KL851
KL851
    KINGLIGHT(晶台)
    DIP-4
    晶体管光耦(DC),电流传输比50~600%,正向电压1.2V,反向电流10uA,Min击穿电压350V,Max暗电流100nA,隔离电压5000V,总消耗功率200mW,上升时间4us,下降时间5u...
KL851 数据手册
KL851 Datasheet KL851 HIGH VOLTAGE PHOTO TRANSISTOR DIP4 高压晶体管光耦 *本文档中包含的信息反映了具有代表性的使用场景,仅供技术参考。 The information contained in this document reflects representative usage scenarios and is intended for technical reference only. *本文档中提到的产品型号和规格如有更改或改进,恕不另行通知。在生产使用之前,客户应参考产品规格书的最新数据表。 Product models and specifications mentioned in this document are subject to change or improvement without notice. Customers should refer to the latest data sheets in the product specifications prior to production use. *在使用本文档中引用的产品时,请确保产品在数据手册中规定的环境和电气限制范围内运行。如果客户使用超过指定的限制,晶台将不会对任何后续问 题负责。 When using the products referenced in this document, ensure that the products are operated within the environmental and electrical limits specified in the data sheet. If the customer uses the product beyond the specified limits, Kinglight will not be responsible for any subsequent problems. *本文档中的信息适用于电子元器件应用中的典型用法。如有任何特殊用途,请向晶台咨询,以获得进一步的帮助。 The information in this document applies to typical use in electronic component applications. For special applications, please contact Kinglight for further assistance. *未经晶台允许,不得复制或转载本文件的内容和信息。对于最新的信息,请参考官方网站 Http://www.kinglight-OC.com。 The contents and information in this document may not be copied or reproduced without the permission of Kinglight. For the latest information, please visit the official Http://www.kinglight-OC.com. KL851 Datasheet 1. 产品特点 Product features • 电流转换率(Current transfer ratio) (CTR: 50~600% at IF = 5mA, VCE = 5V) • 集电极-发射极高电压(VCE Min350V) High collector- emitter voltage (VCE Min350V) • 输入与输出高隔离电压(Viso=5000 V rms) High isolation voltage between inputs and output (Viso=5000 V rms) • 紧凑的双列式封装 Compact dual-in-line package • 产品本身将保持在符合RoHS的版本范围内 The product itself will remain within RoHS compliant version • 符合欧盟REACH法规 Compliance with EU REACH • 合规无卤素(仅限铜引线框)(溴
KL851 价格&库存
很抱歉,暂时无法提供与“KL851”相匹配的价格&库存,您可以联系我们找货
