SUB-DRAM-602A-002
SUB-DRAM-602A-002
    NEXTRON(正凌)
    弯插
    D-Sub连接器 9Pin 双排 弯插
SUB-DRAM-602A-002 数据手册
1 2 3 4 5 6 DIM C±0.38 DIM B±0.25 DIM A±0.13 2.84 2.77 8.38 1# XX# 18.5±0.30 DIM X 2.84±0.20 6.0 B 37P 55.42 63.50 69.32 8.08 9.50 25P 38.96 47.04 53.04 8.08 9.50 1.0 POS. NO. DIM B 0.15 6 TYPE A 7 TYPE 9 TYPE C X 6=SCREWED HEX SCREW ON BOARD LOCK 7=RIVETED W/ BOARD LOCK/WASHER 8=RIVETED W/BOARD LOCK/ WASHER/HEX SCREW 9=RIVETED W/ BOARD LOCK/WASHER/ ATTACHED HEX SCREW Y C TYPE H #4-40 H L PLATED A=GOLD 1u"/LIGHT TIN B=GOLD 3u"/LIGHT TIN C=GOLD 5u"/LIGHT TIN E=GOLD 15u"/LIGHT TIN F=GOLD 30u"/LIGHT TIN BOARD LOCK/WASHER RIVETED W/ BOARD LOCK/WASHER/ ATTACHED HEX SCREW D CONTACT MATERIAL 2=BRASS C=SCERWED HEX SCREW DIRECT RIVETING NUT LOCK NUT POST HEIGHT(H*L) 0=5.8*12.8(STD) 1=4.8*11.8 SCREW 2PCS RIVETED W/BOARD LOCK/ WASHER/HEX SCREW RIVETED W/ SCREWED HEX SCREW ON BOARD LOCK C INSULATOR MATERIAL 0=PBT 2=NYLON MOUNTING OPTIONS DIMENSION H H 8 TYPE B INSULATOR COLOR 0=BLACK 6=BLUE 9=WHITE TYPE M=MALE 9P 16.92 24.99 30.81 8.08 9.50 1# LOGO 0=NO LOGO 2=NEXTRON LOGO NO. OF CONTACTS A=9PIN B=15PIN C=25PIN E=37PIN 15P 25.25 33.32 39.14 8.08 9.50 XX# D Z-SUBDR * M * * 2 * * * * 0 3. 2 0± 0.1 2.84 DIM Y 2.77 B PART NO. 3.2 SQ0.64 C A MATERIAL AND FINISH Insulator:PBT+30%G.F(UL94V-0) Contact:Copper Alloy, Nickel Undercoated Selective Gold Plated Shell:Metal Iron, With Tin Plated 10 ° #4-40 8 SPECIFICATIONS: Current rating:3.0A AC/DC Voltage rating:250V AC/DC Contact resistance:30m ohm MAX Insulation resistance:5000M ohm MIN Withstanding voltage:1000V AC for one minute Operating temperature range:-40°C~+85°C 12.5 A 7 SCERWED HEX SCREW DIRECT RIVETING NUT LOCK B Mounting Options E UNITS: mm CS NI RP ISSUE DATE CO ENGINEERING AT mm ± ** ± ** ± 0.20 ± 0.30 X°± 3° N NE IO This file is automatically issued by EPDM B MARK MODIFY ECN-19105 B =1 NEW RELEASED A1 REV. DESCRIPTION and is not valid without the issue date 1 A3 GENERAL TOLERANCE: (UNLESS SPECIFIED) OR XT RO SIZE inch 2 3 2019/10/21 2019/05/29 DATE 4 4 PLACE 3 PLACE 2 PLACE 1 PLACE ANGLES 5 inch ±. ** ±. ** ±. ** ±. ** NAME: D-SUB DR TYPE MALE PCB SOLDER TYPE E NEXTRONICS ENGINEERING CORP. PART NO: Z-SUBDRXMXX2XXXX APPD: DRAW: 6 CUSTOMER DWG DWG NO: 010-0000-687 CHKD: DESIGN: Lu 陳 惠 枝 TITLE: 2019/10/21 7 SCALE SHEET REV. B 1/1 1/1 8 CON FIDEN TIAL: THIS DOC UMENT C ON TA INED THE INF OR MA TION IS P ROP RIETARY AND CONFIDE NTIAL TO Nextronics Engineering Corp. NO PERSON IS ALLOWED TO USE C OPY , PUBLISH OR OTHERW ISE D ISCLOSE THE INFOR MATION TO OTHER S, U NLESS BY TH E PRIOR WRITTEN EXPRESS AUTHORIZATION OF N extronics E ngineering C orp. (C )C OPYR IGHT- Nextronics Engineering Corp. A5 C D-PRD-034
SUB-DRAM-602A-002 价格&库存
很抱歉,暂时无法提供与“SUB-DRAM-602A-002”相匹配的价格&库存,您可以联系我们找货
SUB-DRAM-602A-002
  • 1+1.88000
  • 10+1.70000
  • 50+1.55600
  • 150+1.46000
  • 300+1.40000
