770-864/011-000/073-000
    WAGO(万可电子)
    插件,P=10mm
    接线端子 间距:10.00mm 1x4P 直插
770-864/011-000/073-000 数据手册
'DWDVKHHW{_,WHPQXPEHU{‫܁܁܁܄܈܁܁܁܁܂܂܁܅܇܉܁܈܈‬ 6RFNHWIRU3&%VDQJOHGSROH&RG%OLJKWJUHHQ ZZZZDJRFRP &RORU 6XEMHFWWRFKDQJHV3OHDVHDOVRREVHUYHWKHIXUWKHUSURGXFWGRFXPHQWDWLRQ :$*2*PE+ &R.* +DQVDVWU 0LQGHQ 3KRQH_)D[ (PDLOLQIRGH#ZDJRFRP_:HEZZZZDJRFRP 'R\RXKDYHDQ\TXHVWLRQVDERXWRXUSURGXFWV" :HDUHDOZD\VKDSS\WRWDNH\RXUFDOODW   {{{{3DJH‫܈ ܂‬ 'DWDVKHHW{_,WHPQXPEHU{‫܁܁܁܄܈܁܁܁܁܂܂܁܅܇܉܁܈܈‬ ZZZZDJRFRP ,WHPGHVFULSWLRQ )HPDOHFRQQHFWRUVRFNHW:,167$‹0,',%FRGLQJ 7KH:,167$‹0,',IHPDOHFRQQHFWRUVRFNHW%FRGLQJDUHFRPSDFWEXWRXWVWDQGLQJ3&%WHUPLQDOEORFNV7KH\RƬHUFRQYHQLHQWRSHUDWLRQDQGWKH JUHDWHVWưH[LELOLW\IRULQVWDOODWLRQ7KHSOXJJDEOH3&%FRQQHFWRUVZLWKVSULQJSUHVVXUHFRQQHFWLRQWHFKQRORJ\DQG3XVKLQ&$*(&/$03‹ WHFKQRORJ\IURP:$*2SHUPLWLPSDFWUHVLVWDQWPDLQWHQDQFHIUHHIDVWWHUPLQDOFRQQHFWLRQV7KHFRGLQJRSWLRQVUHGXFHLQVWDOODWLRQHUURUV DOORZLQJIDVWVHFXUHZLULQJRIDOOFRPSRQHQWV6ROXWLRQVOLNHWKH:,167$‹0,',SFEFRQQHFWRUVZLWK%FRGLQJDUHVXLWDEOHIRUDSSOLFDWLRQVUHODWHGWR SURFHVVFRQWUROIRUH[DPSOHIRUOLJKWLQJRUZLWKLQGDWDQHWZRUNV7KLVSFEFRQQHFWRUVFDQEHHPSOR\HGIRUDFXUUHQWORDGRIXSWR$7KHUHIRUH SFEFRQQHFWRUVFDQDOVREHXVHGIRUKLJKSRZHUORDGV2XU:,167$‹0,',SURGXFWOLQHRƬHUVưH[LELOLW\IRUWKHLQVWDOODWLRQRIDSSOLFDWLRQV7KURXJK LWV3XVKLQ&$*(&/$03‹VSULQJSUHVVXUHFRQQHFWLRQWHFKQRORJ\LWJXDUDQWHHVHUURUIUHHWLPHVDYLQJLQVWDOODWLRQDQGRƬHUVưH[LELOLW\IRUPHHWLQJ DQHQRUPRXVYDULHW\RILQVWDOODWLRQUHTXLUHPHQWV :,167$‹0,',VROXWLRQVIRU\RXUHOHFWULFDOLQVWDOODWLRQsSURWHFWHGDJDLQVWPLVPDWLQJDQGPDLQWHQDQFHIUHH 7KH:,167$‹3OXJJDEOH&RQQHFWLRQ6\VWHPLVSHUIHFWO\WDLORUHGWRWKHVWULFWUHTXLUHPHQWVRIEXLOGLQJLQVWDOODWLRQ,WPDNHVHOHFWULFDOLQVWDOODWLRQ SOXJJDEOHDQGFRQVHTXHQWO\PRUHHƱ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ƮJXUHGDWKWWSVFRQƮJXUDWRUZDJRFRP (OHFWULFDOGDWD 5DWLQJVSHU,(&(1 5DWLQJVSHU ,(&(1 1RPLQDOYROWDJH ,,, ‫{ ܁܁܅‬9 6XEMHFWWRFKDQJHV3OHDVHDOVRREVHUYHWKHIXUWKHUSURGXFWGRFXPHQWDWLRQ :$*2*PE+ &R.* +DQVDVWU 0LQGHQ 3KRQH_)D[ (PDLOLQIRGH#ZDJRFRP_:HEZZZZDJRFRP 'R\RXKDYHDQ\TXHVWLRQVDERXWRXUSURGXFWV" :HDUHDOZD\VKDSS\WRWDNH\RXUFDOODW   {{{{3DJH‫܈ ܃‬ 'DWDVKHHW{_,WHPQXPEHU{‫܁܁܁܄܈܁܁܁܁܂܂܁܅܇܉܁܈܈‬ ZZZZDJRFRP 1RPLQDOYROWDJH ,,, ‫{ ܁܁܅‬9 5DWHGLPSXOVHYROWDJH ,,, ‫{ ܇‬N9 5DWHGFXUUHQW ‫{ ܆܃‬$ /HJHQG UDWLQJV ,,, Ε2YHUYROWDJHFDWHJRU\,,,3ROOXWLRQGHJUHH 5DWLQJVSHU,(&(1s1RWHV 1RWH UDWHGFXUUHQW $IRUSROHORDG $IRUSROHORDG 5DWLQJVSHU8/ 1RWHIRUWKH86PDUNHW 6RPHYHUVLRQVPD\DOVREHXVHGIRUFXUUHQWLQWHUUXSWLRQLQ DFFRUGDQFHZLWKWKH8/FHUWLƮFDWHLQVHOHFWDSSOLFDWLRQVZLWK FXUUHQWVEHORZ$DQGYROWDJHVXSWR9)RUIXUWKHU LQIRUPDWLRQSOHDVHFRQWDFW\RXUORFDOVDOHVRƱFH 5DWHGYROWDJH 8/ ‫{ ܁܁܇‬9 5DWHGFXUUHQW8/ ‫{ ܄܃‬$ *HQHUDOLQIRUPDWLRQ 1RWHRQFRQWDFWUHVLVWDQFH DSSUR[PƠRIFRQWDFWUHVLVWDQFH DSSUR[PƠFRQWDFWWUDQVLWLRQSOXJVRFNHW &RQQHFWLRQGDWD 7RWDOQXPEHURISRWHQWLDOV ‫܅‬ 1XPEHURIOHYHOV ‫܂‬ &RQQHFWLRQ 3ROHQXPEHU ‫܅‬ 3K\VLFDOGDWD 3LQVSDFLQJ {PP{{LQFKHV :LGWK {PP{{LQFKHV +HLJKW {PP{{LQFKHV +HLJKWIURPWKHVXUIDFH {PP{{LQFKHV 'HSWK {PP{{LQFKHV 6ROGHUSLQOHQJWK ‫{ ܆܄‬PP 6ROGHUSLQGLPHQVLRQV [{PP 'ULOOHGKROHGLDPHWHUZLWKWROHUDQFH ‫܂܁ {܆܂‬f‫{ ܂܁ۿ‬PP 6XEMHFWWRFKDQJHV3OHDVHDOVRREVHUYHWKHIXUWKHUSURGXFWGRFXPHQWDWLRQ :$*2*PE+ &R.* +DQVDVWU 0LQGHQ 3KRQH_)D[ (PDLOLQIRGH#ZDJRFRP_:HEZZZZDJRFRP 'R\RXKDYHDQ\TXHVWLRQVDERXWRXUSURGXFWV" :HDUHDOZD\VKDSS\WRWDNH\RXUFDOODW   {{{{3DJH‫܈ ܄‬ 'DWDVKHHW{_,WHPQXPEHU{‫܁܁܁܄܈܁܁܁܁܂܂܁܅܇܉܁܈܈‬ ZZZZDJRFRP ‫܂܁ {܆܂‬f‫{ ܂܁ۿ‬PP 0HFKDQLFDO'DWD $SSOLFDWLRQ &RQWUROWHFKQRORJ\ &RGLQJ % 9DULDEOHFRGLQJ
物料型号:WAGO 插座,型号 770-864/011-000/073-000
器件简介: - 该插座设计用于 PCB,具有 4 个极点,带角度,采用 B 编码,颜色为浅绿色。 - 使用 WAGO 的 Push-in CAGE CLAMP 技术和弹簧压力连接技术,实现抗冲击、免维护、快速的终端连接。 - 带有编码选项减少安装错误,适用于过程控制,例如照明或数据网络。
引脚分配: - 极点数:4 - 引脚间距:10 mm/0.394 英寸
参数特性: - 额定电压(L/N):400V - 额定脉冲电压(L/N):6kV - 额定电流:3 极负载时 25A,4 极负载时 20A - 接触电阻:大约 1 毫欧(mΩ)
功能详解: - 提供防错配保护,100% 防止不同极数的插头插入错误。 - 带有锁定杆,确保插头和插座安全锁定。
应用信息: - 适用于控制技术,编码为 B。 - 可用于过程自动化,如照明技术。
封装信息: - 物理尺寸:宽 37 mm/1.457 英寸,高 18.1 mm/0.713 英寸,从表面高度 14.6 mm/0.575 英寸,深度 26 mm/1.024 英寸。 - 焊接引脚长度:3.5mm,尺寸:1x0.8 mm - 钻孔直径:1.5 ± 0.1 mm
其他信息: - 材料:绝缘材料为聚酰胺(PA66),阻燃等级为 UL94 VO。 - 环境要求:加工温度 -5...+40 °C,连续工作温度 -35...+85°C。 - 符合 RoHS 标准,拥有 QDPH 证书。
技术支持: - 提供 CAD/CAE 数据,支持多种 PCB 设计软件格式。
770-864/011-000/073-000 价格&库存
很抱歉,暂时无法提供与“770-864/011-000/073-000”相匹配的价格&库存,您可以联系我们找货
