Technical Data 11205
Effective November 2020
10BJ
1000 W Transient voltage suppressor
Applications
Product features
Low profile SMB package
Excellent clamping capability
1000 W peak pulse power capability at
10/1000 μs waveform
Typical IR less than 1 μA above 12 V
Fast response time: typically less than 1.0 ps
from 0 V to VBR minimum
High temperature reflow soldering:
+260 °C /40 s at terminal
Plastic package meets UL 94 V-0 flammability
rating
Meets moisture sensitivity level (MSL) level 1
Terminal: Solder plated leads,
solderable per J-STD-002
For surface mounted applications in order to
optimize board space
UL 497B recognized
File No. : E198449 Guide QVGQ2
PIN configuration
Consumer electronics
Telecommunications
Computing and servers
Appliances
Industrial automation
Mobile and wearables
Environmental compliance and general
specifications
HALOGEN
Pb HF
FREE
Ordering part number
10BJ 6-0 C A
Family name
VR voltage
(“-” indicates decimal point)
Bi-/Uni-Directional
(Blank=Uni, C=Bi)
Voltage tolerance
10BJ
Absolute maximum ratings
(+25 °C, RH=45%-75%, unless otherwise noted)
Parameter
Symbol
Value
Unit
TSTG/ TJ
-55 to +150
°C
Steady state power dissipation at TL= +75 °C
PM(AV)
5.0
W
Peak pulse power dissipation on 10/1000 μs
waveform
PPP
1000
W
Maximum instantaneous forward voltage at
50 A for unidirectional
VF
3.5
V
Peak forward surge current, 8.3 ms single
half sine wave1
IFSM
120
A
Typical thermal resistance junction to lead
R
JL
°C/W
Typical thermal resistance junction to ambient
R
JA
100
°C/W
Storage operating junction temperature range
1. Measured on 8.3 ms single half sine wave or equivalent square wave for unidirectional device only,
duty cycle = 4 per minute maximum
Mechanical parameters, pad layout- mm
Millimeters
Dimension Minimum
Part marking
Inches
Maximum
Minimum
Maximum
A
3.30
3.94
0.130
0.155
B
4.30
4.80
0.169
0.189
C
1.90
2.20
0.075
0.087
D
0.95
1.52
0.037
0.060
E
5.20
5.60
0.205
0.220
Cathode band (Uni-polar only)
F
0.051
0.203
0.002
0.008
Part marking: xxxx = Date code
yyyy- Refer to marking designator
listed in Electrical Characteristics table
G
0.15
0.31
0.006
0.012
H
2.10
2.40
0.083
0.094
J
2.20
K
L
0.087
2.60
0.102
2.30
Packaging information (mm)
0.091
Dimensions
Millimeters
Inches
Drawing not to scale.
A0
3.76 ± 0.3
0.148 ± 0.012
Supplied in tape and reel packaging, 3,000 parts per 13” diameter reel
(EIA-481 compliant)
B0
5.69 ± 0.3
0.224 ± 0.012
C
330.0
13.0
D0
1.55 ± 0.1
0.061 ± 0.004
E
1.75 ± 0.2
0.069 ± 0.008
E1
13.3 ± 0.3
0.524 ± 0.012
F
5.5 ± 0.2
0.217 ± 0.008
P0
4.00 ± 0.2
0.157 ± 0.008
P1
8.00 ± 0.2
0.315 ± 0.008
P2
2.00 ± 0.2
0.079 ± 0.008
W
12.0 ± 0.2
0.472 ± 0.008
W1
15.7 ± 2.0
0.618 ± 0.079
2
www.eaton.com/electronics
10BJ
Electrical characteristics (+25 °C)
Part number
Uni-polar
Bi-polar
Marking
Uni
Bi
VR
(V)
IR @ VR
(μA)
VBR @ IT
min (V)
max (V)
IT
(mA)
VC @ IPP
max (V)
IPP
(A)
10BJ5-0A
10BJ5-0CA
A5
5.0
200
6.40
7.00
10
9.2
108.7
C5
10BJ6-0A
10BJ6-0CA
A6
C6
6.0
200
6.67
7.37
10
10.3
97.1
10BJ6-5A
10BJ6-5CA
A6V
C6V
6.5
120
7.22
7.98
10
11.2
89.3
10BJ7-0A
10BJ7-0CA
A7
C7
7.0
80
7.78
8.60
10
12.0
83.4
10BJ7-5A
10BJ7-5CA
A7V
C7V
7.5
50
8.33
9.21
1
12.9
77.6
10BJ8-0A
10BJ8-0CA
A8
C8
8.0
9.83
1
13.6
73.6
10BJ8-5A
10BJ8-5CA
A8V
C8V
8.5
10
9.44
10.40
1
14.4
69.5
10BJ9-0A
10BJ9-0CA
A9
C9
9.0
5
10.00
11.10
1
15.4
65.0
10BJ10A
10BJ10CA
A10
C10
10
2
11.10
12.30
1
17.0
58.9
10BJ11A
10BJ11CA
A11
C11
11
2
12.20
13.50
1
18.2
55.0
10BJ12A
10BJ12CA
A12
C12
12
2
13.30
14.70
1
19.9
50.3
10BJ13A
10BJ13CA
A13
C13
13
1
14.40
15.90
1
21.5
46.6
10BJ14A
10BJ14CA
A14
C14
14
1
15.60
17.20
1
23.2
43.1
10BJ15A
10BJ15CA
A15
C15
15
1
16.70
18.50
1
24.4
41.0
10BJ16A
10BJ16CA
A16
C16
16
1
17.80
19.70
1
26.0
38.5
10BJ17A
10BJ17CA
A17
C17
17
1
18.90
20.90
1
27.6
36.3
10BJ18A
10BJ18CA
A18
C18
18
1
20.00
22.10
1
29.2
34.3
10BJ20A
10BJ20CA
A20
C20
22.20
24.50
1
32.4
30.9
10BJ22A
10BJ22CA
A22
C22
22
1
24.40
26.90
1
35.5
28.2
10BJ24A
10BJ26CA
A24
C24
24
1
26.70
29.50
1
38.9
25.7
10BJ26A
10BJ26CA
A26
C26
26
1
28.90
31.90
1
42.1
23.8
10BJ28A
10BJ28CA
A28
C28
28
1
31.10
34.40
1
45.4
22.1
10BJ30A
10BJ30CA
A30
C30
30
1
33.30
36.80
1
48.4
20.7
10BJ33A
10BJ33CA
A33
C33
33
1
36.70
40.60
1
53.3
18.8
10BJ36A
10BJ40CA
A36
C36
36
1
40.00
44.20
1
58.1
17.2
10BJ40A
10BJ40CA
A40
C40
40
1
44.40
49.10
1
64.5
15.5
10BJ43A
10BJ43CA
A43
C43
43
1
47.80
52.80
1
69.4
14.4
10BJ45A
10BJ45CA
A45
C45
45
1
50.00
55.30
1
72.7
13.8
10BJ48A
10BJ48CA
A48
C48
48
1
53.30
58.90
1
77.4
13.0
10BJ51A
10BJ54CA
A51
C51
51
1
56.70
62.70
1
82.4
12.2
10BJ54A
10BJ54CA
A54
C54
54
1
60.00
66.30
1
87.1
11.5
10BJ58A
10BJ60CA
A58
C58
58
1
64.40
71.20
1
93.6
10.7
10BJ60A
10BJ60CA
A60
C60
60
1
66.70
73.70
1
96.8
10.3
10BJ64A
10BJ64CA
A64
C64
64
1
71.10
78.60
1
103.0
9.7
10BJ70A
10BJ70CA
A70
C70
70
1
77.80
86.00
1
113.0
8.9
10BJ75A
10BJ75CA
A75
C75
75
1
83.30
92.10
1
121.0
8.3
10BJ78A
10BJ78CA
A78
C78
78
1
86.70
95.80
1
126.0
7.9
10BJ85A
10BJ85CA
A85
C85
85
1
94.40
104.0
1
137.0
7.3
10BJ90A
10BJ90CA
A90
C90
90
1
100.0
111.0
1
146.0
6.9
10BJ100A
10BJ100CA
A100
C100
100
1
111.0
123.0
1
162.0
6.2
10BJ110A
10BJ110CA
A110
C110
110
1
122.0
135.0
1
177.0
5.6
10BJ120A
10BJ120CA
A120
C120
120
1
133.0
147.0
1
193.0
5.2
10BJ130A
10BJ130CA
A130
C130
130
1
144.0
159.0
1
209.0
4.8
10BJ150A
10BJ150CA
A150
C150
150
1
167.0
185.0
1
243.0
4.2
10BJ160A
10BJ160CA
A160
C160
160
1
178.0
197.0
1
259.0
3.9
10BJ170A
10BJ170CA
A170
C170
170
1
189.0
209.0
1
275.0
3.7
10BJ180A
10BJ180CA
A180
C180
180
1
201.0
222.0
1
292.0
3.5
10BJ190A
10BJ190CA
A190
C190
190
1
211.0
234.0
1
307.0
3.3
10BJ200A
10BJ200CA
A200
C200
200
1
224.0
247.0
1
324.0
3.1
3
10BJ
Ratings and V-I characteristic curves (+25 °C unless otherwise noted)
V- I curve characteristics (Uni-directional)
V- I curve characteristics (Bi-directional)
Surge waveform: 10/1000 μs
VR: Stand-off voltage -- Maximum voltage that can be applied
VBR: Breakdown voltage VC: Clamping voltage -- Peak voltage measured across the suppressor at a specified IPP
IR: Reverse leakage current IT: Test current
VF: Forward voltage drop for Uni-directional TVS diode
Pulse derating curve
150
tr = rise time to peak value
td = decay time to half value
IPPM (% IRSM)
tr=10 μs
100
PPP derating in percentage (%)
Pulse waveform
Peak value
Half value
50
td
2.0
3.0
4.0
t (ms)
Peak pulse power dissipation vs. pulse width
100
Ppp (kW)
1000 W at 10/1000 μs +25 ć
10
1.0
0.1
0.001
0.01
0.1
td-Pulse width (ms)
4
1.0
100
80
60
40
50
75
100
125
150
TJ-Initial junction temperature (°C)
175
10BJ
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
t
Table 1 - Standard SnPb solder (Tc)
Package
thickness
Volume
mm3
很抱歉,暂时无法提供与“10BJ6-0A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+7.232191+0.94016
- 10+4.4726510+0.58143
- 100+2.88541100+0.37510
- 500+2.20138500+0.28618
- 1000+1.980681000+0.25749
- 国内价格 香港价格
- 1+4.285421+0.55709
- 10+2.6859910+0.34917
- 100+1.98190100+0.25764
- 500+1.71243500+0.22261
- 1000+1.555971000+0.20227
- 3000+1.451663000+0.18871
- 国内价格
- 1+3.98508
- 10+2.49502
- 100+1.84341
- 500+1.59188
- 1000+1.44335
- 3000+1.34992
- 国内价格 香港价格
- 3000+1.783243000+0.23182
- 6000+1.725226000+0.22428
