756-3501/050-150
756-3501/050-150
    WAGO(万可电子)
    CBL CIRC 5POS FEM 49.2
756-3501/050-150 数据手册
'DWDVKHHW{_,WHPQXPEHU{‫܁܆܂܁܆܁܂܁܆܄܇܆܈‬ 3RZHUFDEOH0/VRFNHWVWUDLJKWSROH/HQJWKP ZZZZDJRFRP ,WHPGHVFULSWLRQ 6KRUWGHVFULSWLRQ 7KHVHSRZHUFDEOHVDUHDQDFFHVVRU\IRUWKH:$*2,26\VWHP)LHOG 8VHWKHPDVưH[LEOHưDPHUHWDUGDQWDQGKDORJHQIUHHVXSSO\FDEOHVIRULQGXVWULDOPHFKDQLFDOHQJLQHHULQJDSSOLFDWLRQVsSDUWLFXODUO\WKRVHZLWK 6XEMHFWWRFKDQJHV3OHDVHDOVRREVHUYHWKHIXUWKHUSURGXFWGRFXPHQWDWLRQ :$*2*PE+ &R.* +DQVDVWU 0LQGHQ 3KRQH_)D[ (PDLOLQIRGH#ZDJRFRP_:HEZZZZDJRFRP 'R\RXKDYHDQ\TXHVWLRQVDERXWRXUSURGXFWV" :HDUHDOZD\VKDSS\WRWDNH\RXUFDOODW   {{{{3DJH‫܅ ܂‬ 'DWDVKHHW{_,WHPQXPEHU{‫܁܆܂܁܆܁܂܁܆܄܇܆܈‬ ZZZZDJRFRP 8VHWKHPDVưH[LEOHưDPHUHWDUGDQWDQGKDORJHQIUHHVXSSO\FDEOHVIRULQGXVWULDOPHFKDQLFDOHQJLQHHULQJDSSOLFDWLRQVsSDUWLFXODUO\WKRVHZLWK KLJKUHTXLUHPHQWVHJIRUXVHLQFDEOHFKDLQV GUDJFKDLQV DQGPRYLQJPDFKLQHSDUWV 6WURQJUHVLVWDQFHWRPLFUREHVDQGK\GURO\VLV *RRGWRYHU\JRRGZHDWKHUUHVLVWDQFH 89DQGR]RQH +LJKUHVLVWDQFHDJDLQVWZHOGLQJVSDUNV ([FHOOHQWFKHPLFDODQGRLOUHVLVWDQFH 6LOLFRQDQG39&IUHH )UHHIURPSDLQWZHWWLQJLPSDLUPHQWVXEVWDQFHV )OH[LEOHDWORZWHPSHUDWXUHV 'DWD 7HFKQLFDOGDWD *HQHUDOLQIRUPDWLRQ 2SHUDWLQJYROWDJH 9'&SHU,(& 2SHUDWLQJFXUUHQW ‫{ ܇܂‬$ 5DWHGVXUJHYROWDJH N9SHU,(& ,QVXODWLRQUHVLVWDQFH ƪ‫ ܉ ܁܂‬Ƴ &RQWDFWUHVLVWDQFH ‫{ ܆‬PƳ &RQGXFWRUUHVLVWDQFH ƩƳNP 3ROOXWLRQGHJUHH SHU,(& 3URWHFWLRQW\SH ,3 $PELHQWWHPSHUDWXUH RSHUDWLRQ f& 8/PD[& $PELHQW RSHUDWLQJ WHPSHUDWXUH VWDWLF f& $PELHQW RSHUDWLQJ WHPSHUDWXUH G\QDPLF f& 'UDJFKDLQFRPSDWLEOH $PELHQWDLU RSHUDWLQJ WHPSHUDWXUHLQGUDJFKDLQ f& %HQGLQJUDGLXV )L[HG![µ)OH[LEOH![µ %HQGLQJF\FOHV ‫{ ܁܂‬0LR 2WKHUSURSHUWLHV 1RWH ([FOXVLRQRIKD]DUGRXVVXEVWDQFHVSHU(&(& (& 1R(8 6XEMHFWWRFKDQJHV3OHDVHDOVRREVHUYHWKHIXUWKHUSURGXFWGRFXPHQWDWLRQ :$*2*PE+ &R.* +DQVDVWU 0LQGHQ 3KRQH_)D[ (PDLOLQIRGH#ZDJRFRP_:HEZZZZDJRFRP 'R\RXKDYHDQ\TXHVWLRQVDERXWRXUSURGXFWV" :HDUHDOZD\VKDSS\WRWDNH\RXUFDOODW   {{{{3DJH‫܅ ܃‬ 'DWDVKHHW{_,WHPQXPEHU{‫܁܆܂܁܆܁܂܁܆܄܇܆܈‬ ZZZZDJRFRP &DEOH &DEOHOHQJWK ‫{ ܆܂‬P 7\SHFRGH /L)
756-3501/050-150
物料型号:WAGO 756-3501/050-150
器件简介: - 这些电源电缆是WAGO VO系统现场的附件。 - 它们被设计为工业机械工程应用的柔性、阻燃和无卤电源电缆,特别适用于高要求的应用,例如在电缆拖链和移动机械部件中使用。 - 具有以下特性:抗微生物和耐水解、良好的耐候性(抗紫外线和臭氧)、高抗焊渣性、优异的化学和耐油性、无硅和PVC、低温下保持柔性。
引脚分配: - 引脚1/接地:1.5mm棕色线 - 引脚2:白色线 - 引脚3:蓝色线 - 引脚4:黑色线 - 引脚5/接地:灰色线
参数特性: - 工作电压:63VDC(IEC 60664-1) - 工作电流:16A - 额定冲击电压:1.5kV(IEC61076-2-111) - 绝缘电阻:10MΩ - 接触电阻:5mΩ - 导体电阻:13.7Ω/km - 污染等级:3级(IEC60664-1) - 保护类型:IP68 - 环境温度(工作):-40...+90°C(UL最大+80°C) - 环境温度(静态工作):-40...+90°C - 环境温度(动态工作):-30...+90°C
功能详解: - 电缆长度:15米 - 类型代码:LiF9YH-11Y-0B 5x1.5mm² - 导体配置:裸铜线(84x0.15mm) - 导体绝缘:PP9Y(无卤) - 护套电缆颜色:灰色 - 护套电缆直径:9.6...10.2mm
应用信息: - 适用于电缆拖链中的环境空气(工作)温度:-25...+60°C - 弯曲半径:固定:>4x0;柔性:>7.5x0 - 弯曲周期:1000万次
封装信息: - 连接类型:M12插座 - 末端自由 - 极数:5 - 电缆连接方向与配对方向:0 - 连接器接口编码(电缆/适配器):L编码 - 外壳材料:TPU/TPU,黑色(~RAL 9005) - 连接器:六角滚花螺母:CuZn;滚花螺母表面:镀镍; - 密封圈:FPM/FKM - 拧紧扭矩:1Nm
商业数据: - ETIM8.0:EC001855 - ETIM7.0:EC003249 - PU(SPU):1件 - 包装类型:未包装 - 原产国:德国 - GTIN:4055143974486 - 海关关税编号:85444290900
环境产品合规性: - RoHS合规状态:符合,无豁免
756-3501/050-150 价格&库存
很抱歉,暂时无法提供与“756-3501/050-150”相匹配的价格&库存,您可以联系我们找货
