P6SMB530CA-AT/TR13
P6SMB530CA-AT/TR13
    YAGEO(国巨)
    SMB(DO-214AA)
    725V 夹子 800mA Ipp TVS - 二极管 表面贴装型 DO-214AA(SMB)
P6SMB530CA-AT/TR13 数据手册
DATA SHEET TRANSIENT VOLTAGE SUPPRESSORS AC/DC POWER SUPPLY P6SMB-AT series Product specification– June 30, 2023 V.4 RoHS compliant & Halogen free Circuit Protection Product Specification Transient Voltage Suppressors 2 9 P6SMB-AT Transient Voltage Suppressors (TVS) Data Sheet Features ■ For surface mounted applications in order to optimize board space ■ Low profile package ■ Built-in strain relief ■ Glass passivated junction ■ Low inductance ■ Excellent clamping capability ■ 600W peak pulse power capability at 10/1000μs waveform, repetition rate (duty cycle): 0.01% ■ Fast response time ■ Typical IR less than 1μA above 12V ■ High Temperature soldering: 260℃/10 seconds at terminals ■ Plastic package has underwriters laboratory flammability 94V-0 ■ Meets MSL level 1, per J-STD-020 ■ Safety certification: UL ■ AEC-Q101 qualified ■ IEC61000-4-2 ESD 30KV Air, 30KV contact compliance Mechanical Data ■ Case: JEDEC DO-214AA. Molded plastic over glass passivated junction ■ Terminal: Tin plated, solderable per MIL-STD-750, Method 2026 ■ Polarity: Color band denotes cathode except bi-directional models ■ Standard Packaging: 12mm tape (EIA STD RS-481) ■ Weight: 0.10g Applications ■ I/O interface ■ AC/DC power supply ■ Low frequency signal transmission line (RS232, RS485, etc.) Maximum Ratings and Characteristics Ratings at 25℃ ambient temperature unless otherwise specified. Rating Symbol Value Units PPPM Minimum 600 Watts IPPM See Table Amps PM(AV) 5.0 Watts IFSM 100 Amps TJ,TSTG -55 to +150 ℃ Typical thermal resistance junction to lead RθJL 20 ℃/W Typical thermal resistance junction to ambient RθJA 100 ℃/W Peak pulse power dissipation at 10/1000μs waveform (Note1, Note2, Fig.1) Peak pulse current of at 10/1000μs waveform (Note 1, Fig.3) Steady state power dissipation at TA=50℃ (Fig.5) Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load, (JEDEC Method) (Note3, Fig.6) Operating junction and Storage Temperature Range. Notes: 1. Non-repetitive current pulse, per Fig.3 and derated above T A=25℃ per Fig.2. 2. Mounted on 5.0mm×5.0mm (0.03mm thick) copper pads to each terminal. 3. 8.3ms single half sine-wave, or equivalent square wave, duty cycle=4 pulses per minutes maximum. www.ya geo.com Jun. 30, 2023 V.4 Circuit Protection Product Specification Transient Voltage Suppressors 3 9 P6SMB-AT Dimensions (SMB/DO-214AA) Product: Millimeters Inches Symbol Cathode Band Min. Max. Min. Max. L 4.06 4.57 0.160 0.180 D 3.30 3.94 0.130 0.155 D1 1.95 2.20 0.077 0.086 T 5.21 5.59 0.205 0.220 T1 0.76 1.52 0.030 0.060 d - 0.203 - 0.008 H 2.15 2.65 0.085 0.104 H1 2.13 2.47 0.084 0.097 D1 D L H1 H d T1 T 2.18mm Pad: 1.75mm 2.16mm 1.75mm Electrical Characteristics (TA=25℃) Part Number Device Marking Code Reverse Stand-Off Voltage Breakdown Voltage @IT Test Current Maximum Clamping Voltage @IPP Peak Pulse Current Reverse Leakage @VRWM Unidirectional Bidirectional UNI BI VRWM(V) VBR(V) IT(mA) VC(V) IPP(A) IR(μA) P6SMB6.8A-AT P6SMB6.8CA-AT 6V8A 6V8C 5.80 6.45~7.14 10 10.5 58.1 1000 P6SMB7.5A-AT P6SMB7.5CA-AT 7V5A 7V5C 6.40 7.13~7.88 10 11.3 54.0 500 P6SMB8.2A-AT P6SMB8.2CA-AT 8V2A 8V2C 7.02 7.79~8.61 10 12.1 50.4 200 P6SMB9.1A-AT P6SMB9.1CA-AT 9V1A 9V1C 7.78 8.65~9.55 1 13.4 45.5 50 P6SMB10A-AT P6SMB10CA-AT 10A 10C 8.55 9.50~10.50 1 14.5 42.1 10 P6SMB11A-AT P6SMB11CA-AT 11A 11C 9.40 10.50~11.60 1 15.6 39.1 5 P6SMB12A-AT P6SMB12CA-AT 12A 12C 10.20 11.40~12.60 1 16.7 36.5 5 P6SMB13A-AT P6SMB13CA-AT 13A 13C 11.10 12.40~13.70 1 18.2 33.5 1 P6SMB15A-AT P6SMB15CA-AT 15A 15C 12.80 14.30~15.80 1 21.2 28.8 1 P6SMB16A-AT P6SMB16CA-AT 16A 16C 13.60 15.20~16.80 1 22.5 27.1 1 P6SMB18A-AT P6SMB18CA-AT 18A 18C 15.30 17.10~18.90 1 25.2 24.2 1 P6SMB20A-AT P6SMB20CA-AT 20A 20C 17.10 19.00~21.00 1 27.7 22.0 1 P6SMB22A-AT P6SMB22CA-AT 22A 22C 18.80 20.90~23.10 1 30.6 19.9 1 P6SMB24A-AT P6SMB24CA-AT 24A 24C 20.50 22.80~25.20 1 33.2 18.4 1 P6SMB27A-AT P6SMB27CA-AT 27A 27C 23.10 25.70~28.40 1 37.5 16.3 1 www.ya geo.com Jun. 30, 2023 V.4 Circuit Protection Product Specification Transient Voltage Suppressors Part Number 9 P6SMB-AT Device Marking Code 4 Reverse Stand-Off Voltage Breakdown Voltage @IT Test Current Maximum Clamping Voltage @IPP Peak Pulse Current Reverse Leakage @VRWM Unidirectional Bidirectional UNI BI VRWM(V) VBR(V) IT(mA) VC(V) IPP(A) IR(μA) P6SMB30A-AT P6SMB30CA-AT 30A 30C 25.60 28.50~31.50 1 41.4 14.7 1 P6SMB33A-AT P6SMB33CA-AT 33A 33C 28.20 31.40~34.70 1 45.7 13.3 1 P6SMB36A-AT P6SMB36CA-AT 36A 36C 30.80 34.20~37.80 1 49.9 12.2 1 P6SMB39A-AT P6SMB39CA-AT 39A 39C 33.30 37.10~41.00 1 53.9 11.3 1 P6SMB43A-AT P6SMB43CA-AT 43A 43C 36.80 40.90~45.20 1 59.3 10.3 1 P6SMB47A-AT P6SMB47CA-AT 47A 47C 40.20 44.70~49.40 1 64.8 9.4 1 P6SMB51A-AT P6SMB51CA-AT 51A 51C 43.60 48.50~53.60 1 70.1 8.7 1 P6SMB56A-AT P6SMB56CA-AT 56A 56C 47.80 53.20~58.80 1 77.0 7.9 1 P6SMB62A-AT P6SMB62CA-AT 62A 62C 53.00 58.90~65.10 1 85.0 7.2 1 P6SMB68A-AT P6SMB68CA-AT 68A 68C 58.10 64.60~71.40 1 92.0 6.6 1 P6SMB75A-AT P6SMB75CA-AT 75A 75C 64.10 71.30~78.80 1 103.0 5.9 1 P6SMB82A-AT P6SMB82CA-AT 82A 82C 70.10 77.90~86.10 1 113.0 5.4 1 P6SMB91A-AT P6SMB91CA-AT 91A 91C 77.80 86.50~95.50 1 125.0 4.9 1 P6SMB100A-AT P6SMB100CA-AT 100A 100C 85.50 95.00~105.00 1 137.0 4.5 1 P6SMB110A-AT P6SMB110CA-AT 110A 110C 94.00 105.00~116.00 1 152.0 4.0 1 P6SMB120A-AT P6SMB120CA-AT 120A 120C 102.00 114.00~126.00 1 165.0 3.7 1 P6SMB130A-AT P6SMB130CA-AT 130A 130C 111.00 124.00~137.00 1 179.0 3.4 1 P6SMB150A-AT P6SMB150CA-AT 150A 150C 128.00 143.00~158.00 1 207.0 2.9 1 P6SMB160A-AT P6SMB160CA-AT 160A 160C 136.00 152.00~168.00 1 219.0 2.8 1 P6SMB170A-AT P6SMB170CA-AT 170A 170C 145.00 162.00~179.00 1 234.0 2.6 1 P6SMB180A-AT P6SMB180CA-AT 180A 180C 154.00 171.00~189.00 1 246.0 2.5 1 P6SMB200A-AT P6SMB200CA-AT 200A 200C 171.00 190.00~210.00 1 274.0 2.2 1 P6SMB220A-AT P6SMB220CA-AT 220A 220C 185.00 209.00~231.00 1 328.0 1.9 1 P6SMB250A-AT P6SMB250CA-AT 250A 250C 214.00 237.00~263.00 1 344.0 1.8 1 P6SMB300A-AT P6SMB300CA-AT 300A 300C 256.00 285.00~315.00 1 414.0 1.5 1 P6SMB350A-AT P6SMB350CA-AT 350A 350C 300.00 332.00~368.00 1 482.0 1.3 1 P6SMB400A-AT P6SMB400CA-AT 400A 400C 342.00 380.00~420.00 1 548.0 1.1 1 P6SMB440A-AT P6SMB440CA-AT 440A 440C 376.00 418.00~462.00 1 602.0 1.0 1 P6SMB480A-AT P6SMB480CA-AT 480A 480C 408.00 456.00~504.00 1 658.0 0.9 1 P6SMB510A-AT P6SMB510CA-AT 510A 510C 434.00 485.00~535.00 1 698.0 0.9 1 P6SMB530A-AT P6SMB530CA-AT 530A 530C 450.00 503.50~556.50 1 725.0 0.8 1 P6SMB540A-AT P6SMB540CA-AT 540A 540C 459.00 513.00~567.00 1 740.0 0.8 1 P6SMB550A-AT P6SMB550CA-AT 550A 550C 467.00 522.50~577.50 1 760.0 0.8 1 P6SMB600A-AT P6SMB600CA-AT 600A 600C 510.00 570.00~630.00 1 828.0 0.75 1 TTT www.ya geo.com Jun. 30, 2023 V.4 Circuit Protection Product Specification Transient Voltage Suppressors 5 9 P6SMB-AT Ratings and Characteristic Curves (T A=25℃ unless otherwise noted) Figure 1. Peak Pulse Power Rating Curve Figure 2. Pulse Derating Curve Peak Pulse Power (PPP) or Current (IPP) Derating in Percentage % PPPM - Peak Pulse Power (kW) 100 10 1 0.2×0.2″(5.0×5.0mm) Copper Pad Area 0.1 1 100 10 100 80 60 40 20 0 1000 0 td-Pulse Width (µs) 75 100 125 150 175 Figure 4. Typical Junction Capacitance 10000 150 TJ=25℃ Pulse Width(td) is defined as the point where the peak current decays to 50% of IPPM tr=10µs Bi-directional V=0V 1000 Uni-directional V=0V Peak Value IPPM 100 Uni-directional @VR Cj (pF) IPPM - Peak Pulse Current, %IRSM 50 TA-Ambient Temperature (℃) Figure 3. Pulse Waveform Half Value IPPM (IPPM/2) 50 td 0 100 1 1.0 2.0 3.0 Bi-directional @VR 10 10/1000µs Waveform as defined by R.E.A 0 4.0 TJ=25℃ f=1.0MHz Vsig=50mVp-p 1 Figure 5. Steady State Power Dissipation Derating 1000 Surge Current Uni-Directional Only IFSM - Peak Forward Surve Current (A) 6 5 4 3 2 1 0 25 100 Figure 6. Maximum Non-Repetitive Forward Curve 0 10 VBR-Reverse Breakdown Voltage (V) t-Time (ms) PM(AV), Steady State Power Dissipation (W) 25 50 75 100 125 TA-Ambient Temperature (℃) 150 175 120 100 80 60 40 20 0 1 10 100 Number of Cycles at 60Hz www.ya geo.com Jun. 30, 2023 V.4 Circuit Protection Product Specification Transient Voltage Suppressors 6 9 P6SMB-AT Recommended Soldering Conditions Reflow Soldering Critical Zone TL to TP tP TP Ramp-up TL tL Temperature TS max TS min Ramp-down tS Preheat 25 t 25℃ to Peak Time Recommended Conditions Profile Feature Pb-Free Assembly Average ramp-up rate (TL to TP) 3℃/second max. Preheat -Temperature Min (TS min) -Temperature Max (TS max) -Time (min to max) (tS) 150℃ 200℃ 60-180 seconds TS max to TL -Ramp-up Rate 3℃/second max. Time maintained above: -Temperature (TL) -Time (tL) 217℃ 60-150 seconds Peak Temperature (TP) 260℃ Time within 5℃ of actual Peak Temperature (tP) Ramp-down Rate Time 25℃ to Peak Temperature 20-40 seconds 6℃/second max. 8 minutes max. www.ya geo.com Jun. 30, 2023 V.4 Circuit Protection Product Specification Transient Voltage Suppressors 7 9 P6SMB-AT Marking Code Cathode Band YXXX YXXX 6V8A Logo 6V8C Internal control code Marking Code Logo Internal control code Marking Code Part Number Code P6SMB XXX C A AT / XXXX Package Code TR7: 7 inch reel package TR13: 13 inch reel package Internal Control Code 5% VBR Voltage Tolerance Bidirectional VBR Voltage Series Code Ordering Code for Different Package 7 inch reel package: Add suffix “ /TR7 ” at the end of the part number, such as P6SMBXXXCA-AT/TR7 13 inch reel package: Add suffix “ /TR13 ” at the end of the part number, such as P6SMBXXXCA-AT/TR13 www.ya geo.com Jun. 30, 2023 V.4 Circuit Protection Product Specification Transient Voltage Suppressors 8 9 P6SMB-AT Packaging Tape P0 P1 P2 D0 B T E F W B0 D1 A A K0 B SECTION B-B Symbol Dimension (mm) W 12.00±0.20 P0 4.00±0.10 P1 8.00±0.10 P2 2.00±0.10 D0 Φ1.55±0.10 D1 Φ1.5±0.10 E 1.75±0.10 F 5.50±0.10 A0 3.86±0.15 B0 5.65±0.10 K0 2.75±0.15 T 0.25±0.05 D2 Φ178.0±2.0 D3 Φ50.0Min. D4 Φ13.0±0.5 W1 16.0±2.0 A0 SECTION A-A 7” Reel D4 D3 D2 13” Reel W1 Quantity: 500PCS D5 Φ330.0±2.0 D6 Φ13.5±0.5 H 2.5±1.0 W2 16.0±2.0 Quantity: 3000PCS www.ya geo.com Jun. 30, 2023 V.4 Product specification Circuit Protection Components LEGAL DISCLAIMER YAGEO, its distributors and agents (collectively, “YAGEO”), hereby disclaims any and all liabilities for any errors, inaccuracies or incompleteness contained in any product related information, including but not limited to product specifications, datasheets, pictures and/or graphics. YAGEO may make changes, modifications and/or improvements to product related information at any time and without notice. YAGEO makes no representation, warranty, and/or guarantee about the fitness of its products for any particular purpose or the continuing production of any of its products. To the maximum exten t permitted by law, YAGEO disclaims (i) any and all liability arising out of the application or use of any YAGEO product, (ii) any and all liability, including without limitation special, consequential or incidental damages, and (iii) any and all implied warranties, including warranties of fitness for a particular purpose, non -infringement and merchantability. YAGEO products are designed for general purpose applications under normal operation and usage conditions. Please contact YAGEO for the applications listed below which require especially high reliability for the prevention of defects which might directly cause damage to the third party's life, body or property: Aerospace equipment (artificial satellite, rocket, etc.), Atomic energy -related equipment, Aviation equipment, Disaster prevention equipment, crime prevention equipment, Electric heating apparatus, burning equipment, Highly public information network equipment, data-processing equipment , Medical devices, Military equipment, Power generation control equipment, Safety equipment, Traffic signal equipment, Transportation equipment and Undersea equipment, or for any other application or use in which the failure of YAGEO products could result in personal injury or death, or serious property damage. P articularly YAGEO Corporation and its affiliates do not recommend the use of commercial or automotive grade products for high reliability applications or manned space flight. Information provided here is intended to indicate product specifications only. YAGEO reserves all the rights for revising this content without further notification, as long as products are unchanged. Any product change will be announced by PCN. www.yageo.com
P6SMB530CA-AT/TR13 价格&库存
很抱歉,暂时无法提供与“P6SMB530CA-AT/TR13”相匹配的价格&库存,您可以联系我们找货
P6SMB530CA-AT/TR13
  • 1+4.684541+0.60132
  • 10+2.8749010+0.36903
  • 100+1.82558100+0.23434
  • 500+1.37268500+0.17620
  • 1000+1.226301000+0.15741
库存:1367
P6SMB530CA-AT/TR13
  • 3000+1.040043000+0.13350
  • 6000+0.946116000+0.12145
  • 9000+0.898259000+0.11530
  • 15000+0.8444515000+0.10840
  • 21000+0.8125821000+0.10431
  • 30000+0.7816130000+0.10033
  • 75000+0.7531275000+0.09668
库存:1367
