SHENZHEN ORIENT TECHNOLOGY CO., LTD
Specification
PRODUCT NAME: Photocoupler
PART NO.: ORPC-817
●Feature:
1. Current conversion ratio (Min 50% Working condition IF=5mA, VCE=5V)
2. Insulation Voltage=5,000Vrms
3. Response Time (tr: TYP. 4μs ,Operating condition:VCE=2V, IC=2mA, RL=100 Ω)
●Instruction
1. ORPC-817S photocoupler consist of one piece of GaAs emitter and one piece of NPN transistor
2. Bin width of ORPC-817 is 2.54mm
●Application Range
1.Computer
2.Instrument application, measurement machine
3.Imbursement equipments, duplicating machine, automat.
4.Family-use electric equipments, such as fans
5.Signal transforming systems
●Max Absolute rated Value(Normal Temperature=25
Temperature=25℃
Parameter
Symbol
IF
VR
P
VCEO
VECO
IC
PC
Ptot
Viso
VIOTM
VIORM
Topr
Tstg
Tsol
Forward Current
Input
Reverse Voltage
Consume Power
Collector and emitter Voltage
Emitter and Collector Voltage
Output
Collector Current
Consume Power
Total Consume Power
Insulation Voltage
Max Insulation Voltage
Rated Impulse Insulation Voltage
Working Temperature
Deposit Temperature
Soldering Temperature
*1. AC Test,1 minute, humidity=40~60 %
Insulation test method as below:
(1) Short circuit both terminals of photocoupler
(2) No Current when testing insulation voltage
Tel :86-755-27477119
Rated Value
Unit
50
6
70
35
6
50
150
200
5,000
6,000
630
-30 to + 100
-55 to + 125
260
mA
V
mW
www.orient-opto.com
Fax:86-755-29980030 Web
Web:www.orient-opto.com
V
mA
mW
mW
Vrms
V
V
(3) Adding sine wave voltage when testing
*2. soldering time is 10 seconds
●Opto-electronic Characteristics
Parameter
Input
Output
Transforming
Characteristics
Symbol
Condition
Min
Min.. Midiu Max Unit
m
Forward Current
VF
IF=20mA
1.2
1.4
V
Reverse Voltage
IR
VR=4V
10
μA
Collector capacitance
Ct
V=0, f=1KHz
30
250
pF
Collector to emitter
Current
ICEO
VCE=20V,
IF=0
100
nA
35
V
6
V
2.5
30
mA
50
600
0.1
0.2
V
DC500V
5×1010 1×1011 --40~60%R.H.
Ω
IC=0.1m
Collector and Emitter
attenuation Voltage
BVCEO A
attenuation Voltage
BVECO
Collector Current
Ic
CTR
Saturation Voltage
VCE(sat)
Insulation Impedance
Riso
capacitance
Cf
V=0, f=1MHz
0.6
1
pF
fc
VCE=5V,
IC=2mA
RL=100Ω,
-3dB
80
kHz
4
18
μs
3
18
μs
Transforming Frequency
IF=0
Rise Time
tr
Descend Time
tf
IE=10μA
IF=0
IF=5mA
VCE=5V
IF=20mA
IC= 1mA
VCE=2V,
IC=2mA
RL=100Ω
*1 Current Conversion= IC / IF × 100%
●Grades of Current conversion ratio
www.orient-opto.com
Gr a d e Si ggn
n
Mi n (% )
Ma x (%)
L
50
10 0
A
80
16 0
B
13 0
26 0
C
20 0
40 0
D
30 0
60 0
50
60 0
L or A or B or C or D
Note:Working condition: IF=5mA, VCE=5V, Ta=25℃.
●Outer Dimension
4.60
4
3
pin No. and Internal
connection diagram
ORIENT
*1
817
6.40
P/N
*2
Anode
*3
1 Anode
2 Cathode
3 Emitter
4 Collector
1
4.60±0.05
2
6.40±0.05
1.64
3.48
3.48±0.05
1.25
0.50
1.60
3.30±0.25
2.80±0.25
6.50±0.05
2.54±0.25
0.50
9.01±0.15
Note
Note:*1. Company name
*2. Bin
*3. Production period
www.orient-opto.com
●Characteristics Curve
www.orient-opto.com
www.orient-opto.com
很抱歉,暂时无法提供与“ORPC-817B-F”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.25272
- 200+0.19991
- 600+0.16686
- 2000+0.14699
