770-245/064-000
770-245/064-000
    WAGO(万可电子)
    P=10mm
    接线端子 间距:10.00mm 1x5P 自由悬挂(直插式)
770-245/064-000 数据手册
'DWDVKHHW{_,WHPQXPEHU{‫܁܁܁܅܇܁܆܅܃܁܈܈‬ 6RFNHWSROH&RG%PPJUD\ ZZZZDJRFRP &RORU ,WHPGHVFULSWLRQ )HPDOHFRQQHFWRUVRFNHW:,167$‹0,',SROH 8VHHƬHFWLYHSOXJJDEOHFRQQHFWLRQVLQVWHDGRIODERULRXVVFUHZFRQQHFWLRQV:LWKWKH:,167$‹0,',IHPDOHFRQQHFWRUVRFNHWZLWKSURWHFWLRQ DJDLQVWPLVPDWLQJ:$*2SOXJJDEOHLQVWDOODWLRQFRQQHFWRUVDUHXVHIXOZKHQUHTXLUHPHQWVUHSHDWRUDUHSODQQHGRQDGHƮQHGSDWWHUQIRUH[DPSOH IRULQVWDOOLQJJULGOLJKWLQJRUưXVKPRXQWOLJKWLQJ)RUJUHDWHUVHFXULW\LQHOHFWULFDOLQVWDOODWLRQVWKHSOXJJDEOHLQVWDOODWLRQFRQQHFWRULVSURYLGHGZLWK PHFKDQLFDOSURWHFWLRQDJDLQVWPLVPDWLQJ7KHSOXJJDEOHLQVWDOODWLRQFRQQHFWRURƬHUVWRXFKSURRISURWHFWLRQZLWKOLYHFRPSRQHQWVLQDFFRUGDQFH ZLWKSURWHFWLRQW\SH,3 :KHQPDWHGDQGVHFXUHGZLWKDVWUDLQUHOLHIKRXVLQJ,3[& 7KHVHFRPSDFWFRQQHFWRUVDUHQRWGHVLJQHGIRUXVHLQRSHQ HDVLO\DFFHVVLEOHDUHDV 6ROXWLRQVOLNHWKH:,167$‹0,',SOXJJDEOHLQVWDOODWLRQFRQQHFWRUVZLWK%FRGLQJDUHVXLWDEOHIRUDSSOLFDWLRQVLQYROYLQJ SURFHVVFRQWUROVXFKDVIRUOLJKWLQJRUZLWKLQGDWDQHWZRUNV7KLVSOXJJDEOHLQVWDOODWLRQFRQQHFWRUFDQEHXVHGIRUDYROWDJHORDGRIXSWR$ 7KHUHIRUHLWFDQDOVREHXVHGIRUKLJKSRZHUORDGV2XU:,167$‹0,',SURGXFWOLQHDFKLHYHVPD[LPXPưH[LELOLW\IRUWKHLQVWDOODWLRQRIDSSOLFDWLRQV 7KURXJKLWV3XVKLQ&$*(&/$03‹VSULQJSUHVVXUHFRQQHFWLRQWHFKQRORJ\LWDFKLHYHVHUURUIUHHWLPHVDYLQJLQVWDOODWLRQDQGRƬHUVưH[LELOLW\DQG FXVWRPL]DWLRQIRUPHHWLQJDOOLQVWDOODWLRQUHTXLUHPHQWV :,167$‹0,',VROXWLRQVIRU\RXUHOHFWULFDOLQVWDOODWLRQsSURWHFWHGDJDLQVWPLVPDWLQJDQGPDLQWHQDQFHIUHH 7KH:,167$‹3OXJJDEOH&RQQHFWLRQ6\VWHPLVLGHDOO\WDLORUHGWRWKHVWULFWUHTXLUHPHQWVRIEXLOGLQJLQVWDOODWLRQ,WPDNHVHOHFWULFDOLQVWDOODWLRQ 6XEMHFWWRFKDQJHV3OHDVHDOVRREVHUYHWKHIXUWKHUSURGXFWGRFXPHQWDWLRQ :$*2*PE+ &R.* +DQVDVWU 0LQGHQ 3KRQH_)D[ (PDLOLQIRGH#ZDJRFRP_:HEZZZZDJRFRP 'R\RXKDYHDQ\TXHVWLRQVDERXWRXUSURGXFWV" :HDUHDOZD\VKDSS\WRWDNH\RXUFDOODW   {{{{3DJH‫܃܂ ܂‬ 'DWDVKHHW{_,WHPQXPEHU{‫܁܁܁܅܇܁܆܅܃܁܈܈‬ ZZZZDJRFRP 7KH:,167$‹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Ʈ[WXUHV FXVWRPHQJLQHHUHGVROXWLRQV TXLFNUHSODFHPHQWRIGHIHFWLYHXQLWVGXULQJRQJRLQJRSHUDWLRQ 'DWD 1RWHV 9DULDQWV 2WKHUSROHPDUNLQJV 2WKHUYHUVLRQV RUYDULDQWV FDQEHUHTXHVWHGIURP:$*26DOHVRU FRQƮJXUHGDWKWWSVFRQƮJXUDWRUZDJRFRP (OHFWULFDOGDWD 5DWLQJVSHU,(&(1 5DWLQJVSHU ,(&(1 1RPLQDOYROWDJH ,,, ‫{ ܁܁܅‬9 5DWHGLPSXOVHYROWDJH ,,, ‫{ ܇‬N9 5DWHGFXUUHQW ‫{ ܆܃‬$ /HJHQG UDWLQJV ,,, Ε2YHUYROWDJHFDWHJRU\,,,3ROOXWLRQGHJUHH 5DWLQJVSHU,(&(1s1RWHV 1RWH UDWHGFXUUHQW $IRUSROHORDG $IRUDQGSROHORDG 5DWLQJVSHU8/ 1RWHIRUWKH86PDUNHW 6RPHYHUVLRQVPD\DOVREHXVHGIRUFXUUHQWLQWHUUXSWLRQLQ DFFRUGDQFHZLWKWKH8/FHUWLƮFDWHLQVHOHFWDSSOLFDWLRQVZLWK FXUUHQWVEHORZ$DQGYROWDJHVXSWR9)RUIXUWKHU LQIRUPDWLRQSOHDVHFRQWDFW\RXUORFDOVDOHVRƱFH 5DWHGYROWDJH 8/ ‫{ ܁܁܇‬9 5DWHGFXUUHQW8/ ‫{ ܄܃‬$ 6XEMHFWWRFKDQJHV3OHDVHDOVRREVHUYHWKHIXUWKHUSURGXFWGRFXPHQWDWLRQ :$*2*PE+ &R.* +DQVDVWU 0LQGHQ 3KRQH_)D[ (PDLOLQIRGH#ZDJRFRP_:HEZZZZDJRFRP 'R\RXKDYHDQ\TXHVWLRQVDERXWRXUSURGXFWV" :HDUHDOZD\VKDSS\WRWDNH\RXUFDOODW   {{{{3DJH‫܃܂ ܃‬ 'DWDVKHHW{_,WHPQXPEHU{‫܁܁܁܅܇܁܆܅܃܁܈܈‬ ZZZZDJRFRP *HQHUDOLQIRUPDWLRQ 1RWHRQFRQWDFWUHVLVWDQFH DSSUR[PƠRIFRQWDFWUHVLVWDQFH DSSUR[PƠFRQWDFWWUDQVLWLRQSOXJVRFNHW &RQQHFWLRQGDWD &RQQHFWLRQSRLQWV ‫܁܂‬ 7RWDOQXPEHURISRWHQWLDOV ‫܆‬ &RQQHFWLRQ &RQQHFWLRQWHFKQRORJ\ 3XVKLQ&$*(&/$03‹ $FWXDWLRQW\SH 2SHUDWLQJWRRO 3XVKLQ 1RPLQDOFURVVVHFWLRQ PP$:* 6ROLGFRQGXFWRU f{PP{f{$:* 6ROLGFRQGXFWRUSXVKLQWHUPLQDWLRQ f{PP{f{$:* 6WUDQGHGFRQGXFWRU f{PP{f{$:* )LQHVWUDQGHGFRQGXFWRU f{PP{f{$:* )LQHVWUDQGHGFRQGXFWRUZLWKLQVXODWHGIHUUXOH f{PP{f{$:* )LQHVWUDQGHGFRQGXFWRUZLWKXQLQVXODWHGIHUUXOH f{PP{f{$:* )LQHVWUDQGHGFRQGXFWRUZLWKIHUUXOHSXVKLQWHUPLQDWLRQ {PP{{$:* 6WULSOHQJWK {PP{{LQFKHV 3ROHQXPEHU ‫܆‬ &RQGXFWRUHQWU\GLUHFWLRQWRPDWLQJGLUHFWLRQ ‫{ ܁‬ 3K\VLFDOGDWD 3LQVSDFLQJ {PP{{LQFKHV :LGWK {PP{{LQFKHV +HLJKW {PP{{LQFKHV 'HSWK {PP{{LQFKHV 0HFKDQLFDO'DWD $SSOLFDWLRQ &RQWUROWHFKQRORJ\ &RGLQJ % 9DULDEOHFRGLQJ
770-245/064-000
物料型号: - 型号:770-245/064-000 - 描述:5针插拔式连接器,额定截面积为4.00 mm²,灰色。
器件简介: - WAGO的插拔式安装连接器适用于需要重复或按定义模式安装的应用,例如安装网格照明或嵌入式照明。 - 提供机械防错配保护,确保电气安装的安全性。 - 当与张力释放外壳配合使用时,提供符合IP20保护等级的触摸保护。
引脚分配: - 连接点:10个 - 总电位数:5个 - 连接技术:Push-in CAGE CLAMP(推入式笼夹) - 额定截面积:4mm²/12AWG - 导线入口方向与配合方向:0度
参数特性: - 额定电压:400V - 额定冲击电压:6kV - 额定电流:25A(3针负载),20A(4针和5针负载) - 保护类型:IP20(当配合并用张力释放外壳固定时为IP2xC)
功能详解: - 该连接器系统适用于建筑安装的严格要求,使电气安装变得可插拔,从而更快、更可靠、无错误。 - 通过预装的系统减少安装时间和错误。 - 提供防错配保护,简化电路,如控制器的B编码电路,例如遮阳篷和照明装置。
应用信息: - 适用于控制技术领域。 - 编码:B - 可变编码:是 - 标记:N L2L1L - 电位标记:N L2L1L
封装信息: - 引脚间距:10 mm/0.394英寸 - 宽度:50 mm/1.969英寸 - 高度:12.9 mm/0.508英寸 - 深度:37.5 mm/1.476英寸
机械数据: - 插拔连接的配合力:大约20...70 N(取决于极数) - 插拔连接的保持力:锁定时>80 N - 插拔连接的解锁力:解锁时大约20...70 N(取决于极数) - 配合周期数:200次(无电阻负载)
材料数据: - 颜色:灰色 - 材料组:I - 绝缘材料:聚酰胺(PA66) - 可燃性等级:VO - 夹紧弹簧材料:铬镍弹簧钢(CrNi) - 接触材料:铜或铜合金;表面处理 - 接触镀层:锡 - 火灾负荷:0.407 MJ
环境要求: - 处理温度:-5... +40 °C - 连续工作温度:-35... +85°C
商业数据: - eCl@ss 10.0:27-44-06-05 - eCl@ss 9.0:27-44-06-05 - ETIM 8.0:EC002560 - ETIM7.0:EC002560 - 包装类型:盒装 - 原产国:德国 - GTIN:4050821486268 - 海关关税编号:85366990990
环境产品合规性: - RoHS合规状态:符合,无豁免 - 认证/证书:cURus(UL1977),CMUS(UL1059)
770-245/064-000 价格&库存
很抱歉,暂时无法提供与“770-245/064-000”相匹配的价格&库存,您可以联系我们找货
  • 1+45.17640
  • 10+38.03760
  • 30+33.80400
  • 100+29.50560
  • 500+27.52920
  • 1000+26.63280
    • 25+37.20402
    • 77+35.37828
    • 308+33.81854
    库存:722
