770-774
770-774
    WAGO(万可电子)
    P=10mm
    接线端子 间距:10.00mm 面板安装,卡入式
770-774 数据手册
'DWDVKHHW{_,WHPQXPEHU{‫܅܈܈܁܈܈‬ 6QDSLQSOXJSROH&RG%PPOLJKWJUHHQ ZZZZDJRFRP &RORU 'LPHQVLRQVLQ{PP 3ODWHWKLFNQHVVf{PP &XWRXWWROHUDQFH{PP 3OHDVHQRWH 6XEMHFWWRFKDQJHV3OHDVHDOVRREVHUYHWKHIXUWKHUSURGXFWGRFXPHQWDWLRQ :$*2*PE+ &R.* +DQVDVWU 0LQGHQ 3KRQH_)D[ (PDLOLQIRGH#ZDJRFRP_:HEZZZZDJRFRP 'R\RXKDYHDQ\TXHVWLRQVDERXWRXUSURGXFWV" :HDUHDOZD\VKDSS\WRWDNH\RXUFDOODW   {{{{3DJH‫܁܂ ܂‬ 'DWDVKHHW{_,WHPQXPEHU{‫܅܈܈܁܈܈‬ ZZZZDJRFRP ,WHPGHVFULSWLRQ 0DOHFRQQHFWRUSOXJ:,167$‹0,',UDWHGFXUUHQW$ 7KH:,167$‹0,',PDOHFRQQHFWRUSOXJZLWKORFNLQJODWFKDOORZVLQVWDOODWLRQRIƮQHVWUDQGHGDQGVROLGFRQGXFWRUV7KHSOXJJDEOHLQVWDOODWLRQ FRQQHFWRUVZLWKVSULQJSUHVVXUHFRQQHFWLRQWHFKQRORJ\ZRUNHQWLUHO\ZLWKRXWVFUHZFRQQHFWLRQV7KH\DOORZIDVWHƱFLHQWHUURUIUHHLQVWDOODWLRQLQ QXPHURXVSRVVLEOHXVHV)RUJUHDWHUSURWHFWLRQLQHOHFWULFDOLQVWDOODWLRQVWKHSOXJJDEOHLQVWDOODWLRQFRQQHFWRULVHTXLSSHGZLWKPHFKDQLFDO SURWHFWLRQDJDLQVWPLVPDWLQJ7KHSOXJJDEOHLQVWDOODWLRQFRQQHFWRURƬHUVSURWHFWLRQDJDLQVWFRQWDFWZLWKOLYHFRPSRQHQWVLQDFFRUGDQFHZLWK SURWHFWLRQW\SH,3 :KHQPDWHG,3[& 7KHVHFRPSDFWFRQQHFWRUVDUHQRWGHVLJQHGIRUXVHLQRSHQHDVLO\DFFHVVLEOHDUHDV %FRGLQJHQDEOHV WKH:,167$‹0,',SOXJJDEOHLQVWDOODWLRQFRQQHFWRUVWREHXVHGIRUFRQWUROLQDSSOLFDWLRQVLQDXWRPDWLRQURERWLFVDQGPHFKDQLFDOHQJLQHHULQJ7KLV SOXJJDEOHLQVWDOODWLRQFRQQHFWRULVXVHGIRUHOHFWULFDOFXUUHQWVXSWR$7KXVWKHSURGXFWLVLGHDOO\VXLWDEOHIRUKLJKSRZHUORDGV:,167$‹0,', ZLWK3XVKLQ&$*(&/$03‹VSULQJSUHVVXUHFRQQHFWLRQWHFKQRORJ\LVIRXQGLQDEURDGUDQJHRILQGLYLGXDOSURGXFWV\RXFDQXVHIRUTXLFNHDV\ ưH[LEOHDQGVHFXUHLQVWDOODWLRQ /RZHUFRVWVWKURXJKIDVWFRPPLVVLRQLQJDQGHOLPLQDWLRQRIVHUYLFHH[SHQVHVsVROXWLRQVIURP:,167$‹0,', :,167$‹LVWKHSOXJJDEOHFRQQHFWLRQV\VWHPWKDWLVSHUIHFWO\WDLORUHGWRWKHVWULFWUHTXLUHPHQWVRIHOHFWULFDOLQVWDOODWLRQ,WRƬHUVHUURUIUHH LQVWDOODWLRQRIFDEOHVDQGFRPSRQHQWVTXLFNO\DQGUHOLDEO\1RZ\RXFDQDOVRUHGXFHLQVWDOODWLRQH[SHQVHVZLWKRXWFRPSURPLVLQJTXDOLW\DQGVDIHW\ 7KH:,167$‹0,',SOXJJDEOHLQVWDOODWLRQFRQQHFWRUZLWKSURWHFWLRQW\SH,3UHGXFHVWKHQHHGIRUVHUYLFLQJDQGSUHYHQWVXQQHFHVVDU\GRZQWLPH SURWHFWLRQDJDLQVWPLVPDWLQJHOLPLQDWHVHUURUV IRUDXWRPDWLRQFRQWUROOHUV ZLWK%FRGLQJIRUXVHLQDXWRPDWLRQRISURFHVVHVVXFKDVOLJKWLQJWHFKQRORJ\IRULQVWDQFH FXVWRPHQJLQHHUHGVROXWLRQV TXLFNUHSODFHPHQWRIGHIHFWLYHXQLWVGXULQJRQJRLQJRSHUDWLRQ 'DWD 1RWHV 1RWH 7KHVQDSLQFRQQHFWRUVPXVWEHUHOLHYHGRIWHQVLOHDQGWUDQVYHUVH IRUFHV $VXUIDFHƮQLVKFDQLQưXHQFHWKHHGJHUDGLXVRIWKHFXWRXWV 7KLVPD\DƬHFWWKHVQDSLQVRFNHWƮWVRHQVXUHDQDGHTXDWHƮW EHIRUHXVH ,QDGGLWLRQWKHSXQFKHGHGJHVKRXOGEHRQWKHLQVLGHIRUSXQFKHG FXWRXWV 7KHZLQJVRIWKHVQDSLQFRQQHFWRUVPXVWQRWEHPHFKDQLFDOO\ VWUHVVHGIRUDORQJSHULRGEHIRUHXVH HJGXHWRDSUHORFNLQJ SRVLWLRQ  9DULDQWV 2WKHUSROHPDUNLQJV 6XEMHFWWRFKDQJHV3OHDVHDOVRREVHUYHWKHIXUWKHUSURGXFWGRFXPHQWDWLRQ :$*2*PE+ &R.* +DQVDVWU 0LQGHQ 3KRQH_)D[ (PDLOLQIRGH#ZDJRFRP_:HEZZZZDJRFRP 'R\RXKDYHDQ\TXHVWLRQVDERXWRXUSURGXFWV" :HDUHDOZD\VKDSS\WRWDNH\RXUFDOODW   {{{{3DJH‫܁܂ ܃‬ 'DWDVKHHW{_,WHPQXPEHU{‫܅܈܈܁܈܈‬ ZZZZDJRFRP 9DULDQWV 2WKHUSROHPDUNLQJV 2WKHUYHUVLRQV RUYDULDQWV FDQEHUHTXHVWHGIURP:$*26DOHVRU FRQƮJXUHGDWKWWSVFRQƮJXUDWRUZDJRFRP (OHFWULFDOGDWD 5DWLQJVSHU,(&(1 5DWLQJVSHU ,(&(1 1RPLQDOYROWDJH ,,, ‫{ ܁܁܅‬9 5DWHGLPSXOVHYROWDJH ,,, ‫{ ܇‬N9 5DWHGFXUUHQW ‫{ ܆܃‬$ /HJHQG UDWLQJV ,,, Ε2YHUYROWDJHFDWHJRU\,,,3ROOXWLRQGHJUHH 5DWLQJVSHU,(&(1s1RWHV 1RWH UDWHGFXUUHQW $IRUSROHORDG $IRUSROHORDG 5DWLQJVSHU8/ 1RWHIRUWKH86PDUNHW 6RPHYHUVLRQVPD\DOVREHXVHGIRUFXUUHQWLQWHUUXSWLRQLQ DFFRUGDQFHZLWKWKH8/FHUWLƮFDWHLQVHOHFWDSSOLFDWLRQVZLWK FXUUHQWVEHORZ$DQGYROWDJHVXSWR9)RUIXUWKHU LQIRUPDWLRQSOHDVHFRQWDFW\RXUORFDOVDOHVRƱFH 5DWHGYROWDJH 8/ ‫{ ܁܁܇‬9 5DWHGFXUUHQW8/ ‫{ ܄܃‬$ *HQHUDOLQIRUPDWLRQ 1RWHRQFRQWDFWUHVLVWDQFH DSSUR[PƠRIFRQWDFWUHVLVWDQFH DSSUR[PƠFRQWDFWWUDQVLWLRQSOXJVRFNHW &RQQHFWLRQGDWD &RQQHFWLRQSRLQWV ‫܉‬ 7RWDOQXPEHURISRWHQWLDOV ‫܅‬ &RQQHFWLRQ &RQQHFWLRQWHFKQRORJ\ 3XVKLQ&$*(&/$03‹ $FWXDWLRQW\SH 2SHUDWLQJWRRO 3XVKLQ 1RPLQDOFURVVVHFWLRQ PP$:* 6XEMHFWWRFKDQJHV3OHDVHDOVRREVHUYHWKHIXUWKHUSURGXFWGRFXPHQWDWLRQ :$*2*PE+ &R.* +DQVDVWU 0LQGHQ 3KRQH_)D[ (PDLOLQIRGH#ZDJRFRP_:HEZZZZDJRFRP 'R\RXKDYHDQ\TXHVWLRQVDERXWRXUSURGXFWV" :HDUHDOZD\VKDSS\WRWDNH\RXUFDOODW   {{{{3DJH‫܁܂ ܄‬ 'DWDVKHHW{_,WHPQXPEHU{‫܅܈܈܁܈܈‬ ZZZZDJRFRP 1RPLQDOFURVVVHFWLRQ PP$:* 6ROLGFRQGXFWRU f{PP{f{$:* 6ROLGFRQGXFWRUSXVKLQWHUPLQDWLRQ f{PP{f{$:* 6WUDQGHGFRQGXFWRU f{PP{f{$:* )LQHVWUDQGHGFRQGXFWRU f{PP{f{$:* )LQHVWUDQGHGFRQGXFWRUZLWKLQVXODWHGIHUUXOH f{PP{f{$:* )LQHVWUDQGHGFRQGXFWRUZLWKXQLQVXODWHGIHUUXOH f{PP{f{$:* )LQHVWUDQGHGFRQGXFWRUZLWKIHUUXOHSXVKLQWHUPLQDWLRQ {PP{{$:* 6WULSOHQJWK {PP{{LQFKHV 3ROHQXPEHU ‫܅‬ &RQGXFWRUHQWU\GLUHFWLRQWRPDWLQJGLUHFWLRQ ‫{ ܁‬ 3K\VLFDOGDWD 3LQVSDFLQJ {PP{{LQFKHV :LGWK {PP{{LQFKHV +HLJKW {PP{{LQFKHV 'HSWK {PP{{LQFKHV 0HFKDQLFDO'DWD $SSOLFDWLRQ &RQWUROWHFKQRORJ\ &RGLQJ % 9DULDEOHFRGLQJ
770-774
物料型号:770-774
器件简介: - 这是WAGO品牌的接线端子,采用弹簧压力连接技术,无需焊接。 - 提供快速、安全、方便的多种用途连接。 - 具有机械防错插功能,增加电气安装的安全性。 - 提供IP20的保护等级(连接时为IP2xC),防止接触带电部件。
引脚分配: - 4极设计,适合4mm²/12AWG的导线。 - 支持不同截面积的导线连接,包括实心导线和绞合导线。
参数特性: - 额定电压:400V - 额定冲击电压:6kV - 额定电流:25A(3极负载时为20A) - 接触电阻:约为1mΩ - 连接技术:Push-in CAGE CLAMP(推入式笼夹)
功能详解: - 提供防错插保护,适用于自动化控制器等应用。 - 适用于需要快速更换故障单元的场合。 - 提供多种变体和版本,可通过WAGO销售或在线配置器定制。
应用信息: - 适用于控制技术领域。 - 产品编码为B,可变编码。 - 具有锁定杠杆,确保插头和插座安全锁定。
封装信息: - 安装类型:快插式法兰 - 材料:绝缘材料为聚酰胺(PA66),阻燃等级为VO。 - 弹簧材料:铬镍弹簧钢(CrNi) - 接触材料:铜或铜合金,表面处理。 - 接触镀层:锡 - 重量:15.9克
环境要求: - 处理温度:-5至+40°C - 持续工作温度:-35至+85°C
商业数据: - 产品组:20(Winsta) - 包装类型:盒装 - 原产国:德国(DE)
环境产品合规性: - 符合RoHS标准,无豁免。 - 获得UL认证和CE认证。
安装说明: - 推荐在端接前将预锁紧的拉紧件拉过电缆。 - 详细说明了端接细绞合导线的方法。
770-774 价格&库存
很抱歉,暂时无法提供与“770-774”相匹配的价格&库存,您可以联系我们找货
  • 1+32.15160
  • 10+27.07560
  • 30+24.05160
  • 100+21.00600
  • 500+19.59120
  • 1000+18.95400
