ORPC-852
ORPC-852
    ORIENT(奥伦德)
    DIP-4
    DC输入 隔离电压(RMS):5000V
ORPC-852 数据手册
1 Shenzhen Orient Components Co ., Ltd ORPC-852 ORIENT Photo coupler Product Data Sheet Part Number: ORPC-852 Customer: Date: SHENZHEN ORIENT COMPONENTS CO ., LTD Block A 3rd Floor No.4 Building,Tian’an Cyber Park,Huangge Rd,LongGangDist,Shenzhen,GD TEL:0755-29681816 FAX:0755-29681200 www.orient-opto.com Copyright© 2020 Orient .All rights Reserved 1 V3 1 Shenzhen Orient Components Co ., Ltd ORPC-852 1. Features (1) (2) (3) (4) (5) High collector- emitter voltage (V CEO = 350V) High current transfer ratio ( CTR : MIN. 1000% at IF = 1mA, VCE = 2V ) High isolation voltage between input and output (Viso = 5000 Vrms) In compliance with RoHS, REACH standards Safety approval UL approved (No.E323844) VDE approved(No.40029733) CQC approved (No.CQC09001029446) 2. Description (1) The OR-852 series devices consist an infrared emitting diodes, optically coupled to a high voltage photo Darlington detector. (2) The devices are in a 4-pin DIP package and available in wide-lead spacing and SMD option. 3. Applications (1) Telephone set,telephone exchangers (2) System appliances,measuring instruments (3) Sequence controllers (4) Signal transmission between circuits of different potentials and impedances 4. Absolute Maximum Ratings at Ta=25℃ Parameter Forward Current Peak forward current (100μs pulse, 100Hz frequency) Reverse Voltage Input Output Symbol Rated Value IF 60 mA IFP 1 A VR 6 V Storage Temperature PD VCEO VECO IC PC Ptot Viso Topr Tstg 60 350 0.1 150 150 200 5,000 -50 to + 110 -55 to + 125 *2 Soldering Temperature Tsol 260 Power dissipation Collector and emitter Voltage Emitter and collector Voltage Collector Current Consume Power Total Power Dissipation *1 Isolation Voltage Operating Temperature Unit mW V mA mW mW Vrms ℃ 1. AC For 1 Minute, R.H. = 40 ~ 60% Isolation voltage shall be measured using the following method. (1) Short between anode and cathode on the primary side and between collector and emitter on the secondary side. (2) The isolation voltage tester with zero-cross circuit shall be used. (3) The waveform of applied voltage shall be a sine wave. 2. For 10 Seconds Copyright© 2020 Orient .All rights Reserved 2 V3 1 Shenzhen Orient Components Co ., Ltd ORPC-852 5. Electro-Optical Characteristics (Ta=25℃ unless specified otherwise) Parameter Unit VF --- 1.2 1.4 V Reverse Current IR --- --- 5 µA Collector capacitance Ct --- 30 250 pF Collector to emitter Current ICEO --- --- 100 nA Collector and Emitter attenuation Voltage BV CEO 350 --- --- V Emitter and Collector attenuation Voltage BV ECO 0.1 --- --- V *1 Current conversion ratio CTR 1000 --- 15000 % Collector Current IC 10 --- 150 mA VCE(sat) --- --- 1.2 V --- Ω Collector and Emitter Saturation Voltage Transforming Characteristics Min Typ.* Max Forward Voltage Input Output Symbol Insulation Impedance Riso 5×1010 1×1012 Floating Capacitance Cf --- 0.6 1.0 pF Cut-off Frequency fc --- 6 --- kHz Rise Time tr --- 40 --- μs Descend Time tf --- 15 --- μs Turn-On Time ton --- 50 --- μs Turn-Off Time toff --- 15 --- μs Condition IF=10mA VR= 5V V=0, f=1KHz VCE=200V, IF=0mA IC=0.1mA IF=0mA IE=0.1mA IF=0mA IF=1mA, VCE=2V IF=20mA IC= 100mA DC500V 40~60%R.H. V=0, f=1MHz V CE =5V, IC =2mA RL=100Ω, -3dB VCC=10V, IC=10mA, RL=100Ω *1 Current Conversion Ratio = IC / IF × 100%, CTR Tolerance:±3%. Copyright© 2020 Orient .All rights Reserved 3 V3 1 Shenzhen Orient Components Co ., Ltd ORPC-852 6. Order Information Part Number ORPC-852T-W-X-Y-Z Note T = Lead form option (S, M or none) W = Tape and reel option (TP,TP1 or none). X = Lead frame option (F: Iron, C:copper) Y = ‘V’ code for VDE safety (This options is not necessary). Z = ‘G’ code for Halogen free (This options is not necessary). * VDE Code can be selected. * Halogen Free can be selected. Option Description Packing quantity None Standard DIP-4 100 units per tube M Wide lead bend (0.4 inch spacing) 100 units per tube S(TP) Surface mount lead form (low profile) + TP tape & reel option 2000 units per reel S(TP1) Surface mount lead form (low profile) + TP1 tape & reel option 2000 units per reel Copyright© 2020 Orient .All rights Reserved 4 V3 1 Shenzhen Orient Components Co ., Ltd ORPC-852 7. Naming Rule 1. Manufacturer : ORIENT. 2. Part Number : 852. 3. Lead frame Code 4. Year Code 5. Week Code 6. Day Code 7. VDE Code 8. HF Code 9. Anode. :‘F’ means Iron,‘C’ means Copper. : '1' means '2021' and so on. : 01 means the first week, 02 means the second week and so on. : ‘A to F’ means ‘Monday to Sunday’. . (Optional) : Halogen Free. (Optional) * Halogen Free Mark can be selected. * VDE Mark can be selected. Copyright© 2020 Orient .All rights Reserved 5 V3 1 Shenzhen Orient Components Co ., Ltd ORPC-852 8. Package Dimension (Unit:mm) 1. ORPC-852 2. ORPC-852M Copyright© 2020 Orient .All rights Reserved 6 V3 1 Shenzhen Orient Components Co ., Ltd ORPC-852 3. ORPC-852S 9. Recommended Foot Print Patterns (Mount Pad) (Unit:mm) Copyright© 2020 Orient .All rights Reserved 7 V3 1 Shenzhen Orient Components Co ., Ltd 10. ORPC-852 Taping Dimensions (1)ORPC-852S-TP (2)ORPC-852S-TP1 Description Symbol Dimension in mm (inch) Tape wide W 16±0.3 (.63) Pitch of sprocket holes P0 4±0.1 (.15) Distance of compartment F P2 7.5±0.1 (.295) Distance of compartment to compartment P1 8±0.1 (.472) 2±0.1 (.0079) Package Type Quantities(pcs) Copyright© 2020 Orient .All rights Reserved TP/TP1 2000 8 V3 1 Shenzhen Orient Components Co ., Ltd ORPC-852 11. Package Dimension DIP Type Packing Information Packing type Tube Qty per Tube 100pcs Small box (Inner) Dimension 525*128*60mm Large box (Outer) Dimension 545*290*335mm The Amount per Inner Box 5,000pcs The Amount per Outer Box 50,000pcs SOP Type Packing Information Packing type Reel type Tape Width 16mm Qty per Reel 2,000pcs Small box (inner) Dimension 345*345*58.5mm Large box (Outer) Dimension 620x360x360mm Max qty per small box 4,000pcs Max qty per large box 40,000pcs (2)Packing Label Sample Note: 1. 2. Material Code :Product ID. P/N :Contents with "Order Information" in the specification. 3. Lot No. :Product data. 4. D/C :Product weeks. 5. Quantity :Packaging quantity. Copyright© 2020 Orient .All rights Reserved 9 V3 1 Shenzhen Orient Components Co ., Ltd ORPC-852 12. Reliability Test Reliability Testing NO. ITEMS 1 RSH 耐焊接热 QTY (Pcs) 22 Condition 260±5℃ Process 5s/3 次 168 hrs 2 HTSL 高温存储 77 125℃ 500 hrs 1000 hrs Device Standard 锡炉 JESD22-A106 高温烤 箱 测试仪 JESD22-A103 低温箱 测试仪 JESD22-A119 168 hrs 3 LTSL 低温存储 77 -55℃ 500 hrs 1000 hrs 4 5 6 7 8 9 TC 温度循环 TS 温度冲击 HTOL 高温操作 ESD-HBM 人体模式 SD 可焊性 HTRB 高温反向偏压 77 H:125℃ 15min ∫5min L:-55℃ 15min 300 cycle 冷热冲 击机 JESD22-A104 77 H:100℃ 5min ∫15s L:-40℃ 5min 300 cycle 冷热冲 击机 JESD22-A106 168 hrs 高温烤 箱 测试 仪、老 化电路 板 JESD22-A108 ESD静电 测试仪 JESD22-A114 110°C IF=10mA Vce=5V 500 hrs 22 ≥8KV 1Cycle 1次 22 Pb-free 245±5℃ 5S/1次 锡炉 JESD22-B102 168 hrs 高温烤 箱 ,测试 仪 JESD22-A103 恒温恒湿 机,测试 仪 JESD22-A101 压力锅 JESD22-A102 77 77 @100℃ Vce=280v 1000 hrs 500 hrs 1000 hrs 168 hrs 10 11 H3TRB 温湿度反向偏 压,寿命试验 Autoclave 压力锅 77 77 85℃,85%RH Vce=80v 500 hrs Ta=121 ℃,100%RH,2atm 96hrs Copyright© 2020 Orient .All rights Reserved 1000 hrs 10 V3 1 Shenzhen Orient Components Co ., Ltd 13. ORPC-852 Temperature Profile Of Soldering (1).IR Reflow soldering (JEDEC-STD-020C compliant) One time soldering reflow is recommended within the condition of temperature and time profile shown below. Do not solder more than three times. Profile item Conditions Preheat 150˚C - Temperature Min (T Smin ) 200˚C - Temperature Max (T Smax ) 90±30 sec - Time (min to max) (ts) Soldering zone - Temperature (TL ) 217˚C - Time (t L ) 60 sec Peak Temperature 260˚C Peak Temperature time 20 sec Ramp-up rate 3˚C / sec max. Ramp-down rate from peak temperature 3~6˚C / sec Reflow times ≤3 Copyright© 2020 Orient .All rights Reserved 11 V3 1 Shenzhen Orient Components Co ., Ltd ORPC-852 (2).Wave soldering (JEDEC22A111 compliant) One time soldering is recommended within the condition of temperature. Temperature 260+0/-5˚C Time 10 sec Preheat temperature 25 to 140˚C Preheat time 30 to 80 sec (3).Hand soldering by soldering iron Allow single lead soldering in every single process. One time soldering is recommended. Copyright© 2020 Orient .All rights Reserved Temperature 380+0/-5˚C Time 3 sec max 12 V3 1 Shenzhen Orient Components Co ., Ltd 14. ORPC-852 Characteristics Curves Copyright© 2020 Orient .All rights Reserved 13 V3 1 Shenzhen Orient Components Co ., Ltd Copyright© 2020 Orient .All rights Reserved 14 ORPC-852 V3
ORPC-852 价格&库存
很抱歉,暂时无法提供与“ORPC-852”相匹配的价格&库存,您可以联系我们找货
