SMBJ100A-AT/TR13
SMBJ100A-AT/TR13
    YAGEO(国巨)
    SMB(DO-214AA)
    162V 夹子 3.7A Ipp TVS - 二极管 表面贴装型 DO-214AA(SMB)
SMBJ100A-AT/TR13 数据手册
DATA SHEET TRANSIENT VOLTAGE SUPPRESSORS AC/DC POWER SUPPLY SMBJ-AT series Product specification– June 30, 2023 V.4 RoHS compliant & Halogen free Circuit Protection Product Specification Transient Voltage Suppressors 2 9 SMBJ-AT Transient Voltage Suppressors (TVS) Data Sheet Features ■ For surface mounted applications in order to optimize board space ■ Low profile package ■ Built-in strain relief ■ Glass passivated junction ■ Low inductance ■ Excellent clamping capability ■ 600W peak pulse power capability at 10/1000μs waveform, repetition rate (duty cycle): 0.01% ■ Fast response time ■ Typical IR less than 1μA above 12V ■ High Temperature soldering: 260℃/10 seconds at terminals ■ Plastic package has underwriters laboratory flammability 94V-0 ■ Meets MSL level 1, per J-STD-020 ■ Safety certification: UL ■ AEC-Q101 qualified ■ IEC61000-4-2 ESD 30KV Air, 30KV contact compliance Mechanical Data ■ Case: JEDEC DO-214AA. Molded plastic over glass passivated junction ■ Terminal: Solder plated, solderable per MIL-STD-750, Method 2026 ■ Polarity: Color band denotes cathode except bi-directional models ■ Standard Packaging: 12mm tape (EIA STD RS-481) ■ Weight: 0.10g Applications ■ I/O interface ■ AC/DC power supply ■ Low frequency signal transmission line (RS232, RS485, etc.) Maximum Ratings and Characteristics Ratings at 25℃ ambient temperature unless otherwise specified. Rating Symbol Value Units Peak pulse power dissipation at 10/1000μs waveform (Note1, Note2, Fig.1) PPPM Minimum 600 Watts Peak pulse current of at 10/1000μs waveform (Note 1, Fig.3) IPPM See Table Amps PM(AV) 5.0 Watts IFSM 100 Amps TJ,TSTG -55 to +150 ℃ Typical thermal resistance junction to lead RθJL 20 ℃/W Typical thermal resistance junction to ambient RθJA 100 ℃/W Steady state power dissipation at TA=50℃ (Fig.5) Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load, (JEDEC Method) (Note3, Fig.6) Operating junction and Storage Temperature Range. Notes: 1. Non-repetitive current pulse, per Fig.3 and derated above TA=25℃ per Fig.2. 2. Mounted on 5.0mm×5.0mm (0.03mm thick) copper pads to each terminal. 3. 8.3ms single half sine-wave, or equivalent square wave, duty cycle=4 pulses per minutes maximum. www.ya geo.com Jun. 30, 2023 V.4 Circuit Protection Product Specification Transient Voltage Suppressors 3 9 SMBJ-AT Dimensions (SMB/DO-214AA) Product: Millimeters Inches Symbol Cathode Band Min. Max. Min. Max. L 4.06 4.57 0.160 0.180 D 3.30 3.94 0.130 0.155 D1 1.95 2.20 0.077 0.086 T 5.21 5.59 0.205 0.220 T1 0.76 1.52 0.030 0.060 d - 0.203 - 0.008 H 2.15 2.65 0.085 0.104 H1 2.13 2.47 0.084 0.097 D1 D L H1 H d T1 T 2.18mm Pad: 1.75mm 2.16mm 1.75mm Electrical Characteristics (TA=25℃) Part Number Device Marking Code Reverse Stand-Off Voltage Breakdown Voltage @IT Test Current Maximum Clamping Voltage @IPP Peak Pulse Current Reverse Leakage @VRWM Unidirectional Bidirectional UNI BI VRWM(V) VBR(V) IT(mA) VC(V) IPP(A) IR(μA) SMBJ5.0A-AT SMBJ5.0CA-AT KE AE 5.0 6.40~7.00 10 9.2 65.3 800 SMBJ6.0A-AT SMBJ6.0CA-AT KG AG 6.0 6.67~7.37 10 10.3 58.3 800 SMBJ6.5A-AT SMBJ6.5CA-AT KK AK 6.5 7.22~7.98 10 11.2 53.6 500 SMBJ7.0A-AT SMBJ7.0CA-AT KM AM 7.0 7.78~8.60 10 12.0 50.0 200 SMBJ7.5A-AT SMBJ7.5CA-AT KP AP 7.5 8.33~9.21 1 12.9 46.6 100 SMBJ8.0A-AT SMBJ8.0CA-AT KR AR 8.0 8.89~9.83 1 13.6 44.2 50 SMBJ8.5A-AT SMBJ8.5CA-AT KT AT 8.5 9.44~10.40 1 14.4 41.7 20 SMBJ9.0A-AT SMBJ9.0CA-AT KV AV 9.0 10.00~11.10 1 15.4 39.0 10 SMBJ10A-AT SMBJ10CA-AT KX AX 10.0 11.10~12.30 1 17.0 35.3 5 SMBJ11A-AT SMBJ11CA-AT KZ AZ 11.0 12.20~13.50 1 18.2 33.0 1 SMBJ12A-AT SMBJ12CA-AT LE BE 12.0 13.30~14.70 1 19.9 30.2 1 SMBJ13A-AT SMBJ13CA-AT LG BG 13.0 14.40~15.90 1 21.5 28.0 1 SMBJ14A-AT SMBJ14CA-AT LK BK 14.0 15.60~17.20 1 23.2 25.9 1 SMBJ15A-AT SMBJ15CA-AT LM BM 15.0 16.70~18.50 1 24.4 24.6 1 SMBJ16A-AT SMBJ16CA-AT LP BP 16.0 17.80~19.70 1 26.0 23.1 1 SMBJ17A-AT SMBJ17CA-AT LR BR 17.0 18.90~20.90 1 27.6 21.8 1 SMBJ18A-AT SMBJ18CA-AT LT BT 18.0 20.00~22.10 1 29.2 20.6 1 www.ya geo.com Jun. 30, 2023 V.4 Circuit Protection Product Specification Transient Voltage Suppressors Part Number Device Marking Code 4 9 SMBJ-AT Reverse Stand-Off Voltage Breakdown Voltage @IT Test Current Maximum Clamping Voltage @IPP Peak Pulse Current Reverse Leakage @VRWM Unidirectional Bidirectional UNI BI VRWM(V) VBR(V) IT(mA) VC(V) IPP(A) IR(μA) SMBJ20A-AT SMBJ20CA-AT LV BV 20.0 22.20~24.50 1 32.4 18.6 1 SMBJ22A-AT SMBJ22CA-AT LX BX 22.0 24.40~26.90 1 35.5 16.9 1 SMBJ24A-AT SMBJ24CA-AT LZ BZ 24.0 26.70~29.50 1 38.9 15.5 1 SMBJ26A-AT SMBJ26CA-AT ME CE 26.0 28.90~31.90 1 42.1 14.3 1 SMBJ28A-AT SMBJ28CA-AT MG CG 28.0 31.10~34.40 1 45.4 13.3 1 SMBJ30A-AT SMBJ30CA-AT MK CK 30.0 33.30~36.80 1 48.4 12.4 1 SMBJ33A-AT SMBJ33CA-AT MM CM 33.0 36.70~40.60 1 53.3 11.3 1 SMBJ36A-AT SMBJ36CA-AT MP CP 36.0 40.00~44.20 1 58.1 10.4 1 SMBJ40A-AT SMBJ40CA-AT MR CR 40.0 44.40~49.10 1 64.5 9.3 1 SMBJ43A-AT SMBJ43CA-AT MT CT 43.0 47.80~52.80 1 69.4 8.7 1 SMBJ45A-AT SMBJ45CA-AT MV CV 45.0 50.00~55.30 1 72.7 8.3 1 SMBJ48A-AT SMBJ48CA-AT MX CX 48.0 53.30~58.90 1 77.4 7.8 1 SMBJ51A-AT SMBJ51CA-AT MZ CZ 51.0 56.70~62.70 1 82.4 7.3 1 SMBJ54A-AT SMBJ54CA-AT NE DE 54.0 60.00~66.30 1 87.1 6.9 1 SMBJ58A-AT SMBJ58CA-AT NG DG 58.0 64.40~71.20 1 93.6 6.5 1 SMBJ60A-AT SMBJ60CA-AT NK DK 60.0 66.70~73.70 1 96.8 6.2 1 SMBJ64A-AT SMBJ64CA-AT NM DM 64.0 71.10~78.60 1 103.0 5.9 1 SMBJ70A-AT SMBJ70CA-AT NP DP 70.0 77.80~86.00 1 113.0 5.3 1 SMBJ75A-AT SMBJ75CA-AT NR DR 75.0 83.30~92.10 1 121.0 5.0 1 SMBJ78A-AT SMBJ78CA-AT NT DT 78.0 86.70~95.80 1 126.0 4.8 1 SMBJ85A-AT SMBJ85CA-AT NV DV 85.0 94.40~104.00 1 137.0 4.4 1 SMBJ90A-AT SMBJ90CA-AT NX DX 90.0 100.00~111.00 1 146.0 4.1 1 SMBJ100A-AT SMBJ100CA-AT NZ DZ 100.0 111.00~123.00 1 162.0 3.7 1 SMBJ110A-AT SMBJ110CA-AT PE EE 110.0 122.00~135.00 1 177.0 3.4 1 SMBJ120A-AT SMBJ120CA-AT PG EG 120.0 133.00~147.00 1 193.0 3.1 1 SMBJ130A-AT SMBJ130CA-AT PK EK 130.0 144.00~159.00 1 209.0 2.9 1 SMBJ150A-AT SMBJ150CA-AT PM EM 150.0 167.00~185.00 1 243.0 2.5 1 SMBJ160A-AT SMBJ160CA-AT PP EP 160.0 178.00~197.00 1 259.0 2.3 1 SMBJ170A-AT SMBJ170CA-AT PR ER 170.0 189.00~209.00 1 275.0 2.2 1 SMBJ180A-AT SMBJ180CA-AT PT ET 180.0 201.00~222.00 1 292.0 2.1 1 SMBJ190A-AT SMBJ190CA-AT PA EC 190.0 211.00~233.00 1 308.0 2.0 1 SMBJ200A-AT SMBJ200CA-AT PV EV 200.0 224.00~247.00 1 324.0 1.9 1 SMBJ210A-AT SMBJ210CA-AT PB ED 210.0 237.00~263.00 1 340.0 1.8 1 SMBJ220A-AT SMBJ220CA-AT PX EX 220.0 246.00~272.00 1 356.0 1.7 1 SMBJ250A-AT SMBJ250CA-AT PZ EZ 250.0 279.00~309.00 1 405.0 1.5 1 SMBJ300A-AT SMBJ300CA-AT QE FE 300.0 335.00~371.00 1 486.0 1.3 1 SMBJ350A-AT SMBJ350CA-AT QG FG 350.0 391.00~432.00 1 567.0 1.1 1 SMBJ400A-AT SMBJ400CA-AT QK FK 400.0 447.00~494.00 1 648.0 0.9 1 SMBJ440A-AT SMBJ440CA-AT QM FM 440.0 492.00~543.00 1 713.0 0.9 1 www.ya geo.com Jun. 30, 2023 V.4 Circuit Protection Product Specification Transient Voltage Suppressors 5 9 SMBJ-AT Ratings and Characteristic Curves (T A=25℃ unless otherwise noted) Figure 1. Peak Pulse Power Rating Curve Figure 2. Pulse Derating Curve Peak Pulse Power (PPP) or Current (IPP) Derating in Percentage % PPPM - Peak Pulse Power (kW) 100 10 1 0.2×0.2″(5.0×5.0mm) Copper Pad Area 0.1 1 100 10 100 80 60 40 20 0 1000 0 td-Pulse Width (µs) td 100 1 2.0 3.0 Bi-directional @VR 4.0 TJ=25℃ f=1.0MHz Vsig=50mVp-p 1 Figure 5. Steady State Power Dissipation Derating 1000 Surge Current Uni-Directional Only 6 IFSM - Peak Forward Surve Current (A) PM(AV), Steady State Power Dissipation (W) 100 Figure 6. Maximum Non-Repetitive Forward Curve 5 4 3 2 1 0 25 10 VBR-Reverse Breakdown Voltage (V) t-Time (ms) 0 175 Uni-directional V=0V 10 10/1000µs Waveform as defined by R.E.A 1.0 150 Uni-directional @VR Cj (pF) IPPM - Peak Pulse Current, %IRSM 1000 50 0 125 Bi-directional V=0V Half Value IPPM (IPPM/2) 0 100 10000 Peak Value IPPM 100 75 Figure 4. Typical Junction Capacitance TJ=25℃ Pulse Width(td) is defined as the point where the peak current decays to 50% of IPPM tr=10µs 50 TA-Ambient Temperature (℃) Figure 3. Pulse Waveform 150 25 50 75 100 125 TA-Ambient Temperature (℃) 150 175 120 100 80 60 40 20 0 1 10 100 Number of Cycles at 60Hz www.ya geo.com Jun. 30, 2023 V.4 Circuit Protection Product Specification Transient Voltage Suppressors 6 9 SMBJ-AT Recommended Soldering Conditions Reflow Soldering Critical Zone TL to TP tP TP Ramp-up TL tL Temperature TS max TS min Ramp-down tS Preheat 25 t 25℃ to Peak Time Recommended Conditions Profile Feature Pb-Free Assembly Average ramp-up rate (TL to TP) 3℃/second max. Preheat -Temperature Min (TS min) -Temperature Max (TS max) -Time (min to max) (tS) 150℃ 200℃ 60-180 seconds TS max to TL -Ramp-up Rate 3℃/second max. Time maintained above: -Temperature (TL) -Time (tL) 217℃ 60-150 seconds Peak Temperature (TP) 260℃ Time within 5℃ of actual Peak Temperature (tP) Ramp-down Rate Time 25℃ to Peak Temperature 20-40 seconds 6℃/second max. 8 minutes max. www.ya geo.com Jun. 30, 2023 V.4 Circuit Protection Product Specification Transient Voltage Suppressors 7 9 SMBJ-AT Marking Code Cathode Band YXXX YXXX KE AE Logo Intermal Control Code Marking Code Logo Intermal Control Code Marking Code Part Number Code SMBJ XXX C A AT / XXXX Package code TR7: 7 inch reel package TR13: 13 inch reel package Internal Control Code 5% VBR Voltage Tolerance Bidirectional VRWM Voltage Series Code Ordering Code for Different Package 7 inch reel package: Add suffix “ /TR7 ” at the end of the part number, such as SMBJXXXCA-AT/TR7 13 inch reel package: Add suffix “ /TR13 ” at the end of the part number, such as SMBJXXXCA-AT/TR13 www.ya geo.com Jun. 30, 2023 V.4 Circuit Protection Product Specification Transient Voltage Suppressors 8 9 SMBJ-AT Packaging Tape P0 P1 P2 D0 B T E F W B0 D1 A A K0 B SECTION B-B Symbol Dimension (mm) W 12.00±0.20 P0 4.00±0.10 P1 8.00±0.10 P2 2.00±0.10 D0 Φ1.55±0.10 D1 Φ1.5±0.10 E 1.75±0.10 F 5.50±0.10 A0 3.86±0.15 B0 5.65±0.10 K0 2.75±0.15 T 0.25±0.05 D2 Φ178.0±2.0 D3 Φ50.0Min. D4 Φ13.0±0.5 W1 16.0±2.0 A0 SECTION A-A 7” Reel D4 D3 D2 W1 Quantity: 500PCS 13” Reel D5 Φ330.0±2.0 D6 Φ13.5±0.5 H 2.5±1.0 W2 16.0±2.0 Quantity: 3000PCS www.ya geo.com Jun. 30, 2023 V.4 Product specification Circuit Protection Components LEGAL DISCLAIMER YAGEO, its distributors and agents (collectively, “YAGEO”), hereby disclaims any and all liabilities for any errors, inaccuracies or incompleteness contained in any product related information, including but not limited to product specifications, datasheets, pictures and/or graphics. YAGEO may make changes, modifications and/or improvements to product related information at any time and without notice. YAGEO makes no representation, warranty, and/or guarantee about the fitness of its products for any particular purpose or the continuing production of any of its products. To the maximum exten t permitted by law, YAGEO disclaims (i) any and all liability arising out of the application or use of any YAGEO product, (ii) any and all liability, including without limitation special, consequential or incidental damages, and (iii) any and all implied warranties, including warranties of fitness for a particular purpose, non -infringement and merchantability. YAGEO products are designed for general purpose applications under normal operation and usage conditions. Please contact YAGEO for the applications listed below which require especially high reliability for the prevention of defects which might directly cause damage to the third party's life, body or property: Aerospace equipment (artificial satellite, rocket, etc.), Atomic energy -related equipment, Aviation equipment, Disaster prevention equipment, crime prevention equipment, Electric heating apparatus, burning equipment, Highly public information network equipment, data-processing equipment , Medical devices, Military equipment, Power generation control equipment, Safety equipment, Traffic signal equipment, Transportation equipment and Undersea equipment, or for any other application or use in which the failure of YAGEO products could result in personal injury or death, or serious property damage. P articularly YAGEO Corporation and its affiliates do not recommend the use of commercial or automotive grade products for high reliability applications or manned space flight. Information provided here is intended to indicate product specifications only. YAGEO reserves all the rights for revising this content without further notification, as long as products are unchanged. Any product change will be announced by PCN. www.yageo.com
SMBJ100A-AT/TR13 价格&库存
很抱歉,暂时无法提供与“SMBJ100A-AT/TR13”相匹配的价格&库存,您可以联系我们找货
SMBJ100A-AT/TR13
  • 1+4.315091+0.55988
  • 10+2.6348710+0.34188
  • 50+1.9031250+0.24693
  • 100+1.66520100+0.21606
  • 500+1.24479500+0.16151
库存:2450
SMBJ100A-AT/TR13
  • 3000+0.845023000+0.10964
  • 9000+0.724089000+0.09395
库存:2450
