E1J
E1J
    LGE(鲁光)
    SMF(SOD-123FL)
    耐压:600V 电流:1A 反向恢复时间:35NS
E1J 数据手册
E1A-E1J Surface Mount Rectifiers REVERSE VOLTAGE: 50 - 600 V CURRENT: 1.0 A SOD-123FL Features      Glass passivated device Ideal for surface mounted applications Low leakage current Metallurgically bonded construction High temperature soldering: 250℃/10 seconds at terminals 0.114(2.9) 0.098(2.5)    0.008(0.20) 0.004(0.10) 0.047(1.19) 0.043(1.09) Mechanical Data  0.043(1.09) 0.035(0.89) 0.075(1.90) 0.067(1.70) 0.030(0.76) 0.018(0.45) Case:JEDEC SOD-123FL,molded plastic over passivated chip Polarity: Color band denotes cathode end Weight: 0.003 ounces, 0.01 gram Mounting position: Any 0.154(3.9) 0.138(3.5) Dimensions in inches and(millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25℃ ambient temperature unless otherwise specified. Single phase,half wave,60Hz,resistive or inductive load.For capactive load,derate current by 20%. ABSOLUTE RATINGS E1A Device marking E1B E1C E1D E1E E1A E1B E1C E1D E1E E1G E1H E1G E1J E1H UNITS E1J Maximum recurrent peak reverse voltage VRRM 50 100 150 200 300 400 500 600 V Maximum RMS voltage VRMS 35 70 105 140 210 280 350 420 V Maximum DC blocking voltage VDC 50 100 150 200 300 400 500 600 V Maximum average forward rectified current T A=65℃ I(AV) 1.0 A IFSM 30 A Peak forward surge current 8.3ms single half-sine-wave superimposed on rated load T L=25℃ Maximum instantaneous (NOTE 1) VF forward voltage at 1.0A Maximum DC reverse current @TA=25℃ IR at rated DC blocking voltage @T A=125℃ 1.25 5.0 150 1.7 V µA Trr 35 nS Tj - 55 --- + 150 ℃ TSTG - 55 --- + 150 ℃ Maximum reverse recovery Time(note2) Operating temperature range Storage temperature range 0.95 NOTES:1.Pulse test:300ms pulse width,1% duty cycle. 2.Measured with IF=0.5A, IR=1A, Irr=0.25A. ht t p : // Revision:20170701-P1 www.lgesemi .c o m mail:lge@lgesemi.com E1A-E1J Surface Mount Rectifiers Ratings AND Charactieristic Curves .8 .7 .6 .4 Single Phase Half Wave 60Hz Resistive or Inductive Load .2 0 0 25 50 75 100 125 150 175 20 10 8.3ms Single Half Sine-Wave (JEDED Method) 0 1 4 2 6 8 10 20 40 60 80 100 NUMBER OF CYCLES AT 60Hz FIG. 3 - TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS FIG. 4 - TYPICAL REVERSE CHARACTERISTICS INSTANTANEOUS REVERSE CURRENT, (uA) AMBIENT TEMPERATURE, ( ) 100 10 ER 07 ER E-E 07 HR0 ER 7G 07 J 1 0.1 o 0.01 Tj=25 C Pulse Width=300 s 1% Duty Cycle 0.4 0.5 0.6 0.7 0.8 0.9 1.0 1.1 INSTANTANEOUS FORWARD VOLTAGE, (V) 100 TJ = 100 10 4 1 .4 TJ = 25 .1 0 20 40 60 80 100 120 140 PERCENT OF RATED PEAK REVERSE VOLTAGE, (%) PACKAGE SPQ/PCS CARTON SPQ/PCS CARTON SIZE/CM CARTON GW/KG CARTON NW/KG SOD-123FL 3000/REEL 90000 40X20X22 5.00 4.00 ht t p : // Revision:20170701-P1 FIG. 2 - MAXIMUM NON-REPETITIVE FORWARD SURGE CURRENT PEAK FORWARD SURGE CURRENT, (A) 1.0 ER 07A -ER 07D INSTANTANEOUS FORWARD CURRENT, (A) AVERAGE FORWARD CURRENT, (A) FIG. 1 - TYPICAL FORWARD CURRENT DERATING CURVE www.lgesemi .c o m mail:lge@lgesemi.com
很抱歉,暂时无法提供与“E1J”相匹配的价格&库存,您可以联系我们找货
E1J
  • 20+0.10979
  • 200+0.08660
  • 600+0.07367
  • 3000+0.06033
  • 9000+0.05366
  • 21000+0.04998
库存:1633
