CBM706P/706R/706S/706T/708R/708S/708T
OPERATION INSTRUCTION
FEATURES
GENERAL DESCRIPTION
The
Precision supply voltage monitor
CBM706P/
CBM706R/
2.63 V (CBM706P, CBM706R, CBM708R)
CBM706T and the CBM708R/ CBM708S /
2.93 V (CBM706S, CBM708S)
CBM708T microprocessor supervisory circuits
are suitable for monitoring either 3V or 3.3V
3.08 V (CBM706T, CBM708T)
power supplies.
100µA quiescent current
200ms reset pulse width
Debounced manual reset input (MR)
Independent watchdog timer
power-up,
1.6 sec timeout (CBM706P, CBM706R,
conditions.
CBM706S, CBM706T)
operational with VCC as low as 1V.
CBM706S/
The
Superior upgrade for ADM706P/R/S/T,
CBM706S/
circuitry that generate a reset output during
power-down,
The
reset
Independent
and
brownout
output
watchdog
remains
monitoring
circuitry is also provided. This activates if the
battery warning
Guaranteed RESET valid with VCC = 1 V
CBM706R/
CBM706T provide power supply monitoring
Voltage monitor for power fail or low
CBM706P/
watchdog input does not toggle within 1.6
sec.
In addition, there is a 1.25V threshold
ADM708R/S/T
detector for a power fail warning, low battery
detection, or to monitor an additional power
APPLICATIONS
supply. An active low debounced MR input is
also included.
Microprocessor systems
Computers
The CBM706R, CBM706S, and CBM706T
Controllers
are identical except for the reset threshold
Intelligent instruments
Critical microprocessor monitoring
Battery operated systems
Portable instruments
monitor levels, which are 2.63V, 2.93V, and
3.08V, respectively. The CBM706P is identical
to the CBM706R in that the reset threshold is
2.63V. It differs only in that it has an active
high reset output.
The
provide
CBM708R/
similar
CBM708S/
functio-nality
CBM708T
as
the
CBM706R/CBM706S/CBM706T and only differ
in that a watchdog timer function is not
available. Instead, an active high reset output
(RESET) is provided in addition to the active
low (RESET) output.
All devices are available in narrow 8-lead
PDIP and 8-lead SOIC packages.
1
www.corebai.com
FUNCTIONAL BLOCK DIAGRAMS
*VOLTAGE REFERENCE = 2.63V (P/R), 2.93V (S), 3.08V (T)
Figure 1. CBM706P/CBM706R/CBM706S/CBM706T
* VOLTAGE REFERENCE = 2.63V (R), 2.93V (S), 3.08V (T)
Figure 2. CBM708R/CBM708S/CBM708T
2
www.corebai.com
SPECIFICATIONS
VCC = 2.70 V to 5.5 V (CBM706P/CBM706R/CBM708R), VCC = 3.00 V to 5.5 V (CBM70XS), VCC =
3.15 V to 5.5 V (CBM70XT), TA = TMIN to TMAX unless otherwise noted.
Table 1.
Parameter
Min
Typ
Max
Unit
Test Conditions/Comments
5.5
V
200
μA
VCC < 3.6 V
150
μA
VCC < 5.5 V
POWER SUPPLY
VCC Operating Voltage Range
1.0
Supply Current
100
LOGIC OUTPUT
Reset Threshold(VRST)
2.55
2.63
2.70
V
2.85
2.93
3.00
V
CBM706S/CBM708S
3.00
3.08
3.15
V
CBM706T/CBM708T
Reset Threshold Hysteresis
RESET PULSE WIDTH
160
mV
200
280
ms
CBM706P/CBM706R/CBM708R,
VCC=3V
VCC = 3.3 V
200
ms
VCC = 5.0 V
RESET OUTPUT VOLTAGE (CBM706R/CBM708R/CBM706S/CBM708S/CBM706T/CBM708T)
VOH
0.8 × VCC
VOL
0.3
VOH
VCC−1.5V
V
VRST(max)
很抱歉,暂时无法提供与“CBM706PAS8”相匹配的价格&库存,您可以联系我们找货
