P6SMB8.2A/TR13
P6SMB8.2A/TR13
    YAGEO(国巨)
    SMB(DO-214AA)
    12.1V 夹子 50.4A Ipp TVS - 二极管 表面贴装型 DO-214AA(SMB)
P6SMB8.2A/TR13 数据手册
DATA SHEET TRANSIENT VOLTAGE SUPPRESSORS AC/DC POWER SUPPLY P6SMB series Product specification– June 30, 2023 V.5 RoHS compliant & Halogen free Circuit Protection Product Specification Transient Voltage Suppressors 2 9 P6SMB Transient Voltage Suppressors (TVS) Data Sheet Features ■ For surface mounted applications in order to optimize board space ■ Low profile package ■ Built-in strain relief ■ Glass passivated junction ■ Low inductance ■ Excellent clamping capability ■ 600W peak pulse power capability at 10/1000μs waveform, repetition rate (duty cycle): 0.01% ■ Fast response time ■ Typical IR less than 1μA above 12V ■ High Temperature soldering: 260℃/10 seconds at terminals ■ Plastic package has underwriters laboratory flammability 94V-0 ■ Meets MSL level 1, per J-STD-020 ■ Safety certification: UL ■ IEC61000-4-2 ESD 30KV Air, 30KV contact compliance Mechanical Data ■ Case: JEDEC DO-214AA. Molded plastic over glass passivated junction ■ Terminal: Tin plated, solderable per MIL-STD-750, Method 2026 ■ Polarity: Color band denotes cathode except bi-directional models ■ Standard Packaging: 12mm tape (EIA STD RS-481) ■ Weight: 0.10g Applications ■ I/O interface ■ AC/DC power supply ■ Low frequency signal transmission line (RS232, RS485, etc.) Maximum Ratings and Characteristics Ratings at 25℃ ambient temperature unless otherwise specified. Rating Symbol Value Units Peak pulse power dissipation at 10/1000μs waveform (Note1, Note2, Fig.1) PPPM Minimum 600 Watts Peak pulse current of at 10/1000μs waveform (Note 1, Fig.3) IPPM See Table Amps PM(AV) 5.0 Watts IFSM 100 Amps TJ,TSTG -55 to +150 ℃ Typical thermal resistance junction to lead RθJL 20 ℃/W Typical thermal resistance junction to ambient RθJA 100 ℃/W Steady state power dissipation at TA=50℃ (Fig.5) Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load, (JEDEC Method) (Note3, Fig.6) Operating junction and Storage Temperature Range. Notes: 1. Non-repetitive current pulse, per Fig.3 and derated above T A=25℃ per Fig.2. 2. Mounted on 5.0mm×5.0mm (0.03mm thick) copper pads to each terminal. 3. 8.3ms single half sine-wave, or equivalent square wave, duty cycle=4 pulses per minutes maximum. www.ya geo.com Jun. 30, 2023 V.5 Circuit Protection Product Specification Transient Voltage Suppressors 3 9 P6SMB Dimensions (SMB/DO-214AA) Product: Millimeters Inches Symbol Cathode Band Min. Max. Min. Max. L 4.06 4.57 0.160 0.180 D 3.30 3.94 0.130 0.155 D1 1.95 2.20 0.077 0.086 T 5.21 5.59 0.205 0.220 T1 0.76 1.52 0.030 0.060 d - 0.203 - 0.008 H 2.15 2.65 0.085 0.104 H1 2.13 2.47 0.084 0.097 D1 D L H1 H d T1 T 2.18mm Pad: 1.75mm 2.16mm 1.75mm Electrical Characteristics (TA=25℃) Part Number Device Marking Code Reverse Stand-Off Voltage Breakdown Voltage @IT Test Current Maximum Clamping Voltage @IPP Peak Pulse Current Reverse Leakage @VRWM Unidirectional Bidirectional UNI BI VRWM(V) VBR(V) IT(mA) VC(V) IPP(A) IR(μA) P6SMB6.8A P6SMB6.8CA 6V8A 6V8C 5.80 6.45~7.14 10 10.5 58.1 1000 P6SMB7.5A P6SMB7.5CA 7V5A 7V5C 6.40 7.13~7.88 10 11.3 54.0 500 P6SMB8.2A P6SMB8.2CA 8V2A 8V2C 7.02 7.79~8.61 10 12.1 50.4 200 P6SMB9.1A P6SMB9.1CA 9V1A 9V1C 7.78 8.65~9.55 1 13.4 45.5 50 P6SMB10A P6SMB10CA 10A 10C 8.55 9.50~10.50 1 14.5 42.1 10 P6SMB11A P6SMB11CA 11A 11C 9.40 10.50~11.60 1 15.6 39.1 5 P6SMB12A P6SMB12CA 12A 12C 10.20 11.40~12.60 1 16.7 36.5 5 P6SMB13A P6SMB13CA 13A 13C 11.10 12.40~13.70 1 18.2 33.5 1 P6SMB15A P6SMB15CA 15A 15C 12.80 14.30~15.80 1 21.2 28.8 1 P6SMB16A P6SMB16CA 16A 16C 13.60 15.20~16.80 1 22.5 27.1 1 P6SMB18A P6SMB18CA 18A 18C 15.30 17.10~18.90 1 25.2 24.2 1 P6SMB20A P6SMB20CA 20A 20C 17.10 19.00~21.00 1 27.7 22.0 1 P6SMB22A P6SMB22CA 22A 22C 18.80 20.90~23.10 1 30.6 19.9 1 P6SMB24A P6SMB24CA 24A 24C 20.50 22.80~25.20 1 33.2 18.4 1 www.ya geo.com Jun. 30, 2023 V.5 Circuit Protection Product Specification Transient Voltage Suppressors Part Number 9 P6SMB Device Marking Code 4 Reverse Stand-Off Voltage Breakdown Voltage @IT Test Current Maximum Clamping Voltage @IPP Peak Pulse Current Reverse Leakage @VRWM Unidirectional Bidirectional UNI BI VRWM(V) VBR(V) IT(mA) VC(V) IPP(A) IR(μA) P6SMB27A P6SMB27CA 27A 27C 23.10 25.70~28.40 1 37.5 16.3 1 P6SMB30A P6SMB30CA 30A 30C 25.60 28.50~31.50 1 41.4 14.7 1 P6SMB33A P6SMB33CA 33A 33C 28.20 31.40~34.70 1 45.7 13.3 1 P6SMB36A P6SMB36CA 36A 36C 30.80 34.20~37.80 1 49.9 12.2 1 P6SMB39A P6SMB39CA 39A 39C 33.30 37.10~41.00 1 53.9 11.3 1 P6SMB43A P6SMB43CA 43A 43C 36.80 40.90~45.20 1 59.3 10.3 1 P6SMB47A P6SMB47CA 47A 47C 40.20 44.70~49.40 1 64.8 9.4 1 P6SMB51A P6SMB51CA 51A 51C 43.60 48.50~53.60 1 70.1 8.7 1 P6SMB56A P6SMB56CA 56A 56C 47.80 53.20~58.80 1 77.0 7.9 1 P6SMB62A P6SMB62CA 62A 62C 53.00 58.90~65.10 1 85.0 7.2 1 P6SMB68A P6SMB68CA 68A 68C 58.10 64.60~71.40 1 92.0 6.6 1 P6SMB75A P6SMB75CA 75A 75C 64.10 71.30~78.80 1 103.0 5.9 1 P6SMB82A P6SMB82CA 82A 82C 70.10 77.90~86.10 1 113.0 5.4 1 P6SMB91A P6SMB91CA 91A 91C 77.80 86.50~95.50 1 125.0 4.9 1 P6SMB100A P6SMB100CA 100A 100C 85.50 95.00~105.00 1 137.0 4.5 1 P6SMB110A P6SMB110CA 110A 110C 94.00 105.00~116.00 1 152.0 4.0 1 P6SMB120A P6SMB120CA 120A 120C 102.00 114.00~126.00 1 165.0 3.7 1 P6SMB130A P6SMB130CA 130A 130C 111.00 124.00~137.00 1 179.0 3.4 1 P6SMB150A P6SMB150CA 150A 150C 128.00 143.00~158.00 1 207.0 2.9 1 P6SMB160A P6SMB160CA 160A 160C 136.00 152.00~168.00 1 219.0 2.8 1 P6SMB170A P6SMB170CA 170A 170C 145.00 162.00~179.00 1 234.0 2.6 1 P6SMB180A P6SMB180CA 180A 180C 154.00 171.00~189.00 1 246.0 2.5 1 P6SMB200A P6SMB200CA 200A 200C 171.00 190.00~210.00 1 274.0 2.2 1 P6SMB220A P6SMB220CA 220A 220C 185.00 209.00~231.00 1 328.0 1.9 1 P6SMB250A P6SMB250CA 250A 250C 214.00 237.00~263.00 1 344.0 1.8 1 P6SMB300A P6SMB300CA 300A 300C 256.00 285.00~315.00 1 414.0 1.5 1 P6SMB350A P6SMB350CA 350A 350C 300.00 332.00~368.00 1 482.0 1.3 1 P6SMB400A P6SMB400CA 400A 400C 342.00 380.00~420.00 1 548.0 1.1 1 P6SMB440A P6SMB440CA 440A 440C 376.00 418.00~462.00 1 602.0 1.04 1 P6SMB480A P6SMB480CA 480A 480C 408.00 456.00~504.00 1 658.0 0.9 1 P6SMB510A P6SMB510CA 510A 510C 434.00 485.00~535.00 1 698.0 0.9 1 P6SMB530A P6SMB530CA 530A 530C 450.00 503.50~556.50 1 725.0 0.8 1 P6SMB540A P6SMB540CA 540A 540C 459.00 513.00~567.00 1 740.0 0.8 1 P6SMB550A P6SMB550CA 550A 550C 467.00 522.50~577.50 1 760.0 0.8 1 P6SMB600A P6SMB600CA 600A 600C 510.00 570.00~630.00 1 828.0 0.75 1 www.ya geo.com Jun. 30, 2023 V.5 Circuit Protection Product Specification Transient Voltage Suppressors 5 9 P6SMB Ratings and Characteristic Curves (T A=25℃ unless otherwise noted) Figure 1. Peak Pulse Power Rating Curve Figure 2. Pulse Derating Curve Peak Pulse Power (PPP) or Current (IPP) Derating in Percentage % PPPM - Peak Pulse Power (kW) 100 10 1 0.2×0.2″(5.0×5.0mm) Copper Pad Area 0.1 1 100 10 100 80 60 40 20 0 1000 0 td-Pulse Width (µs) Cj (pF) IPPM - Peak Pulse Current, %IRSM 100 Bi-directional @VR TJ=25℃ f=1.0MHz Vsig=50mVp-p 1 td 2.0 3.0 1 4.0 Figure 5. Steady State Power Dissipation Derating 1000 Surge Current Uni-Directional Only 6 IFSM - Peak Forward Surve Current (A) PM(AV), Steady State Power Dissipation (W) 100 Figure 6. Maximum Non-Repetitive Forward Curve 5 4 3 2 1 0 25 10 VBR-Reverse Breakdown Voltage (V) t-Time (ms) 0 Uni-directional V=0V 10 10/1000µs Waveform as defined by R.E.A 1.0 175 Uni-directional @VR 50 0 150 Bi-directional V=0V 1000 Half Value IPPM (IPPM/2) 0 125 100 10000 Peak Value IPPM 100 75 Figure 4. Typical Junction Capacitance TJ=25℃ Pulse Width(td) is defined as the point where the peak current decays to 50% of IPPM tr=10µs 50 TA-Ambient Temperature (℃) Figure 3. Pulse Waveform 150 25 50 75 100 125 TA-Ambient Temperature (℃) 150 175 120 100 80 60 40 20 0 1 10 100 Number of Cycles at 60Hz www.ya geo.com Jun. 30, 2023 V.5 Circuit Protection Product Specification Transient Voltage Suppressors 6 9 P6SMB Recommended Soldering Conditions Reflow Soldering Critical Zone TL to TP tP TP Ramp-up TL tL Temperature TS max TS min Ramp-down tS Preheat 25 t 25℃ to Peak Time Recommended Conditions Profile Feature Pb-Free Assembly Average ramp-up rate (TL to TP) 3℃/second max. Preheat -Temperature Min (TS min) -Temperature Max (TS max) -Time (min to max) (tS) 150℃ 200℃ 60-180 seconds TS max to TL -Ramp-up Rate 3℃/second max. Time maintained above: -Temperature (TL) -Time (tL) 217℃ 60-150 seconds Peak Temperature (TP) 260℃ Time within 5℃ of actual Peak Temperature (tP) Ramp-down Rate Time 25℃ to Peak Temperature 20-40 seconds 6℃/second max. 8 minutes max. www.ya geo.com Jun. 30, 2023 V.5 Circuit Protection Product Specification Transient Voltage Suppressors 7 9 P6SMB Marking Code Cathode Band YXXX YXXX 6V8A Logo 6V8C Internal control code Marking Code Logo Internal control code Marking Code Part Number Code P6SMB XXX C A / XXXX Package Code TR7:7 inch reel package TR13:13 inch reel package 5% VBR Voltage Tolerance Bidirectional VBR Voltage Series Code Ordering Code for Different Package 7 inch reel package: Add suffix “ /TR7 ” at the end of the part number, such as P6SMBXXXCA/TR7 13 inch reel package: Add suffix “ /TR13 ” at the end of the part number, such as P6SMBXXXCA/TR13 www.ya geo.com Jun. 30, 2023 V.5 Circuit Protection Product Specification Transient Voltage Suppressors 8 9 P6SMB Packaging Tape P0 P1 P2 D0 B T E F W B0 D1 A A K0 B SECTION B-B Symbol Dimension (mm) W 12.00±0.20 P0 4.00±0.10 P1 8.00±0.10 P2 2.00±0.10 D0 Φ1.55±0.10 D1 Φ1.5±0.10 E 1.75±0.10 F 5.50±0.10 A0 3.86±0.15 B0 5.65±0.10 K0 2.75±0.15 T 0.25±0.05 D2 Φ178.0±2.0 D3 Φ50.0Min. D4 Φ13.0±0.5 W1 16.0±2.0 A0 SECTION A-A 7” Reel D4 D3 D2 13” Reel W1 Quantity: 500PCS D5 Φ330.0±2.0 D6 Φ13.5±0.5 H 2.5±1.0 W2 16.0±2.0 Quantity: 3000PCS www.ya geo.com Jun. 30, 2023 V.5 Product specification Circuit Protection Components LEGAL DISCLAIMER YAGEO, its distributors and agents (collectively, “YAGEO”), hereby disclaims any and all liabilities for any errors, inaccuracies or incompleteness contained in any product related information, including but not limited to product specifications, datasheets, pictures and/or graphics. YAGEO may make changes, modifications and/or improvements to product related information at any time and without notice. YAGEO makes no representation, warranty, and/or guarantee about the fitness of its products for any particular purpose or the continuing production of any of its products. To the maximum exten t permitted by law, YAGEO disclaims (i) any and all liability arising out of the application or use of any YAGEO product, (ii) any and all liability, including without limitation special, consequential or incidental damages, and (iii) any and all implied warranties, including warranties of fitness for a particular purpose, non -infringement and merchantability. YAGEO products are designed for general purpose applications under normal operation and usage conditions. Please contact YAGEO for the applications listed below which require especially high reliability for the prevention of defects which might directly cause damage to the third party's life, body or property: Aerospace equipment (artificial satellite, rocket, etc.), Atomic energy -related equipment, Aviation equipment, Disaster prevention equipment, crime prevention equipment, Electric heating apparatus, burning equipment, Highly public information network equipment, data-processing equipment , Medical devices, Military equipment, Power generation control equipment, Safety equipment, Traffic signal equipment, Transportation equipment and Undersea equipment, or for any other application or use in which the failure of YAGEO products could result in personal injury or death, or serious property damage. P articularly YAGEO Corporation and its affiliates do not recommend the use of commercial or automotive grade products for high reliability applications or manned space flight. Information provided here is intended to indicate product specifications only. YAGEO reserves all the rights for revising this content without further notification, as long as products are unchanged. Any product change will be announced by PCN. www.yageo.com
P6SMB8.2A/TR13
物料型号:P6SMB系列
器件简介:瞬态电压抑制二极管(TVS),适用于表面贴装,优化板空间,低轮廓封装,内置应力消除,玻璃钝化结,低电感,具有600W峰值脉冲功率能力。
引脚分配:JEDEC DO-214AA封装,端子锡镀层,符合MIL-STD-750标准。
参数特性:包括峰值脉冲功率耗散、峰值脉冲电流、稳态功率耗散、最大正向浪涌电流、工作和存储温度范围、典型热阻等。
功能详解:用于输入/输出接口交流/直流电源、低频信号传输线(如RS232、RS485等)的电路保护。
应用信息:保护电子设备免受电压突波的损害。
封装信息:标准包装为12mm胶带(EIA STD RS-481),重量为0.10g。
P6SMB8.2A/TR13 价格&库存
很抱歉,暂时无法提供与“P6SMB8.2A/TR13”相匹配的价格&库存,您可以联系我们找货
P6SMB8.2A/TR13
  • 3000+0.682713000+0.08839
  • 6000+0.615696000+0.07971
  • 9000+0.581529000+0.07529
  • 15000+0.5431015000+0.07031
  • 21000+0.5203321000+0.06736
  • 30000+0.4982030000+0.06450
库存:2835
P6SMB8.2A/TR13
  • 1+3.530041+0.45700
  • 10+2.1692210+0.28083
  • 100+1.36520100+0.17674
  • 500+1.01388500+0.13126
  • 1000+0.900281000+0.11655
库存:2835
