RJ16F0TR500
RJ16F0TR500
    THUNDER(盛雷城)
    插件
    插件电阻 插件 500mΩ ±1% 1W >±100ppm/℃
RJ16F0TR500 数据手册
APPROVAL SHEET RJ SERIES METAL FILM RESISTORS PRODUCE CHECK AND APPROVE ACCEPTED BY EM CE HONORABLE CUSTOMER Edison Chen Charles Chen Mar.28, 2019 Mar.28, 2019 www.thunder-resistor.com sales@thunder-resistor.com Page 1 of 10 1. PRODUCT: METAL FILM PRECISION RESISTORS TYPE 2. PART NUMBER: Part number of the precision metal film resistor is identified by the series name, power rating and size code, tolerance, temperature coefficient, packing type and resistance value. Example: RJ 73 S Series Name Power Rating B 3 T Size Resistance Temperature Code Tolerance Coefficient Packing Type 1004 Resistance Value Style: RJ SERIES (1) Power Rating: 73=1/4W; 74=1/2W; 75=16=1.0W; 76=17=2.0W; 18=3.0W; (2) Size code: - normal size; S:small size; M:mini size; MP: mini size power mode (4) Tolerance: B=±0.1%; C=±0.25%; D=±0.50%; F=±1.0%; G=±2.0%; J=±5.0%; (5) T.C.R.: 7=5ppm/oC; 6=10ppm/ oC; 5=15ppm/ oC; 3=25ppm/ oC; 2 = 50ppm/ oC; 1=100ppm/ oC; 0= over 100ppm/ oC (6) Packaging Type: B=BULK/BOX T=Tape on Box Packing; F type and M type forming are available upon request (7) Resistance Value: 1R00、20R0、1000、1001、1002、3303、1004……… 3. Standard applied: RJ7 series: SJ/T 10571~10574; RJ16, RJ17 series: Q/RU221-94; Thunder Enterprise standard: Q/SLC005-1995 www.thunder-resistor.com sales@thunder-resistor.com Page 2 of 10 4. COLOR BAND-CODE: COLO multipl 1st 2nd 3rd black 0 0 0 1 brown 1 1 1 10 F(±1.0%) red 2 2 2 102 G(±2.0%) orange 3 3 3 103 15ppm/℃ yellow 4 4 4 104 25ppm/℃ green 5 5 5 105 blue 6 6 6 106 purple 7 7 7 gray 8 8 8 white 9 9 9 R e tolerance D(±0.50% ) C(±0.25% ) B(±0.10% ) golden 10-1 J(±5.0%) silver 10-2 K(±10%) TCR 100ppm/ ℃ 50ppm/℃ 15ppm/℃ 10ppm/℃ 5ppm/℃ Five or six color code rings designate the resistance value and tolerance and temperature coefficient in accordance with IEC 60062. Temperature coefficient marked for small TCR on request as the sixth ring in accordance with IEC 60062. Digital marking is available on request. www.thunder-resistor.com sales@thunder-resistor.com Page 3 of 10 5. ELECTRICAL CHARACTERISTICS Unless otherwise specified, all values are tested at the following condition: Temperature: 21℃ to 25℃; Relative humidity: 45% to 70% Resistance out of range is available upon request. www.thunder-resistor.com sales@thunder-resistor.com Page 4 of 10 6. DERATING CURVE normal size resistors; small size and mini size resistors For resistors working at an ambiance temperature of 70℃ or above, the power rating shall be derated in accordance with the above curves. www.thunder-resistor.com sales@thunder-resistor.com Page 5 of 10 7. Deforming FK type 1,2W 12.7 12.7 3.85 5 18 9 17.5 φ4.0 11.5 4.5 功率 P±1.0 P0±0.3 P1±0.7 F±0.5 W±0.5 W 1±0.5 H0±1.0 D0±0.2 L±1.0 D±0.5 8. Deforming M type Dimension varies according to the size of the resistors and could be adjusted upon request. www.thunder-resistor.com sales@thunder-resistor.com Page 6 of 10 9. ENVIRONMENTAL CHARACTERISTICS (1) Insulation Resistance IEC 60115-1, 4.6: in V-block for 60 seconds, the test resistance should be high than 10,000 M Ohm. (2) Dielectric Withstanding Voltage IEC 60115-1 4.7: flashover. (3) Place resistors in V-block for 60 Seconds, no breakdown or Temperature Coefficient Test IEC 60115-1, 4.8: Test of resistors at room temperature and 60°C or 100°C on request above room temperature. Then measure the resistance. The Temperature Coefficient is calculated by the following equation and its value should be within the range requested. Re sistor Temperature Coefficient  R R0 t t0 (4) R  R0 1   10 6 R0 t  t0 = Resistance value under the testing temperature = Resistance value at the room temperature = the 2nd testing temperature = Room temperature Short Time Over Load Test IEC60115-1 4.13: At 10 times rated voltage or 2 times the maximum working voltage whichever is lower for 5 seconds, the resistor should be free from defects. The change of the resistance value should be within ±(0.10%+0.05 Ω) as compared with the value before the test. (5) Solderability IEC 60115-1, 4.17: 235±5°C for 3±0.5 Seconds, there are at least 95% solder coverage on the termination. www.thunder-resistor.com sales@thunder-resistor.com Page 7 of 10 (6) Resistance to soldering heat: IEC 60115-1, 4.18: 260±3°C for 10±1 Seconds, immersed to a point 3±0.5mm from the body. The change of the resistance value should be within ±(0.15%+0.05 Ω) as compared with the value before the test. (7) Climatic sequence IEC 60115-1, 4.19: -55°C to Room Temp. to +155°C to Room Temp. (5 cycles). The change of the resistance value shall be within ±(0.50%+0.05 Ω) for tight tolerance and ±(1.0%+0.05 Ω) for normal tolerance as compared with the value before the test. (8) Damp Heat Steady State IEC 60115-1, 4.24: 40±2°C, 90-95% RH for 56 days, loaded with 0.1 times RCWV or the maximum working voltage whichever is lower. The change of the resistance value should be within ±(0.50%+0.05 Ω) for tight tolerance and ±(2.0%+0.05 Ω) for normal tolerance as compared with the value before the test. (9) Load Life Test IEC 60115-1, 4.25: 70±2°C at RCWV or the maximum working voltage whichever is lower for 1,000+48/-0 Hr. (1.5Hr. on, 0.5Hr. off). The resistors shall be arranged not much effected mutually by the temperature of others and the excessive ventilation shall not be performed. The change of the resistance value should be within ±(0.50%+0.05 Ω) for tight tolerance and ±(2.0%+0.05 Ω) for normal tolerance as compared with the value before the test. (10) Accidental Overload Test IEC 60115-1, 4.26: 4 times RCWV for 1 Minute. No evidence of flaming or arcing (11) Single-pulse high-voltage overload test . IEC 60115-1, 4.27: Apply 4 times rated voltage or 2 times the maximum working voltage whichever is lower to the resistor at the 0.1 second on and 2.5 seconds off cycle for 1000 cycles. The change of the resistance shall be within ± (2.0%+0.05Ω). www.thunder-resistor.com sales@thunder-resistor.com Page 8 of 10 (12) High voltage high pulse overload IEC 60115-1, 4.28: Apply 10 pulses with 10 times rated voltage or 2 times the maximum working voltage whichever is lower to the resistor, the pulses parameter is 10μs/700μs. The change of the resistance shall be within ± (2.0%+0.05Ω). (13) Resistance to Solvent IEC 60115-1, 4.30: IPA for 5±0.5 Min. with ultrasonic. No deterioration of coating and color code occurred. (14) Boiling test Sample 80 pcs from each lot boiling in boiling water for 1hour, dry them in room temperature for 30 minutes and load them with rated DC voltage or maximum working voltage whichever is lower for 1hour, repeat to boil and load for another 1cycle, dry them at least 30m before test. The change of the tolerance of the resistors shall be within ±(2.00%+0.05Ω). www.thunder-resistor.com sales@thunder-resistor.com Page 9 of 10 Disclaimer All products, product specifications and data are subject to change without notice to improve reliability, function or design or otherwise. Thunder Precision Resistors makes no warranty, representation or guarantee regarding the suitability of the products for any particular purpose or the continuing production of any product to the maximum extent permitted by applicable law. www.thunder-resistor.com sales@thunder-resistor.com Page 10 of 10
RJ16F0TR500 价格&库存
很抱歉,暂时无法提供与“RJ16F0TR500”相匹配的价格&库存,您可以联系我们找货
