M4
M4
    BORN(伯恩)
    SMA(DO-214AC)
    二极管 电压:400V 电流:1A SMA(DO-214AC)
M4 数据手册
ROHS RECTIFIER SMA Plastic-Encapsulate Silicon Rectifiers M1 M7 M1-M7 ROHS FEATURES  Low cost  Diffused junction  Low Leakage  Low forward voltage drop  High current capability  Easily cleaned with Freon. Alcohol. Lsopropanol and similar solvents  The plastic material carries U/L recognition 94V-O MECHANICAL DATA  Case: JEDEC DO - 214AC. molded plastic body  Terminals: Solder plated. Solderable per MIL - STD - 750. Method 2026  Polarity: Color band denotes cathode  Weight: 0.003 ounce.0.093 grams  Mounting position: Any MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25 ℃ ambient temperature unless otherwise specified. Single phase. half wave. 60HZ. resistive or inductive load. For capacitive load. derate current by 20% SYMBOL M1 M2 M3 M4 M5 M6 M7 UNITS Maximum Recurrent Peak Reverse Voltage VRRM 50 100 200 400 600 800 1000 V Maximum RMS Voltage VRMS 35 70 140 280 420 560 700 V Maximum DC Blocking Voltage VDC 50 100 200 400 600 800 1000 V Maximum Average Forward Rectified Current at TL = 110℃ I(AV) 1.0 A IFSM 30 A VF 1.1 V Peak Forward Surge Current 8.3ms Single half-sine-wave superimposed on rated Tj = 125℃ Maximum Forward Voltage at 1.0A DC Maximum Reverse Current TA = 25℃ at Rated DC Blocking Voltage TA = 100℃ 5.0 IR μA 50 Typical Junction Capacitance ( Note 1 ) Cj 15 pF Typical Thermal Resistance ( Note 2 ) RQJA ℃/W Operating Junction Temperature Range Tj 75 55 to 125 TSTG 55 to 150 ℃ Storage Temperature Range NOTE: ℃ 1. Reverse revovery condition IF=0.5A IR=1.0A Irr=0.25A. 2. Measured at 1.0MHZ and applied reverse voltage of 4.0V DC. 3. Thermal Resistance Junction to Ambient. Rev 8: Nov 2014 www.born-tw.com Page 1 of 2 ROHS RECTIFIER SMA Plastic-Encapsulate Silicon Rectifiers FIG. 1 -- TYPICAL FORWARD CHARACTERISTIC 100 4.0 Tj = 25 ℃ Pulse Width = 300μS Tj = 25 ℃ CAPACITANCE. PF 1.0 0.4 AMPERES INSTANTANEOUS FORWARD CURRENT / ROHS FIG. 2 -- TYPICAL JUNCTION CAPACITANCE 10 0.1 0.04 0 0.4 0.6 0.8 1.0 1.2 1.4 1.6 10 3.0 1.0 1.8 1.0 10 INSTANTANEOUS FORWARD VOLTAGE / VOLTS 100 REVERSE VOLTAGE / VOLTS FIG. 3 -- FORWARD CURRENT DERATING CURVE FIG. 4 -- PEAK FORWARD SURGE CURRENT Resistive or Inductive Load 1.0 0.5 0 0 25 50 75 100 125 150 175 200 CURRENT AMPERES Single Phase Half Wave 60HZ PEAK FORWARD SURGE 40 1.5 CURRENT AMPERES AVERAGE FORWARD RECTIFIED M1-M7 30 Tj = 25 ℃ 8.3 ms Single 20 Half Sing -Wave 10 0 1.0 2.0 10 20 100 NUMBER OF CYCLES AT 60HZ AMBIENT TEMPERATURE / ℃ Fig.5-Typical transient thermal impedance Fig.6-TYPICAL REVERSE CHARACTERISTICS INSTANTANEOUS REVERSE CURRENT. MICROAMPERES TRANSIENT THERMAL IMPEDANCE. C/W 100 10 1 0.1 0.01 1 100 10 INSTANTANEOUS FORWARD VOLTAGE,VOLTS Rev 8: Nov 2014 www.born-tw.com 1000 Tj=150℃ 100 10 Tj=100℃ 1 Tj=25℃ 0.1 0.01 0 20 40 60 80 100 PERCENTAGE OF PEAK REVERSE VOLTAGE,% Page 2 of 2
很抱歉,暂时无法提供与“M4”相匹配的价格&库存,您可以联系我们找货
M4
  • 1+0.20240
  • 500+0.06754
  • 2500+0.04499
  • 5000+0.03674
库存:4872
