2SD965
2SD965
    BLUEROCKET(蓝箭电子)
    TO92-3
    R(340-600) TO-92塑封封装NPN半导体三极管 NPN 电流:5A 电压:20V
2SD965 数据手册
2SD965 Rev.E Mar.-2016 描述 / DATA SHEET Descriptions TO-92 塑封封装 NPN 半导体三极管。Silicon NPN transistor in a TO-92 Plastic Package. 特征 / Features 饱和压降低,高性能。 Low VCE(sat),high performance. 用途 / Applications 用于音频输出放大。 Audio frequency output amplifier. 内部等效电路 引脚排列 12 / Equivalent Circuit / Pinning 3 PIN1:Base PIN 2:Collector 放大及印章代码 / hFE Classifications & Marking hFE Classifications Symbol hFE Range http://www.fsbrec.com PIN 3:Emitter P Q R S 180~270 230~380 340~600 560~1000 1/6 2SD965 Rev.E Mar.-2016 极限参数 / DATA SHEET Absolute Maximum Ratings(Ta=25℃) 参数 Parameter 符号 Symbol 数值 Rating 单位 Unit Collector to Base Voltage VCBO 40 V Collector to Emitter Voltage VCEO 20 V Emitter to Base Voltage VEBO 7.0 V Collector Current - Continuous IC 5.0 A Collector Current – Continuous(Pulse) ICP 8.0 A Collector Power Dissipation PC 750 mW Junction Temperature Tj 150 ℃ Tstg -55~150 ℃ Storage Temperature Range 电性能参数 / Electrical Characteristics(Ta=25℃) 参数 Parameter Collector to Emitter Breakdown Voltage Emitter to Base Breakdown Voltage 符号 Symbol 测试条件 Test Conditions 最小值 典型值 最大值 Min Typ Max 单位 Unit VCEO IC=1.0mA IB=0 20 V VEBO IE=10μA IC=0 7.0 V Collector Cut-Off Current ICBO VCB=10V IE=0 0.1 μA Emitter Cut-Off Current IEBO VEB=7.0V IC=0 0.1 μA hFE(1) VCE=2.0V IC=0.5A 180 hFE(2) VCE=2.0V IC=2.0A 150 IC=3.0A IB=0.1A fT VCE=6.0V IC=50mA Cob VCB=20V f=1.0MHz IE=0 DC Current Gain Collector to Emitter Saturation Voltage Transition Frequency Collector Output Capacitance http://www.fsbrec.com VCE(sat) 1000 1.0 150 V MHz 50 pF 2/6 2SD965 Rev.E Mar.-2016 电参数曲线图 DATA SHEET / Electrical Characteristic Curve http://www.fsbrec.com 3/6 2SD965 Rev.E Mar.-2016 外形尺寸图 DATA SHEET / Package Dimensions http://www.fsbrec.com 4/6 2SD965 Rev.E Mar.-2016 印章说明 / DATA SHEET Marking Instructions BR D965 P **** 说明: BR:    为公司代码 D965:  为型号代码 P:    为 hFE 分档代码 ****:  为生产批号代码,随生产批号变化。 Note: BR: Company Code. D965: Product Type. P:   ****: http://www.fsbrec.com  hFE Classifications Symbol Lot No. Code,code change with Lot No. 5/6 2SD965 Rev.E Mar.-2016 DATA SHEET 波峰焊温度曲线图(无铅) / Temperature Profile for Dip Soldering(Pb-Free) 说明: Note: 1、预热温度 25~150℃,时间 60~90sec; 1.Preheating:25~150℃, Time:60~90sec. 2、峰值温度 255±5℃,时间持续为 5±0.5sec; 2.Peak Temp.:255±5℃, Duration:5±0.5sec. 3、焊接制程冷却速度为 2~10℃/sec. 3. Cooling Speed: 2~10℃/sec. 耐焊接热试验条件 / Resistance to Soldering Heat Test Conditions 温度:270±5℃ 包装规格 散件包装 Units 包装数量 Units/Bag 只/袋 Bags/Inner Box 袋/盒 Units/Inner Box 只/盒 Dimension Inner Boxes/Outer Box 盒/箱 Units/Outer Box 只/箱 Bag 袋 包装尺寸 Inner Box 盒 (unit:mm3) Outer Box 箱 1,000 10 10,000 5 50,000 135×190 237×172×102 560×245×195 1,000 10 10,000 10 100,000 135×190 237×172×102 560×245×375 Units/tape 只/纸带 Tape/Inner Box 纸带/盒 Rows/Inner Box 纸带层/盒 Inner Boxes/Outer Box 盒/箱 Units/Outer Box 只/箱 Inner Box 盒 3,000 1 120 10 30,000 328×230×42 / AMMO Package Type 封装形式 使用说明 Time:10±1 sec / BULK TO-92 TO-92 Temp:270±5℃ / Packaging SPEC. Package Type 封装形式 编带包装 时间:10±1 sec. Units 包装数量 Dimension 包装尺寸 (unit:mm3) Outer Box 箱 小箱 480×346×235, 大箱 547×407×268 / Notices http://www.fsbrec.com 6/6
2SD965 价格&库存
很抱歉,暂时无法提供与“2SD965”相匹配的价格&库存,您可以联系我们找货
2SD965
  • 10+0.43557
  • 100+0.34226
  • 300+0.29560
库存:141
