SF21G
THRU SF28G
2.0 AMP. G lass Passiv ated Sup er Fast Rectiers
Features
·Low forward voltage drop
DO-15
·High current capability
·High reliability
·High surge current capability
MIN.
Mechanical Data
DIA.
DO-15
· Terminals: Plated leads solderable per
MIL-STD-202,Method 208 guaranteed
· Polarity: Color band dentes cathode end
DIA.
· Mounting Position: Any
MIN.
· Making: Type Number
· Lead Free: For RoHS/Lead Free Version
Dimensions in inches and (millimeters)
Maximum Ratings and Electrical Characteristics
Rating at 25℃ ambient temperature unless otherwise specified
Single phase,half wave,60Hz,resistive or inductive load
For capacitive load derate current by 20%
Type Number
SYMBOL SF21G SF22G SF23G SF24G SF25G SF26G SF28G Unit
Maximum Recurrent Peak Reverse Voltage
VRM
50
100
150
200
300
400
600
V
Maximum RMS Voltage
VRMS
35
70
105
140
210
280
420
V
Maximum DC Blocking Voltage
VDC
50
100
150
200
300
400
600
V
Average Rectified Output Current (Note 1)
@TL =100 ℃
Peak Forward Surge Current 8.3ms Single half
sine-wave superimposed on rated load (JEDEC
Method)
I2t Rating for Fusing (t < 8.3ms)
Forward Voltage
@IF=2.0A
Peak Reverse Current
@TA=25℃
At Rated DC Blocking Voltage @TA=125℃
Maximum Reverse Recovery Time (Note2 )
Typical Junction Capacitance (Note 3)
Typical Thermal Resistance Junction to
Ambient (Note 4)
Operating Temperature Range
Storage Temperature Range
IF(AV)
2.0
A
IFSM
50
A
10.375
A2s
V
I 2t
VFM
0.95
1.3
1.7
5.0
IR
uA
100
TRR
35
nS
Cj
25
pF
RθJA
25
℃/W
Tj
-55 to + 150
TSTG
-55 to + 150
Note: 1. Leads maintained at ambient temperature at a distance of 9.5mm from the case
2.Reverse Recovery Test Conditions: IF=0.5A, IR=1.0A, IRR=0.25A
3. Measured at 1.0 MHz and Applied reverse Voltage of 4.0V D.C
4.Thermal Resistance from Junction to Ambient at 0.375(9.5mm) lead length.
version:04
1of3
www.dyelec.com
SF21G
THRU SF28G
FIG.2-TYPICAL FORWARD CHARACTERISTICS
100
1.5
1.0
0.5
50
75
100
125
150
175
INSTANTANEOUS FORWARD CURRENT (A)
AVERAGE FORWARD CURRENT
AMPERES (A)
2.0
SF21G-SF24G
10
SF25G-SF26G
SF28G
1.0
T A = 25°C
PULSE WIDTH 300us
0.1
LEAD TEMPERATURE, ℃
0.2
0.4
0.6
0.8
1.0
1.2
1.4
1.6
1.8
INSTANTANEOUS FORWARD VOLTAGE V
FIG.4 – TYPICAL JUNCTION CAPACITANCE
FIG. 3 – MAXIMUM NON-REPETITIVE SURGE CURRENT
100
80
60
CAPACITANCE, (pF)
SF21G-SF24G
40
PULSE WIDTH 8.3ms
SINGLE HALF-SINE-WAVE
(JEDEC METHOD)
SF25G -SF28G
10
5
10
T A = 25°C
100
f = 1 MHz
NUMBER OF CYCLES AT 60Hz
1
1
4
100
10
REVERSE VOLTAGE V
1
version:04
2of3
PEAK FORWARD SURGE CURRENT,
AMPERES (A)
2.0
FIG. 1 – FORWARD CURRENT DERATING CURVE
2.5
www.dyelec.com
SF21G
THRU SF28G
Important Notice and Disclaimer
•Reproducing and modifying information of the document is prohibited without permission
from XINNUO.
•XINNUOreserves the right to make changes to this document and its products and
specifications at any time without notice. Customers should obtain and confirm the
latest product information and specifications before final design, purchase or use.
•XINNUOdisclaims any and all liability arising out of the application or use of
any product including damages incidentally and consequentially occurred.
•XINNUO does not assume any and all implied warranties, including warranties of fitness for
particular purpose, non-infringement and merchantability.
Applications shown on the here in document are examples of standard use and
operation. Customers are responsible in comprehending the suitable use in particular
applications.
XINNUO makes no representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
•The products shown here in are not designed and authorized for equipments requiring high
level of reliability or relating to human life and for any applications concerning life-saving
or life-sustaining, such as medical instruments, transportation equipment, aerospace
machinery et cetera. Customers using or selling these products for use in such applications
do so at their own ris k andagree to fully indemnifyXINNUOfor any damages resulting from such
improper use or sale.
•Since XINNUO uses lot number as the tracking base, please provide the lot number for tracking
when complaining.
version:04
3 of 3
www.dyelec.com
很抱歉,暂时无法提供与“SF26G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.21438
- 200+0.16816
- 600+0.14246
