770-865/073-000
770-865/073-000
    WAGO(万可电子)
    插件,P=10mm
    接线端子 间距:10.00mm 1x5P 直插
770-865/073-000 数据手册
'DWDVKHHW{_,WHPQXPEHU{‫܁܁܁܄܈܁܆܇܉܁܈܈‬ 6RFNHWIRU3&%VVWUDLJKWSROH&RG%OLJKWJUHHQ ZZZZDJRFRP &RORU 6XEMHFWWRFKDQJHV3OHDVHDOVRREVHUYHWKHIXUWKHUSURGXFWGRFXPHQWDWLRQ :$*2*PE+ &R.* +DQVDVWU 0LQGHQ 3KRQH_)D[ (PDLOLQIRGH#ZDJRFRP_:HEZZZZDJRFRP 'R\RXKDYHDQ\TXHVWLRQVDERXWRXUSURGXFWV" :HDUHDOZD\VKDSS\WRWDNH\RXUFDOODW   {{{{3DJH‫܈ ܂‬ 'DWDVKHHW{_,WHPQXPEHU{‫܁܁܁܄܈܁܆܇܉܁܈܈‬ ZZZZDJRFRP ,WHPGHVFULSWLRQ )HPDOHFRQQHFWRUVRFNHW:,167$‹0,',ZLWKSURWHFWLRQDJDLQVWPLVPDWLQJ 7KH:,167$‹0,',IHPDOHFRQQHFWRUVRFNHWSROHSD\VRƬDQGVSDFHWKDQNVWRLWVFRPSDFWGLPHQVLRQV2XUSOXJJDEOH3&%FRQQHFWRUVSURYLGHD XQLYHUVDOSOXJJDEOHFRQQHFWLRQV\VWHPIRU\RXUGHYLFHVWKDWPHHWVDOOWKHFRQGLWLRQVIRUDVWDEOHGHYLFHFRQQHFWLRQ7KHFRGLQJRSWLRQVUHGXFH LQVWDOODWLRQHUURUVDOORZLQJIDVWPDLQWHQDQFHIUHHZLULQJRIDOOFRPSRQHQWV%FRGLQJHQDEOHVWKH:,167$‹0,',SFEFRQQHFWRUVWREHXVHGIRU DSSOLFDWLRQFRQWUROLQWKHGRPDLQVRIDXWRPDWLRQURERWLFVDQGPHFKDQLFDOHQJLQHHULQJ7KLVSFEFRQQHFWRUVLVXVHGIRUHOHFWULFDOFXUUHQWVXSWR $7KXVWKHSURGXFWLVHVSHFLDOO\VXLWDEOHIRUKLJKSRZHUORDGV7KH:,167$‹0,',SURGXFWOLQHRƬHUVPD[LPXPưH[LELOLW\IRUWKHLQVWDOODWLRQ:LWKLWV 3XVKLQ&$*(&/$03‹VSULQJSUHVVXUHFRQQHFWLRQWHFKQRORJ\LWDFKLHYHVHUURUIUHHWLPHVDYLQJLQVWDOODWLRQDQGRƬHUVưH[LELOLW\DQG FXVWRPL]DWLRQIRUPHHWLQJDOOLQVWDOODWLRQUHTXLUHPHQWV :,167$‹0,',VROXWLRQVIRU\RXUHOHFWULFDOLQVWDOODWLRQsSURWHFWHGDJDLQVWPLVPDWLQJDQGPDLQWHQDQFHIUHH 7KH:,167$‹3OXJJDEOH&RQQHFWLRQ6\VWHPDOORZVSOXJJDEOHHOHFWULFDOLQVWDOODWLRQ7KLVVDYHVWLPHORZHUVFRVWVDQGUHGXFHVWKHQHHGIRU VHUYLFLQJ&KRRVHTXDOLW\DQGGXUDELOLW\sZLWKPDUNLQJIURP:$*2PDNHVWKHLQVWDOODWLRQRIHOHFWULFDOFRPSRQHQWVYLVLEO\HDVLHU SFEFRQQHFWRUVZLWKSURWHFWLRQDJDLQVWPLVPDWLQJ IRUDXWRPDWLRQFRQWUROOHUV ZLWK%FRGLQJIRUXVHLQSURFHVVDXWRPDWLRQVXFKDVOLJKWLQJWHFKQRORJ\IRULQVWDQFH UDSLGVWUXFWXUHGHOHFWULFDOLQVWDOODWLRQ 'DWD 1RWHV 9DULDQWV 2WKHUSROHPDUNLQJV 2WKHUYHUVLRQV RUYDULDQWV FDQEHUHTXHVWHGIURP:$*26DOHVRU FRQƮJXUHGDWKWWSVFRQƮJXUDWRUZDJRFRP (OHFWULFDOGDWD 5DWLQJVSHU,(&(1 5DWLQJVSHU ,(&(1 1RPLQDOYROWDJH ,,, ‫{ ܁܁܅‬9 5DWHGLPSXOVHYROWDJH ,,, ‫{ ܇‬N9 5DWHGFXUUHQW ‫{ ܆܃‬$ 6XEMHFWWRFKDQJHV3OHDVHDOVRREVHUYHWKHIXUWKHUSURGXFWGRFXPHQWDWLRQ :$*2*PE+ &R.* +DQVDVWU 0LQGHQ 3KRQH_)D[ (PDLOLQIRGH#ZDJRFRP_:HEZZZZDJRFRP 'R\RXKDYHDQ\TXHVWLRQVDERXWRXUSURGXFWV" :HDUHDOZD\VKDSS\WRWDNH\RXUFDOODW   {{{{3DJH‫܈ ܃‬ 'DWDVKHHW{_,WHPQXPEHU{‫܁܁܁܄܈܁܆܇܉܁܈܈‬ ZZZZDJRFRP 5DWHGFXUUHQW ‫{ ܆܃‬$ /HJHQG UDWLQJV ,,, Ε2YHUYROWDJHFDWHJRU\,,,3ROOXWLRQGHJUHH 5DWLQJVSHU,(&(1s1RWHV 1RWH UDWHGFXUUHQW $IRUSROHORDG $IRUDQGSROHORDG 5DWLQJVSHU8/ 1RWHIRUWKH86PDUNHW 6RPHYHUVLRQVPD\DOVREHXVHGIRUFXUUHQWLQWHUUXSWLRQLQ DFFRUGDQFHZLWKWKH8/FHUWLƮFDWHLQVHOHFWDSSOLFDWLRQVZLWK FXUUHQWVEHORZ$DQGYROWDJHVXSWR9)RUIXUWKHU LQIRUPDWLRQSOHDVHFRQWDFW\RXUORFDOVDOHVRƱFH 5DWHGYROWDJH 8/ ‫{ ܁܁܇‬9 5DWHGFXUUHQW8/ ‫{ ܄܃‬$ *HQHUDOLQIRUPDWLRQ 1RWHRQFRQWDFWUHVLVWDQFH DSSUR[PƠRIFRQWDFWUHVLVWDQFH DSSUR[PƠFRQWDFWWUDQVLWLRQSOXJVRFNHW &RQQHFWLRQGDWD 7RWDOQXPEHURISRWHQWLDOV ‫܆‬ 1XPEHURIOHYHOV ‫܂‬ &RQQHFWLRQ 3ROHQXPEHU ‫܆‬ 3K\VLFDOGDWD 3LQVSDFLQJ {PP{{LQFKHV :LGWK {PP{{LQFKHV +HLJKW {PP{{LQFKHV +HLJKWIURPWKHVXUIDFH {PP{{LQFKHV 'HSWK {PP{{LQFKHV 6ROGHUSLQOHQJWK ‫{ ܆܄‬PP 6ROGHUSLQGLPHQVLRQV [{PP 'ULOOHGKROHGLDPHWHUZLWKWROHUDQFH ‫܂܁ {܆܂‬f‫{ ܂܁ۿ‬PP 6XEMHFWWRFKDQJHV3OHDVHDOVRREVHUYHWKHIXUWKHUSURGXFWGRFXPHQWDWLRQ :$*2*PE+ &R.* +DQVDVWU 0LQGHQ 3KRQH_)D[ (PDLOLQIRGH#ZDJRFRP_:HEZZZZDJRFRP 'R\RXKDYHDQ\TXHVWLRQVDERXWRXUSURGXFWV" :HDUHDOZD\VKDSS\WRWDNH\RXUFDOODW   {{{{3DJH‫܈ ܄‬ 'DWDVKHHW{_,WHPQXPEHU{‫܁܁܁܄܈܁܆܇܉܁܈܈‬ ZZZZDJRFRP 0HFKDQLFDO'DWD $SSOLFDWLRQ &RQWUROWHFKQRORJ\ &RGLQJ % 9DULDEOHFRGLQJ
770-865/073-000
物料型号:770-865/073-000
器件简介:WAGO的WINSTA MIDI解决方案是用于自动化控制器的通用插拔式连接系统,适用于自动化、机器人技术、机械工程等领域。该PCB连接器用于电气电流高达25A,具有防错接保护,确保安装的安全性和可靠性。
引脚分配:该连接器为5针,引脚间距为10毫米,具有2个串联焊盘/引脚。
参数特性: - 额定电压:400V(I/3) - 额定冲击电压:6kV(I/3) - 额定电流:25A(3针负载),20A(4针和5针负载) - 额定电压(UL 1977):600V - 额定电流(UL 1977):23A - 接触电阻:约1毫欧(接触电阻),约0.25毫欧(接触过渡插孔/插座)
功能详解: - 编码选项:B编码,可变编码 - 防错接保护:所有WINSTA组件在不同引脚数、旋转180度、横向错位或单引脚插入时均100%防错接 - 锁销杠杆:是,用于确保插头和插座安全锁定
应用信息: - 应用领域:控制技术 - 适用环境:处理温度-5... +40 °C,连续工作温度-35... +85°C - 材料:绝缘材料为聚酰胺(PA66),阻燃等级为UL94 V0,接触材料为铜或铜合金,表面处理为锡
封装信息: - 颜色:浅绿色 - 尺寸:宽47毫米,高29.5毫米,从表面高度26毫米,深度14.6毫米 - 重量:10.5克 - 包装类型:盒装,每盒50个
环境产品合规性:符合RoHS标准,无豁免。
附加信息: - 提供CAD/CAE数据,支持多种EDA软件格式,如Accel EDA、Altium、Cadence Allegro、Eagle Libraries等。
770-865/073-000 价格&库存
很抱歉,暂时无法提供与“770-865/073-000”相匹配的价格&库存,您可以联系我们找货
