1.0SMB12A/TR13
1.0SMB12A/TR13
    YAGEO(国巨)
    SMB(DO-214AA)
    16.7V 夹子 60.8A Ipp TVS - 二极管 表面贴装型 DO-214AA(SMB)
1.0SMB12A/TR13 数据手册
DATA SHEET TRANSIENT VOLTAGE SUPPRESSORS AC/DC POWER SUPPLY 1.0SMB series Product specification– June 30, 2023 V.3 RoHS compliant & Halogen free Circuit Protection Transient Voltage Suppressors Product Specification 1.0SMB 2 9 Transient Voltage Suppressors (TVS) Data Sheet Features ■ ■ ■ ■ ■ ■ ■ ■ ■ ■ ■ ■ ■ For surface mounted applications in order to optimize board space Low profile package Built-in strain relief Glass passivated junction Low inductance Excellent clamping capability 1000W peak pulse power capability at 10/1000μs waveform, repetition rate (duty cycle): 0.01% Fast response time Typical IR less than 1μA above 12V High Temperature soldering: 260℃/10 seconds at terminals Plastic package has underwriters laboratory flammability 94V-0 Meets MSL level 1, per J-STD-020 IEC61000-4-2 ESD 30KV Air, 30KV contact compliance Mechanical Data ■ ■ ■ ■ ■ Case: JEDEC DO-214AA. Molded plastic over glass passivated junction Terminal: Tin plated, solderable per MIL-STD-750, Method 2026 Polarity: Color band denotes cathode except bi-directional models Standard Packaging: 12mm tape (EIA STD RS-481) Weight: 0.10g Applications ■ I/O interface ■ AC/DC power supply ■ Low frequency signal transmission line (RS232, RS485, etc.) www.yageo.com Jun. 30, 2023 V.3 Circuit Protection Product Specification Transient Voltage Suppressors 3 9 1.0SMB Maximum Ratings and Characteristics Ratings at 25℃ ambient temperature unless otherwise specified. Rating Symbol Value Units Peak pulse power dissipation at 10/1000μs waveform (Note1, Note2, Fig.1) PPPM Minimum 1000 Watts Peak pulse current of at 10/1000μs waveform (Note 1, Fig.3) IPPM See Table Amps PM(AV) 5.0 Watts IFSM 100 Amps TJ,TSTG -55 to +150 ℃ Typical thermal resistance junction to lead RθJL 20 ℃/W Typical thermal resistance junction to ambient RθJA 100 ℃/W Steady state power dissipation at TA=50℃ (Fig.5) Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load, (JEDEC Method) (Note3, Fig.6) Operating junction and Storage Temperature Range. Notes: 1. Non-repetitive current pulse, per Fig.3 and derated above TA=25℃ per Fig.2. 2. Mounted on 5.0mm×5.0mm (0.03mm thick) copper pads to each terminal. 3. 8.3ms single half sine-wave, or equivalent square wave, duty cycle=4 pulses per minutes maximum. Dimensions (SMB/DO-214AA) Product: Millimeters Inches Symbol Cathode Band Min. Max. Min. Max. L 4.06 4.57 0.160 0.180 D 3.30 3.94 0.130 0.155 D1 1.95 2.20 0.077 0.086 T 5.21 5.59 0.205 0.220 T1 0.76 1.52 0.030 0.060 d - 0.203 - 0.008 H 2.15 2.65 0.085 0.104 H1 2.13 2.47 0.084 0.097 D1 D L H1 H d T1 T 2.18mm Pad: 1.75mm 2.16mm 1.75mm www.yageo.com Jun. 30, 2023 V.3 Circuit Protection Product Specification Transient Voltage Suppressors 4 9 1.0SMB Electrical Characteristics (TA=25℃) Part Number Device Marking Code Reverse Stand-Off Voltage Breakdown Voltage @IT Test Current Maximum Clamping Voltage @IPP Peak Pulse Current Reverse Leakage @VRWM Unidirectional Bidirectional UNI BI VRWM(V) VBR(V) IT(mA) VC(V) IPP(A) IR(μA) 1.0SMB6.8A 1.0SMB6.8CA 6K8A 6K8C 5.80 6.45~7.14 10 10.5 96.8 1000 1.0SMB7.5A 1.0SMB7.5CA 7K5A 7K5C 6.40 7.13~7.88 10 11.3 90.0 500 1.0SMB8.2A 1.0SMB8.2CA 8K2A 8K2C 7.02 7.79~8.61 10 12.1 84.0 200 1.0SMB9.1A 1.0SMB9.1CA 9K1A 9K1C 7.78 8.65~9.55 1 13.4 75.8 50 1.0SMB10A 1.0SMB10CA K10A K10C 8.55 9.50~10.50 1 14.5 70.2 10 1.0SMB11A 1.0SMB11CA K11A K11C 9.40 10.50~11.60 1 15.6 65.2 5 1.0SMB12A 1.0SMB12CA K12A K12C 10.20 11.40~12.60 1 16.7 60.8 5 1.0SMB13A 1.0SMB13CA K13A K13C 11.10 12.40~13.70 1 18.2 55.8 1 1.0SMB15A 1.0SMB15CA K15A K15C 12.80 14.30~15.80 1 21.2 48.0 1 1.0SMB16A 1.0SMB16CA K16A K16C 13.60 15.20~16.80 1 22.5 45.2 1 1.0SMB18A 1.0SMB18CA K18A K18C 15.30 17.10~18.90 1 25.5 40.3 1 1.0SMB20A 1.0SMB20CA K20A K20C 17.10 19.00~21.00 1 27.7 36.7 1 1.0SMB22A 1.0SMB22CA K22A K22C 18.80 20.90~23.10 1 30.6 33.2 1 1.0SMB24A 1.0SMB24CA K24A K24C 20.50 22.80~25.20 1 33.2 30.7 1 1.0SMB27A 1.0SMB27CA K27A K27C 23.10 25.70~28.40 1 37.5 27.2 1 1.0SMB30A 1.0SMB30CA K30A K30C 25.60 28.50~31.50 1 41.4 24.5 1 1.0SMB33A 1.0SMB33CA K33A K33C 28.20 31.40~34.70 1 45.7 22.2 1 1.0SMB36A 1.0SMB36CA K36A K36C 30.80 34.20~37.80 1 49.9 20.3 1 1.0SMB39A 1.0SMB39CA K39A K39C 33.30 37.10~41.00 1 53.9 18.8 1 1.0SMB43A 1.0SMB43CA K43A K43C 36.80 40.90~45.20 1 59.3 17.2 1 1.0SMB47A 1.0SMB47CA K47A K47C 40.20 44.70~49.40 1 64.8 15.7 1 1.0SMB51A 1.0SMB51CA K51A K51C 43.60 48.50~53.60 1 70.1 14.5 1 1.0SMB56A 1.0SMB56CA K56A K56C 47.80 53.20~58.80 1 77.0 13.2 1 1.0SMB62A 1.0SMB62CA K62A K62C 53.00 58.90~65.10 1 85.0 12.0 1 1.0SMB68A 1.0SMB68CA K68A K68C 58.10 64.60~71.40 1 92.0 11.0 1 www.yageo.com Jun. 30, 2023 V.3 Circuit Protection Product Specification Transient Voltage Suppressors 5 9 1.0SMB Ratings and Characteristic Curves (TA=25℃ unless otherwise noted) Figure 1. Peak Pulse Power Rating Curve Figure 2. Pulse Derating Curve Peak Pulse Power (PPP) or Current (IPP) Derating in Percentage % PPPM - Peak Pulse Power (kW) 100 10 1 0.2×0.2″(5.0×5.0mm) Copper Pad Area 0.1 1 100 10 100 80 60 40 20 0 1000 0 td-Pulse Width (µs) 50 75 125 100 150 175 TA-Ambient Temperature (℃) Figure 3. Pulse Waveform Figure 4. Typical Junction Capacitance 10000 150 Bi-directional V=0V TJ=25℃ Pulse Width(td) is defined as the point where the peak current decays to 50% of IPPM tr=10µs Uni-directional V=0V 1000 Uni-directional @VR Peak Value IPPM 100 Cj (pF) IPPM - Peak Pulse Current, %IRSM 25 100 Half Value IPPM (IPPM/2) Bi-directional @VR 50 10 10/1000µs Waveform as defined by R.E.A 1 td 0 0 TJ=25℃ f=1.0MHz Vsig=50mVp-p 1 1.0 2.0 3.0 4.0 10 100 1000 VBR-Reverse Breakdown Voltage (V) t-Time (ms) 6 Figure 6. Maximum Non-Repetitive Forward Surge Current Uni-Directional Only IFSM - Peak Forward Surve Current (A) PM(AV), Steady State Power Dissipation (W) Figure 5. Steady State Power Dissipation Derating Curve 5 4 3 2 1 0 0 25 50 75 100 125 TA-Ambient Temperature (℃) 150 175 120 100 80 60 40 20 0 1 10 100 Number of Cycles at 60Hz www.yageo.com Jun. 30, 2023 V.3 Circuit Protection Product Specification Transient Voltage Suppressors 6 9 1.0SMB Recommended Soldering Conditions Reflow Soldering Critical Zone TL to TP tP TP Ramp-up TL tL Temperature TS max TS min Ramp-down tS Preheat 25 t 25℃ to Peak Time Recommended Conditions Profile Feature Pb-Free Assembly Average ramp-up rate (TL to TP) 3℃/second max. Preheat -Temperature Min (TS min) -Temperature Max (TS max) -Time (min to max) (tS) 150℃ 200℃ 60-180 seconds TS max to TL -Ramp-up Rate 3℃/second max. Time maintained above: -Temperature (TL) -Time (tL) 217℃ 60-150 seconds Peak Temperature (TP) 260℃ Time within 5℃ of actual Peak Temperature (tP) Ramp-down Rate Time 25℃ to Peak Temperature 20-40 seconds 6℃/second max. 8 minutes max. www.yageo.com Jun. 30, 2023 V.3 Circuit Protection Product Specification Transient Voltage Suppressors 7 9 1.0SMB Marking Code Cathode Band YXXX YXXX 6K8A 6K8C Logo Intermal Control Code Marking Code Logo Intermal Control Code Marking Code Part Number Code 1.0SMB XXX C A / XXXX Package Code TR7:7 inch reel package TR13:13 inch reel package 5% VBR Voltage Tolerance Bidirectional VBR Voltage Series Code Ordering Code for Different Package 7 inch reel package: Add suffix “/TR7 ” at the end of the part number, such as 1.0SMBXXXCA/TR7 13 inch reel package: Add suffix “/TR13 ” at the end of the part number,such as 1.0SMBXXXCA/TR13 www.yageo.com Jun. 30, 2023 V.3 Circuit Protection Product Specification Transient Voltage Suppressors 8 9 1.0SMB Packaging Tape P0 P1 P2 D0 B W 12.00±0.20 P0 4.00±0.10 P1 8.00±0.10 P2 2.00±0.10 D0 Φ1.55±0.10 D1 Φ1.5±0.10 E 1.75±0.10 F 5.50±0.10 A0 3.86±0.15 B0 5.65±0.10 K0 2.75±0.15 T 0.25±0.05 D2 Φ178.0±2.0 D3 Φ50.0Min. D4 Φ13.0±0.5 W1 16.0±2.0 W B0 D1 A Dimension (mm) T E F A Symbol K0 B SECTION B-B A0 SECTION A-A 7” Reel D4 D3 D2 13” Reel W1 Quantity: 500PCS D5 Φ330.0±2.0 D6 Φ13.5±0.5 H 2.5±1.0 W2 16.0±2.0 Quantity: 3000PCS www.yageo.com Jun. 30, 2023 V.3 Product specification Circuit Protection Components LEGAL DISCLAIMER YAGEO, its distributors and agents (collectively, “YAGEO”), hereby disclaims any and all liabilities for any errors, inaccuracies or incompleteness contained in any product related information, including but not limited to product specifications, datasheets, pictures and/or graphics. YAGEO may make changes, modifications and/or improvements to product related information at any time and without notice. YAGEO makes no representation, warranty, and/or guarantee about the fitness of its products for any particular purpose or the continuing production of any of its products. To the maximum exten t permitted by law, YAGEO disclaims (i) any and all liability arising out of the application or use of any YAGEO product, (ii) any and all liability, including without limitation special, consequential or incidental damages, and (iii) any and all implied warranties, including warranties of fitness for a particular purpose, non -infringement and merchantability. YAGEO products are designed for general purpose applications under normal operation and usage conditions. Please contact YAGEO for the applications listed below which require especially high reliability for the prevention of defects which might directly cause damage to the third party's life, body or property: Aerospace equipment (artificial satellite, rocket, etc.), Atomic energy -related equipment, Aviation equipment, Disaster prevention equipment, crime prevention equipment, Electric heating apparatus, burning equipment, Highly public information network equipment, data-processing equipment , Medical devices, Military equipment, Power generation control equipment, Safety equipment, Traffic signal equipment, Transportation equipment and Undersea equipment, or for any other application or use in which the failure of YAGEO products could result in personal injury or death, or serious property damage. P articularly YAGEO Corporation and its affiliates do not recommend the use of commercial or automotive grade products for high reliability applications or manned space flight. Information provided here is intended to indicate product specifications only. YAGEO reserves all the rights for revising this content without further notification, as long as products are unchanged. Any product change will be announced by PCN. www.yageo.com
1.0SMB12A/TR13 价格&库存
很抱歉,暂时无法提供与“1.0SMB12A/TR13”相匹配的价格&库存,您可以联系我们找货
1.0SMB12A/TR13
  • 3000+0.684793000+0.08860
  • 6000+0.617616000+0.07991
  • 9000+0.583349000+0.07547
  • 15000+0.5448115000+0.07049
  • 21000+0.5219821000+0.06754
  • 30000+0.4997930000+0.06466
库存:2448
1.0SMB12A/TR13
  • 1+3.532851+0.45707
  • 10+2.1805510+0.28212
  • 100+1.36896100+0.17711
  • 500+1.01699500+0.13158
  • 1000+0.903051000+0.11684
库存:2448
