FMMT495
FMMT495
    MSKSEMI(美森科)
    SOT-23
    三极管 耐压:150V 电流:1A NPN SOT-23
FMMT495 数据手册
www.msksemi.com FMMT495 Semiconductor FMMT495 Compiance TRANSISTOR (NPN) FEATURE  Low VCE(sat)  hFE characterised up to 1A for high current gain hold up  For general amplification 1. BASE 2. EMITTER SOT–23 MARKING: 495 3. COLLECTOR MAXIMUM RATINGS (Ta=25℃ unless otherwise noted) Symbol Parameter Value Unit VCBO Collector-Base Voltage 170 V VCEO Collector-Emitter Voltage 150 V VEBO Emitter-Base Voltage 5 V Collector Current 1 A Collector Power Dissipation 250 mW Thermal Resistance from Junction to Ambient 500 ℃/W -55~+150 ℃ IC PC RΘJA TJ,Tstg Operation Junction and Storage Temperature Range ELECTRICAL CHARACTERISTICS (Ta=25℃ unless otherwise specified) Parameter Collector-base breakdown voltage Symbol Test V(BR)CBO * conditions Min Typ Max Unit IC=100µA, IE=0 170 V IC=10mA, IB=0 150 V 5 V Collector-emitter breakdown voltage V(BR)CEO Emitter-base breakdown voltage V(BR)EBO IE=100µA, IC=0 Collector cut-off current ICBO VCB=150V, IE=0 0.1 µA Collector cut-off current ICES VCE=150V,VBE=0 0.1 µA Emitter cut-off current IEBO VEB=4V, IC=0 0.1 µA DC current gain Collector-emitter saturation voltage Base-emitter turn-on voltage Base-emitter saturation voltage Transition frequency Collector output capacitance hFE(1) * VCE=10V, IC=1mA 100 hFE(2) * VCE=10V, IC=250mA 100 hFE(3) * VCE=10V, IC=500mA 50 hFE(4) * VCE=10V, IC=1A 10 300 VCE(sat)(1) * IC=250mA, IB=25mA 0.2 V VCE(sat)(2) * IC=500mA, IB=50mA 0.3 V VBE(on) * VCE=10V, IC=500mA 1 V VBE(sat) * IC=500mA, IB=50mA 1 V fT Cob VCE=10V,IC=50mA,f=100MHz VCB=10V,IE=0,f=1MHz 100 MHz 10 pF *Pulse test: pulse width ≤300μs, duty cycle≤ 2.0%. www.msksemi.com FMMT495 Semiconductor Compiance PACKAGE MECHANICAL DATA Symbol A A1 A2 b c D E E1 e e1 L L1 θ Dimensions In Millimeters Min Max 0.900 1.150 0.000 0.100 0.900 1.050 0.300 0.500 0.080 0.150 2.800 3.000 1.200 1.400 2.250 2.550 0.950 TYP 1.800 2.000 0.550 REF 0.300 0.500 0° 8° Dimensions In Inches Min Max 0.035 0.045 0.000 0.004 0.035 0.041 0.012 0.020 0.003 0.006 0.110 0.118 0.047 0.055 0.089 0.100 0.037 TYP 0.071 0.079 0.022 REF 0.012 0.020 0° 8° REEL SPECIFICATION P/N FMMT495 PKG QTY SOT-23 3000 www.msksemi.com FMMT495 Semiconductor Compiance Attention ■ Any and all MSKSEMI Semiconductor products described or contained herein do not have specifications that can handle applications that require extremely high levels of reliability, such as life-support systems, aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your MSKSEMI Semiconductor representative nearest you before using any MSKSEMI Semiconductor products described or contained herein in such applications. ■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products specificationsof any andall MSKSEMI Semiconductor products described orcontained herein. ■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the customer’sproducts orequipment. ■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all semiconductor products fail with someprobability. It is possiblethat these probabilistic failures could give rise to accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures include but are not limited to protective circuits anderror prevention circuitsfor safedesign, redundant design, and structural design. ■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described or contained herein are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the export license from theauthorities concerned in accordance with the above law. ■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of MSKSEMI Semiconductor. ■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume production. MSKSEMI Semiconductor believes information herein is accurate and reliable, but no guarantees are made or implied regarding its use or any infringementsof intellectual property rights or other rightsof third parties. ■ Any and all information described or contained herein are subject to change without notice due to product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the MSKSEMI Semiconductor productthat you intend to use. www.msksemi.com
FMMT495 价格&库存
很抱歉,暂时无法提供与“FMMT495”相匹配的价格&库存,您可以联系我们找货
FMMT495
  • 10+0.40932
  • 100+0.33156
  • 300+0.29268
  • 3000+0.25380
  • 6000+0.23048
  • 9000+0.21870
库存:13053
