IW662-02-SO8
IW662-02-SO8
    DIALOGSEMICONDUCTOR(戴乐格)
    SOIC-8
    AC/DC 二次侧同步整流和快速充电接口控制器,适用于高通 QUICK CHARGE 3.0
IW662-02-SO8 数据手册
iW662 AC/DC Secondary-Side Synchronous Rectification and Rapid ChargeTM Interface Controller for Qualcomm® Quick Charge™ 3.0 1 Description The iW662 is an AC/DC secondary-side combo controller for Qualcomm® Quick ChargeTM 3.0 (QC3.0) which includes USB interface, secondary-to-primary communication and synchronous rectification functions in a single IC. The iW662 resides on the secondary side of an AC/DC power supply and allows the adapter to be configured for multi-level output voltages from 3.6V to 12V in 200mV increments, depending on the voltage requested by the mobile device (MD). It can be used in Dialog’s primary-side controlled AC/ DC systems to achieve fast voltage transition, low noload power consumption, and fast dynamic load response. The iW662 uses Dialog’s proprietary XM-Comm secondary-to-primary digital communication technology. When paired with Dialog’s primary-side controller, the iW1790, the optocoupler can be completely eliminated in the system. The iW662 transmits all necessary information for rapid charge through the power transformer, including output voltage requests, output current limits, output voltage undershoot, output over-voltage, and fault and reset signals. The iW662 is also an advanced synchronous rectifier (SR) controller with an integrated MOSFET driver, enabling discontinuous mode flyback converters with high efficiency operation. The device works with an external power MOSFET to replace the main rectifying diode on the secondary of a flyback converter, improving efficiency by reducing secondaryside conduction losses. Dialog’s digital adaptive turn-off control technology minimizes turn-off deadtime, eliminating the need for an additional Schottky diode that is typically needed in parallel with the synchronous MOSFET in conventional synchronous rectifiers. The iW662 and iW1790 provide double-layer cable protection. On the secondary side, the iW662 incorporates Dialog’s proprietary D+/D- over-voltage protection to address VBUS D+/D- soft shorts. On the primary side, the iW1790 uses Dialog’s SmartDefender+TM advanced hiccup technology to reduce the average output power during soft shorts without latch. Qualcomm® Quick ChargeTM 3.0 is a product of Qualcomm Technologies, Inc. 2 Features xx Primary side (iW1790): SmartDefender+TM smart hiccup technology reduces average output power at fault conditions without latch ●● XM-Comm proprietary secondary-to-primary digital communication transmits all information for rapid charge without an optocoupler: output voltage requests, output current limits, output voltage undershoot, over-voltage protection, and other fault and reset signals ●● Adaptive OVP/UV detection for most VBUS levels ●● Backward compatible with QC2.0 and USB Battery Charging Specification Revision 1.2 (USB BC1.2) ●● Lossless MOSFET VDS sensing for SR timing control with digital adaptive turn-off control ●● Wide operating voltage range from 3V to 16V ●● Optimized 5V MOSFET gate driver ●● High-voltage drain sensing up to 100V with no additional external clamping circuits required ●● Supports Qualcomm® Quick ChargeTM 3.0 technology High Voltage Dedicated Charging Port (HVDCP) to provide VBUS from 3.6V to 12V in 200mV increments ●● Double-layer cable protection: xx Secondary side (iW662): Proprietary D+/D- overvoltage protection (OVP) addresses VBUS D+/D-soft shorts Product Summary www.dialog-semiconductor.com ●● Programmable active fast discharge from a high voltage to 5V at MD unplug or from a high voltage level to a lower level upon request with built-in switch or external switch ●● Intelligent low power mode enables < 20mW no-load power consumption ●● Dual Over-Temperature Protection (OTP) via on-chip temperature sensing circuit and external NTC (10lead MSOP package only) ●● 10-lead MSOP and 8-Lead SOIC packages Rev. 0.6 Preliminary 1 of 8 30-Oct-2017 © 2017 Dialog Semiconductor iW662 AC/DC Secondary-Side Synchronous Rectification and Rapid ChargeTM Interface Controller for Qualcomm® Quick Charge™ 3.0 3 Applications ●● 18W/24W QC AC/DC adapters for smart phones, tablets, and other portable devices L + + + COUT N VOUT - R1 NTC VCC 8 GND 2 SD 3 VSENSE 4 GATE 7 SOURCE 6 ISENSE 5 CFG GND U1 iW662 (10-Lead MSOP) U1 iW1790 1 VBUS 1 DRAIN SD 10 2 DIS VIN 9 3 D- 4 SOURCE GND 7 5 D+ OUT 6 VCC 8 D- R2 D+ Figure 3.1 : iW662 (10-Lead MSOP) 18W/24W Typical Application Circuit for Multi-Level Output Voltage and Current (Using iW1790 as Primary-Side Controller. Achieving < 20mW No-Load Power Consumption.) L + + + COUT N VOUT - R1 NTC GND 2 SD 3 VSENSE 4 CFG GND U1 iW662 (8-Lead SOIC package) U1 iW1790 1 VBUS VCC 8 GATE 7 SOURCE 6 ISENSE 5 1 DRAIN 2 DIS VIN 8 VCC 7 3 D- GND 6 4 D+ OUT 5 DD+ R2 Figure 3.2 : iW662 (8-Lead SOIC package) 18W/24W Typical Application Circuit for Multi-Level Output Voltage and Current (Using iW1790 as Primary-Side Controller. Achieving < 20mW No-Load Power Consumption.) Product Summary www.dialog-semiconductor.com Rev. 0.6 Preliminary 2 of 8 30-Oct-2017 © 2017 Dialog Semiconductor iW662 AC/DC Secondary-Side Synchronous Rectification and Rapid ChargeTM Interface Controller for Qualcomm® Quick Charge™ 3.0 4 Pinout Description iW662 iW662 1 DRAIN SD 10 2 DIS VIN 9 3 D- VCC 8 1 DRAIN VIN 8 2 DIS VCC 7 4 SOURCE GND 7 3 D- GND 6 5 D+ OUT 6 4 D+ OUT 5 Figure 4.2 : 8-Lead SOIC Package Figure 4.1 : 10-Lead MSOP Package Pin No. Pin No. (10-Lead MSOP) (8-Lead SOIC) Pin Name Type Pin Description Synchronous rectifier MOSFET drain voltage sensing and the Pulse Linear Regulator (PLR) input. 1 1 DRAIN Analog Input 2 2 DIS Analog Output 3 3 D- 4 ─ SOURCE 5 4 D+ 6 5 OUT Output Synchronous rectifier MOSFET driver. 7 6 GND Ground Ground. 8 7 VCC Power Input 9 8 VIN Analog Input Connect to adapter/charger output for bias voltage. The 10 ─ SD Product Summary www.dialog-semiconductor.com Discharging circuit. Used for fast discharging of output capacitor. Analog Input USB D- signal. Analog input Synchronous rectifier MOSFET source voltage sensing input. Analog Input USB D+ signal. LDO and PLR output. Connect this pin to a capacitor. Input of the internal LDO and output voltage sensing circuit. internal LDO clamps the VCC voltage at 5V when VIN > 5V. Analog Output External shutdown control. It can be configured for external over-temperature protection (OTP) by connecting an NTC resistor from this pin to Ground. Rev. 0.6 Preliminary 3 of 8 30-Oct-2017 © 2017 Dialog Semiconductor iW662 AC/DC Secondary-Side Synchronous Rectification and Rapid ChargeTM Interface Controller for Qualcomm® Quick Charge™ 3.0 5 Absolute Maximum Ratings Absolute maximum ratings are the parameter values or ranges which can cause permanent damage if exceeded. For maximum safe operating conditions, refer to Electrical Characteristics in Section 6. Parameter Symbol Value Units VIN DC supply voltage range (ICC = 15mA max) VIN -0.3 to 33 V Continuous DC supply current at VIN pin (VIN = 25V) IVO 15 mA Continuous DC supply current at VCC pin (VCC = 5.5V) IVCC 15 mA Gate peak output current IG ±3 A DRAIN pin voltage (Note 1) VD -1.5 to 100 V IDRAIN -40 to 350 mA -0.6 to 5 V DRAIN pin peak current SOURCE pin voltage (10-Lead MSOP Package only) OUT pin voltage VOUT -0.6 to VCC +0.6 V VCC pin voltage VCC -0.6 to 6 V DIS pin voltage VDIS 30 V SD pin voltage (10-Lead MSOP Package only) VSD 6.5 V D+ pin voltage VD+ -0.3 to 7 V D- pin voltage VD- -0.3 to 7 V Junction temperature TJ -40 to 150 °C -65 to 150 °C TBD V ± 2,000 V Storage temperature ESD rating per JEDEC JESD22-A114 (D+ and D- pins) ESD rating per JEDEC JESD22-A114 (all other pins) Notes: Note 1: The DRAIN pin voltage should not be below -0.6V for more than 500ns. Product Summary www.dialog-semiconductor.com Rev. 0.6 Preliminary 4 of 8 30-Oct-2017 © 2017 Dialog Semiconductor iW662 AC/DC Secondary-Side Synchronous Rectification and Rapid ChargeTM Interface Controller for Qualcomm® Quick Charge™ 3.0 6 Physical Dimensions 6.1 10-Lead MSOP Package Product Summary www.dialog-semiconductor.com Rev. 0.6 Preliminary 5 of 8 30-Oct-2017 © 2017 Dialog Semiconductor iW662 AC/DC Secondary-Side Synchronous Rectification and Rapid ChargeTM Interface Controller for Qualcomm® Quick Charge™ 3.0 6.2 8-Lead SOIC Package Product Summary www.dialog-semiconductor.com Rev. 0.6 Preliminary 6 of 8 30-Oct-2017 © 2017 Dialog Semiconductor iW662 AC/DC Secondary-Side Synchronous Rectification and Rapid ChargeTM Interface Controller for Qualcomm® Quick Charge™ 3.0 7 Ordering Information Options Part no. Package Description Note 1 MSOP-10 Tape & Reel2 iW1790-09 Note 1 MSOP-10 Tape & Reel2 0.5 for VBUS = 3.6V to 8V Determined by constant max power for 8.2V to 12V iW1790-09 Note 1 MSOP-10 Tape & Reel2 3.6V to 12V 0.5 for VBUS = 3.6V to 6V Determined by constant max power for 6.2V to 12V iW1790-19 14.76V MSOP-10 Tape & Reel2 iW662-00-SO8 3.6V to 12V 0.422 for VBUS = 3.6V to 8V Determined by constant max power for 8.2V to 12V iW1790-08 Note 1 SOIC-8 Tape & Reel2 iW662-01-SO8 3.6V to 12V 0.5 for VBUS = 3.6V to 6V Determined by constant max power for 6.2V to 12V iW1790-09 Note 1 SOIC-8 Tape & Reel2 iW662-02-SO8 3.6V to 12V 0.5 for VBUS = 3.6V to 8V Determined by constant max power for 8.2V to 12V iW1790-09 Note 1 SOIC-8 Tape & Reel2 iW662-03-SO8 3.6V to 12V 0.5 for VBUS = 3.6V to 6V Determined by constant max power for 6.2V to 12V iW1790-19 14.76V SOIC-8 Tape & Reel2 iW662-05-SO83 3.6V to 9V 0.422 for VBUS = 3.6V to 9V iW1790-08 Note 1 SOIC-8 Tape & Reel2 iW662-18-SO83 3.6V to 9V 0.422 for VBUS = 3.6V to 9V iW1790-18 11.07V SOIC-8 Tape & Reel2 VBUS Range kCC Primary-Side Controller OVP Level iW662-00 3.6V to 12V 0.422 for VBUS = 3.6V to 8V Determined by constant max power for 8.2V to 12V iW1790-08 iW662-01 3.6V to 12V 0.5 for VBUS = 3.6V to 6V Determined by constant max power for 6.2V to 12V iW662-02 3.6V to 12V iW662-03 Note 1: The OVP threshold is adjusted according to the nominal output voltage. For details, see the Discharge/UV/OV section of the electrical characteristics table in section 6. Note 2: Tape & Reel packing quantity is 2,500/reel. Minimum packing quantity is 2,500. Note 3: The iW662-05 option is a customized product option with 12V disabled. Adapters designed with this product option may not pass QC2.0 HVDCP compliancy test. Product Summary www.dialog-semiconductor.com Rev. 0.6 Preliminary 7 of 8 30-Oct-2017 © 2017 Dialog Semiconductor iW662 AC/DC Secondary-Side Synchronous Rectification and Rapid ChargeTM Interface Controller for Qualcomm® Quick Charge™ 3.0 Disclaimer Information in this document is believed to be accurate and reliable. However, Dialog Semiconductor does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information. Dialog Semiconductor furthermore takes no responsibility whatsoever for the content in this document if provided by any information source outside of Dialog Semiconductor. Dialog Semiconductor reserves the right to change without notice the information published in this document, including without limitation the specification and the design of the related semiconductor products, software and applications. Applications, software, and semiconductor products described in this document are for illustrative purposes only. Dialog Semiconductor makes no representation or warranty that such applications, software and semiconductor products will be suitable for the specified use without further testing or modification. Unless otherwise agreed in writing, such testing or modification is the sole responsibility of the customer and Dialog Semiconductor excludes all liability in this respect. Customer notes that nothing in this document may be construed as a license for customer to use the Dialog Semiconductor products, software and applications referred to in this document. Such license must be separately sought by customer with Dialog Semiconductor. All use of Dialog Semiconductor products, software and applications referred to in this document are subject to Dialog Semiconductor’s Standard Terms and Conditions of Sale, available on the company website (www.dialog-semiconductor.com) unless otherwise stated. Dialog and the Dialog logo are trademarks of Dialog Semiconductor plc or its subsidiaries. All other product or service names are the property of their respective owners. Qualcomm is a trademark of Qualcomm Incorporated, registered in the United States and other countries. Qualcomm Quick Charge is a trademark of Qualcomm Incorporated. All Qualcomm Incorporated marks are used with permission. © 2017 Dialog Semiconductor. All rights reserved. RoHS Compliance Dialog Semiconductor’s suppliers certify that its products are in compliance with the requirements of Directive 2011/65/EU of the European Parliament on the restriction of the use of certain hazardous substances in electrical and electronic equipment. RoHS certificates from our suppliers are available on request. Contacting Dialog Semiconductor United Kingdom (Headquarters) Dialog Semiconductor (UK) LTD Phone: +44 1793 757700 North America Dialog Semiconductor Inc. Phone: +1 408 845 8500 Hong Kong Dialog Semiconductor Hong Kong Phone: +852 2607 4271 China (Shenzhen) Dialog Semiconductor China Phone: +86 755 2981 3669 Germany Dialog Semiconductor GmbH Phone: +49 7021 805-0 Japan Dialog Semiconductor K. K. Phone: +81 3 5769 5100 Korea Dialog Semiconductor Korea Phone: +82 2 3469 8200 China (Shanghai) Dialog Semiconductor China Phone: +86 21 5424 9058 The Netherlands Dialog Semiconductor B.V. Phone: +31 73 640 8822 Taiwan Dialog Semiconductor Taiwan Phone: +886 281 786 222 Email info_pcbg@diasemi.com Web site: www.dialog-semiconductor.com Product Summary www.dialog-semiconductor.com Rev. 0.6 Preliminary 8 of 8 30-Oct-2017 © 2017 Dialog Semiconductor
IW662-02-SO8 价格&库存
很抱歉,暂时无法提供与“IW662-02-SO8”相匹配的价格&库存,您可以联系我们找货
