TUSD05L4U
TUSD05L4U
    SPSEMI(瞬雷)
    DFN2510-10
    ESD抑制器/TVS二极管 VRWM=5V VBR(min)=6V VC=25V@Ipp=5A DFN2510-10L
TUSD05L4U 数据手册
SPSEMI ESD/TUSD05L4U     Electro-Static Discharge TUSD05L4U Low Capacitance TVS Diode DFN2510-10L Pin Configuration 10 9 8 7 6 1 2 3 4 5 Features 150 Watts Peak Pulse Power per Line (tp=8/20μs) Protects two or four I/O lines Low capacitance: 0.3pF typical (I/O to I/O) Low operating voltage: 5V RoHS Compliant IEC Compatibility IEC61000-4-2 (ESD) ±15kV (air), ±8kV (contact) IEC61000-4-4 (EFT) 40A (5/50ns) IEC61000-4-5 (Lightning) 5A (8/20μs) Applications High Defi nition Multi-Media Interface (HDMI) Digital Visual Interface (DVI) Unifi ed Display Interface (UDI) MDDI Ports PCI Express Serial ATA Mechanical Characteristics JEDEC DFN2510-10L Package Molding Compound Flammability Rating : UL 94V-O Weight 15 Millgrams (Approximate) Quantity Per Reel : 3,000pcs Reel Size : 7 inch Lead Finish : Lead Free REV.2019.12.13 www.spsemi.cn Page 1 of 3 SPSEMI ESD/TUSD05L4U     Maximum Ratings (T A =25 ℃ unless otherwise specified ) Symbol Value Units Peak Pulse Power(tp=8/20μs) P PP 150 Watts Lead Soldering Temperature TL 260(10 sec.) ℃ Operating Temperature Range TJ -55~150 ℃ T STG -55~150 ℃ Parameter Storage Temperature Range Electrical Characteristics (T A =25 ℃ unless otherwise specified ) TUSD05L4U(Marking:0524F) Symbol Parameter Reverse Stand-off Voltage Min. Conditions V RWM Breakdown Voltage V BR Clamping Voltage VC Reverse Leakage Current Junction Capacitance I T =1mA Max. Units 5 V 6 V I PP =1A,tp=8/20μs 15 V I PP =5A,tp=8/20μs 25 V IR @V RWM 1 μA C I/O 0Vdc,f=1MHz Between I/O Pins and GND 0.8 pF Ratings and Characteristic Curves Fig.2 Pulse Waveform Fig.1 Non-repetitive Peak Pulse Power V.S Pulse Time 110 100 Waveform Parameters: tr=8μs t d =20μs 90 80 Percent of I PP Peak Pulse Power-P PP (kW) 1 0.1 70 e 60 -1 50 40 t d =I PP /2 30 20 10 0.01 0 10 100 1000 5 10 15 20 25 30 Time( μs ) Pulse Duration-tp( μs ) REV.2019.12.13 0 0 www.spsemi.cn Page 2 of 3 SPSEMI ESD/TUSD05L4U     Ratings and Characteristic Curves Fig.3 Normalized Capacitance vs. Reverse Voltage C J (V R )/C J (V R =0) 1.5 1.0 0.5 0 0 1 3 2 4 Reverse Voltage-V R (V) 5 Application HDMI Protection HDMI Chipset HDMI Port TUSD05L4U 10 2 9 D2- 3 8 1 D2+ 8 Outside World 9 D0- 3 D0+ 2 D1- 10 1 6 5 7 4 D1+ 6 5 7 4 CLK+ CLK- TUSD05L4U Dimensions(DFN2510-10L) DFN2510-10L A B DIM A A1 C A1 A2 G D H 1 E REV.2019.12.13 A2 Millimeters Max Min 2.6 2.4 0.13 BSC 0.00 0.05 Inches Min Max 0.094 0.102 Recommended Mounting Pad Layout 1.0 0.039 0.50 0.020 0.675 0.027 0.005 BSC 0.00 0.002 B 0.90 1.10 0.035 0.043 C 0.40 0.65 0.015 0.026 D 0.15 0.25 0.006 0.010 E G 0.020 BSC 0.50 BSC 0.35 0.45 0.014 0.018 H 0.30 0.425 0.012 0.017 www.spsemi.cn 1.55 0.875 0.061 0.034 0.20 0.008 0.20 0.008 0.40 0.016 Dimensions in ( millimeters ) inches Page 3 of 3
TUSD05L4U 价格&库存
很抱歉,暂时无法提供与“TUSD05L4U”相匹配的价格&库存,您可以联系我们找货
TUSD05L4U
    • 5+0.99590
    • 50+0.82480
    • 150+0.73930
    • 500+0.67510
    库存:1530
