10BJ20CA
10BJ20CA
    EATON(伊顿)
    SMB(DO-214AA)
    32.4V 夹子 30.9A Ipp TVS - 二极管 表面贴装型 SMB
10BJ20CA 数据手册
Technical Data 11205 Effective November 2020 10BJ 1000 W Transient voltage suppressor Applications Product features • Low profile SMB package • Excellent clamping capability • 1000 W peak pulse power capability at 10/1000 μs waveform • Typical IR less than 1 μA above 12 V • Fast response time: typically less than 1.0 ps from 0 V to VBR minimum • High temperature reflow soldering: +260 °C /40 s at terminal • Plastic package meets UL 94 V-0 flammability rating • Meets moisture sensitivity level (MSL) level 1 • Terminal: Solder plated leads, solderable per J-STD-002 • For surface mounted applications in order to optimize board space • UL 497B recognized File No. : E198449 Guide QVGQ2 PIN configuration • Consumer electronics • Telecommunications • Computing and servers • Appliances • Industrial automation • Mobile and wearables Environmental compliance and general specifications HALOGEN Pb HF FREE Ordering part number 10BJ 6-0 C A Family name VR voltage (“-” indicates decimal point) Bi-/Uni-Directional (Blank=Uni, C=Bi) Voltage tolerance 10BJ 1000 W Transient voltage suppressor  Technical Data 11205 Effective November 2020 Absolute maximum ratings (+25 °C, RH=45%-75%, unless otherwise noted) Parameter Symbol Value Unit TSTG/ TJ -55 to +150 °C Steady state power dissipation at TL= +75 °C PM(AV) 5.0 W Peak pulse power dissipation on 10/1000 μs waveform PPP 1000 W Maximum instantaneous forward voltage at 50 A for unidirectional VF 3.5 V Peak forward surge current, 8.3 ms single half sine wave1 IFSM 120 A Typical thermal resistance junction to lead R JL 20 °C/W Typical thermal resistance junction to ambient R JA 100 °C/W Storage operating junction temperature range 1. Measured on 8.3 ms single half sine wave or equivalent square wave for unidirectional device only, duty cycle = 4 per minute maximum Mechanical parameters, pad layout- mm Millimeters Dimension Minimum Part marking Inches Maximum Minimum Maximum A 3.30 3.94 0.130 0.155 B 4.30 4.80 0.169 0.189 C 1.90 2.20 0.075 0.087 D 0.95 1.52 0.037 0.060 E 5.20 5.60 0.205 0.220 Cathode band (Uni-polar only) F 0.051 0.203 0.002 0.008 Part marking: xxxx = Date code yyyy- Refer to marking designator listed in Electrical Characteristics table G 0.15 0.31 0.006 0.012 H 2.10 2.40 0.083 0.094 J 2.20 K L 0.087 2.60 0.102 2.30 Packaging information (mm) 0.091 Dimensions Millimeters Inches Drawing not to scale. A0 3.76 ± 0.3 0.148 ± 0.012 Supplied in tape and reel packaging, 3,000 parts per 13” diameter reel (EIA-481 compliant) B0 5.69 ± 0.3 0.224 ± 0.012 C 330.0 13.0 D0 1.55 ± 0.1 0.061 ± 0.004 E 1.75 ± 0.2 0.069 ± 0.008 E1 13.3 ± 0.3 0.524 ± 0.012 F 5.5 ± 0.2 0.217 ± 0.008 P0 4.00 ± 0.2 0.157 ± 0.008 P1 8.00 ± 0.2 0.315 ± 0.008 P2 2.00 ± 0.2 0.079 ± 0.008 W 12.0 ± 0.2 0.472 ± 0.008 W1 15.7 ± 2.0 0.618 ± 0.079 2 www.eaton.com/electronics Technical Data 11205  10BJ  1000 W Transient voltage suppressor Effective November 2020 Electrical characteristics (+25 °C) Part number Uni-polar Bi-polar Marking Uni Bi VR (V) IR @ VR (μA) VBR @ IT min (V) max (V) IT (mA) VC @ IPP max (V) IPP (A) 10BJ5-0A 10BJ5-0CA A5 5.0 200 6.40 7.00 10 9.2 108.7 C5 10BJ6-0A 10BJ6-0CA A6 C6 6.0 200 6.67 7.37 10 10.3 97.1 10BJ6-5A 10BJ6-5CA A6V C6V 6.5 120 7.22 7.98 10 11.2 89.3 10BJ7-0A 10BJ7-0CA A7 C7 7.0 80 7.78 8.60 10 12.0 83.4 10BJ7-5A 10BJ7-5CA A7V C7V 7.5 50 8.33 9.21 1 12.9 77.6 10BJ8-0A 10BJ8-0CA A8 C8 8.0 20 8.89 9.83 1 13.6 73.6 10BJ8-5A 10BJ8-5CA A8V C8V 8.5 10 9.44 10.40 1 14.4 69.5 10BJ9-0A 10BJ9-0CA A9 C9 9.0 5 10.00 11.10 1 15.4 65.0 10BJ10A 10BJ10CA A10 C10 10 2 11.10 12.30 1 17.0 58.9 10BJ11A 10BJ11CA A11 C11 11 2 12.20 13.50 1 18.2 55.0 10BJ12A 10BJ12CA A12 C12 12 2 13.30 14.70 1 19.9 50.3 10BJ13A 10BJ13CA A13 C13 13 1 14.40 15.90 1 21.5 46.6 10BJ14A 10BJ14CA A14 C14 14 1 15.60 17.20 1 23.2 43.1 10BJ15A 10BJ15CA A15 C15 15 1 16.70 18.50 1 24.4 41.0 10BJ16A 10BJ16CA A16 C16 16 1 17.80 19.70 1 26.0 38.5 10BJ17A 10BJ17CA A17 C17 17 1 18.90 20.90 1 27.6 36.3 10BJ18A 10BJ18CA A18 C18 18 1 20.00 22.10 1 29.2 34.3 10BJ20A 10BJ20CA A20 C20 20 1 22.20 24.50 1 32.4 30.9 10BJ22A 10BJ22CA A22 C22 22 1 24.40 26.90 1 35.5 28.2 10BJ24A 10BJ26CA A24 C24 24 1 26.70 29.50 1 38.9 25.7 10BJ26A 10BJ26CA A26 C26 26 1 28.90 31.90 1 42.1 23.8 10BJ28A 10BJ28CA A28 C28 28 1 31.10 34.40 1 45.4 22.1 10BJ30A 10BJ30CA A30 C30 30 1 33.30 36.80 1 48.4 20.7 10BJ33A 10BJ33CA A33 C33 33 1 36.70 40.60 1 53.3 18.8 10BJ36A 10BJ40CA A36 C36 36 1 40.00 44.20 1 58.1 17.2 10BJ40A 10BJ40CA A40 C40 40 1 44.40 49.10 1 64.5 15.5 10BJ43A 10BJ43CA A43 C43 43 1 47.80 52.80 1 69.4 14.4 10BJ45A 10BJ45CA A45 C45 45 1 50.00 55.30 1 72.7 13.8 10BJ48A 10BJ48CA A48 C48 48 1 53.30 58.90 1 77.4 13.0 10BJ51A 10BJ54CA A51 C51 51 1 56.70 62.70 1 82.4 12.2 10BJ54A 10BJ54CA A54 C54 54 1 60.00 66.30 1 87.1 11.5 10BJ58A 10BJ60CA A58 C58 58 1 64.40 71.20 1 93.6 10.7 10BJ60A 10BJ60CA A60 C60 60 1 66.70 73.70 1 96.8 10.3 10BJ64A 10BJ64CA A64 C64 64 1 71.10 78.60 1 103.0 9.7 10BJ70A 10BJ70CA A70 C70 70 1 77.80 86.00 1 113.0 8.9 10BJ75A 10BJ75CA A75 C75 75 1 83.30 92.10 1 121.0 8.3 10BJ78A 10BJ78CA A78 C78 78 1 86.70 95.80 1 126.0 7.9 10BJ85A 10BJ85CA A85 C85 85 1 94.40 104.0 1 137.0 7.3 10BJ90A 10BJ90CA A90 C90 90 1 100.0 111.0 1 146.0 6.9 10BJ100A 10BJ100CA A100 C100 100 1 111.0 123.0 1 162.0 6.2 10BJ110A 10BJ110CA A110 C110 110 1 122.0 135.0 1 177.0 5.6 10BJ120A 10BJ120CA A120 C120 120 1 133.0 147.0 1 193.0 5.2 10BJ130A 10BJ130CA A130 C130 130 1 144.0 159.0 1 209.0 4.8 10BJ150A 10BJ150CA A150 C150 150 1 167.0 185.0 1 243.0 4.2 10BJ160A 10BJ160CA A160 C160 160 1 178.0 197.0 1 259.0 3.9 10BJ170A 10BJ170CA A170 C170 170 1 189.0 209.0 1 275.0 3.7 10BJ180A 10BJ180CA A180 C180 180 1 201.0 222.0 1 292.0 3.5 10BJ190A 10BJ190CA A190 C190 190 1 211.0 234.0 1 307.0 3.3 10BJ200A 10BJ200CA A200 C200 200 1 224.0 247.0 1 324.0 3.1 www.eaton.com/electronics 3 10BJ 1000 W Transient voltage suppressor  Technical Data 11205 Effective November 2020 Ratings and V-I characteristic curves (+25 °C unless otherwise noted) V- I curve characteristics (Uni-directional) V- I curve characteristics (Bi-directional) Surge waveform: 10/1000 μs VR: Stand-off voltage -- Maximum voltage that can be applied VBR: Breakdown voltage VC: Clamping voltage -- Peak voltage measured across the suppressor at a specified IPP IR: Reverse leakage current IT: Test current VF: Forward voltage drop for Uni-directional TVS diode Pulse derating curve 150 tr = rise time to peak value td = decay time to half value IPPM (% IRSM) tr=10 μs 100 PPP derating in percentage (%) Pulse waveform Peak value Half value 50 td 0 0 1.0 2.0 3.0 4.0 t (ms) Peak pulse power dissipation vs. pulse width 100 Ppp (kW) 1000 W at 10/1000 μs +25 ć 10 1.0 0.1 0.001 0.01 0.1 td-Pulse width (ms) 4 www.eaton.com/electronics 1.0 100 80 60 40 20 0 0 25 50 75 100 125 150 TJ-Initial junction temperature (°C) 175 Technical Data 11205 10BJ  1000 W Transient voltage suppressor Effective November 2020  Solder reflow profile TP TC -5°C tP Max. Ramp Up Rate = 3°C/s Max. Ramp Down Rate = 6°C/s Temperature TL Preheat A T smax t Table 1 - Standard SnPb solder (Tc) Package thickness Volume mm3
10BJ20CA 价格&库存
很抱歉,暂时无法提供与“10BJ20CA”相匹配的价格&库存,您可以联系我们找货
10BJ20CA
  • 1+4.285421+0.55709
  • 10+2.6859910+0.34917
  • 100+1.98190100+0.25764
  • 500+1.71243500+0.22261
  • 1000+1.555971000+0.20227
  • 3000+1.451663000+0.18871
10BJ20CA
  • 1+3.98508
  • 10+2.49502
  • 100+1.84341
  • 500+1.59188
  • 1000+1.44335
  • 3000+1.34992
10BJ20CA
  • 1+7.317531+0.95126
  • 10+4.5430510+0.59059
  • 100+2.93299100+0.38128
  • 500+2.23932500+0.29111
  • 1000+2.015441000+0.26200
库存:4545
10BJ20CA
  • 3000+1.648483000+0.21430
  • 6000+1.568746000+0.20393
库存:4545
