深圳市首韩科技有限公司
SHENZHEN SHOUHAN TECHNOLOGYCO.,LTD
Tel: 0755-27597601 Fax: 0755-27597491
承
认
书
产品名称 Project:
贴片电感
科
规格型号 Part No:
有
户 Customer:
技
客
限
公
司
SPECIFICATION FOR APPROVAL
韩
CY54-3.3UH
首
贵公司承认印 Approal slgnatures
签
章/Signatures
深
圳
市
料 号/Part No.
日期 Date:
拟制/Drawn
李春风
审核/Check
钟华华
批准/Approved
罗孝金
深圳市首韩科技有限公司
1.Features
①. High performance (Isat) realize by metal dust core .
②. Low profile: Thickness max.2.0~5.0mm.
③. Low loss and low resistance.
④. Capable of corresponding high frequency 1MHz~5MHz.
⑤ Ultra low buzz noise, due to composite construction.
⑥. The products contain no lead and also support lead-free soldering.
司
2.Applications area
Ideally used in NB/Desktop/server/Graphic card, LCD TV/Projector, etc as DC-DC Converter.
限
C
D E F
科
技
B
有
A
公
Externl Dimensions (unit : mm )
G
3.
UNIT: mm
A:5.2 ± 0.3
B:5.8 ± 0.3
C:4.5 ± 0.35
D:2.15
E:1.7
F:2.15
G:5.5
4. Product Code
54
3R3
圳
市
CY
首
韩
注:印2号(宽2.9*高1.6)宋体
M
Code 代码
TOLERANCE 公差
INDUCTANCE VALUE 电感值
深
DIMENSIONS 尺寸
SERIAL CODE 系列代码
• 电感值Inductance Value
(1R0:1.0uH; 100: 10uH; 101:100uH)
Tolerance 公差
J
±5%
K
±10%
L
±15%
M
±20%
P
±25%
N
±30%
深圳市首韩科技有限公司
5. Electrical
Characteristics
NOMINAL
INDUCTANCE
( uH )
1.0
1.5
DCR
(Ω)MAX
IDC
(A)MAX
100/0.25
13.00m
5.40
100/0.25
16.90m
4.70
100/0.25
19.50m
4.50
CY54-2R2M
1.8
2.2
100/0.25
22.10m
4.00
CY54-3R3M
3.3
100/0.25
31.20m
3.70
CY54-3R9M
3.9
100/0.25
36.40m
CY54-4R7M
4.7
100/0.25
52.00m
CY54-5R6M
5.6
100/0.25
54.60m
2.80
CY54-6R8M
6.8
100/0.25
58.50m
2.40
CY54-8R2M
8.2
100/0.25
62.40m
2.00
CY54-100K
10
100/0.25
87.90m
1.42
CY54-120K
12
100/0.25
75.40m
1.38
CY54-150K
15
100/0.25
105.30m
1.28
CY54-180K
18
100/0.25
117.00m
1.22
CY54-220K
22
100/0.25
169.00m
1.10
CY54-270K
27
100/0.25
153.40m
950m
CY54-330K
33
100/0.25
208.00m
860m
CY54-390K
39
100/0.25
214.50m
780m
CY54-470K
47
100/0.25
355.00m
710m
56
100/0.25
377.00m
660m
68
100/0.25
390.00m
600m
82
100/0.25
416.00m
570m
100
100/0.25
611.00m
510m
CY54-121K
120
100/0.25
754.00m
470m
CY54-151K
150
100/0.25
845.00m
380m
CY54-181K
180
100/0.25
1.04
360m
CY54-221K
220
100/0.25
1.45
340m
CY54-271K
270
100/0.25
1.51
310m
CY54-331K
330
100/0.25
1.76
280m
CY54-391K
390
100/0.25
2.08
260m
CY54-471K
470
100/0.25
2.99
240m
CY54-561K
560
100/0.25
3.12
220m
CY54-681K
680
100/0.25
3.90
200m
CY54-821K
820
100/0.25
5.20
190m
CY54-820K
深
圳
CY54-101K
市
CY54-560K
CY54-680K
公
限
有
技
首
CY54-1R8M
科
CY54-1R5M
韩
CY54-1R0M
司
Test Freq. (kHz/v)
PART No.
3.20
3.10
深圳市首韩科技有限公司
• Notes
1. All test data is referenced to 25 °C ambient
2. Operating temperature range - 55 °C to + 125 °C
3. Irms (A):DC current (A) that will cause an approximate ΔT of 40 °C(reference ambient temperature is 25 °C)
4. Isat(A):DC current (A) that will cause L0 to drop approximately 30 %
5. The part temperature (ambient + temp rise) should not exceed 125 °C under worst case operating conditions.
Circuit design, component placement, PWB trace size and thickness, airflow and other cooling provisions
all affect the part temperature. Part temperature should be verified in the end application.
6.Absolute maximum voltage 30VDC
司
6.Minimum Packaging and storage
D
规 格
尺寸
C
B
CY32
3000
CY42
3000
Φ178±2.0
B
Φ90 ± 2.0
C
2.3
CY75
1000
2000
CY77
600
2000
CY105
1000
CY106
800
1500
1500/盘
Standard Quantity
(pcs/reel)
1000
首
CY53
Type
21.5
CY73
韩
CY43
技
Standard Quantity
(pcs/reel)
科
Type
深
圳
市
• Tearing Off Force
Φ330±2.0
D
• Tape Carrier Packaging:
CY54
7"
限
A
13"
有
A
公
• 包装Packing
The force for tearing off cover tape is 15 to 60 grams in the arrow direction under the following conditions
Room
Temp. ( )℃
5~35
Room Humidity
45~85
Room atm
(hPa)
860~1060
Tearing Speed
mm/min
300
• Application Notice
Storage Conditions To maintain the solderability of terminal electrodes:
1. Temperature and humidity conditions: Less than 30℃ and 70% RH.
2. Recommended products should be used within 6 months form the time of delivery.
3. The packaging material should be kept where no chlorine or sulfur exists in the air.
Transportation
1. Products should be handled with care to avoid damage or contamination from perspiration and skin oils .
2. The use of tweezers or vacuum pick up is strongly recommended for individual components. Bulk handling
should ensure that abrasion and mechanical shock are minimized.
很抱歉,暂时无法提供与“CY54-3.3UH”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.33817
- 100+0.27118
- 300+0.23763
- 1500+0.19443
- 4500+0.17432
- 10500+0.16427
- 国内价格
- 10+0.21390
- 100+0.20010
- 500+0.18630
- 2000+0.16560
- 5000+0.15870
- 10000+0.15456
