CFM25S240-E
CFM25S240-E
    CINCON
    DIP6 模块
    封闭式 AC DC 转换器 1 输出 24V 1.05A 90 ~ 264 VAC 输入
CFM25S240-E 数据手册
CFM25S SERIES 25 WATT OPEN FRAME AC-DC MODULES Features  Universal Input Range 90~264Vac  High Efficiency up to 87%  2”x 1.1” Open Frame Compact Size  Class II  No Load Input Power < 0.1W  Approval IEC/EN/UL 62368-1 Ed 3.0  Approval IEC/EN 60335-1  Approval EN 55032 Class B and CISPR/FCC Class B  Operating Altitude 5000m  Continuous Short Circuit Protection  Over Voltage Protection  Peak Load (2 Times of Rated Current (note7))  Over Voltage Category OVC II & OVC III VOLTAGE RIPPLE& LINE LOAD ACCURACY NOISE REGULATION REGULATION (Typ.) NOTE1 NOTE2 NOTE3 NOTE4 NOTE5 4.0 A ±2% 50mV ±1% ±1% 81% 12 V 2.1 A ±1% 120mV ±1% ±1% 84% CFM25S150 15 V 1.67 A ±1% 150mV ±1% ±1% 85% CFM25S240 24 V 1.05 A ±1% 240mV ±1% ±1% 86% CFM25S360 36 V 0.7 A ±1% 360mV ±1% ±1% 87% CFM25S480 48 V 0.52 A ±1% 480mV ±1% ±1% 87% MODEL OUTPUT OUTPUT NUMBER VOLTAGE CURRENT CFM25S050 5V CFM25S120 %EFF. Note: 1. Voltage accuracy is set at 100% full load. 2. Add a 0.1uF ceramic capacitor and a 10uF E.L. capacitor to output for ripple & noise measurement @20MHz BW. 3. Line regulation is measured from 90Vac to 264Vac with 100% full load. 4. Load regulation is measured from 10% to 100% full load. 5. Typical efficiency at 230 Vac and 100% full load at 25℃. 6. T Version wafer with JST B3B-XH/B4B-XH and mate with JST housing XH series or equivalent. 7. PL (peak load function) lasting time 95% Reduction Criterion A Voltage Interruptions IEC 61000-4-11:2020, >95% Reduction Criterion B Application Note Link CFM25S Series App Notes CHARACTERISTIC CURVE Power Derating Curve CFM250S120(-T),CFM25S150(-T) CFM25S240(-T),CFM250S360(-T) CFM25S480(-T), CFM25SXXX-E CFM250S050(-T) 100% Rated Load (%) Rated Load (%) 100% 75% 50% 25% 20LFM(Natural Convection) 75% 50% 25% 20LFM(Natural Convection) 0% 0% -30 -20 -10 0 10 20 30 40 50 -30 60 -20 -10 0 10 20 30 40 50 60 70 Ambient Temperature (℃) Ambient Temperature (℃) Performance Data CFM25S050 (Eff Vs Io) CFM25S120 (Eff Vs Io) 90% Efficiency (%) Efficiency (%) 85% 80% 115V 85% 115V 80% 230V 75% 10% 20% 30% 40% 50% 60% 70% 80% 230V 75% 10% 90% 100% 20% 30% Current Load (%) 50% 60% 70% 80% CFM25S150 (Eff Vs Io) CFM25S240 (Eff Vs Io) Efficiency (%) 90% 85% 80% 115V 85% 80% 115V 230V 75% 10% 90% 100% Current Load (%) 90% Efficiency (%) 40% 20% 30% 40% 50% 60% 70% 80% 230V 90% 100% Current Load (%) www.cincon.com 75% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) 4 REVISION: V18 CFM25S CFM25S360 (Eff Vs Io) CFM25S480 (Eff Vs Io) 90% Efficiency (%) 90% Efficiency (%) Series 85% 80% 115V 85% 80% 115V 230V 75% 10% 20% 30% 40% 50% 60% 70% 80% 230V 90% 100% 75% 10% 20% 30% 40% Current Load (%) 50% 60% 70% 80% 90% 100% Current Load (%) MECHANICAL SPECIFICATION CFM25SXXX-E BOTTOM VIEW 3 4 0.145[3.69] 0.145[3.69] 1.800[45.72] 2.091[53.10] 5 All Dimensions are in inches[mm] Tolerance:Inches:X.XXX±0.02 Millimeters:X.XX±0.5 0.400[10.16] 1 1.800[45.72] www.cincon.com 1.193[30.30] 2 Φ0.039[1.00] Φ0.071[1.80] PIN CONNECTION Pin Function 1 ACL 2 ACN 3 +Vout 4 -Vout 0.136[3.46] 0.800[20.32] Φ0.039[1.00] 0.205[5.20] 0.610[15.50] 0.098[2.50]max 0.150[3.80] 0.173[4.40] 0.257 [6.52] 3 2 0.980[24.90]max 1.100[27.94] 4 0.976[24.80] 0.100[2.54] 0.768[19.50]max 0.210[5.34] 2.000[50.80] 0.100[2.54] 1 0.800[20.32] 0.090[2.28] 0.400[10.16] CFM25SXXX REVISION: V18 CFM25S CFM25SXXX PL Series CFM25SXXX-E PL 2.000[50.80] 1.193[30.30] Φ0.039[1.00] 0.800[20.32] 0.768[19.50]max PIN CONNECTION 2 3 BOTTOM VIEW 1 4 5 Φ0.039[1.00] 6 0.100[2.54] 0.136[3.46] Φ0.039[1.00] Φ0.071[1.80] 1.800[45.72] 0.337[8.56] 0.145[3.69] Pin 1 2 3 4 5 6 Function ACL ACN +Vout -Vout BC+(Optional) BC-(Optional) All Dimensions are in inches[mm] Tolerance:Inches:X.XXX±0.02 Millimeters:X.XX±0.5 0.400[10.16] 3 2 0.136[3.46] 1.100[27.94] 4 0.976[24.80] 1 0.098[2.50]max 0.800[20.32] 0.090[2.28] 0.173[4.40] 6 0.150[3.80] 0.323[8.20] 0.100[2.54] 5 0.980[24.90]max 0.100[2.54] 0.100[2.54] 0.205[5.20] 0.400[10.16] 0.292[7.41] 1.800[45.72] 2.091[53.10] 0.125[3.18] CFM25SXXX-T 2.776 [70.50] 2.500 [63.50] 3 CN2 1 4 1.100 [27.94] ] 8[Φ3.50 4-Φ0.13 CN1 1 0.138 [3.50] 0.850 [21.59] 0.138 [3.50] All Dimensions In Inches[mm] Tolerance Inches:x.xxx= ± 0.02 Millimeters: x.xx = ± 0.5 0.906 [23.00]max 0.098 [2.50]max 0.125 [3.18] 0.768 [19.50]max AC Input Connector(CN1):JST B3B-XH-A(LF)(SN)(2N) or equivalent Pin 1 2 3 Function Mating Housing Terminal ACL JST JST XHP-3 or equivalent SXH-001T-P0.6N or equivalent ACN DC Output Connector(CN2):JST B4B-XH-A(LF)(SN) or equivalent Pin 1 2 3 4 Function Mating Housing -Vout -Vout JST XHP-4 or equivalent +Vout +Vout Terminal JST SXH-001T-P0.6N or equivalent sales@cincon.com.tw www.cincon.com 6 REVISION: V18
CFM25S240-E 价格&库存
很抱歉,暂时无法提供与“CFM25S240-E”相匹配的价格&库存,您可以联系我们找货
