PCB SMD NUT CONNECTOR
电路板表贴螺母柱连接器
下列条件适用于 SMD 产品系列内的所有零件:
• 请参照技术手册中的建议设计电路板。
• 必须根据回流焊/波峰焊技术规范选择合格的焊料,严格控制焊接温度、时间。 •焊
接工艺会导致产品表面变色。
• 爬锡现象会导致内孔堵塞,因此通孔产品不适用波峰焊,建议采用回流焊。 •所有
产品应在出厂 12 个月内使用,超出有效期会影响可焊性。
• 必须在密封、干燥环境下保存。
• 零件与 PCB 的连接强度由产品、焊盘、焊接效果等因素综合决定
• 必须控制最大锁附扭力,防止元件和 PCB 受到机械破坏。
• 工作电流由 PCB、电缆接头、电缆横截面等因素综合决定。
• 手册中如有标注参考电流,零件使用材料为黄铜 C3604(H59)
Cautions and Warnings:
The following conditions apply to all goods within the product series of yiyuan PCB SMD
General:
All recommendations according to the general technical specifications of the data-sheet have to be complied with.
The responsibility for the applicability of customer specific products and use in a particular customer design is always within the authority of the
customer. All technical specifications for standard products do also apply for customer specific products.
Product Specific:
Follow all instructions in the datasheet, especially:
• The solder profile has to be complied with according to the technical reflow soldering specification, otherwise no warranty will be sustained.
• Surface discoloration due to reflow processing is permitted.
• Wave soldering is not applicable. Reflow soldering is recommended.
• All products shall be used before the end of the period of 12 months based on the product date-code, if not a 100% solderability can't be ensured.
• The maximum permissible torques must be complied with to prevent mechanical destruction of the elements and PCB.
• Operating current depends on PCB, cable lug and cross section of the cableo
• The connection strength between parts and PCB is determined by product, pad and welding effect
• If the operating current is marked in the manual, the material used for the parts is brass C3604(H59)
深圳市怡远科技有限公司
info@yiyuanswitches.com
www.yiyuanswitches.com
电路板表贴螺母柱连接器
Thread sizes 080, S1, S1.2, S1.4 and M1.6
All dimensions are in milineters.
Thread
Size x
Pitch
Thru
Hole
Type
+0.10
-0.08
1hread or
Thru Hole
Code
Therad/thru hole sizes M2, M2, M2. 5, M3, M3. 5, M4, 3. 6, 4. 2
Length Code"H"±0.13
(Length code in
millimeters)
METRIC 公制尺寸
4.19
15
0.3
2.5
4.19
15
0.6
0.5
0.48 2.41 3.66 —
3.18
2.5
4.19
15
1
0.5
0.48 2.41 3.66 —
3.18
2.5
4.19
15
1.5
1.5 2
2.5 3
M1.4x0.3
SMTSO
M1.4 0.5 1
1.5 2
2.5 3
M1.6x0.35
SMTSO
M1.6 0.5 1
1.5 2
2.5 3
M2x0.4
SMTSO
M2
2 2.5 3
3.5 4
4.5 5
5.5 6
6.5 7
8
9 10
11
M2.5x0.45
SMTSO
M2.5 —
1
1.5 2
2.5 3
3.5 4
4.5 5
5.5 6
6.5 7
8
9 10
11 12
13 15
M3x0.5
SMTSO
M3
1
1.5 2
2.5 3
3.5 4
4.5 5
5.5 6
6.5 7
8
9 10
11 12
SMTSO
M3.5 —
2.5 3
3.5 4
4.5 5
5.5 6
6.5 7
8
9 10
11 12
2 2.5 3
3.5 4
4.5 5
5.5 6
6.5 7
8
9 10
11
2.5 3
3.5 4
4.5 5
5.5 6
6.5 7
8
9 10
SMTSO
M4
3.2
SMTSO
K
1
3.6
SMTSO
L
2
2.5 3
3.5 4
4.5 5
5.5 6
6.5 7
8
9 10
4.2
SMTSO
M
2
2.5 3
3.5 4
4.5 5
5.5 6
6.5 7
8
9 10 —
1.5 2
12 13 15
18
1.53 1.53
3.6 —
5.56 —
3.73
6.2
30
1.5
18
1.53 1.53 4.09 —
5.56 —
4.22
6.2
30
3
13 15
18
1.53 1.53 4.09 —
5.56 —
4.22
6.2
30
5
13 15
18
1.53 1.53 5.28 —
7.14 —
5.41
7.77
40
6
12 13 15
18
1.53 1.53 6.22 —
8.74 —
6.35
9.37
50
8
1.53 1.53 4.09 —
5.56 —
4.22
6.2
1.53 1.53 5.28 —
7.14 —
5.41
7.77
30
1.53 1.53 6.22 —
8.74 —
6.35
9.37
40
*更多”L"尺寸未列在表中,请略我们确认! MORE "L" SIZES ARE NOT LISTED IN THE TABLE, PLEASE CONTACT US FOR CONFIRMATIO
Therad/thru hole sizes M2, M. 5, M3, M3. 5, M4, 3. 6, 4. 2
Thread s i zes 0, S1, S1.2, S1.4 and M1.6
Ref. ±0.13
2.5
M1.2 0.5 1
3.18
SMTSO
3.18
2
0.48 2.41 3.66 —
M1.2x0.25
0.5
M1
1.5
Tightening
Torque
(Kgf.cm)
SMTSO
0.5 1
2 2.5 3
Rated
Hole Size
0D
In Sheet Min.Solder Current
+0.08
Pad
(A)
0.48 2.41 3.66 —
M4x0.7
1.5
L
Nom
一 0.5
M 1x0.25
M3.5x0.6
0.5 1
Min.
Sheet
A
C
Thickne Max. Max.
ss
Below is blind hole with 7mm thread depth
Length Code"H"±0.13 (Length code in millimeters)
2, 4, 6, 8, 116 and 143
All dimensions are in inches.
Thread
Size
Thru Hole
+.004 -.003
Type
Thread or
Thru Hole
Code
Length Code"H"±.005 (Length code in 32nds of an inch)
UNIFIED 英制尺寸
,060-80
(#0-80)
SMTSO
.125
.086-56
(#2-56)
SMTSO
2
.062
.125
.187
.112-40
(#4-40)
SMTSO
4
.062
.125
.187
,060-80
(#6-32)
SMTSO
6
.062
.125
.187
.164-32
(#8-32)
Min. Sheet
A
Thickness Max.
C
Max.
R
Ref.
±.005
L
Nom.
0H
Hole Size In
Sheet +.003-.000
0D
Rated
Min.Solder Current
Pad
(A)
Tightening
Torque
(Kgf.cm)
.020
.019
.095
.144
.125
.098
.165
15
1.5
.250
.312
.375
.060
.060
.142
.219
.147
.244
30
1.5
.250
.312
.375
.060
.060
.161
.219
.166
.244
30
5
.312
.375
.060
.060
.208
.281
.213
.306
40
6
.250
SMTSO
8
.062
.125
.187
.250
.312
.375
.060
.060
.245
.344
.250
.369
50
8
.116
SMTSO
9
.062
.125
.187
.250
.312
.375
.060
.060
.161
.219
.166
.244
30
.143
SMTSO
10
.062
.125
.187
.250
.312
.375
.060
.060
.208
.281
.213
.306
40
深圳市怡远科技有限公司
电路板表贴螺母柱连接器
Classification Reflow Profile for SMT components:
Classification Reflow Soldering Profile:
Profile Feature
Value
Preheat Temperature Min〔)
L min
Preheat Temperature Max
Ts max 200 °C
Preheat Time ts from Tsmi„ to Tsmax
ts
Ramp-up Rate (TL to Tp)
150 °C
60-120 seconds
3 °C/ second max.
Liquidous Temperature
TL
217 °C
Time tL maintained above TL
匕
60-150 seconds
Peak package body temperature
Time within 5°C of actual peak temperaure
Package Classification Reflow Temperature:
Time
Properties
Volume mm3
2000
PB-Free Assembly I Package Thickness < 1.6 mm
260 °C
260 °C
260 °C
PB-Free Assembly I Package Thickness 1.6 mm - 2.5 mm
PB-Free Assembly I Package Thickness > 2.5 mm
260 °C
250 °C
250 °C
245 °C
245 °C
245 °C
see table
tp
20 - 30 seconds
Ramp-down Rate (TL to Tp)
6 °C/ second max.
Time 25°C to peak temperature
8 minutes max.
深圳市怡远科技有限公司
很抱歉,暂时无法提供与“SMTSOM360BTR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.65042
- 100+0.60846
- 500+0.56649
- 2000+0.50355
- 5000+0.48257
- 10000+0.46998
