SMBJE9-0CA
SMBJE9-0CA
    EATON(伊顿)
    SMB(DO-214AA)
    15.4V 夹子 39A Ipp TVS - 二极管 表面贴装型 SMB
SMBJE9-0CA 数据手册
Technical Data 11214 Effective November 2020 SMBJE 600 W Transient voltage suppressor Applications Product features • Low profile SMB package • Excellent clamping capability • 600 W peak pulse power capability at 10/1000 μs waveform • Typical IR less than 1 μA above 10 V • Fast response time: typically less than 1.0 ps from 0 V to VBR minimum • High temperature reflow soldering: +260 °C /40 s at terminal • Plastic package meets UL 94 V-0 flammability rating • Meets moisture sensitivity level (MSL) level 1 • Terminal: Solder plated leads, solderable per J-STD-002 • For surface mounted applications in order to optimize board space • UL 497B recognized. File No. : E198449 Guide QVGQ2 PIN configuration • Consumer electronics • Telecommunications • Computing and servers • Appliances • Industrial automation • Mobile and wearables Environmental compliance and general specifications HALOGEN Pb HF FREE Ordering part number SMBJE 5-0 C A Family name VR voltage (“-” indicates decimal point) Bi-/Uni-Directional (Blank=Uni, C=Bi) Voltage tolerance SMBJE 600 W Transient voltage suppressor  Technical Data 11214 Effective November 2020 Absolute maximum ratings (+25 °C, RH=45%-75%, unless otherwise noted) Parameter Symbol Value Unit TSTG/ TJ -55 to +150 °C Steady state power dissipation at TL= +75 °C PM(AV) 5.0 W Peak pulse power dissipation on 10/1000 μs waveform PPP 600 W Maximum instantaneous forward voltage at 100 A for unidirectional VF 5.0 V Peak forward surge current, 8.3 ms single half sine wave1 IFSM 100 A Typical thermal resistance junction to lead R JL 20 °C/W Typical thermal resistance junction to ambient R JA 100 °C/W Storage operating junction temperature range 1. Measured on 8.3 ms single half sine wave or equivalent square wave for unidirectional device only, duty cycle = 4 per minute maximum Mechanical parameters, pad layout- mm Part marking Millimeters Inches Dimension Minimum Maximum Minimum Maximum A 3.94 0.130 0.155 3.30 B 4.30 4.80 0.169 0.189 C 1.90 2.20 0.075 0.087 D 0.95 1.52 0.037 0.060 E 5.20 5.60 0.205 0.220 F 0.051 0.203 0.002 0.008 G 0.15 0.31 0.006 0.012 H 2.10 2.40 0.083 0.094 J 2.20 K L Cathode band (Uni-polar only) Part marking: xxxx = Date code yy- Refer to marking designator listed in Electrical Characteristics table 0.087 2.60 2.30 Packaging information (mm) 0.102 0.091 Dimension Millimeters Inches Drawing not to scale. A0 3.76 ± 0.3 0.148 ± 0.012 Supplied in tape and reel packaging, 3,000 parts per 13” diameter reel (EIA-481 compliant) B0 5.69 ± 0.3 0.224 ± 0.012 C 330.0 13.0 D0 1.55 ± 0.1 0.061 ± 0.004 E 1.75 ± 0.2 0.069 ± 0.008 E1 13.3 ± 0.3 0.524 ± 0.012 F 5.50 ± 0.2 0.217 ± 0.008 P0 4.00 ± 0.2 0.157 ± 0.008 P1 8.00 ± 0.2 0.3145 ± 0.008 P2 2.00 ± 0.2 0.079 ± 0.008 W 12.0 ± 0.2 0.472 ± 0.008 W1 15.7 ± 2.0 0.618 ± 0.079 2 www.eaton.com/electronics Technical Data 11214  SMBJE 600 W Transient voltage suppressor Effective November 2020 Electrical characteristics (+25 °C) Part number Uni-polar Bi-polar Marking Uni Bi VR (V) IR @ VR (μA) VBR @ IT min (V) max (V) IT (mA) VC @ IPP max (V) IPP (A) SMBJE5-0A SMBJE5-0CA KE AE 5 120 6.4 7 10 9.2 65.2 SMBJE6-0A SMBJE6-0CA KG AG 6 120 6.67 7.37 10 10.3 58.3 SMBJE6-5A SMBJE6-5CA KK AK 6.5 120 7.22 7.98 10 11.2 53.6 SMBJE7-0A SMBJE7-0CA KM AM 7 50 7.78 8.6 10 12 50 SMBJE7-5A SMBJE7-5CA KP AP 7.5 50 8.33 9.21 1 12.9 46.5 SMBJE8-0A SMBJE8-0CA KR AR 8 20 8.89 9.83 1 13.6 44.1 SMBJE8-5A SMBJE8-5CA KT AT 8.5 10 9.44 10.4 1 14.4 41.7 SMBJE9-0A SMBJE9-0CA KV AV 9 5 10 11.1 1 15.4 39 SMBJE10A SMBJE10CA KX AX 10 2 11.1 12.3 1 17 35.3 SMBJE11A SMBJE11CA KZ AZ 11 1 12.2 13.5 1 18.2 33 SMBJE12A SMBJE12CA LE BE 12 1 13.3 14.7 1 19.9 30.2 SMBJE13A SMBJE13CA LG BG 13 1 14.4 15.9 1 21.5 27.9 SMBJE14A SMBJE14CA LK BK 14 1 15.6 17.2 1 23.2 25.9 SMBJE15A SMBJE15CA LM BM 15 1 16.7 18.5 1 24.4 24.6 SMBJE16A SMBJE16CA LP BP 16 1 17.8 19.7 1 26 23.1 SMBJE17A SMBJE17CA LR BR 17 1 18.9 20.9 1 27.6 21.8 SMBJE18A SMBJE18CA LT BT 18 1 20 22.1 1 29.2 20.6 SMBJE20A SMBJE20CA LV BV 20 1 22.2 24.5 1 32.4 18.6 SMBJE22A SMBJE22CA LX BX 22 1 24.4 26.9 1 35.5 16.9 SMBJE24A SMBJE24CA LZ BZ 24 1 26.7 29.5 1 38.9 15.4 SMBJE26A SMBJE26CA ME CE 26 1 28.9 31.9 1 42.1 14.3 SMBJE28A SMBJE28CA MG CG 28 1 31.1 34.4 1 45.4 13.2 SMBJE30A SMBJE30CA MK CK 30 1 33.3 36.8 1 48.4 12.4 SMBJE33A SMBJE33CA MM CM 33 1 36.7 40.6 1 53.3 11.3 SMBJE36A SMBJE36CA MP CP 36 1 40 44.2 1 58.1 10.4 SMBJE40A SMBJE40CA MR CR 40 1 44.4 49.1 1 64.5 9.3 SMBJE43A SMBJE43CA MT CT 43 1 47.8 52.8 1 69.4 8.7 SMBJE45A SMBJE45CA MV CV 45 1 50 55.3 1 72.7 8.3 SMBJE48A SMBJE48CA MX CX 48 1 53.3 58.9 1 77.4 7.8 SMBJE51A SMBJE51CA MZ CZ 51 1 56.7 62.7 1 82.4 7.3 SMBJE54A SMBJE54CA NE DE 54 1 60 66.3 1 87.1 6.9 SMBJE58A SMBJE58CA NG DG 58 1 64.4 71.2 1 93.6 6.4 SMBJE60A SMBJE60CA NK DK 60 1 66.7 73.7 1 96.8 6.2 SMBJE64A SMBJE64CA NM DM 64 1 71.1 78.6 1 103 5.8 SMBJE70A SMBJE70CA NP DP 70 1 77.8 86 1 113 5.3 SMBJE75A SMBJE75CA NR DR 75 1 83.3 92.1 1 121 5 SMBJE78A SMBJE78CA NT DT 78 1 86.7 95.8 1 126 4.8 SMBJE85A SMBJE85CA NV DV 85 1 94.4 104 1 137 4.4 SMBJE90A SMBJE90CA NX DX 90 1 100 111 1 146 4.1 SMBJE100A SMBJE100CA NZ DZ 100 1 111 123 1 162 3.7 SMBJE110A SMBJE110CA PE EE 110 1 122 135 1 177 3.4 SMBJE120A SMBJE120CA PG EG 120 1 133 147 1 193 3.1 SMBJE130A SMBJE130CA PK EK 130 1 144 159 1 209 2.9 SMBJE150A SMBJE150CA PM EM 150 1 167 185 1 243 2.5 SMBJE160A SMBJE160CA PP EP 160 1 178 197 1 259 2.3 SMBJE170A SMBJE170CA PR ER 170 1 189 209 1 275 2.2 SMBJE180A SMBJE180CA PT ET 180 1 201 222 1 292 2.1 SMBJE190A SMBJE190CA PV EV 190 1 211 234 1 307 2 SMBJE200A SMBJE200CA PX EX 200 1 224 247 1 324 1.9 SMBJE210A SMBJE210CA PZ EZ 210 1 233 258 1 337 1.8 SMBJE220A SMBJE220CA QE FE 220 1 246 272 1 356 1.7 SMBJE250A SMBJE250CA QG FG 250 1 279 309 1 405 1.5 SMBJE300A SMBJE300CA QK FK 300 1 335 371 1 486 1.3 SMBJE350A SMBJE350CA QM FM 350 1 391 432 1 567 1.1 SMBJE400A SMBJE400CA QP FP 400 1 447 494 1 648 0.9 SMBJE440A SMBJE440CA QR FR 440 1 492 543 1 713 0.8 www.eaton.com/electronics 3 SMBJE 600 W Transient voltage suppressor  Technical Data 11214 Effective November 2020 Ratings and V-I characteristic curves (+25 °C unless otherwise noted) V- I curve characteristics (Uni-directional) V- I curve characteristics (Bi-directional) Surge waveform: 10/1000 μs VR: Stand-off voltage -- Maximum voltage that can be applied VBR: Breakdown voltage VC: Clamping voltage -- Peak voltage measured across the suppressor at a specified IPP IR: Reverse leakage current IT: Test current VF: Forward voltage drop for Uni-directional TVS diode Pulse derating curve 150 tr = rise time to peak value td = decay time to half value IPPM (% IRSM) tr=10 μs 100 PPP derating in percentage (%) Pulse waveform Peak value Half value 50 0 0 td 1.0 2.0 3.0 4.0 Peak pulse power dissipation vs. pulse width 100 Ppp (kW) 600 W at 10/1000 μs +25 °C 10 1.0 0.01 0.1 td-Pulse width (ms) 4 www.eaton.com/electronics 80 60 40 20 0 0 25 50 75 100 125 150 TJ-Initial junction temperature (°C) t (ms) 0.1 0.001 100 1.0 10 175 Technical Data 11214 SMBJE 600 W Transient voltage suppressor Effective November 2020  Solder reflow profile TP TC -5°C tP Max. Ramp Up Rate = 3°C/s Max. Ramp Down Rate = 6°C/s Temperature TL Preheat A T smax t Table 1 - Standard SnPb solder (Tc) Package thickness Volume mm3
SMBJE9-0CA
1. 物料型号:文档中列出了不同额定电压的瞬态电压抑制二极管型号,如SMBJE5-DA、SMBJE6-DA等,以及它们的双极性或单极性版本。
2. 器件简介:瞬态电压抑制二极管用于多种应用,包括消费电子、通信、计算和服务器、家电、工业自动化、移动和可穿戴设备等。
3. 引脚分配:文档提供了引脚配置图,显示了阴极和阳极的位置。
4. 参数特性:包括存储工作结温范围、稳态功率耗散、峰值脉冲功率耗散、最大瞬态正向电压、峰值正向浪涌电流、典型热阻等。
5. 功能详解:瞬态电压抑制二极管具有低轮廓SMB封装、优异的钳位能力、600W的峰值脉冲功率能力、快速响应时间、高温度回流焊接能力等特性。
6. 应用信息:适用于需要瞬态电压保护的多种场合,如电源线、数据线、信号线等。
7. 封装信息:提供了封装的尺寸信息,包括最小和最大尺寸,以及包装信息,如胶带和卷轴包装,每卷3000个零件。
8. 电气特性:列出了不同型号的电气特性,如工作电压、漏电流、电容、箝位电压等。
9. 额定值和V-I特性曲线:提供了单向和双向瞬态电压抑制二极管的V-I特性曲线。
10. 焊接回流曲线:提供了焊接过程中的温度曲线和时间参数。
11. 生命支持政策:Eaton公司不授权未经公司官员书面批准,将其产品用于生命支持设备或系统中。
SMBJE9-0CA 价格&库存
很抱歉,暂时无法提供与“SMBJE9-0CA”相匹配的价格&库存,您可以联系我们找货
SMBJE9-0CA
  • 1+3.607401+0.46895
  • 10+2.2426810+0.29154
  • 100+1.46035100+0.18984
  • 250+1.24303250+0.16159
  • 500+1.10395500+0.14351
  • 1000+0.982261000+0.12769
  • 3000+0.825793000+0.10735
  • 6000+0.738876000+0.09605
  • 15000+0.6519415000+0.08475
库存:2905
SMBJE9-0CA
  • 1+3.35144
  • 10+2.08537
  • 100+1.35950
  • 250+1.15468
  • 500+1.02412
  • 1000+0.91272
  • 3000+0.76300
  • 6000+0.68873
  • 15000+0.61088
库存:2905
SMBJE9-0CA
    • 201000+0.72546
    库存:3000
