9015
Rev.F Mar.-2016
DATA SHEET
Descriptions
TO-92 塑封封装 PNP 半导体三极管。Silicon PNP transistor in a TO-92 Plastic Package.
特征
/ Features
PC 大,hFE 高而且特性好,与 9014 互补。
High PC, excellent hFE linearity, complementary pair with 9014.
用途
Applications
用于低电平、低噪声的前置放大器。
Low frequency, low noise amplifier.
内部等效电路
引脚排列
12
/ Equivalent Circuit
/ Pinning
3
PIN1:Collector
放大及印章代码
PIN 2:Base
PIN 3:Emitter
/ hFE Classifications & Marking
hFE Classifications
Symbol
hFE Range
http://www.fsbrec.com
A
B
C
D
60~150
100~300
200~600
400~1000
1/6
9015
Rev.F Mar.-2016
极限参数
DATA SHEET
Absolute Maximum Ratings(Ta=25℃)
参数
Parameter
符号
Symbol
数值
Rating
单位
Unit
Collector to Base Voltage
VCBO
-50
V
Collector to Emitter Voltage
VCEO
-45
V
Emitter to Base Voltage
VEBO
-5.0
V
Collector Current - Continuous
IC
-100
mA
Collector Power Dissipation
PC
450
mW
Junction Temperature
Tj
150
Tstg
-55~150
Storage Temperature Range
电性能参数
/ Electrical Characteristics(Ta=25℃)
参数
Parameter
Collector to Base Breakdown
Voltage
Collector to Emitter Breakdown
Voltage
符号
Symbol
测试条件
Test Conditions
最小值 典型值 最大值 单位
Min
Typ
Max
Unit
VCBO
IC=-0.1mA
IE=0
-50
V
VCEO
IC=-1.0mA
IB=0
-45
V
Emitter to Base Breakdown Voltage
VEBO
IE=-0.1mA
IC=0
-5.0
V
Collector Cut-Off Current
ICBO
VCB=-50V
IE=0
-0.05
μA
Emitter Cut-Off Current
IEBO
VEB=-5.0V
IC=0
-0.05
μA
DC Current Gain
Collector to Emitter Saturation
Voltage
hFE
VCE=-5.0V
IC=-1.0mA
VCE(sat)
IC=-100mA
IB=-5.0mA
-0.2
-0.7
V
Base to Emitter Saturation Voltage
VBE(sat)
IC=-100mA
IB=-5.0mA
-0.82
-1.0
V
VBE
VCE=-5.0V
IC=-2.0mA
-0.65
-0.75
V
VCE=-5.0V
IC=-10mA
VCB=-10V
f=1.0MHz
VCE=-5.0V
Rg=2.0KΩ
△f=200Hz
IE=0
4.5
7.0
pF
IC=-0.2mA
f=1.0KHz
0.7
10
dB
Base to Emitter Voltage
Transition Frequency
fT
Collector Output Capacitance
Cob
Noise Figure
NF
60
100
1000
190
MHz
2/6
9015
Rev.F Mar.-2016
电参数曲线图
DATA SHEET
/ Electrical Characteristic Curve
3/6
9015
Rev.F Mar.-2016
外形尺寸图
DATA SHEET
/ Package Dimensions
4/6
9015
Rev.F Mar.-2016
印章说明
DATA SHEET
Marking Instructions
BR
9015
A ****
说明:
BR:
为公司代码
9015:
为产品型号
A:
为 hFE 分档代码
为生产批号代码,随生产批号变化。
Note:
BR:
Company Code.
9015:
Product Type.
A:
hFE Classifications Symbol.
Lot No. Code, code change with Lot No.
5/6
9015
Rev.F Mar.-2016
DATA SHEET
波峰焊温度曲线图(无铅)
Temperature Profile for Dip Soldering(Pb-Free)
说明:
Note:
1、预热温度 25~150℃,时间 60~90sec;
1.Preheating:25~150℃, Time:60~90sec.
2、峰值温度 255±5℃,时间持续为 5±0.5sec;
2.Peak Temp.:255±5℃, Duration:5±0.5sec.
3、焊接制程冷却速度为 2~10℃/sec.
3. Cooling Speed: 2~10℃/sec.
耐焊接热试验条件
温度:270±5℃
包装规格
散件包装
Time:10±1 sec
Units 包装数量
Units/Bag
只/袋
Bags/Inner Box
袋/盒
Units/Inner Box
只/盒
Dimension
Inner Boxes/Outer Box
盒/箱
Units/Outer Box
只/箱
Bag 袋
包装尺寸
Inner Box 盒
(unit:mm3)
Outer Box 箱
1,000
10
10,000
5
50,000
135×190
237×172×102
560×245×195
1,000
10
10,000
10
100,000
135×190
237×172×102
560×245×375
Units/tape
只/纸带
Tape/Inner Box
纸带/盒
Rows/Inner Box
纸带层/盒
盒/箱
Units/Outer Box
只/箱
Inner Box 盒
3,000
1
120
10
30,000
328×230×42
/ AMMO
Package Type
封装形式
使用说明
Temp.:270±5℃
/ BULK
TO-92
TO-92
时间:10±1 sec.
/ Packaging SPEC.
Package Type
封装形式
编带包装
Resistance to Soldering Heat Test Conditions
Units 包装数量
Dimension
包装尺寸
(unit:mm3)
Outer Box 箱
小箱 480×346×235,
大箱 547×407×268
/ Notices
6/6
很抱歉,暂时无法提供与“9015-C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.20596
- 200+0.16816
- 1000+0.14710
- 2000+0.13446
- 10000+0.12356
- 20000+0.11762
