UF2010
UF2010
    SUNMATE(森美特)
    DO-15(DO-204AC)
    耐压:1KV 电流:2A 反向恢复时间:75NS
UF2010 数据手册
UF200 - UF2010 ULTRA FAST SWITCHING RECTIFIER DIODES VOLTAGE RANGE: 50 - 1000V CURRENT: 2.0 A Features ! Diffused Junction ! ! ! ! Low Forward Voltage Drop High Current Capability High Reliability High Surge Current Capability B A A Mechanical Data ! ! ! ! ! ! C D Case: D O - 1 5 , Molded Plastic Terminals: Plated Leads Solderable per MIL-STD-202, Method 208 Polarity: Cathode Band Weight: 0.40 grams (approx.) Mounting Position: Any Marking: Type Number DO-15 Dim Min A 25.40 — B 5.50 7.62 C 0.686 0.889 2.60 3.60 D Max All Dimensions in mm Maximum Ratings and Electrical Characteristics @TA=25°C unless otherwise specified Single Phase, half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. Characteristic Symbol Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage RMS Reverse Voltage Average Rectified Output Current (Note 1) @TA = 55°C UF200 UF201 UF202 UF204 UF205 UF206 UF208 UF2010 Unit VRRM VRWM VR 50 100 200 300 400 600 800 1000 V VR(RMS) 35 70 140 210 280 420 560 700 V IO 2.0 A Non-Repetitive Peak Forward Surge Current 8.3ms Single half sine-wave superimposed on rated load (JEDEC Method) IFSM 60 A Forward Voltage @IF = 2.0A VFM @TA = 25°C @TA = 100°C IRM Peak Reverse Current At Rated DC Blocking Voltage 1.0 1.3 1.7 5.0 100 V µA Reverse Recovery Time (Note 2) trr 50 75 nS Typical Junction Capacitance (Note 3) Cj 60 40 pF Operating Temperature Range Tj -65 to +125 °C TSTG -65 to +150 °C Storage Temperature Range Note: 1. Leads maintained at ambient temperature at a distance of 9.5mm from the case 2. Measured with IF = 0.5A, IR = 1.0A, IRR = 0.25A. See figure 5. 3. Measured at 1.0 MHz and applied reverse voltage of 4.0V D.C. 1 of 2 www.sunmate.tw RATING AND CHARACTERISTIC CURVES UF200 THRU UF2010 trr +0.5A 0 -0.25 -1.0 NOTE:1.Rise Time = 7ns max. Input Impedance = 1 megohm. 22pF 2.Rise Time = 10ns max. 1cm SET TIME BASE FOR 50 ns/cm Source Impedance = 50 Ohms Fig. 1-REVERSE RECOVERY TIME CHARACTERISTIC AND TEST CIRCUIT DIAGRAM AVERAGE FORWARD RECTIFIED CURRENT, AMPERES 10 UF200 TYPICAL IFM, Apk 1 UF2010 TJ = 25 ¢J 0.1 0.01 .2 .4 .6 .8 1.0 1.2 1.4 SINGLE PHASE HALF WAVE 60Hz RESISSTIVE OR INDUCTIVE LOAD .375" 9.5mm LEAD LENGTHS 2.0 1.4 1.2 0.8 0.4 0 1.6 25 50 75 100 125 150 175 FORWARD VOLTAGE-VFM(Vpk) AMBIENT TEMPERATURE, ¢J Fig. 2-FORWARD CHARACTERISTICS Fig. 3-FORWARD CURRENT DERATING CURVE PEAD FORWARD SURGE CURRENT, AMPERES JUNCTION CAPACITANCE, pF 0 2.4 100 TJ = 25 ¢J f = 1.0MHz Vsig = 50mVp-p 10 5 1 10 100 REVERSE VOLTAGE, VOLTS 60 48 36 24 12 1 2 4 6 8 10 20 40 60 80 100 NUMBER OF CYCLES AT 60Hz Fig. 4-TYPICAL JUNCTION CAPACITANCE Fig. 5-PEAK FORWARD SURGE CURRENT 2 of 2 www.sunmate.tw
UF2010 价格&库存
很抱歉,暂时无法提供与“UF2010”相匹配的价格&库存,您可以联系我们找货
UF2010
  • 10+0.36700
  • 100+0.30298
  • 300+0.27097
  • 2000+0.23578
  • 4000+0.21660
  • 10000+0.20695
库存:847
