770-1165
770-1165
    WAGO(万可电子)
    P=10mm
    接线端子 间距:10.00mm 1x5P 自由悬挂(直插式)
770-1165 数据手册
'DWDVKHHW{_,WHPQXPEHU{‫܆܇܂܂܁܈܈‬ 6RFNHWSROH&RG/PPGDUNJUD\ ZZZZDJRFRP &RORU ,WHPGHVFULSWLRQ )HPDOHFRQQHFWRUVRFNHW:,167$‹0,',/FRGLQJ 7KH:,167$‹0,',IHPDOHFRQQHFWRUVRFNHWZLWKSURWHFWLRQW\SH,3DOORZVLQVWDOODWLRQRIVROLGDQGƮQHVWUDQGHGFRQGXFWRUV7KHSOXJJDEOH LQVWDOODWLRQFRQQHFWRUVZLWKVSULQJSUHVVXUHFRQQHFWLRQWHFKQRORJ\ZRUNHQWLUHO\ZLWKRXWVFUHZFRQQHFWLRQV7KH\DOORZUHVRXUFHHƱFLHQWHUURU IUHHLQVWDOODWLRQLQDODUJHQXPEHURIDSSOLFDWLRQV7KHPHFKDQLFDOFRGLQJDQGFRORUFRGLQJRIWKHSOXJJDEOHLQVWDOODWLRQFRQQHFWRUHQVXUHHUURUIUHH LQVWDOODWLRQRIWKHLQGLYLGXDOFRPSRQHQWVsLQFOXGLQJSURWHFWLRQDJDLQVWPLVPDWLQJ7KHSOXJJDEOHLQVWDOODWLRQFRQQHFWRURƬHUVWRXFKSURRI SURWHFWLRQZLWKOLYHFRPSRQHQWVLQDFFRUGDQFHZLWKSURWHFWLRQW\SH,3 :KHQPDWHGDQGVHFXUHGZLWKDVWUDLQUHOLHIKRXVLQJ,3[& 7KHVH FRPSDFWFRQQHFWRUVDUHQRWGHVLJQHGIRUXVHLQRSHQHDVLO\DFFHVVLEOHDUHDV :,167$‹0,',SOXJJDEOHLQVWDOODWLRQFRQQHFWRUVZLWK/FRGLQJ  SROHRUSROH DUHSHUIHFWIRUXVHLQVXSSO\LQJSRZHUWRSRZHUVXSSO\XQLWVRUVPDOOVHUYRPRWRUV7KHUDWHGFXUUHQWDQGYROWDJHDUHLPSRUWDQW FULWHULDIRUVHOHFWLQJDSOXJJDEOHLQVWDOODWLRQFRQQHFWRU7KH\WHOOXVDERXWWKHSURGXFW VGRPDLQVRIXVH7KLVSURGXFWKDVDFXUUHQWUDWLQJRI$s WKHUHIRUHLWLVVXLWDEOHIRUKLJKSRZHUORDGV7KH:,167$‹0,',3OXJJDEOH&RQQHFWLRQ6\VWHPZLWK3XVKLQ&$*(&/$03‹VSULQJSUHVVXUH FRQQHFWLRQWHFKQRORJ\IDFLOLWDWHVH[HPSODU\HOHFWULƮFDWLRQ7KDQNVWRWKHLQWHJUDWHGWHVWVORWLWLVSRVVLEOHWRFKHFNFRQQHFWLRQVHYHQZKHQWKH\ DUHSOXJJHGLQ7KDWVDYHVWLPHDQGUHGXFHVLQVWDOODWLRQODERUDQGFRVWV 6XEMHFWWRFKDQJHV3OHDVHDOVRREVHUYHWKHIXUWKHUSURGXFWGRFXPHQWDWLRQ :$*2*PE+ &R.* +DQVDVWU 0LQGHQ 3KRQH_)D[ (PDLOLQIRGH#ZDJRFRP_:HEZZZZDJRFRP 'R\RXKDYHDQ\TXHVWLRQVDERXWRXUSURGXFWV" :HDUHDOZD\VKDSS\WRWDNH\RXUFDOODW   {{{{3DJH‫܂܂ ܂‬ 'DWDVKHHW{_,WHPQXPEHU{‫܆܇܂܂܁܈܈‬ ZZZZDJRFRP 3XVKLQ&$*(&/$03‹VSULQJSUHVVXUHFRQQHFWLRQWHFKQRORJ\sSOXJJDEOHLQVWDOODWLRQLQVWHDGRIODERULRXVVFUHZ FRQQHFWLRQV 7KH:,167$‹3OXJJDEOH&RQQHFWLRQ6\VWHPDOORZVSOXJJDEOHHOHFWULFDOLQVWDOODWLRQ7KLVVLJQLƮFDQWO\UHGXFHVWKHQHHGIRUVHUYLFLQJDQGORZHUV FRVWV7DNHDGYDQWDJHRIWKHSOXJJDEOHYHUVLRQRIRXUPDLQWHQDQFHIUHHVSULQJSUHVVXUHFRQQHFWLRQWHFKQRORJ\WRR3ODQ\RXULQVWDOODWLRQZLWKZLWK SURWHFWLRQDJDLQVWPLVPDWLQJIURP:$*2 HƬHFWLYHSURWHFWLRQDJDLQVWPLVPDWLQJ IRUDXWRPDWLRQFRQWUROOHUV ZLWK/FRGLQJIRUVXSSO\LQJSRZHULQDXWRPDWLRQ FXVWRPHQJLQHHUHGVROXWLRQV FRQYHQLHQWLQVWDOODWLRQDQGFRPPLVVLRQLQJ 'DWD (OHFWULFDOGDWD 5DWLQJVSHU,(&(1 5DWLQJVSHU ,(&(1 1RPLQDOYROWDJH ,,, ‫{ ܁܁܅‬9 5DWHGLPSXOVHYROWDJH ,,, ‫{ ܇‬N9 5DWHGFXUUHQW ‫{ ܆܃‬$ /HJHQG UDWLQJV ,,, Ε2YHUYROWDJHFDWHJRU\,,,3ROOXWLRQGHJUHH 5DWLQJVSHU8/ 1RWHIRUWKH86PDUNHW 6RPHYHUVLRQVPD\DOVREHXVHGIRUFXUUHQWLQWHUUXSWLRQLQ DFFRUGDQFHZLWKWKH8/FHUWLƮFDWHLQVHOHFWDSSOLFDWLRQVZLWK FXUUHQWVEHORZ$DQGYROWDJHVXSWR9)RUIXUWKHU LQIRUPDWLRQSOHDVHFRQWDFW\RXUORFDOVDOHVRƱFH 5DWHGYROWDJH 8/ ‫{ ܁܁܇‬9 5DWHGFXUUHQW8/ ‫{ ܄܃‬$ *HQHUDOLQIRUPDWLRQ 1RWHRQFRQWDFWUHVLVWDQFH DSSUR[PƠRIFRQWDFWUHVLVWDQFH DSSUR[PƠFRQWDFWWUDQVLWLRQSOXJVRFNHW &RQQHFWLRQGDWD 6XEMHFWWRFKDQJHV3OHDVHDOVRREVHUYHWKHIXUWKHUSURGXFWGRFXPHQWDWLRQ :$*2*PE+ &R.* +DQVDVWU 0LQGHQ 3KRQH_)D[ (PDLOLQIRGH#ZDJRFRP_:HEZZZZDJRFRP 'R\RXKDYHDQ\TXHVWLRQVDERXWRXUSURGXFWV" :HDUHDOZD\VKDSS\WRWDNH\RXUFDOODW   {{{{3DJH‫܂܂ ܃‬ 'DWDVKHHW{_,WHPQXPEHU{‫܆܇܂܂܁܈܈‬ ZZZZDJRFRP &RQQHFWLRQGDWD &RQQHFWLRQSRLQWV ‫܁܂‬ 7RWDOQXPEHURISRWHQWLDOV ‫܆‬ &RQQHFWLRQ &RQQHFWLRQWHFKQRORJ\ 3XVKLQ&$*(&/$03‹ $FWXDWLRQW\SH 2SHUDWLQJWRRO 3XVKLQ 1RPLQDOFURVVVHFWLRQ PP$:* 6ROLGFRQGXFWRU f{PP{f{$:* 6ROLGFRQGXFWRUSXVKLQWHUPLQDWLRQ f{PP{f{$:* 6WUDQGHGFRQGXFWRU f{PP{f{$:* )LQHVWUDQGHGFRQGXFWRU f{PP{f{$:* )LQHVWUDQGHGFRQGXFWRUZLWKLQVXODWHGIHUUXOH f{PP{f{$:* )LQHVWUDQGHGFRQGXFWRUZLWKXQLQVXODWHGIHUUXOH f{PP{f{$:* )LQHVWUDQGHGFRQGXFWRUZLWKIHUUXOHSXVKLQWHUPLQDWLRQ {PP{{$:* 6WULSOHQJWK {PP{{LQFKHV 3ROHQXPEHU ‫܆‬ &RQGXFWRUHQWU\GLUHFWLRQWRPDWLQJGLUHFWLRQ ‫{ ܁‬ 3K\VLFDOGDWD 3LQVSDFLQJ {PP{{LQFKHV :LGWK {PP{{LQFKHV +HLJKW {PP{{LQFKHV 'HSWK {PP{{LQFKHV 0HFKDQLFDO'DWD $SSOLFDWLRQ (PHUJHQF\SRZHUVXSSO\ &RGLQJ / 9DULDEOHFRGLQJ 1R 0DUNLQJ 1ங/1 / 3RWHQWLDOPDUNLQJ 1ங/1 / 0DWLQJIRUFHRIDSOXJLQFRQQHFWLRQ DSSUR[f1 GHSHQGLQJRQSROHQXPEHU 5HWHQWLRQIRUFHRIDSOXJLQFRQQHFWLRQ /RFNHG!1 8QPDWLQJIRUFHRIDSOXJLQFRQQHFWLRQ 8QORFNHGDSSUR[f1 GHSHQGLQJRQSROHQXPEHU 1XPEHURIPDWLQJF\FOHV ZLWKRXWUHVLVWLYHORDG 3URWHFWLRQW\SH ,3:KHQPDWHGDQGVHFXUHGZLWKDVWUDLQUHOLHIKRXVLQJ,3[& 6XEMHFWWRFKDQJHV3OHDVHDOVRREVHUYHWKHIXUWKHUSURGXFWGRFXPHQWDWLRQ :$*2*PE+ &R.* +DQVDVWU 0LQGHQ 3KRQH_)D[ (PDLOLQIRGH#ZDJRFRP_:HEZZZZDJRFRP 'R\RXKDYHDQ\TXHVWLRQVDERXWRXUSURGXFWV" :HDUHDOZD\VKDSS\WRWDNH\RXUFDOODW   {{{{3DJH‫܂܂ ܄‬ 'DWDVKHHW{_,WHPQXPEHU{‫܆܇܂܂܁܈܈‬ ZZZZDJRFRP 3URWHFWLRQW\SH ,3:KHQPDWHGDQGVHFXUHGZLWKDVWUDLQUHOLHIKRXVLQJ,3[& 7KHVHFRPSDFWFRQQHFWRUVDUHQRWGHVLJQHGIRUXVHLQRSHQHDVLO\ DFFHVVLEOHDUHDV 3OXJLQFRQQHFWLRQ &RQWDFWW\SH SOXJJDEOHFRQQHFWRU )HPDOHFRQQHFWRUVRFNHW &RQQHFWRU FRQQHFWLRQW\SH IRUFRQGXFWRU 0LVPDWLQJSURWHFWLRQ
770-1165
物料型号:770-1165
器件简介: - 该产品为WAGO品牌的安装连接器,采用弹簧压力连接技术,无需螺丝连接,适用于多种应用场景。 - 提供机械编码和颜色编码,确保错误少的组件安装,包括防错配保护。 - 提供符合IP20标准的触摸保护,当配合固定拉力外壳使用时,可达IP2xC保护等级。
引脚分配: - 该连接器为5极设计,具有10个接触点,适用于紧急电源供应。
参数特性: - 额定电压:400V(IEC/EN60664-1标准) - 额定脉冲电压:6kV(IEC/EN60664-1标准) - 额定电流:25A - 美国市场额定电压和电流:600V和23A(UL 1977标准)
功能详解: - 采用Push-in CAGE CLAMP技术,实现便捷的插拔式安装。 - 集成测试槽,即使在连接状态下也能检查连接情况,节省时间和减少安装劳动及成本。
应用信息: - 适用于自动化控制器的电源供应,具有L编码。 - 提供定制工程解决方案,方便安装和调试。
封装信息: - 物理尺寸:宽度50mm,高度12.9mm,深度37.5mm。 - 材料:绝缘材料为聚酰胺(PA66),阻燃等级为UL94 VO。 - 重量:15.7克。
770-1165 价格&库存
很抱歉,暂时无法提供与“770-1165”相匹配的价格&库存,您可以联系我们找货
