  f{9$& ơf 6LJQDOIUHTXHQF\ PLQ ‫{ ܆܅‬+] 6LJQDOIUHTXHQF\ PD[ ‫{ ܆܇‬+] ,QSXWGDWDZLGWK LQWHUQDO PD[ ‫{ ܅‬ELWV 6XSSO\YROWDJH V\VWHP {9'&{YLDGDWDFRQWDFWV &XUUHQWFRQVXPSWLRQ 9V\VWHPVXSSO\ ‫{ ܆܂‬P$ 6XSSO\YROWDJH ƮHOG 9$&YLDSRZHUMXPSHUFRQWDFWV SRZHUVXSSO\YLDEODGH FRQWDFWWUDQVPLVVLRQ VXSSO\YROWDJHƮHOGVLGHRQO\ YLDVSULQJ FRQWDFW ,VRODWLRQ {9 V\VWHPƮHOG ,QGLFDWRUV /(' $' JUHHQ6WDWXV',f', 1XPEHURILQFRPLQJSRZHUMXPSHUFRQWDFWV ‫܃‬ 1XPEHURIRXWJRLQJSRZHUMXPSHUFRQWDFWV ‫܃‬ &XUUHQWFDUU\LQJFDSDFLW\ SRZHUMXPSHUFRQWDFWV ‫{ ܁܂‬$ &RQQHFWLRQGDWD &RQQHFWLRQWHFKQRORJ\LQSXWVRXWSXWV [&$*(&/$03‹ LQSXWV &RQQHFWLRQW\SH ,QSXW 6ROLGFRQGXFWRU f{PP{f{$:* )LQHVWUDQGHGFRQGXFWRU f{PP{f{$:* 6XEMHFWWRFKDQJHV3OHDVHDOVRREVHUYHWKHIXUWKHUSURGXFWGRFXPHQWDWLRQ :$*2*PE+ &R.* +DQVDVWU 0LQGHQ 3KRQH_)D[ (PDLOLQIRGH#ZDJRFRP_:HEZZZZDJRFRP 'R\RXKDYHDQ\TXHVWLRQVDERXWRXUSURGXFWV" :HDUHDOZD\VKDSS\WRWDNH\RXUFDOODW   {{{{3DJH‫܃܂ ܄‬ 'DWDVKHHW{_,WHPQXPEHU{‫܁܅܅܄܆܈‬ ZZZZDJRFRP )LQHVWUDQGHGFRQGXFWRU f{PP{f{$:* 6WULSOHQJWK f{PP{f{LQFKHV 3K\VLFDOGDWD :LGWK {PP{{LQFKHV +HLJKW {PP{{LQFKHV 'HSWK {PP{{LQFKHV 'HSWKIURPXSSHUHGJHRI',1UDLO {PP{{LQFKHV 0HFKDQLFDO'DWD 0RXQWLQJW\SH ',1UDLO 3OXJJDEOHFRQQHFWRU SOXJJDEOH 0DWHULDOGDWD &RORU OLJKWJUD\ +RXVLQJPDWHULDO 3RO\FDUERQDWHSRO\DPLGH )LUHORDG ‫{ ܅܂܆܂‬0- :HLJKW ‫{ ܆܃܅‬J &RQIRUPLW\PDUNLQJ &( (QYLURQPHQWDOUHTXLUHPHQWV $PELHQWWHPSHUDWXUH RSHUDWLRQ f& $PELHQWWHPSHUDWXUH VWRUDJH f& 3URWHFWLRQW\SH ,3 3ROOXWLRQGHJUHH SHU,(& 2SHUDWLQJDOWLWXGH f{PfIW 0RXQWLQJSRVLWLRQ KRUL]RQWDO VWDQGLQJO\LQJ YHUWLFDO 5HODWLYHKXPLGLW\ ZLWKRXWFRQGHQVDWLRQ ‫۽{ ܆܊‬ 9LEUDWLRQUHVLVWDQFH SHU,(& 6KRFNUHVLVWDQFH JSHU,(& (0&LPPXQLW\WRLQWHUIHUHQFH SHU(1 (0&HPLVVLRQRILQWHUIHUHQFH SHU(1 ([SRVXUHWRSROOXWDQWV SHU,(&DQG,(& 3HUPLVVLEOH+‫ ܃‬6FRQWDPLQDQWFRQFHQWUDWLRQDWDUHODWLYHKXPLGLW\‫܆܈‬ ‫{ ܁܂‬SSP ‫۽‬ 3HUPLVVLEOH62‫ ܃‬FRQWDPLQDQWFRQFHQWUDWLRQDWDUHODWLYHKXPLGLW\‫܆܈‬ ‫{ ܆܃‬SSP ‫۽‬ 6XEMHFWWRFKDQJHV3OHDVHDOVRREVHUYHWKHIXUWKHUSURGXFWGRFXPHQWDWLRQ :$*2*PE+ &R.* +DQVDVWU 0LQGHQ 3KRQH_)D[ (PDLOLQIRGH#ZDJRFRP_:HEZZZZDJRFRP 'R\RXKDYHDQ\TXHVWLRQVDERXWRXUSURGXFWV" :HDUHDOZD\VKDSS\WRWDNH\RXUFDOODW   {{{{3DJH‫܃܂ ܅‬ 'DWDVKHHW{_,WHPQXPEHU{‫܁܅܅܄܆܈‬ ZZZZDJRFRP ‫۽‬ &RPPHUFLDOGDWD 3URGXFW*URXS  ,26\VWHP H&O#VV ‫܅܁܇܃܅܃܈܃‬ H&O#VV ‫܅܁܇܃܅܃܈܃‬ (7,0 (& (7,0 (& 5HFXSHO7\SH 38 638 {SFV 3DFNDJLQJW\SH %R[ &RXQWU\RIRULJLQ '( *7,1 ‫܆܆܅܅܊܄܅܆܅܆܅܁܅‬ &XVWRPVWDULƬQXPEHU ‫܁܊܊܊܊܁܊܉܄܆܉‬ (QYLURQPHQWDO3URGXFW&RPSOLDQFH 5R+6&RPSOLDQFH6WDWXV &RPSOLDQW1R([HPSWLRQ $SSURYDOV&HUWLƮFDWHV *HQHUDODSSURYDOV /RJR &HUWLƮFDWH QDPH $SSURYDO $GGLWLRQDO$SSURYDO7H[W ($& %UMDQVNHU=HUWLƮ]LHUXQJVVWHOOH 737& ($&58& '($0 % ‫܊܂‬ .& 1DWLRQDO5DGLR5HVHDUFK$JHQF\ $UWLFOH&ODXVH 06,3 5(0: ',0 8/ 8/,QWHUQDWLRQDO1HWKHUODQGV%9 25',1$5
753-440
物料型号:753-440
器件简介:这是一个4通道数字输入模块,用于接收现场设备(例如传感器)的控制信号。模块具有四个输入通道,并且可以直接连接到四个2线传感器。现场和系统电平是电气隔离的。
引脚分配:文档中提到了DI1至DI4四个数字输入通道,以及相关的电源跳线接触点。
参数特性: - 数字输入数量:4 - 信号类型:数字 - 信号电压类型:120VAC - 传感器供电:AC 230V - 传感器连接:4x(2线) - 输入特性:高侧开关 - 输入滤波(数字):10ms - 输入电流(特定输入电压下):120V时2.3mA,230V时4.7mA - 防止错误接线保护:通过压敏电阻提供过电压保护(275V) - 信号电压范围(0):0...40VAC - 信号电压范围(1):79...230VAC(-15...+10%) - 信号频率(最小):45Hz - 信号频率(最大):65Hz - 输入数据宽度(内部)最大:4位 - 系统供电电压:5VDC,通过数据接触点 - 系统供电电流消耗:15mA - 现场供电电压:230VAC,通过电源跳线接触点(仅通过刀片接触传输现场侧的供电电压)通过弹簧接触点
功能详解:该模块接收来自传感器的控制信号,并具有电气隔离以确保安全。它还具有过电压保护和输入滤波功能。
应用信息:适用于需要接收多个数字输入信号的自动化控制系统。
封装信息: - 宽度:12mm - 高度:100mm - 深度:69.8mm - 从DIN导轨上边缘的深度:62.6mm - 安装类型:DIN-35导轨 - 材料:聚碳酸酯;聚酰胺6.6 - 防火等级:1.514MJ - 重量:42.5g - 符合性标记:CE - 环境要求:工作温度0...+55°C,存储温度-40...+85°C,防护类型IP20等。
753-440 价格&库存
很抱歉,暂时无法提供与“753-440”相匹配的价格&库存,您可以联系我们找货
  • 1+771.548441+100.29880
库存:2
753-440
      • 1+2188.365011+284.48037
      • 10+1822.5807210+236.92960
      • 25+1708.1441825+222.05322
      • 50+1632.9524650+212.27854
      库存:4
