KL8171
KL8171
    KINGLIGHT(晶台)
    DIP-4
    晶体管光耦(DC),电流传输比100~350%,正向电压1.2V,反向电流10uA,Min击穿电压70V,Max暗电流100nA,隔离电压5000V,总消耗功率170mW,工作温度-30~+100℃,...
KL8171 数据手册
KL8171 Datasheet KL8171 PHOTO TRANSISTOR DIP4 晶体管光耦 提供隔离反馈,逻辑电路之间的接口,带基极引脚高可靠输出光耦 *本文档中包含的信息反映了具有代表性的使用场景,仅供技术参考。 The information contained in this document reflects representative usage scenarios and is intended for technical reference only. *本文档中提到的产品型号和规格如有更改或改进,恕不另行通知。在生产使用之前,客户应参考产品规格书的最新数据表。 Product models and specifications mentioned in this document are subject to change or improvement without notice. Customers should refer to the latest data sheets in the product specifications prior to production use. *在使用本文档中引用的产品时,请确保产品在数据手册中规定的环境和电气限制范围内运行。如果客户使用超过指定的限制,晶台将不会对任何后续问 题负责。 When using the products referenced in this document, ensure that the products are operated within the environmental and electrical limits specified in the data sheet. If the customer uses the product beyond the specified limits, Kinglight will not be responsible for any subsequent problems. *本文档中的信息适用于电子元器件应用中的典型用法。如有任何特殊用途,请向晶台咨询,以获得进一步的帮助。 The information in this document applies to typical use in electronic component applications. For special applications, please contact Kinglight for further assistance. *未经晶台允许,不得复制或转载本文件的内容和信息。对于最新的信息,请参考官方网站 Http://www.kinglight-OC.com。 The contents and information in this document may not be copied or reproduced without the permission of Kinglight. For the latest information, please visit the official website Http://www.kinglight-OC.com. KL8171 Datasheet 1. 产品特点 Product features • 电流转换率(Current transfer ratio) CTR: 100~350% at IF =0.5mA, VCE =5V • 输入与输出高隔离电压(Viso=5000 V rms) High isolation voltage between inputs and output (Viso=5000 V rms) • 爬电距离大于7.62mm Creepage distance >7.62mm • 工作温度可达+100℃ Operating temperature up to +100°C • 4PIN引脚封装模式 4PIN DIP encapsulation mode • 符合无卤素(溴
KL8171 价格&库存
很抱歉,暂时无法提供与“KL8171”相匹配的价格&库存,您可以联系我们找货
