770-863
770-863
    WAGO(万可电子)
    插件,P=10mm
    接线端子 间距:10.00mm 1x3P 直插
770-863 数据手册
'DWDVKHHW{_,WHPQXPEHU{‫܄܇܉܁܈܈‬ 6RFNHWIRU3&%VVWUDLJKWSROH&RG%OLJKWJUHHQ ZZZZDJRFRP &RORU 6XEMHFWWRFKDQJHV3OHDVHDOVRREVHUYHWKHIXUWKHUSURGXFWGRFXPHQWDWLRQ :$*2*PE+ &R.* +DQVDVWU 0LQGHQ 3KRQH_)D[ (PDLOLQIRGH#ZDJRFRP_:HEZZZZDJRFRP 'R\RXKDYHDQ\TXHVWLRQVDERXWRXUSURGXFWV" :HDUHDOZD\VKDSS\WRWDNH\RXUFDOODW   {{{{3DJH‫܉ ܂‬ 'DWDVKHHW{_,WHPQXPEHU{‫܄܇܉܁܈܈‬ ZZZZDJRFRP ,WHPGHVFULSWLRQ )HPDOHFRQQHFWRUVRFNHW:,167$‹0,',%FRGLQJ 3HUPDQHQWO\VHFXUHHOHFWULFDOLQVWDOODWLRQVFRQQHFWLRQWHFKQRORJ\7KH:,167$‹0,',IHPDOHFRQQHFWRUVRFNHW2XUUHPDUNDEOHQXPEHURI SOXJJDEOH3&%FRQQHFWRUVZLWKGLƬHUHQWLQVHUWLRQGLUHFWLRQVDQGRSHUDWLQJYDULDQWVRƬHUV\RXWKHULJKWVROXWLRQIRU\RXUDSSOLFDWLRQDWDQ\WLPH)RU JUHDWHUSURWHFWLRQLQHOHFWULFDOLQVWDOODWLRQVWKHSFEFRQQHFWRUVLVSURYLGHGZLWKPHFKDQLFDOSURWHFWLRQDJDLQVWPLVPDWLQJ6ROXWLRQVOLNHWKH :,167$‹0,',SFEFRQQHFWRUVZLWK%FRGLQJDUHVXLWDEOHIRUDSSOLFDWLRQVLQYROYLQJSURFHVVFRQWUROVXFKDVIRUOLJKWLQJRULQGDWDQHWZRUNV ,PSRUWDQWSDUDPHWHUVLQWKHVHOHFWLRQRIDSFEFRQQHFWRUVDUHWKHUDWHGFXUUHQWDQGYROWDJH7KH\WHOOXVDERXWWKHSURGXFW VGRPDLQVRIXVH7KLV SURGXFWKDVDFXUUHQWUDWLQJRI$sVRLWLVVXLWDEOHIRUKLJKSRZHUORDGV:,167$‹0,',ZLWK3XVKLQ&$*(&/$03‹VSULQJSUHVVXUHFRQQHFWLRQ WHFKQRORJ\LVXVHGLQFDQEHIRXQGLQDYDULHW\RISURMHFWV\RXFDQXVHIRUTXLFNHDV\VHFXUHWDLORUHGHOHFWULFDOLQVWDOODWLRQ /RZHUFRVWVWKURXJKIDVWFRPPLVVLRQLQJDQGHOLPLQDWLRQRIVHUYLFHH[SHQVHVsVROXWLRQVIURP:,167$‹0,', :,167$‹LVWKHSOXJJDEOHFRQQHFWLRQV\VWHPWKDWLVRSWLPDOO\WDLORUHGWRWKHVWULFWUHTXLUHPHQWVRIHOHFWULFDOLQVWDOODWLRQ,WRƬHUVIDVWVHFXUHDQG DERYHDOOHUURUIUHHLQVWDOODWLRQRIFRPSRQHQWVDQGFDEOHV(QMR\WKHEHQHƮWVRIWKHSOXJJDEOHYHUVLRQRIRXUPDLQWHQDQFHIUHHVSULQJSUHVVXUH FRQQHFWLRQWHFKQRORJ\WRR3ODQ\RXULQVWDOODWLRQZLWKZLWKPDUNLQJIURP:$*2 HƬHFWLYHSURWHFWLRQDJDLQVWPLVPDWLQJ IRUDXWRPDWLRQFRQWUROOHUV IRUDXWRPDWLRQFRQWUROOHUV TXLFNUHSODFHPHQWRIGHIHFWLYHXQLWVGXULQJRQJRLQJRSHUDWLRQ 'DWD 1RWHV 9DULDQWV 2WKHUSROHPDUNLQJV 2WKHUYHUVLRQV RUYDULDQWV FDQEHUHTXHVWHGIURP:$*26DOHVRU FRQƮJXUHGDWKWWSVFRQƮJXUDWRUZDJRFRP (OHFWULFDOGDWD 5DWLQJVSHU,(&(1 5DWLQJVSHU ,(&(1 1RPLQDOYROWDJH ,,, ‫{ ܁܆܃‬9 5DWHGLPSXOVHYROWDJH ,,, ‫{ ܅‬N9 5DWHGFXUUHQW ‫{ ܆܃‬$ /HJHQG UDWLQJV ,,, Ε2YHUYROWDJHFDWHJRU\,,,3ROOXWLRQGHJUHH 6XEMHFWWRFKDQJHV3OHDVHDOVRREVHUYHWKHIXUWKHUSURGXFWGRFXPHQWDWLRQ :$*2*PE+ &R.* +DQVDVWU 0LQGHQ 3KRQH_)D[ (PDLOLQIRGH#ZDJRFRP_:HEZZZZDJRFRP 'R\RXKDYHDQ\TXHVWLRQVDERXWRXUSURGXFWV" :HDUHDOZD\VKDSS\WRWDNH\RXUFDOODW   {{{{3DJH‫܉ ܃‬ 'DWDVKHHW{_,WHPQXPEHU{‫܄܇܉܁܈܈‬ ZZZZDJRFRP /HJHQG UDWLQJV ,,, Ε2YHUYROWDJHFDWHJRU\,,,3ROOXWLRQGHJUHH 5DWLQJVSHU8/ 1RWHIRUWKH86PDUNHW 6RPHYHUVLRQVPD\DOVREHXVHGIRUFXUUHQWLQWHUUXSWLRQLQ DFFRUGDQFHZLWKWKH8/FHUWLƮFDWHLQVHOHFWDSSOLFDWLRQVZLWK FXUUHQWVEHORZ$DQGYROWDJHVXSWR9)RUIXUWKHU LQIRUPDWLRQSOHDVHFRQWDFW\RXUORFDOVDOHVRƱFH 5DWHGYROWDJH 8/ ‫{ ܁܁܇‬9 5DWHGFXUUHQW8/ ‫{ ܄܃‬$ *HQHUDOLQIRUPDWLRQ 1RWHRQFRQWDFWUHVLVWDQFH DSSUR[PƠRIFRQWDFWUHVLVWDQFH DSSUR[PƠFRQWDFWWUDQVLWLRQSOXJVRFNHW &RQQHFWLRQGDWD 7RWDOQXPEHURISRWHQWLDOV ‫܄‬ 1XPEHURIOHYHOV ‫܂‬ &RQQHFWLRQ 3ROHQXPEHU ‫܄‬ 3K\VLFDOGDWD 3LQVSDFLQJ {PP{{LQFKHV :LGWK {PP{{LQFKHV +HLJKW {PP{{LQFKHV +HLJKWIURPWKHVXUIDFH {PP{{LQFKHV 'HSWK {PP{{LQFKHV 6ROGHUSLQOHQJWK ‫{ ܆܄‬PP 6ROGHUSLQGLPHQVLRQV [{PP 'ULOOHGKROHGLDPHWHUZLWKWROHUDQFH ‫܂܁ {܆܂‬f‫{ ܂܁ۿ‬PP 0HFKDQLFDO'DWD $SSOLFDWLRQ &RQWUROWHFKQRORJ\ &RGLQJ % 9DULDEOHFRGLQJ
770-863
物料型号:WAGO 770-863
器件简介: - WAGO 770-863是用于PCB的直式三极插座,提供机械防误插保护,适用于电气安装,特别是自动化控制器和过程控制应用。
引脚分配: - 引脚间距:10 mm/0.394英寸 - 宽度:27 mm/1.063英寸 - 高度:29.5 mm/1.161英寸 - 从表面高度:26 mm/1.024英寸 - 深度:14.6 mm/0.575英寸 - 焊盘长度:3.5 mm - 焊盘尺寸:1x0.8 mm
参数特性: - 额定电压:250V - 额定脉冲电压:4kV - 额定电流:25A - 接触电阻:约1 mΩ - 连接数据:3个电位,1个级别
功能详解: - 提供快速、安全、无误的组件和电缆安装 - 有效防误插保护 - 适用于自动化控制器 - 在运行中快速更换故障单元
应用信息: - 适用于控制技术 - 编码:B - 可变编码:是 - 标记:123
封装信息: - 颜色:浅绿色 - 绝缘材料:聚酰胺(PA66) - 阻燃等级:UL94 VO - 夹紧弹簧材料:铬镍弹簧钢(CrNi)
环境要求: - 加工温度:-5... +40 °C - 连续工作温度:-35... +85°C
商业数据: - 产品组:20(WINSTA) - eCl@ss 10.0:27-44-06-05 - ETIM 8.0:EC002560 - 包装类型:盒装 - 原产国:PL - GTIN:4050821458227
环境产品合规性: - RoHS合规状态:合规,无豁免 - 认证/证书:DEKRA Certification B.V. /RJR $SSURYDO &&$ &&$ QDPH NL-32104 173495.01 KEMR DEKRA Certification B.V. Underwriters Laboratories Inc. F85XV E45171 c9UUS
安装说明: - WINSTA MIDI系列提供所有产品 - 还提供了所需的配件和CAD/CAE数据,以方便PCB设计集成。
770-863 价格&库存
很抱歉,暂时无法提供与“770-863”相匹配的价格&库存,您可以联系我们找货
