753-461/003-000
753-461/003-000
    WAGO(万可电子)
    I/O MODULE 2 ANALOG 0-5V
753-461/003-000 数据手册
'DWDVKHHW{_,WHPQXPEHU{‫܁܁܁܄܁܁܂܇܅܄܆܈‬ FKDQQHODQDORJLQSXW)RU3W57'UHVLVWDQFHVHQVRUV$GMXVWDEOH ZZZZDJRFRP 6XEMHFWWRFKDQJHV3OHDVHDOVRREVHUYHWKHIXUWKHUSURGXFWGRFXPHQWDWLRQ :$*2*PE+ &R.* +DQVDVWU 0LQGHQ 3KRQH_)D[ (PDLOLQIRGH#ZDJRFRP_:HEZZZZDJRFRP 'R\RXKDYHDQ\TXHVWLRQVDERXWRXUSURGXFWV" :HDUHDOZD\VKDSS\WRWDNH\RXUFDOODW   {{{{3DJH‫܅܂ ܂‬ 'DWDVKHHW{_,WHPQXPEHU{‫܁܁܁܄܁܁܂܇܅܄܆܈‬ ZZZZDJRFRP ,WHPGHVFULSWLRQ 7KLVDQDORJLQSXWPRGXOHGLUHFWO\FRQQHFWVWR3WRU1LUHVLVWDQFHVHQVRUV 7ZRRUWKUHHZLUHVHQVRUVFDQEHFRQQHFWHG 7KHPRGXOHDXWRPDWLFDOO\OLQHDUL]HVWKHHQWLUHWHPSHUDWXUHUDQJH$VHQVRUHUURU VKRUWFLUFXLWOLQHEUHDNRUPHDVXUHPHQWUDQJHRYHUưRZ LV LQGLFDWHGE\DUHG/(' $JUHHQ/('LQGLFDWHVUHDGLQHVVIRURSHUDWLRQDQGHUURUIUHHFRPPXQLFDWLRQZLWKWKHFRXSOHU 7KHVKLHOGGLUHFWO\FRQQHFWVWRWKH',1UDLO 'DWD 1RWHV 1RWH 6XEMHFWWRFKDQJHV3OHDVHDOVRREVHUYHWKHIXUWKHUSURGXFWGRFXPHQWDWLRQ :$*2*PE+ &R.* +DQVDVWU 0LQGHQ 3KRQH_)D[ (PDLOLQIRGH#ZDJRFRP_:HEZZZZDJRFRP 'R\RXKDYHDQ\TXHVWLRQVDERXWRXUSURGXFWV" :HDUHDOZD\VKDSS\WRWDNH\RXUFDOODW   {{{{3DJH‫܅܂ ܃‬ 'DWDVKHHW{_,WHPQXPEHU{‫܁܁܁܄܁܁܂܇܅܄܆܈‬ ZZZZDJRFRP 3OXJJDEOHFRQQHFWRUVDQGFRGLQJƮQJHUV 6HULHV DUHQRW LQFOXGHG 7HFKQLFDOGDWD 1XPEHURIDQDORJLQSXWV ‫܃‬ 7RWDOQXPEHURIFKDQQHOV PRGXOH ‫܃‬ 6LJQDOW\SH 5HVLVWDQFHPHDVXUHPHQW 6LJQDOW\SH FRQƮJXUDEOH \HV 6HQVRUFRQQHFWLRQ [ ZLUH{ZLUH 'DWDZLGWK [ELWGDWD[ELWFRQWUROVWDWXV RSWLRQDO 5HVROXWLRQ RYHUHQWLUHUDQJH {& &RQYHUVLRQWLPH W\S ‫{ ܁܃܄‬PV 0HDVXUHPHQWHUURU UHIHUHQFHWHPSHUDWXUH ‫&{ ܆܃‬ 0HDVXUHPHQWHUURUGHYLDWLRQ PD[ IURPWKHXSSHUUDQJHYDOXH ‫۽{ ܃܁‬ 7HPSHUDWXUHHUURU PD[ RIWKHXSSHUUDQJHYDOXH ‫{ ܂܁܁‬. 0HDVXULQJFXUUHQW W\S P$ 5HVSRQVHWLPH PD[ ‫{ ܅‬V 6HQVRUW\SHV 3W&RQƮJXUDEOH3W1L2KP 7HPSHUDWXUHUDQJH ơ&f& 3W ơ&f& 1L 6XSSO\YROWDJH V\VWHP {9'&{YLDGDWDFRQWDFWV &XUUHQWFRQVXPSWLRQ 9V\VWHPVXSSO\ ‫{ ܁܉‬P$ ,VRODWLRQ {9V\VWHPƮHOG ,QGLFDWRUV /(' $& JUHHQ)XQFWLRQ$,$,/(' %' UHG(UURU$,$, &RQQHFWLRQGDWD &RQQHFWLRQWHFKQRORJ\LQSXWVRXWSXWV [&$*(&/$03‹ &RQQHFWLRQW\SH ,QSXWV2XWSXWV 6ROLGFRQGXFWRU f{PP{f{$:* )LQHVWUDQGHGFRQGXFWRU f{PP{f{$:* 6WULSOHQJWK f{PP{f{LQFKHV 3K\VLFDOGDWD :LGWK {PP{{LQFKHV +HLJKW {PP{{LQFKHV 'HSWK {PP{{LQFKHV 'HSWKIURPXSSHUHGJHRI',1UDLO {PP{{LQFKHV 6XEMHFWWRFKDQJHV3OHDVHDOVRREVHUYHWKHIXUWKHUSURGXFWGRFXPHQWDWLRQ :$*2*PE+ &R.* +DQVDVWU 0LQGHQ 3KRQH_)D[ (PDLOLQIRGH#ZDJRFRP_:HEZZZZDJRFRP 'R\RXKDYHDQ\TXHVWLRQVDERXWRXUSURGXFWV" :HDUHDOZD\VKDSS\WRWDNH\RXUFDOODW   {{{{3DJH‫܅܂ ܄‬ 'DWDVKHHW{_,WHPQXPEHU{‫܁܁܁܄܁܁܂܇܅܄܆܈‬ ZZZZDJRFRP 'HSWKIURPXSSHUHGJHRI',1UDLO {PP{{LQFKHV 0HFKDQLFDO'DWD 0RXQWLQJW\SH ',1UDLO 3OXJJDEOHFRQQHFWRU 3OXJJDEOH 0DWHULDOGDWD +RXVLQJPDWHULDO 3RO\FDUERQDWHSRO\DPLGH )LUHORDG ‫{ ܃܉܉܁‬0- :HLJKW ‫{ ܉܂܅‬J &RQIRUPLW\PDUNLQJ &( (QYLURQPHQWDOUHTXLUHPHQWV $PELHQWWHPSHUDWXUH RSHUDWLRQ f& $PELHQWWHPSHUDWXUH VWRUDJH f& 3URWHFWLRQW\SH ,3 3ROOXWLRQGHJUHH SHU,(& 2SHUDWLQJDOWLWXGH f{PfIW 0RXQWLQJSRVLWLRQ KRUL]RQWDO VWDQGLQJO\LQJ YHUWLFDO 5HODWLYHKXPLGLW\ ZLWKRXWFRQGHQVDWLRQ ‫۽{ ܆܊‬ 9LEUDWLRQUHVLVWDQFH JSHU,(& 6KRFNUHVLVWDQFH JSHU,(& (0&LPPXQLW\WRLQWHUIHUHQFH SHU(1PDULQHDSSOLFDWLRQV (0&HPLVVLRQRILQWHUIHUHQFH SHU(1PDULQHDSSOLFDWLRQV ([SRVXUHWRSROOXWDQWV 3HU,(&DQG,(& 3HUPLVVLEOH+‫ ܃‬6FRQWDPLQDQWFRQFHQWUDWLRQDWDUHODWLYHKXPLGLW\‫܆܈‬ ‫{ ܁܂‬SSP ‫۽‬ 3HUPLVVLEOH62‫ ܃‬FRQWDPLQDQWFRQFHQWUDWLRQDWDUHODWLYHKXPLGLW\‫܆܈‬ ‫{ ܆܃‬SSP ‫۽‬ &RPPHUFLDOGDWD 3URGXFW*URXS  ,26\VWHP H&O#VV ‫܂܁܇܃܅܃܈܃‬ H&O#VV ‫܂܁܇܃܅܃܈܃‬ (7,0 (& (7,0 (& 38 638 {SFV 6XEMHFWWRFKDQJHV3OHDVHDOVRREVHUYHWKHIXUWKHUSURGXFWGRFXPHQWDWLRQ :$*2*PE+ &R.* +DQVDVWU 0LQGHQ 3KRQH_)D[ (PDLOLQIRGH#ZDJRFRP_:HEZZZZDJRFRP 'R\RXKDYHDQ\TXHVWLRQVDERXWRXUSURGXFWV" :HDUHDOZD\VKDSS\WRWDNH\RXUFDOODW   {{{{3DJH‫܅܂ ܅‬ 'DWDVKHHW{_,WHPQXPEHU{‫܁܁܁܄܁܁܂܇܅܄܆܈‬ ZZZZDJRFRP 38 638 {SFV 3DFNDJLQJW\SH ER[ &RXQWU\RIRULJLQ '( *7,1 ‫܈܉܃܈܉܅܅܆܅܆܅܁܅‬ &XVWRPVWDULƬQXPEHU ‫܁܊܊܊܊܁܊܉܄܆܉‬ (QYLURQPHQWDO3URGXFW&RPSOLDQFH &$61R ‫܉܇܄܈܂܄܂‬ ‫܁܂܆܁܆܆܆܃‬ ‫܂܃܊܊܄܅܈‬ 5($&+&DQGLGDWH/LVW6XEVWDQFH 0HWK\OF\FORKH[DQHGLFDUER[\OLFDQK\GULGH /HDG /HDGPRQR[LGH 5R+6&RPSOLDQFH6WDWXV &RPSOLDQW:LWK([HPSWLRQ 5R+6([HPSWLRQ  F  D  F ,  F ,, 6&,3QRWLƮFDWLRQQXPEHU $XVWULD FFIEHFHDDFHF 6&,3QRWLƮFDWLRQQXPEHU %HOJLXP DHDDGDFFEFFFFHIF 6&,3QRWLƮFDWLRQQXPEHU %XOJDULD FFFDDIEFHDDH 6&,3QRWLƮFDWLRQQXPEHU &]HFK5HSXEOLF FIFGDIIIGEHI 6&,3QRWLƮFDWLRQQXPEHU 'HQPDUN GEIFDIDFHDDE 6&,3QRWLƮFDWLRQQXPEHU )LQODQG DHFHIDHFGGH 6&,3QRWLƮFDWLRQQXPEHU )UDQFH DDDIDHIEƬFI 6&,3QRWLƮFDWLRQQXPEHU *HUPDQ\ EFDDDEIGIGHIHFF 6&,3QRWLƮFDWLRQQXPEHU +XQJDU\ DEFGDEEDDFIH 6&,3QRWLƮFDWLRQQXPEHU ,WDO\ FIFHHDIFEDI 6&,3QRWLƮFDWLRQQXPEHU 1HWKHUODQGV GGIFDEDF 6&,3QRWLƮFDWLRQQXPEHU 3RODQG EGEFEDDHDIDHI 6&,3QRWLƮFDWLRQQXPEHU 5RPDQLD DƬDFGFGGIDI 6&,3QRWLƮFDWLRQQXPEHU 6ZHGHQ GDIDDEIFH $SSURYDOV&HUWLƮFDWHV *HQHUDODSSURYDOV /RJR $SSURYDO $GGLWLRQDO$SSURYDO7H[W ($& %UMDQVNHU=HUWLƮ]LHUXQJVVWHOOH 737& 6XEMHFWWRFKDQJHV3OHDVHDOVRREVHUYHWKHIXUWKHUSURGXFWGRFXPHQWDWLRQ :$*2*PE+ &R.* +DQVDVWU 0LQGHQ 3KRQH_)D[ (PDLOLQIRGH#ZDJRFRP_:HEZZZZDJRFRP &HUWLƮFDWH QDPH ($&58& '($0 % ‫܊܂‬ 'R\RXKDYHDQ\TXHVWLRQVDERXWRXUSURGXFWV" :HDUHDOZD\VKDSS\WRWDNH\RXUFDOODW   {{{{3DJH‫܅܂ ܆‬ 'DWDVKHHW{_,WHPQXPEHU{‫܁܁܁܄܁܁܂܇܅܄܆܈‬ ZZZZDJRFRP % ‫܊܂‬ .& 1DWLRQDO5DGLR5HVHDUFK$JHQF\ $UWLFOH&ODXVH 06,3 5(0: $,0 8/ 8/,QWHUQDWLRQDO1HWKHUODQGV%9 25',1$5
753-461/003-000
物料型号为753-461/003-000。
这是一个WAGO品牌的2通道模拟输入模块,专为Pt100/RTD电阻传感器设计。
它具有以下特点:
- 可连接2线或3线传感器。
- 模块自动将整个温度范围线性化。
- 传感器错误(短路、线路断开或测量范围溢出)由红色LED指示。
- 绿色LED表示操作准备就绪和与耦合器的错误免费通信。
- 屏蔽直接连接到DIN导轨。
技术数据: - 模拟输入数量:2 - 模块的总通道数:2 - 信号类型:电阻测量 - 信号类型(可配置):是 - 传感器连接:2x(2线,3线) - 数据宽度:2x 16位数据;2x 8位控制/状态(可选) - 整个范围的分辨率:0.1°C - 转换时间(典型值):320毫秒 - 测量误差(参考温度):25°C - 测量误差,偏差(最大值):从上范围值的0.2% - 测量电流(典型值):0.5mA - 响应时间(最大值):4秒 - 传感器类型:Pt100;可配置:Pt,Ni,Ohm - 温度范围:-200°C... +850°C(Pt),-60°C... +250°C(Ni) - 系统供电电压:5 VDC;通过数据接触点 - 5V系统供电时的电流消耗:80mA - 隔离:系统/现场500V
连接数据: - 连接技术:输入/输出8x CAGE CLAMP - 固体导体:0.08 ... 2.5 mm2 / 28... 14 AWG - 细股导体:0.08...2.5 mm2 / 28....14 AWG - 剥线长度:9... 10 mm/0.35 ... 0.39英寸
物理数据: - 宽度:12 mm/0.472英寸 - 高度:100 mm/3.937英寸 - 深度:69.8 mm/2.748英寸
环境要求: - 工作环境温度:0...+55°C - 存储环境温度:-40...+85°C - 保护类型:IP20 - 污染等级:IEC61131-2的2级 - 工作海拔:0... 2000米/0... 6562英尺 - 安装位置:水平(立式/卧式);垂直 - 相对湿度(无凝结):95% - 抗振性:IEC60068-2-6的4g - 抗冲击性:IEC 60068-2-27的15g - EMC抗干扰:EN 61000-6-2,海洋应用 - EMC干扰发射:EN 61000-6-4,海洋应用 - 污染物暴露:IEC 60068-2-42和IEC60068-2-43 - 允许的H2S污染物浓度在相对湿度75%:10ppm - 允许的SO2污染物浓度在相对湿度75%:25ppm
商业数据、环境产品合规性、批准/证书、所需配件、可选配件等信息也包含在PDF文档中,如果您需要更详细的信息,请告知。
753-461/003-000 价格&库存
很抱歉,暂时无法提供与“753-461/003-000”相匹配的价格&库存,您可以联系我们找货
