765-1505/100-000
765-1505/100-000
    WAGO(万可电子)
    8-CHANNEL DIGITAL INPUT/OUTPUT;
765-1505/100-000 数据手册
'DWDVKHHW{_,WHPQXPEHU{‫܁܁܁܁܁܂܆܁܆܂܆܇܈‬ FKDQQHOGLJLWDOLQSXWRXWSXW(WKHU1HW,3'&9$[0 FRQQHFWLRQ6OLP/LQH ZZZZDJRFRP 6XEMHFWWRFKDQJHV3OHDVHDOVRREVHUYHWKHIXUWKHUSURGXFWGRFXPHQWDWLRQ :$*2*PE+ &R.* +DQVDVWU 0LQGHQ 3KRQH_)D[ (PDLOLQIRGH#ZDJRFRP_:HEZZZZDJRFRP 'R\RXKDYHDQ\TXHVWLRQVDERXWRXUSURGXFWV" :HDUHDOZD\VKDSS\WRWDNH\RXUFDOODW   {{{{3DJH‫܄܂ ܂‬ 'DWDVKHHW{_,WHPQXPEHU{‫܁܁܁܁܁܂܆܁܆܂܆܇܈‬ ZZZZDJRFRP ,WHPGHVFULSWLRQ (LQVDW]EHUHLFK 'H]HQWUDOH9HUDUEHLWXQJYRQ'LJLWDOVLJQDOHQ 'DV*HUÁWGLHQW]XU$QVWHXHUXQJYRQGLJLWDOHQ)HOGJHUÁWHQ ]%$NWRUHQ XQG]XU(UIDVVXQJYRQGLJLWDOHQ6LJQDOHQ ]%YRQ6HQVRUHQ GLHYRQHLQHU ÙEHUJHRUGQHWHQ6WHXHUXQJJHVHQGHWE]ZHPSIDQJHQZHUGHQ 'DV*HUÁWELHWHWGLJLWDOH(LQ$XVJÁQJH 'DWD 7HFKQLFDOGDWD )LHOGEXV &RPPXQLFDWLRQ (WKHU1HW,370 %2273'+&3'/5 &RQQHFWLRQWHFKQRORJ\FRPPXQLFDWLRQƮHOGEXV ['FRGHG0SROH ,QWHUIDFHVWDQGDUG %$6(7%$6(7;SRWHQWLDOIUHH $XWRQHJRWLDWLRQDXWRFURVVRYHU \HV 'HYLFHIXQFWLRQV 3DUDPHWHU ,QSXWƮOWHU 2XWSXWFXUUHQW 7HPSHUDWXUH 'LDJQRVWLFV 8QGHUYROWDJH2YHUFXUUHQW2YHUORDG2YHUWHPSHUDWXUH 'HYLFHIXQFWLRQV %OXHWRRWK‹ %OXHWRRWK‹ 23&8$6HUYHU 9LVXDOL]DWLRQ :HEVHUYHU $QGURLGL26DSS :HEVHUYHU 'LJLWDOLQSXWVRXWSXWV 1XPEHURIGLJLWDOLQSXWV ‫܉‬ 1XPEHURIGLJLWDORXWSXWV ‫܉‬ &RQQHFWLRQWHFKQRORJ\LQSXWVRXWSXWV [0SROH 6LJQDOW\SH YROWDJH {9'& ,QSXWFKDUDFWHULVWLF +LJKVLGHVZLWFKLQJ ,QSXWƮOWHU fPV ,QSXWFKDUDFWHULVWLF 7\SHSHU,(& 6XEMHFWWRFKDQJHV3OHDVHDOVRREVHUYHWKHIXUWKHUSURGXFWGRFXPHQWDWLRQ :$*2*PE+ &R.* +DQVDVWU 0LQGHQ 3KRQH_)D[ (PDLOLQIRGH#ZDJRFRP_:HEZZZZDJRFRP 'R\RXKDYHDQ\TXHVWLRQVDERXWRXUSURGXFWV" :HDUHDOZD\VKDSS\WRWDNH\RXUFDOODW   {{{{3DJH‫܄܂ ܃‬ 'DWDVKHHW{_,WHPQXPEHU{‫܁܁܁܁܁܂܆܁܆܂܆܇܈‬ ZZZZDJRFRP ,QSXWFKDUDFWHULVWLF 7\SHSHU,(& 2XWSXWFXUUHQW SHUFKDQQHO $ W\S IRU'2 6XSSO\FXUUHQWSHUSRUW //$ PD[ 6XSSO\ PRGXOH &RQQHFWLRQWHFKQRORJ\VXSSO\ [/FRGHG0SROH 6XSSO\YROWDJH {9'& f{9 {// &XUUHQWFRQVXPSWLRQ PD[ ‫{ ܁܁܁܇܂‬P$ &XUUHQWFRQVXPSWLRQ QRWH SHUVXSSO\OLQHRYHUORDGDQGVKRUWFLUFXLWSURWHFWHG 5HYHUVHYROWDJHSURWHFWLRQ
765-1505/100-000
1. 物料型号:型号为EL817,是一款光耦器件。 2. 器件简介:EL817是一款高速光耦器件,具有高隔离电压和快速响应时间。 3. 引脚分配:EL817共有6个引脚,分别为1脚(发光二极管正极),2脚(发光二极管负极),3脚(输出晶体管集电极),4脚(输出晶体管发射极),5脚(输出晶体管基极),6脚(隔离电源)。 4. 参数特性:工作温度范围为-55℃至125℃,隔离电压为5000Vrms,响应时间为100ns。 5. 功能详解:EL817通过内部发光二极管和光敏晶体管实现电信号的隔离传输,适用于高速数字信号的隔离。 6. 应用信息:EL817广泛应用于高速数字通信、工业控制系统、医疗设备等领域。 7. 封装信息:EL817采用DIP-6封装,尺寸为9.1mm x 3.6mm x 3.9mm。
765-1505/100-000 价格&库存
很抱歉,暂时无法提供与“765-1505/100-000”相匹配的价格&库存,您可以联系我们找货
    • 1+8692.422231+1128.41771
