SMBJE12CAH
SMBJE12CAH
    EATON(伊顿)
    SMB(DO-214AA)
    19.9V 夹子 30.2A Ipp TVS - 二极管 表面贴装型 DO-214AA(SMBJ)
SMBJE12CAH 数据手册
Technical Data ELX1063 Effective June 2021 SMBJE Automotive grade 600 W Transient voltage suppressor Applications Product features • Automotive grade (AEC-Q101 qualified) • Low profile SMB package • Excellent clamping capability • High reliability application • 600 W peak pulse power capability at 10/1000 μs waveform • Typical IR less than 1 μA above 9 V • Fast response time: typically less than 1.0 ps from 0 V to VBR minimum • Plastic package meets UL 94 V-0 flammability rating • Meets moisture sensitivity level (MSL) level 1 • Terminal: tin plated, solderable per J-STD-002 • UL 497B recognized. File No. : E198449 Guide QVGQ2 • Automotive chassis and safety systems • Advanced driver assistance systems (ADAS) • Communication and infotainment systems • Network systems and body electronics • Power Train controls • xEV and battery systems Environmental compliance and general specifications • AEC-Q101 qualified Ordering part number SMBJE 5-0 C A H Family name VR voltage (“-” indicates decimal point) Bi-/Uni-Directional (Blank=Uni, C=Bi) Voltage tolerance High reliability application PIN configuration SMBJE Automotive grade 600 W Transient voltage suppressor  Technical Data ELX1063 Effective June 2021 Absolute maximum ratings (+25 °C, RH=45%-75%, unless otherwise noted) Symbol Value Unit Storage operating junction temperature range Parameter TSTG/ TJ -55 to +150 °C Steady state power dissipation at TL= +75 °C PM(AV) 5 W Peak pulse power dissipation on 10/1000 μs waveform PPP 600 W Maximum instantaneous forward voltage at 100 A for unidirectional VF 5 V Peak forward surge current, 8.3 ms single half sine wave1 IFSM 100 A Typical thermal resistance junction to lead R JL 20 °C/W Typical thermal resistance junction to ambient R JA 100 °C/W 1. Measured on 8.3 ms single half sine wave or equivalent square wave for unidirectional device only, duty cycle = 4 per minute maximum Mechanical parameters, pad layout- mm/inches Millimeters Part marking Inches Dimension Minimum Maximum Minimum Maximum A 3.30 3.94 0.130 0.155 B 4.30 4.80 0.169 0.189 C 1.90 2.20 0.075 0.087 D 0.95 1.52 0.037 0.060 E 5.20 5.60 0.205 0.220 F 0.051 0.203 0.002 0.008 G 0.15 0.31 0.006 0.012 H 2.10 2.40 0.083 0.094 J 2.00 - 0.087 - K - 2.60 - 0.102 L 2.30 - 0.091 - Cathode band (uni-polar only) Part marking: xxxx = Date code yy- Refer to marking designator listed in Electrical characteristics table Packaging information - mm/inches Drawing not to scale. Supplied in tape and reel packaging, 3,000 parts per 13” diameter reel (EIA-481 compliant) 2 www.eaton.com/electronics Dimensions Millimeters Inches A0 3.76 ± 0.3 0.148 ± 0.012 B0 5.69 ± 0.3 0.224 ± 0.012 C 330.0 13.0 D0 1.55 ± 0.1 0.061 ± 0.004 E 1.75 ± 0.2 0.069 ± 0.008 E1 13.3 ± 0.3 0.524 ± 0.012 F 5.50 ± 0.2 0.217 ± 0.008 P0 4.00 ± 0.2 0.157 ± 0.008 P1 8.00 ± 0.2 0.3145 ± 0.008 P2 2.00 ± 0.2 0.079 ± 0.008 W 12.0 ± 0.2 0.472 ± 0.008 W1 15.7 ± 2.0 0.618 ± 0.079 Technical Data ELX1063 SMBJE  Automotive grade 600 W Transient voltage suppressor  Electrical specifications (+25 °C) Part number Effective June 2021 * = not UL497B recognized VR IR @ VR VBR @ IT IT VC @ IPP IPP Uni-polar Bi-polar Marking Uni Bi (V) (µA) min (V) max (V) (mA) max (V) (A) SMBJE5-0AH SMBJE5-0CAH KE AE 5 120 6.4 7 10 9.2 65.2 SMBJE6-0AH SMBJE6-0CAH KG AG 6 120 6.67 7.37 10 10.3 58.3 SMBJE6-5AH SMBJE6-5CAH KK AK 6.5 120 7.22 7.98 10 11.2 53.6 SMBJE7-0AH SMBJE7-0CAH KM AM 7 50 7.78 8.6 10 12 50 SMBJE7-5AH SMBJE7-5CAH KP AP 7.5 50 8.33 9.21 1 12.9 46.5 SMBJE8-0AH SMBJE8-0CAH KR AR 8 20 8.89 9.83 1 13.6 44.1 SMBJE8-5AH SMBJE8-5CAH KT AT 8.5 10 9.44 10.4 1 14.4 41.7 SMBJE9-0AH SMBJE9-0CAH KV AV 9 5 10 11.1 1 15.4 39 SMBJE11AH SMBJE11CAH KZ AZ 11 1 12.2 13.5 1 18.2 33 SMBJE12AH SMBJE12CAH LE BE 12 1 13.3 14.7 1 19.9 30.2 SMBJE13AH SMBJE13CAH LG BG 13 1 14.4 15.9 1 21.5 27.9 SMBJE14AH SMBJE14CAH LK BK 14 1 15.6 17.2 1 23.2 25.9 SMBJE15AH SMBJE15CAH LM BM 15 1 16.7 18.5 1 24.4 24.6 SMBJE16AH SMBJE16CAH LP BP 16 1 17.8 19.7 1 26 23.1 SMBJE17AH SMBJE17CAH LR BR 17 1 18.9 20.9 1 27.6 21.8 SMBJE18AH SMBJE18CAH LT BT 18 1 20 22.1 1 29.2 20.6 SMBJE20AH SMBJE20CAH LV BV 20 1 22.2 24.5 1 32.4 18.6 SMBJE22AH SMBJE22CAH LX BX 22 1 24.4 26.9 1 35.5 16.9 SMBJE24AH SMBJE24CAH LZ BZ 24 1 26.7 29.5 1 38.9 15.4 SMBJE26AH SMBJE26CAH ME CE 26 1 28.9 31.9 1 42.1 14.3 SMBJE28AH SMBJE28CAH MG CG 28 1 31.1 34.4 1 45.4 13.2 SMBJE30AH SMBJE30CAH MK CK 30 1 33.3 36.8 1 48.4 12.4 SMBJE33AH SMBJE33CAH MM CM 33 1 36.7 40.6 1 53.3 11.3 SMBJE36AH SMBJE36CAH MP CP 36 1 40 44.2 1 58.1 10.4 SMBJE40AH SMBJE40CAH MR CR 40 1 44.4 49.1 1 64.5 9.3 SMBJE43AH SMBJE43CAH MT CT 43 1 47.8 52.8 1 69.4 8.7 SMBJE45AH SMBJE45CAH MV CV 45 1 50 55.3 1 72.7 8.3 SMBJE48AH SMBJE48CAH MX CX 48 1 53.3 58.9 1 77.4 7.8 SMBJE51AH SMBJE51CAH MZ CZ 51 1 56.7 62.7 1 82.4 7.3 SMBJE54AH SMBJE54CAH NE DE 54 1 60 66.3 1 87.1 6.9 SMBJE58AH SMBJE58CAH NG DG 58 1 64.4 71.2 1 93.6 6.4 SMBJE60AH SMBJE60CAH NK DK 60 1 66.7 73.7 1 96.8 6.2 SMBJE64AH SMBJE64CAH NM DM 64 1 71.1 78.6 1 103 5.8 SMBJE70AH SMBJE70CAH NP DP 70 1 77.8 86 1 113 5.3 SMBJE75AH SMBJE75CAH NR DR 75 1 83.3 92.1 1 121 5 SMBJE78AH SMBJE78CAH NT DT 78 1 86.7 95.8 1 126 4.8 SMBJE85AH SMBJE85CAH NV DV 85 1 94.4 104 1 137 4.4 SMBJE90AH SMBJE90CAH NX DX 90 1 100 111 1 146 4.1 SMBJE100AH SMBJE100CAH NZ DZ 100 1 111 123 1 162 3.7 SMBJE110AH SMBJE110CAH PE EE 110 1 122 135 1 177 3.4 SMBJE120AH SMBJE120CAH PG EG 120 1 133 147 1 193 3.1 SMBJE130AH SMBJE130CAH PK EK 130 1 144 159 1 209 2.9 SMBJE150AH SMBJE150CAH PM EM 150 1 167 185 1 243 2.5 SMBJE160AH SMBJE160CAH PP EP 160 1 178 197 1 259 2.3 SMBJE170AH SMBJE170CAH PR ER 170 1 189 209 1 275 2.2 SMBJE180AH SMBJE180CAH PT ET 180 1 201 222 1 292 2.1 SMBJE190AH SMBJE190CAH PV EV 190 1 211 234 1 307 2 SMBJE200AH SMBJE200CAH PX EX 200 1 224 247 1 324 1.9 SMBJE210AH SMBJE210CAH PZ EZ 210 1 233 258 1 337 1.8 SMBJE220AH SMBJE220CAH QE FE 220 1 246 272 1 356 1.7 SMBJE250AH SMBJE250CAH QG FG 250 1 279 309 1 405 1.5 SMBJE300AH SMBJE300CAH QK FK 300 1 335 371 1 486 1.3 SMBJE350AH SMBJE350CAH QM FM 350 1 391 432 1 567 1.1 SMBJE400AH SMBJE400CAH QP FP 400 1 447 494 1 648 0.9 SMBJE440AH SMBJE440CAH QR FR 440 1 492 543 1 713 0.8 SMBJE460AH* SMBJE460CAH* QT FT 460 1 510 560 1 735 0.8 www.eaton.com/electronics 3 Technical Data ELX1063 Effective June 2021 SMBJE Automotive grade 600 W Transient voltage suppressor  Ratings and V-I characteristic curves (+25 °C unless otherwise noted) V- I curve characteristics (Uni-directional) V- I curve characteristics (Bi-directional) Surge waveform: 10/1000 μs VR: Stand-off voltage -- Maximum voltage that can be applied VBR: Breakdown voltage VC: Clamping voltage -- Peak voltage measured across the suppressor at a specified IPP IR: Reverse leakage current IT: Test current VF: Forward voltage drop for Uni-directional Pulse waveform IPPM (% IRSM) PPP derating in percentage (%) Pulse derating curve t (ms) TJ (°C) PPP (KW) Peak pulse power dissipation curve td - Pulse width (ms) 4 www.eaton.com/electronics Technical Data ELX1063 SMBJE  Automotive grade 600 W Transient voltage suppressor Effective June 2021  Solder reflow profile TP TC -5°C tP Max. Ramp Up Rate = 3°C/s Max. Ramp Down Rate = 6°C/s Temperature TL Preheat A T smax t Table 1 - Standard SnPb solder (Tc) Package thickness Volume mm3
SMBJE12CAH
物料型号:BUSSMANN SERIES ELX1063
器件简介:这是一种汽车级600W瞬态电压抑制器,适用于多种汽车系统,包括底盘与安全系统、高级驾驶辅助系统(ADAS)、通信和信息娱乐系统、网络系统和车身电子、动力传动控制以及xEV和电池系统。
引脚分配:文档中提到了两种引脚配置,分别是单向和双向配置。单向配置中,只有一个阳极和一个阴极;双向配置中,有两个阳极标记为A和K。
参数特性:包括工作结温范围(-55°C至+150°C)、稳态功率耗散(5W)、峰值脉冲功率耗散(600W)、最大瞬态正向电压(5V)、峰值正向浪涌电流(100A)等。
功能详解:瞬态电压抑制器具有优秀的钳位能力、快速响应时间(小于1.0皮秒)、高可靠性应用、低典型反向漏电流(小于1μA)等特点。
应用信息:适用于汽车电子系统中的多种应用,如底盘与安全系统、ADAS、通信和信息娱乐系统等。
封装信息:采用低剖面SMB封装,符合UL 94 V-0可燃性等级,满足湿度敏感性等级1,端子为锡镀层,符合J-STD-002标准。
SMBJE12CAH 价格&库存
很抱歉,暂时无法提供与“SMBJE12CAH”相匹配的价格&库存,您可以联系我们找货
SMBJE12CAH
    • 1+0.27821
    • 200+0.10768
    • 500+0.10390
    • 1000+0.10206
    SMBJE12CAH
    • 201000+0.76174
    库存:2902
